domoticz in synology as package! Available now.
gielie
Domoticz version: latest β
Re: domoticz in synology as package! Available now.
Post by gielie »
jumbotroll wrote:@jumbo70
Now I have spent many hours trying to figure this out.
Aotec Gen 5 stick uses cdc-acm driver.
It looks like your NAS have an older kernel with an older cdc-acm driver and that's the problem.
I'll try to find a solution, but no promises.
This is the reason i switched form eaontec to a Vision Z stick, this works perfect, the eaon stick didnt on my DS415play
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
cherowley
Post by cherowley »
Hi!
I think I must have had the beta builds ticked at some point as now it's not updating versions.
Is there a way to get it doing package updates again without uninstalling and re-installing?
jumbotroll
Post by jumbotroll »
cherowley wrote:Hi!
Add http://www.jadahl.com/domoticz_beta/ to your Synology NAS Package Center sources.
https://paypal.me/Jumbotroll
Jumbotroll
cherowley
Post by cherowley »
jumbotroll wrote:
cherowley wrote:Hi!
Just to confirm, that will enable NON beta updates through again?
Boots33
Post by Boots33 »
cherowley wrote:
jumbotroll wrote:
cherowley wrote:Hi!
If you look back here viewtopic.php?f=17&t=2620&p=70488&hilit=beta#p70488 you can see the address for the beta and stable releases posted by jumbotroll
cherowley
Post by cherowley »
Thanks. Think I will have to uninstall/reinstall to get back on the non-beta releases thanks anyways :)
mortyre
Domoticz version: v3.4921
Post by mortyre »
Please Help me!
I'm new to this forum, I've got through all the posts but haven't found any explanation about my problem with my USB serial port when I use RFXtrx433E on /dev/ttyUSB0 to pilot somfy rts with my synology (I have no bug with domoticz on windows or with RFXmngr)
my configuration :
dsm 6.0-7274
synology ds1815+
DomoticZ v2.4547 (avoton)
RfxcomE (bios 251)
usb Zwave.me on /dev/ttyACM0 --> ok with Fibaro plugs
Log from DomoticZ
2016-02-26 12:39:29.668 RFXCOM: Using serial port: /dev/ttyUSB0
2016-02-26 12:39:29.668 Error: Serial Port closed!... Error: End of file
I have been read that it should be a problem with right permission on the port ?
I'd be grateful if anyone could suggest something to try to fix this. Many Thanks
gevegest
Post by gevegest »
When i install the latest Domoticz beta from the Jumbotroll repository on my DS214+, the HTTPS server does not start and says that the 8443 port might already be used. As you can see the HTTP server starts fine.
Screen Shot 2016-02-27 at 16.07.32.png (53.96 KiB) Viewed 3176 times
I have checked the used ports with netstat and the 8443 port is not listed anywhere.
I have tried reinstalling the package after a restart of the server, but the error persists.
Can anybody help me?
gevegest
Post by gevegest »
Did some more digging on the forum, it seems this is a problem in beta 2.4768 and seems to be fixed in 2.4790, so i will wait for this release from Jumbotroll.
Thanks in advance Jumbotroll!
gevegest
Post by gevegest »
Hi Jumbotroll,
Many thanks for your quick help, all is working fine now.
You should have a donation in your account ;)
Keep up your great work!
Best regards,
gevegest
staradmin
Post by staradmin »
Thank you for this great package. I have one question here about /var/domoticz.log
Every time I reboot my NAS, all previous logs are lost. How can I make it not deleted? I tried graphical interface log menu with no success
Thank you for your help
mortyre
Post by mortyre »
hello
Very good news for me with the last version of domoticz 2.4814 :
- first the last version from my RFXcom of firmware 251 is correctly identified (before is was written 250)
- and now my problem with the permissions on USB ports is Ok -> I can pilot my Somfy RTS
thank you very much Jumbotroll for new version
mortyre
Post by mortyre »
I'm looking for a way to change SSL port (443) on my Domoticz hosted on my Synology, because my synology use already this port...
Does anyone know how to do that ?
jumbotroll
Domoticz on synology use SSL port:8443
Jumbotroll
jumbotroll
Domoticz V3.4834 Stable.
http://www.jadahl.com/domoticz_stable/
I will keep V2.3530 a while.
Jumbotroll
deennoo
Post by deennoo »
Great ! De got v3 on syno !!!
http://domo-attitude.fr
jumbo70
Post by jumbo70 »
Hi Jumbotroll,
Did you manage to find solution for below issue with the aeotec gen5 stick?
If not, I'm considering to buy other zwave usb stick like:
zwave.me or Vision usb-stick.
Do you think one of these will work with my DS112+ ?
Thanks for your support!
Jumbo70
jumbotroll
jumbo70 wrote:Hi Jumbotroll,
Jumbo70
You can do a test and telnet or ssh the NAS and type: killall synousbmodemd
Then plug in your device and see if it appears in Hardware meny on domoticz.
Jumbotroll
jumbo70
Post by jumbo70 »
The 'killall synousbmodemd' command did not help. Actually 'No process was killed'.
Any idea if the Vision or Zwave.me usb stick will give similar problem, or is this problem specific for the Aeotec gen5 stick?
kind regards,
Jumbo70
jumbotroll
jumbo70 wrote:Hi,
kind regards,
Jumbo70
What DSM version du you have on your NAS? 4.2,4.3 or 5.2?
Jumbotroll
