Dashticz - Show your dashboard and how-to's!
leonhannink
Domoticz version: 4.9700
Post by leonhannink »
without the slash in the name
Lokonli
Post by Lokonli »
leonhannink wrote: Friday 01 November 2019 14:04 without the slash in the name
ok, good. thanks :)
HansieNL
Post by HansieNL »
My final dashboard :D :D
Blah blah blah
leonhannink
Can anyone help me, buienradar has a forecast for just 1hour, can i change this to 12 hours?
Verzonden vanaf mijn iPad met Tapatalk
HansieNL
Post by HansieNL »
leonhannink wrote: Saturday 09 November 2019 21:14 Can anyone help me, buienradar has a forecast for just 1hour, can i change this to 12 hours?
You can check here what options buienradar is offering:
https://www.buienradar.nl/overbuienrad ... s-weerdata
Blah blah blah
leonhannink
Thanks, but how do i apply this in Dashticz?
HansieNL
Post by HansieNL »
leonhannink wrote: Saturday 09 November 2019 22:40 Thanks, but how do i apply this in Dashticz?
As far as I know you have to create your own web page with the code from Buienradar and load it as an iframe in Dashticz.
How to load an iframe in Dashticz you can find here https://dashticz.readthedocs.io/en/bet ... rames.html
Blah blah blah
leonhannink
Oke Thanks, i Will try and post when it works
niekbruggeman
Post by niekbruggeman »
As of this week i'm running the latest version of Dashticz version 3.1.2. Master.
I did a clean install in the /Dashticz directory. Without the _3.
Most of the dashboard is performing well except all graphs.
I created a new block according to the new graph-documentation
https://dashticz-v3.readthedocs.io/en/b ... dom-graphs
All of my graphs are staying red of color an ignoring all the properties in the "graphProperties : { }" section.
Anyone else experiencing the same issue ?
Some help will be much appreciated!
blocks['graph_123'] = {
    title: 'Stroomverbruik',
    graph: 'bar',
    graphProperties : {
        gridTextColor : '#c3f6fe',
        barColors: ['#40e0d0'],
        ymax:'auto',  //set to 'auto' for auto scaling
		stacked:'true',
		resize:'true'
Lokonli
Post by Lokonli »
niekbruggeman wrote: Saturday 23 November 2019 14:38 As of this week i'm running the latest version of Dashticz version 3.1.2. Master.
    graph: 'bar',
    graphProperties : {
		stacked:'true',
		resize:'true'
In 3.1.2 there is an update of the graph module. The configuration for the graph blocks changed as well.
I see you still use the old documentation. I will remove it. The new documentation can be found here:
https://dashticz.readthedocs.io/en/mast ... raphs.html
If you miss functionality in the new graph module, then leave a note here in the forum, and I'll have a look.
The latest beta is 3.2.0 and contains additional changes, The documentation link above is applicable to the master branch.
EdwinK
Post by EdwinK »
HansieNL wrote: Tuesday 05 November 2019 22:02 My final dashboard :D :D
Nice, now care to share the codes? :)
HansieNL
Post by HansieNL »
EdwinK wrote: Tuesday 26 November 2019 11:00
Here they are:
CONFIG.js
var config = {}
config['domoticz_ip'] = 'http://XXX.XXX.XXX.XXX:XXXX';
config['login_timeout'] = '60';
config['user_name'] = '';
config['pass_word'] = '';
config['room_plan'] = '0';
config['default_news_url'] = 'https://www.bndestem.nl/XXXXXXXXXX/rss.xml';
config['news_scroll_after'] = '12';
config['default_cors_url'] = '';
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = '';
config['standby_call_url_on_end'] = '';
config['theme'] = 'default';
config['background_image'] = 'img/bg14.jpg';
config['standby_after'] = '0';
config['start_page'] = '1';
config['enable_swiper'] = '2';
config['vertical_scroll'] = '2';
config['auto_swipe_back_to'] = '1';
config['auto_swipe_back_after'] = '0';
config['auto_slide_pages'] = '0';
config['slide_effect'] = 'slide';
config['standard_graph'] = 'day';
config['blink_color'] = '255,0,0,0.5';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = '';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 'xxxxxxxxxx';
config['gm_zoomlevel'] = '';
config['gm_latitude'] = 'xx.xxxxxx';
config['gm_longitude'] = 'xx.xxxxxx';
config['speak_lang'] = 'nl-NL';
config['wu_api'] = 'XXXXXXXXXX';
config['wu_city'] = 'XXXXXXXXXX';
config['wu_name'] = '';
config['wu_country'] = 'NL';
config['owm_api'] = 'XXXXXXXXXX';
config['owm_city'] = 'XXXXXXXXXX';
config['owm_name'] = 'XXXXXXXXXX';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '4';
config['idx_moonpicture'] = '';
config['longfonds_zipcode'] = 'XXXXXXXXXX';
config['longfonds_housenumber'] = 'XX';
config['switch_horizon'] = '';
config['host_nzbget'] = '';
config['spot_clientid'] = '';
config['sonarr_url'] = '';
config['sonarr_apikey'] = '';
config['sonarr_maxitems'] = '';
config['garbage_company'] = 'mijnafvalwijzer';
config['garbage_icalurl'] = '';
config['google_api_key'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = 'XXXXXX';
config['garbage_street'] = '';
config['garbage_housenumber'] = 'XX';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = '3';
config['setpoint_min'] = '6';
config['setpoint_max'] = '30';
config['loginEnabled'] = 0;
config['disable_update_check'] = 1;
config['no_rgb'] = 1;
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['disable_googleanalytics'] = 1;
config['last_update'] = 0;
config['hide_topbar'] = 0;
config['security_button_icons'] = 0;
config['edit_mode'] = 0;
config['hide_seconds'] = 1;
config['hide_seconds_stationclock'] = 0;
config['owm_days'] = 1;
config['owm_min'] = 1;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 1;
config['hide_mediaplayer'] = 0;
config['garbage_icon_use_colors'] = 0;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 1;
config['garbage_use_cors_prefix'] = 1;
	//Graph line colors and point size
	config['lineColors'] = ['#EE0000', '#00EE00', '#0000EE'];
	config['pointSize'] = ['0'];
	//Garbage
	config['garbage'] = {
        	gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
        	rest: {kliko: 'grey', code: '#5e5d5c', name: 'Rest', icon: 'img/garbage/kliko_grey.png'},
        	papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
var _STREAMPLAYER_TRACKS     = [
    {"track":1,"name":"NPO Radio 1","file":"http://icecast.omroep.nl/radio1-bb-mp3"},
    {"track":2,"name":"Omroep Brabant","file":"http://streaming.omroepbrabant.nl/mp3hq"},
    {"track":3,"name":"Studio Brussel","file":"http://icecast.vrtcdn.be/stubru-high.mp3"},
var calendars = {}
    calendars.f1 = {
		maxitems: 5,
		image: '../custom/img/f1.png',
		url: 'https://www.f1calendar.com/#!/timezone/Europe-Amsterdam',
		icalurl: 'http://ip:port/kalenders/f1-calendar_gp_2019.ics'
var buttons = {}
    buttons.buienradar = {key: 'buienradar', width:12, isimage:true, refreshimage:60000, btnimage: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=256&h=256', url:'https://gadgets.buienradar.nl/gadget/zoommap/?lat=XX.XXXXX&lng=X.XXX&overname=2&zoom=13&naam=XXXXXX&size=3&voor=1', framewidth:580, frameheight: 520}
    buttons.log = {key:'log', width:12, image: '../custom/img/dz.png', title: 'Domoticz Log', log:true, level: 1}
    buttons.tvgids = {key: 'tvgids', width:4, image: '../custom/img/tv.png', title: 'TV Gids', url: 'https://www.tvgids24.nl/gadget'}
    buttons.bndestem = {key: 'bndestem', width:4, image: '../custom/img/bndestem.png',  title: 'Nieuws', newwindow:true, url: 'https://www.XXXX.nl/XXXXX'}
    buttons.p2000 = {key: 'p2000', width:4, image: '../custom/img/siren.png', title: 'P2000', newwindow:true, url: 'https://monitor.p2000alarm.nl'}
    buttons.fr24 = {key: 'fr24', width:4, image: '../custom/img/fr24.png', title: 'FR24', newwindow:true, url: 'https://flightradar24.com'}
    buttons.books = {key: 'books', width:12, image: '../custom/img/book.png', title: 'Boeken', url: '../clz/book.html'}
    buttons.movies = {key: 'movies', width:12, image: '../custom/img/film.png', title: 'Films', url: '../clz/movie.html'}
    buttons.music = {key: 'music', width:12, image: '../custom/img/music.png', title: 'Muziek', url: '../clz/music.html'}
    buttons.ipcam =  {key: 'ipcam', width:4, image: '../custom/img/camera.png', title: 'Camera', url: '../ipcam'}
var frames = {}
	frames.volumioplayer = { width:12, height:720, refreshiframe: 1000000, frameurl: "http://XXX.XXX.XXX.XXX/playback"}
var publictransport = {}
    publictransport.ovinfobus= { key: 'ovinfobus', show_via: true, station: 'XXXXXXXXXX', show_lastupdate:false, provider: '9292-bus', icon: 'fas fa-bus-alt', results: 7 };
    publictransport.ovinfotrains= { key: 'ovinfotrains', station: 'XXXXXXXXXX', show_lastupdate:false, provider: '9292-train', icon: 'fas fa-train', results: 7 };
var trafficinfo = {}
	trafficinfo.anwba58 = { key:'anwba58', provider: 'anwb', road:'A58', trafficJams: false, roadWorks: true, radars: false, show_lastupdate:false, icon: 'fas fa-car', width:12, results: 10 };
var maps = {}
    maps.thuis = { height: 300, link:'http://www.ovzoeker.nl', width:12, latitude: 51.432103, longitude: 4.314068, zoom:10 }
var tvguide = {}
    tvguide.npo = { key:'tvnpo', image: '../custom/img/tv.png', width:12, channels: [1,2,3], maxitems: 5 }
    tvguide.other = { key:'tvother', image: '../custom/img/tv.png', width:12, channels: [29,18], maxitems: 4 }
var blocks = {}
blocks[6] = { //Thuis
	textOff: 'AFWEZIG',
	textOn: 'AANWEZIG',
	icon: 'fas fa-home'
blocks[7] = { //Slapen
	textOff: 'WAKKER',
	textOn: 'ZZZ',
	image: '../custom/img/bed.png'
	/* imageOff: '../custom/img/awake.png',
	imageOn: '../custom/img/sleep.png' */
blocks[124] = { //Lamp Eettafel
	hide_data: true, width: 6 }
blocks[126] = { //Lamp Slaapkamer
blocks[147] = { //Homey's Mike
    title: 'Mike',
	textOff: 'DICHT',
	textOn: 'OPEN',
	imageOff: '../custom/img/mic_off.png',
	imageOn: '../custom/img/mic_on.png',
    confirmation: 1
    //flash: 5000
blocks[149] = {} //Poetsen
blocks[236] = { //Lamp Salontafel
blocks[249] = {} //Homey (alive)
blocks[252] = { //Lamp Badkamer
blocks[258] = {} //Kodi
blocks['274_1'] = {} //Energieverbruik (P1 USB)
    blocks['274_1']['title'] = 'Nu';
    blocks['274_1']['switch'] = true;
blocks['274_2'] = {} //Energie vandaag (P1 USB)
    blocks['274_2']['title'] = 'Stroom';
    blocks['274_2']['switch'] = true;
blocks[276] = {} //Internet (alive)
blocks['320_1'] = { //Gas vandaag (P1 USB)
    title: 'Gas',
    switch: true,
    icon: 'fas fa-burn'
    //image: '../custom/img/gas.png'
blocks[330] = {} //Afvalwijzer (text)
blocks[344] = {} //Open Weather Map (hidden)
blocks[345] = { //Buienradar (text)
    title: 'Buienradar',
    switch: true,
    width: 12,
    image: '../custom/img/umbrella.png'
blocks[346] = {} //RegenData (rain sensor)
blocks[347] = {} //Paraplu (switch)
blocks[350] = { //Notebook PC
    title: 'Notebook',
	textOff: 'OFFLINE',
	textOn: 'ONLINE',
	image: '../custom/img/laptop.png'
	//icon: 'fas fa-laptop'
blocks[351] = { //Desktop PC
    title: 'Desktop',
	textOff: 'OFFLINE',
	textOn: 'ONLINE',
	image: '../custom/img/desktop.png'
	//icon: 'fas fa-desktop'
blocks[352] = { //Mede8er
	/* textOff: 'OFFLINE',
	textOn: 'ONLINE', */
	//imageOff: '../custom/img/toggle_off.png',
	//imageOn: '../custom/img/toggle_on.png'
	image: '../custom/img/clapper_board.png'
blocks[354] = {} //Buitentemperatuur (OWM)
	blocks[354]['switch'] = true;
blocks[391] = { //Lamp Washok
blocks[392] = {} //Flightradar24 (alive)
blocks[400] = { //Schemerlamp
blocks[401] = {} //Dummie
blocks[413] = {} //Kodi System Alive Check
blocks[417] = { //Lamp Gang
blocks[428] = {} //Beweging Keuken
blocks[431] = { //Lamp Keuken
blocks[435] = {} //Camera
	blocks[435]['image'] = '../custom/img/camera.png';
blocks[437] = {} //Binnentemperatuur (Toon)
	blocks[437]['switch'] = true;
	blocks[437]['title'] = 'Binnen';
blocks[438] = { //Toons (Selector Switch for Toon Program State)
    hide_title: true,
    width: 8,
    image: '../custom/img/toon.png'
blocks['441_2'] = {} //Thermostaat (Toon Setpoint)
    //blocks[441]['hide_title'] = true; // NOT AN OPTION
    blocks['441_2']['image'] = '../custom/img/toon.png';
blocks[442] = {} //TV
    blocks[442]['image'] = '../custom/img/tv.png';
blocks[443] = {} //Tuner
blocks[444] = {} //Volumio
    blocks[444]['image'] = 'volumio.png';
    //blocks[444]['image'] = '../custom/img/jukebox.png';
    //blocks[443]['confirmation'] = 1;
blocks[326] = { protected: true, width: 4 } //Placeholder
blocks['v3'] = { //Uptime
    title: 'Uptime',
	image: '../custom/img/uptime.png',
	switch: true,
	width: 12
blocks['longfonds'] = {
    width: 12,
    switch: true,
    icon: '',
    image: '../custom/img/lungs.png',
blocks['news'] = {
    image:'../custom/img/bndestem.png'
blocks['traffic'] = {
	//image:'../custom/img/car.png'
    icon: 'fas fa-car'
blocks['train'] = {
    //image:'../custom/img/train.png'
blocks['streamplayer'] = {
    image: '../custom/img/radio.png'
blocks['news_nualg'] = {
    feed: 'https://www.nu.nl/rss/algemeen',
    maxheight: 400,
    title: 'Nu.nl' //optional
    //icon: 'fas fa-icon'
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
//--- Topbar ---
columns['bar'] = {}
//--- Screen 1 ---
columns[1] = {}
    columns[1]['blocks'] = [6,7,147,'441_2',438,236,400,124,431,126,252,417,391,442,352,435,350,351]
    columns[1]['width'] = 5;
columns[2] = {}
    columns[2]['blocks'] = ['weather_owm',437,354,'320_1','274_1','274_2',444,258,'streamplayer',buttons.bndestem,buttons.p2000,buttons.fr24,buttons.ipcam,buttons.tvgids]
    columns[2]['width'] = 5;
columns[3] = {}
    columns[3]['blocks'] = ['sunrise',buttons.buienradar,345,'longfonds','garbage','v3']
    columns[3]['width'] = 2;
//--- Screen 2 ---
columns[4] = {}
    columns[4]['blocks'] = ['news',calendars.f1,tvguide.npo,tvguide.other]
    columns[4]['width'] = 5;
columns[5] = {}
    columns[5]['blocks'] = ['traffic',trafficinfo.anwba58,publictransport.ovinfobus,'train',publictransport.ovinfotrains]
    columns[5]['width'] = 5;
columns[6] = {}
    columns[6]['blocks'] = ['stationclock',buttons.homepage,buttons.books,buttons.movies,buttons.music]
    columns[6]['width'] = 2;
columns[7] = {}
    columns[7]['blocks'] = [frames.volumioplayer]
    columns[7]['width'] = 6;
columns[9] = {}
    columns[9]['blocks'] = [frames.homepage]
    columns[9]['width'] = 6;
//--- Standby Screen ---
var columns_standby = {}
columns_standby[1] = {}
    columns_standby[1]['blocks'] = ['clock']
//--- Multiple screens ---
var screens = {}
screens[1] = {}
    screens[1]['background'] = 'bg14.jpg';
screens[2] = {}
    screens[2]['background'] = 'bg14.jpg';
    screens[2]['columns'] = [4,5,6]
screens[3] = {}
    screens[3]['background'] = 'bg14.jpg';
    screens[3]['columns'] = [7]
custom.js:
//add custom javascript in here
// function afterGetDevices(){
function getExtendedBlockTypes(blocktypes){
	//blocktypes.Type['Lighting 2'] = { icon: 'fa fa-lightbulb-o', title: '<Name>', value: 'ds' }
	return blocktypes;
$('<link rel="stylesheet" type="text/css" href="//fonts.googleapis.com/css?family=Orbitron" />').appendTo('head');
 //Lamp Keuken
function getStatus_431(idx,value,device){
  if(device['Data']=="On"){
    $('div.block_431').addClass('slider-on');
  else {
    $('div.block_431').removeClass('slider-on');
 //Lamp Gang
function getStatus_417(idx,value,device){
  if(device['Data']!="Off"){
    $('div.block_417').addClass('slider-on');
  else {
    $('div.block_417').removeClass('slider-on');
 //Lamp Eettafel
function getStatus_124(idx,value,device){
    $('div.block_124').addClass('slider-on');
  else {
    $('div.block_124').removeClass('slider-on');
//Lamp Slaapkamer
function getStatus_126(idx,value,device){
    $('div.block_126').addClass('slider-on');
  else {
    $('div.block_126').removeClass('slider-on');
//Lamp Salontafel
function getStatus_236(idx,value,device){
    $('div.block_236').addClass('slider-on');
  else {
    $('div.block_236').removeClass('slider-on');
//Lamp Badkamer
function getStatus_252(idx,value,device){
    $('div.block_252').addClass('slider-on');
  else {
    $('div.block_252').removeClass('slider-on');
//Schemerlamp
function getStatus_400(idx,value,device){
    $('div.block_400').addClass('slider-on');
  else {
    $('div.block_400').removeClass('slider-on');
//Washok
function getStatus_391(idx,value,device){
    $('div.block_391').addClass('slider-on');
  else {
    $('div.block_391').removeClass('slider-on');
// Buienradar
/* function getStatus_345(idx,value,device){
	if (device.Data == 'Voorlopig droog') {
			blocks[345]['image'] = '../custom/img/rain-off.png'
	 else {
		blocks[345]['image'] = '../custom/img/rain-on.png'
  // Buienradar
  if (alldevices[345].Data == 'Voorlopig droog') {
    $('.block_345 .col-icon').addClass('icon-off');
    $('.block_345 .col-data').addClass('data-off');
  else {
    $('.block_345 .col-icon').removeClass('icon-off');
    $('.block_345 .col-data').removeClass('data-off');
  // Ping CoreELEC device [413] (192.168.2.15) & Kodi Media Server [258]
  if (alldevices[413].Data == 'Off') {
    $('.block_258 .col-icon').addClass('icon-off');
    $('.block_258 .col-data').addClass('data-off');
  else {
    $('.block_258 .col-icon').removeClass('icon-off');
    $('.block_258 .col-data').removeClass('data-off');
  // Volumio
  if (alldevices[444].Data == 'Off') {
    $('.block_444 .col-data').addClass('data-off');
  else {
    $('.block_444 .col-data').removeClass('data-off');
  //Toon Setpoint [441] & Toon Selector [438]
  if (alldevices[441].Data == '6.0') {
    $('.block_441_2 .col-icon').addClass('icon-off');
    $('.block_441_2 .col-data').addClass('data-off');
    $('.block_438 .col-icon').addClass('icon-off');
  else {
    $('.block_441_2 .col-icon').removeClass('icon-off');
    $('.block_441_2 .col-data').removeClass('data-off');
    $('.block_438 .col-icon').removeClass('icon-off');
  // Thuis
  if (alldevices[6].Data == 'Off') {
    $('.block_6 .col-data').addClass('data-off');
  else {
    $('.block_6 .col-data').removeClass('data-off');
  // Mike
  if (alldevices[147].Data == 'Off') {
    $('.block_147 .col-data').addClass('data-off');
  else {
    $('.block_147 .col-data').removeClass('data-off');
  // Slapen
  if (alldevices[7].Data == 'Off') {
    $('.block_7 .col-data').addClass('data-off');
  else {
    $('.block_7 .col-data').removeClass('data-off');
  // Notebook PC
  if (alldevices[350].Data == 'Off') {
    $('.block_350 .col-data').addClass('data-off');
  else {
    $('.block_350 .col-data').removeClass('data-off');
  // Desktop PC
  if (alldevices[351].Data == 'Off') {
    $('.block_351 .col-data').addClass('data-off');
  else {
    $('.block_351 .col-data').removeClass('data-off');
  // Mede8er
  if (alldevices[352].Data == 'Off') {
    $('.block_352 .col-data').addClass('data-off');
  else {
    $('.block_352 .col-data').removeClass('data-off');
  // TV
  if (alldevices[442].Data == 'Off') {
    $('.block_442 .col-data').addClass('data-off');
  else {
    $('.block_442 .col-data').removeClass('data-off');
  // Camera switch [435] & Camera button [ipcam]
  if (alldevices[435].Data == 'Off') {
    $('.block_435 .col-data').addClass('data-off');
	$('[data-id="ipcam"] .col-icon').addClass('icon-off');
	$('[data-id="ipcam"] .dt_content').addClass('data-off');
  else {
    $('.block_435 .col-data').removeClass('data-off');
	$('[data-id="ipcam"] .col-icon').removeClass('icon-off');
	$('[data-id="ipcam"] .dt_content').removeClass('data-off');
Custom.css:
CUSTOM CSS FILE
.transbg[class*="col-xs"] {
    border-width: 3px !important;
    border-radius: 10px;
    background-color: rgba(0,0,0,0.7);
/* .transbg[class*="col-xs"].hover:hover {
    background-color: rgba(128,128,128,0.3);
/* Placeholder */
/* .block_326 {
    background-color: transparent !important;
/* Device blocks */
div.mh {
	height:75px;
@media (max-width: 975px) {
	div.mh {
		height:67px;
/* Dimmer Slider and Handle - Off State */
[class*="block_"] .ui-slider-horizontal {
    background-color: rgba(255,255,255,0.4);
    border-color: transparent;
    height: 1px;
    top: 5px;
[class*="block_"] .ui-slider-handle {
    background-color: rgba(108,108,108,1.0);
    border-radius: 50%;
    height: 15px;
    width: 15px;
.block_431 .title,
.block_417 .title,
.block_124 .title,
.block_126 .title,
.block_236 .title,
.block_252 .title,
.block_391 .title,
.block_400 .title {
/* Dimmer Slider and Handle - On State */
.slider-on [class*="ui-slider-h"] {
    background-color: rgba(255,255,255,1.0);
.slider-on .title {
/* Swiper Pagination Bullet */
.swiper-pagination-bullet {
    display: none !important;
/* Thermostaat Setpoint */
.block_441_2 .icon {
    width: 85% !important;
    height: auto;
/* .block_441_2 .col-data {
    font-family: 'Orbitron';
    font-size: 99% !important;
.block_441_2 .state.stateheating {
    display: none
.input-number {
    font-size: 22px !important;
    font-weight: bold;
	.input-number {
		font-size: 18px !important;
		font-weight: bold;
/* Thermostaat Selector */
.block_438 .icon {
    height: auto;
.block_438 .btn-group {
    margin-top: -15px !important;
.block_438 .btn {
  color: #000000;
  border-color: #000000;
.block_438 .btn.active {
  color: #000000;
  background-color: rgba(255,255,255,0.9);
.block_438 .title {
    font-size: 0px !important;
/* Buienradar image */
[data-id='buienradar'] img {
	-webkit-filter: grayscale(100%);
/* Buienradar text */
.block_345 {
    height: 100% !important;
/* Longfonds */
.longfonds .dt_title {
	font-size: 12px !important;
.longfonds .dt_state {
/* AfvalWijzer */
.block_330  {
.trashcan {
	margin-left:0px !important;
/* Uptime */
.block_v3 {
/* Camera */
.block_435 .icon {
    width: 90%;
/* Kodi */
.block_258 {
/* Streamplayer */
div[data-id='streamplayer'] > div {
  opacity: 0.4 !important;
div[data-id='streamplayer'].playing > div {
  opacity: 1.0 !important;
.streamplayer .title {
	font-size: 125%;
	font-weight: bold;
/* Mike */
[data-id='147'].hover:hover {
    background-color: rgba(255,69,0,1.0) !important;
/* Buttons */
.button {
	min-height: 55px;
    padding-top: 10px !important;
.button .icon {
    width: 75% !important;
.button .dt_title {
	font-size: 125%;
/* Off State
.icon-off,
.data-off {
[class*="-off"] {
Blah blah blah
EdwinK
Post by EdwinK »
Thanks. Going to play with it later
ben53252642
Post by ben53252642 »
CSS code for an alternative version of the Venetian blinds Domoticz block:
My alternate version:
/* Living Room Blinds*/
.block_1553 .title {font-size: 18px}
.block_1553 .col-data .state {font-size: 12px}
.block_1553.transbg.col-xs-12 {height: 90px; overflow:hidden}
.block_1553 .col-button2 {width: 170px}
.block_1553 .btn.btn-number.plus {width: 70px; height: 100%; position: absolute; right: 100px}
.block_1553 .btn.btn-number.min {width: 70px; height: 100%; position: absolute; right: 30px; margin-top: -38px}
.block_1553 .btn.btn-number.stop {width: 88px; height: 30px; position: absolute; margin-right: -9px; padding-left: 15px; padding-top: 2px}
.fa-chevron-up:before {font-size: 70px}
.fa-chevron-down:before {font-size: 70px}
Screenshot of the original default version:
I'm sure someone else could probably do a lot better job on the CSS, I just guessed until I got it worked out for about 6 hours. :geek:
EdwinK
Post by EdwinK »
Nice :)
Guess i need to do some tweaking about the size
Screen Shot 2019-11-27 at 09.33.49.png (46.43 KiB) Viewed 2987 times
mvdheide01
Post by mvdheide01 »
Hi, I would like to display only the graph of my watermeter, coming from Domoticz. So just the one that displays the bars of the last 24 hours.
How could I do that?
I am using Dashticz in my Magic mirror and want my kids to see who used the least water during the morning shower :-)
Raspberry Pi, RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, OpenZWave USB
HansieNL
Post by HansieNL »
mvdheide01 wrote: Friday 29 November 2019 22:44 Hi, I would like to display only the graph of my watermeter, coming from Domoticz. So just the one that displays the bars of the last 24 hours.
You can use blocks['graph_43'] = ... where change 43 with your own Domoticz idx
For custom graph options in the beta version see: https://dashticz.readthedocs.io/en/bet ... tom-graphs
Blah blah blah
mvdheide01
Hi Hansie, Thanks for the reply.
When I use it as you describe, I get the Dashticz standard, not just the Domoticz one.
Maybe you can point me where to find the instructions for using the beta, then I will try that.
That might also just solve the issue with showing liters and get the correct view.
HansieNL wrote: Friday 29 November 2019 23:21
mvdheide01
Already found how to install the beta. First test is very promising:
Screenshot 2019-11-30_14-23-57-543.png (40.1 KiB) Viewed 4714 times
mvdheide01 wrote: Saturday 30 November 2019 11:10 Hi Hansie, Thanks for the reply.
EdwinK
Post by EdwinK »
@Hansienl how did you get that uptime tile look so nice. I only got:
Screen Shot 2019-12-11 at 18.00.24.png (18.68 KiB) Viewed 4607 times
