Dashticz - Show your dashboard and how-to's!
leonhannink
- Domoticz version: 4.9700
without the slash in the name
Lokonli
ok, good. thanks
leonhannink
Can anyone help me, buienradar has a forecast for just 1hour, can i change this to 12 hours?
Verzonden vanaf mijn iPad met Tapatalk
- HansieNL
You can check here what options buienradar is offering:leonhannink wrote: Saturday 09 November 2019 21:14 Can anyone help me, buienradar has a forecast for just 1hour, can i change this to 12 hours?
https://www.buienradar.nl/overbuienrad ... s-weerdata
Blah blah blah
leonhannink
Thanks, but how do i apply this in Dashticz?
- HansieNL
As far as I know you have to create your own web page with the code from Buienradar and load it as an iframe in Dashticz.leonhannink wrote: Saturday 09 November 2019 22:40 Thanks, but how do i apply this in Dashticz?
How to load an iframe in Dashticz you can find here https://dashticz.readthedocs.io/en/bet ... rames.html
Blah blah blah
leonhannink
Oke Thanks, i Will try and post when it works
niekbruggeman
As of this week i'm running the latest version of Dashticz version 3.1.2. Master.
I did a clean install in the /Dashticz directory. Without the _3.
Most of the dashboard is performing well except all graphs.
I created a new block according to the new graph-documentation
https://dashticz-v3.readthedocs.io/en/b ... dom-graphs
All of my graphs are staying red of color an ignoring all the properties in the "graphProperties : { }" section.
Anyone else experiencing the same issue ?
Some help will be much appreciated!
blocks['graph_123'] = {
title: 'Stroomverbruik',
graph: 'bar',
graphProperties : {
gridTextColor : '#c3f6fe',
barColors: ['#40e0d0'],
ymax:'auto', //set to 'auto' for auto scaling
stacked:'true',
resize:'true'
Lokonli
In 3.1.2 there is an update of the graph module. The configuration for the graph blocks changed as well.niekbruggeman wrote: Saturday 23 November 2019 14:38 As of this week i'm running the latest version of Dashticz version 3.1.2. Master.
blocks['graph_123'] = { title: 'Stroomverbruik', graph: 'bar', graphProperties : { gridTextColor : '#c3f6fe', barColors: ['#40e0d0'], ymax:'auto', //set to 'auto' for auto scaling stacked:'true', resize:'true' } }
I see you still use the old documentation. I will remove it. The new documentation can be found here:
https://dashticz.readthedocs.io/en/mast ... raphs.html
If you miss functionality in the new graph module, then leave a note here in the forum, and I'll have a look.
The latest beta is 3.2.0 and contains additional changes, The documentation link above is applicable to the master branch.
- EdwinK
- Domoticz version: BETA
Nice, now care to share the codes?
- EdwinK
Thanks. Going to play with it later
ben53252642
CSS code for an alternative version of the Venetian blinds Domoticz block:
My alternate version:
Screenshot of the original default version:
I'm sure someone else could probably do a lot better job on the CSS, I just guessed until I got it worked out for about 6 hours.
/* Living Room Blinds*/
.block_1553 .title {font-size: 18px}
.block_1553 .col-data .state {font-size: 12px}
.block_1553.transbg.col-xs-12 {height: 90px; overflow:hidden}
.block_1553 .col-button2 {width: 170px}
.block_1553 .btn.btn-number.plus {width: 70px; height: 100%; position: absolute; right: 100px}
.block_1553 .btn.btn-number.min {width: 70px; height: 100%; position: absolute; right: 30px; margin-top: -38px}
.block_1553 .btn.btn-number.stop {width: 88px; height: 30px; position: absolute; margin-right: -9px; padding-left: 15px; padding-top: 2px}
.fa-chevron-up:before {font-size: 70px}
.fa-chevron-down:before {font-size: 70px}
- EdwinK
Nice
Guess i need to do some tweaking about the size
mvdheide01
Hi, I would like to display only the graph of my watermeter, coming from Domoticz. So just the one that displays the bars of the last 24 hours.
How could I do that?
I am using Dashticz in my Magic mirror and want my kids to see who used the least water during the morning shower
Raspberry Pi, RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, OpenZWave USB
- HansieNL
You can use blocks['graph_43'] = ... where change 43 with your own Domoticz idxmvdheide01 wrote: Friday 29 November 2019 22:44 Hi, I would like to display only the graph of my watermeter, coming from Domoticz. So just the one that displays the bars of the last 24 hours.
I am using Dashticz in my Magic mirror and want my kids to see who used the least water during the morning shower![]()
For custom graph options in the beta version see: https://dashticz.readthedocs.io/en/bet ... tom-graphs
Blah blah blah
mvdheide01
Hi Hansie, Thanks for the reply.
When I use it as you describe, I get the Dashticz standard, not just the Domoticz one.
Maybe you can point me where to find the instructions for using the beta, then I will try that.
That might also just solve the issue with showing liters and get the correct view.
HansieNL wrote: Friday 29 November 2019 23:21You can use blocks['graph_43'] = ... where change 43 with your own Domoticz idxmvdheide01 wrote: Friday 29 November 2019 22:44 Hi, I would like to display only the graph of my watermeter, coming from Domoticz. So just the one that displays the bars of the last 24 hours.
mvdheide01
Already found how to install the beta. First test is very promising:
mvdheide01 wrote: Saturday 30 November 2019 11:10 Hi Hansie, Thanks for the reply.
- EdwinK
@Hansienl how did you get that uptime tile look so nice. I only got:
