Rooted Toon plugin
Freakandel
Re: Rooted Toon plugin
Post by Freakandel »
Hi all, just to point out that the plugin is working fine on my Domoticz setup, with Toon 1. No need to change settings, just IP-address.
Could it be that your IP is changing over time (due to DHCP)? Can you set a fixed IP in your router to Toon?
Nodri
Post by Nodri »
For my Toon i have a fixed IP. I can connect to the Toon using Putty. So that all works.
At the moment i enable the plugin all my devices disappear.
The Toon doesn't show in my hardware list
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Nodri wrote: Monday 05 April 2021 11:50 For my Toon i have a fixed IP. I can connect to the Toon using Putty. So that all works.
Do you see something in the log ?
I've seen when i device is not setup properly it could delete all devices of the Toon plugin
Nodri
Post by Nodri »
I had it working for a short time.
All Toon devices showe on DOmoticz and are on the Dashboard.
But a few minutes later, no more devices:
When i stop the Hardware Rooted Toon all devices show, after i start it up all devices disappear:
2021-04-05 11:14:36.062 (Toon) {"HardwareID": 8, "HomeFolder": "/home/pi/domoticz/plugins/domoticz-rooted-toon-master/", "StartupFolder": "/home/pi/domoticz/", "UserDataFolder": "/home/pi/domoticz/", "WebRoot": "", "Database": "/home/pi/domoticz/domoticz.db", "Language": "nl", "Version": "1.0.7", "Author": "Hansaplast31", "Name": "Toon", "Address": "xxxxxxxxx "Mode4": "2.4", "Mode5": "2.6", "Mode6": "", "DomoticzVersion": "2020.2", "DomoticzHash": "b63341bc0", "DomoticzBuildTime": "2020-04-26 12:47:55"}
2021-04-05 11:14:36.057 Status: (Toon) Entering work loop.
2021-04-05 11:14:36.058 Status: (Toon) Initialized version 1.0.7, author 'Hansaplast31'
madpatrick
Nodri wrote: Monday 05 April 2021 12:13 I had it working for a short time.
2021-04-05 11:14:36.062 (Toon) {"HardwareID": 8, "HomeFolder": "/home/pi/domoticz/plugins/domoticz-rooted-toon-master/", "StartupFolder": "/home/pi/domoticz/", "UserDataFolder": "/home/pi/domoticz/", "WebRoot": "", "Database": "/home/pi/domoticz/domoticz.db", "Language": "nl", "Version": "1.0.7", "Author": "Hansaplast31", "Name": "Toon", "Address": "192.168.178.108xxxxxxxxx "Mode4": "2.4", "Mode5": "2.6", "Mode6": "", "DomoticzVersion": "2020.2", "DomoticzHash": "b63341bc0", "DomoticzBuildTime": "2020-04-26 12:47:55"}
Maybe this could be something.
All modes are having a value except Mode6
 "Mode6": ""
Nodri
Post by Nodri »
How do i set that mode??
I only have 5
madpatrick
Nodri wrote: Monday 05 April 2021 12:37 How do i set that mode??
I only have 5
No Clue. I’m not using the plugin.
If you look into the script there should only be 5 modes. Mode 6 is not mentioned in the script
Last edited by madpatrick on Wednesday 14 April 2021 22:20, edited 1 time in total.
CronoS
Post by CronoS »
I have just rooted the Toon and installed the Plugin. I have got two questions:
In the logging I got this error showing from the plugin:
2021-04-14 21:03:10.433 (Toon) onMessage aborted, response format not JSON
2021-04-14 21:03:10.433 (Toon) <?xml version="1.0" encoding="iso-8859-1"?>
2021-04-14 21:03:10.433 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
2021-04-14 21:03:10.433 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
2021-04-14 21:03:10.433 <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
2021-04-14 21:03:10.433 <head>
2021-04-14 21:03:10.433 <title>404 - Not Found</title>
2021-04-14 21:03:10.433 </head>
2021-04-14 21:03:10.433 <body>
2021-04-14 21:03:10.433 <h1>404 - Not Found</h1>
2021-04-14 21:03:10.433 </body>
2021-04-14 21:03:10.433 </html>
And I was wondering what the "Toon - Auto Program" does with the values Yes/no/Temporary. It says temporary but my program is on in the Toon, I don't know if this is the same?
At first glance the plugin seems to work OK afterwards.
CronoS
Post by CronoS »
I think the problem is related to the Boiler part. When I connect manually to the Toon for the Boiler, it also does not seems to work. Also I do not have info related on the Toon for this. So this is my cause I think for the 404 error. I have commented out the lines related to the Boiler in the plugin, that seems to work OK.. Don't have that error, but maybe there is a more permanent way of solving it in the plugin.
Freakandel
CronoS wrote: Friday 16 April 2021 21:09 I think the problem is related to the Boiler part. When I connect manually to the Toon for the Boiler, it also does not seems to work. Also I do not have info related on the Toon for this. So this is my cause I think for the 404 error. I have commented out the lines related to the Boiler in the plugin, that seems to work OK.. Don't have that error, but maybe there is a more permanent way of solving it in the plugin.
Hi Crono, when you install Boilerpressure app in the Toon device, the error should be gone. I had similar problems at first, seems like the script needs some value not available in 'standard' Toon, only trough the Boiler app.
ronalddehaan
Domoticz version: 2021.1
Post by ronalddehaan »
Hey guys,
I have a rooted Toon 1 on Firmware 5.49.7. I don't have Zon op Toon or ToonWater.
I've installed the plugin as described and everything seems to be working however I get these error lines every 10 seconds, any idea how to fix this? :roll:
2022-01-25 09:28:13.197 Error: Toon: (Toon) 'onMessage' failed 'ValueError':'cannot convert float NaN to integer'.
2022-01-25 09:28:13.197 Error: Toon: (Toon) ----> Line 449 in '/home/domoticz/domoticz/plugins/RootedToonPlug/plugin.py'
2022-01-25 09:28:13.197 Error: Toon: (Toon) ----> Line 377 in '/home/domoticz/domoticz/plugins/RootedToonPlug/plugin.py'
2022-01-25 09:28:13.197 Error: Toon: (Toon) ----> Line 322 in '/home/domoticz/domoticz/plugins/RootedToonPlug/plugin.py'
Edit: I do have the boiler pressure app installed on the Toon
pvdgulik
Domoticz version: 2023.1
Post by pvdgulik »
Goodmorning,
I have a Rooted Toon2 working fine, and connected with Domoticz, with these settings.
Settings Domoticz Rooted Toon Plugin
Schermafbeelding 2022-01-25 om 10.24.56.png (294.04 KiB) Viewed 15834 times
I do see the devices created by the plugin.
Devices Rooted Toon Plugin
Schermafbeelding 2022-01-25 om 10.28.33.png (332.58 KiB) Viewed 15834 times
I deactivated the ones which do not function because the boiler does not give the info, and I use a P1 meter, so not interested in double info
about Gas and Electricity.
In the log I constantly see these error.
2022-01-25 09:11:50.065 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 09:19:35.077 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 09:32:10.086 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
I does not help to activate devices which I deactivated, so that's not the solution.
Please help, thanks
ronalddehaan
ronalddehaan wrote: Tuesday 25 January 2022 9:31 Hey guys,
Solved my problem cosmetically by turning off the error logging. Everything seemed to be working fine, so for the time being, this will do for me :mrgreen:
pvdgulik
Post by pvdgulik »
Update:
Since 16:43 the connection is lost with the RootedToon. Don't no what happened.
Devices stopped working
Schermafbeelding 2022-01-25 om 18.44.36.png (365.45 KiB) Viewed 15818 times
A restart of the RootedToon solved the connection-problem, and the errors are gone for now. But I'm sure the errors will come back!
So filtering Errors in the log is not a good idea.
Any help appreciated!
Update 2: As I said, the errors will come back, even while the devices are still working:
2022-01-25 20:13:33.093 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 20:54:28.068 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 20:54:28.069 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 20:56:33.071 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 21:42:53.087 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 22:20:28.081 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 22:22:33.065 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 23:33:03.090 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
Filtering does not seem to be the best option to solve this.
Any help is appreciated
update 3: still errors in the log:
2022-01-27 03:09:33.054 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 04:08:03.064 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 06:15:13.071 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 06:15:13.072 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 06:17:18.090 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 06:17:18.091 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 07:02:43.052 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 07:04:48.085 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 09:17:23.088 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 09:17:23.089 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 09:50:03.084 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 10:29:38.094 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 10:43:23.068 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 10:52:39.089 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 13:16:14.100 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 13:18:19.069 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 13:28:09.083 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
Anybody a idea?
appelflap
Post by appelflap »
Hi, I'm having exactly the same issue as pvdgulik. On a freshly rooted Toon. Has anyone fixed this?
madpatrick
Guys,
I've cloned the plugin and made a small update
- Change : Devices are created automatically
- Change : New device : Boiler status
- Change : small name changes
I hope to make a update on the Toon Scenes based on the temperature change
If somebody has pyhton scripting experience i need all the help there is :D
Location of the plugin : https://github.com/MadPatrick/domoticz_toon
The best is to start with a clean install
PeJeWe
Domoticz version: Latest
Post by PeJeWe »
Is there a option to select witch sensor we want to use or not.
I use a Toon V1 with thermostat on/off mode.
And i have an external P1 port reading.
In domoticz there are several devices created by the plugin i do not use Humidity and system pressure.
when i delete them the script creates them again.
by the way it is working fine and nice work ;)
madpatrick
PeJeWe wrote: Thursday 12 January 2023 14:58 Is there a option to select witch sensor we want to use or not.
Not at the moment
It is quit difficult to make too many option in a plugin.
You can always disable the device is the section Devices in Domoticz.
Also there difference between v1 en v2. And also per version there differences
PeJeWe
Post by PeJeWe »
When I disable them I get errors in the log section.
Can't auto create device because " auto add hardware" is off
Can I disable it in the python script?
Update:
I have managed to adapt the python script to disable the creating of the unnecessary sensors and disable the error giving in domoticz
EdwinK
Post by EdwinK »
madpatrick wrote: Saturday 31 December 2022 17:17 Guys,
<snip>
Thanks for that, at least now I can do some things again with my antiquated Toon V1 :) Although I keep getting '2023-05-01 23:25:05.099 Error: Toon: CConnection_connect, connect request from 'Toon' ignored. Transport is connected.' messages now and then.
Guess that is something to figure out tomorrow
