Rooted Toon plugin
- Freakandel
Re: Rooted Toon plugin
Hi all, just to point out that the plugin is working fine on my Domoticz setup, with Toon 1. No need to change settings, just IP-address.
Could it be that your IP is changing over time (due to DHCP)? Can you set a fixed IP in your router to Toon?
For my Toon i have a fixed IP. I can connect to the Toon using Putty. So that all works.
At the moment i enable the plugin all my devices disappear.
The Toon doesn't show in my hardware list
- madpatrick
- Domoticz version: 2025.2
Do you see something in the log ?Nodri wrote: Monday 05 April 2021 11:50 For my Toon i have a fixed IP. I can connect to the Toon using Putty. So that all works.
I've seen when i device is not setup properly it could delete all devices of the Toon plugin
I had it working for a short time.
All Toon devices showe on DOmoticz and are on the Dashboard.
But a few minutes later, no more devices:
When i stop the Hardware Rooted Toon all devices show, after i start it up all devices disappear:
2021-04-05 11:14:36.062 (Toon) {"HardwareID": 8, "HomeFolder": "/home/pi/domoticz/plugins/domoticz-rooted-toon-master/", "StartupFolder": "/home/pi/domoticz/", "UserDataFolder": "/home/pi/domoticz/", "WebRoot": "", "Database": "/home/pi/domoticz/domoticz.db", "Language": "nl", "Version": "1.0.7", "Author": "Hansaplast31", "Name": "Toon", "Address": "xxxxxxxxx "Mode4": "2.4", "Mode5": "2.6", "Mode6": "", "DomoticzVersion": "2020.2", "DomoticzHash": "b63341bc0", "DomoticzBuildTime": "2020-04-26 12:47:55"}
2021-04-05 11:14:36.057 Status: (Toon) Entering work loop.
2021-04-05 11:14:36.058 Status: (Toon) Initialized version 1.0.7, author 'Hansaplast31'
- madpatrick
Maybe this could be something.Nodri wrote: Monday 05 April 2021 12:13 I had it working for a short time.
2021-04-05 11:14:36.062 (Toon) {"HardwareID": 8, "HomeFolder": "/home/pi/domoticz/plugins/domoticz-rooted-toon-master/", "StartupFolder": "/home/pi/domoticz/", "UserDataFolder": "/home/pi/domoticz/", "WebRoot": "", "Database": "/home/pi/domoticz/domoticz.db", "Language": "nl", "Version": "1.0.7", "Author": "Hansaplast31", "Name": "Toon", "Address": "192.168.178.108xxxxxxxxx "Mode4": "2.4", "Mode5": "2.6", "Mode6": "", "DomoticzVersion": "2020.2", "DomoticzHash": "b63341bc0", "DomoticzBuildTime": "2020-04-26 12:47:55"}
All modes are having a value except Mode6
"Mode6": ""-= HP server GEN11 =- ZwaveJS-=- Domoticz v2025.2 -=- Dashticz =-
How do i set that mode??
I only have 5
I only have 5
- madpatrick
No Clue. I’m not using the plugin.
If you look into the script there should only be 5 modes. Mode 6 is not mentioned in the script
Last edited by madpatrick on Wednesday 14 April 2021 22:20, edited 1 time in total.
I have just rooted the Toon and installed the Plugin. I have got two questions:
In the logging I got this error showing from the plugin:
And I was wondering what the "Toon - Auto Program" does with the values Yes/no/Temporary. It says temporary but my program is on in the Toon, I don't know if this is the same?
At first glance the plugin seems to work OK afterwards.
2021-04-14 21:03:10.433 (Toon) onMessage aborted, response format not JSON
2021-04-14 21:03:10.433 (Toon) <?xml version="1.0" encoding="iso-8859-1"?>
2021-04-14 21:03:10.433 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
2021-04-14 21:03:10.433 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
2021-04-14 21:03:10.433 <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
2021-04-14 21:03:10.433 <head>
2021-04-14 21:03:10.433 <title>404 - Not Found</title>
2021-04-14 21:03:10.433 </head>
2021-04-14 21:03:10.433 <body>
2021-04-14 21:03:10.433 <h1>404 - Not Found</h1>
2021-04-14 21:03:10.433 </body>
2021-04-14 21:03:10.433 </html>At first glance the plugin seems to work OK afterwards.
I think the problem is related to the Boiler part. When I connect manually to the Toon for the Boiler, it also does not seems to work. Also I do not have info related on the Toon for this. So this is my cause I think for the 404 error. I have commented out the lines related to the Boiler in the plugin, that seems to work OK.. Don't have that error, but maybe there is a more permanent way of solving it in the plugin.
- Freakandel
Hi Crono, when you install Boilerpressure app in the Toon device, the error should be gone. I had similar problems at first, seems like the script needs some value not available in 'standard' Toon, only trough the Boiler app.CronoS wrote: Friday 16 April 2021 21:09 I think the problem is related to the Boiler part. When I connect manually to the Toon for the Boiler, it also does not seems to work. Also I do not have info related on the Toon for this. So this is my cause I think for the 404 error. I have commented out the lines related to the Boiler in the plugin, that seems to work OK.. Don't have that error, but maybe there is a more permanent way of solving it in the plugin.
ronalddehaan
- Domoticz version: 2021.1
Hey guys,
I have a rooted Toon 1 on Firmware 5.49.7. I don't have Zon op Toon or ToonWater.
I've installed the plugin as described and everything seems to be working however I get these error lines every 10 seconds, any idea how to fix this?
Edit: I do have the boiler pressure app installed on the Toon
2022-01-25 09:28:13.197 Error: Toon: (Toon) 'onMessage' failed 'ValueError':'cannot convert float NaN to integer'.
2022-01-25 09:28:13.197 Error: Toon: (Toon) ----> Line 449 in '/home/domoticz/domoticz/plugins/RootedToonPlug/plugin.py'
2022-01-25 09:28:13.197 Error: Toon: (Toon) ----> Line 377 in '/home/domoticz/domoticz/plugins/RootedToonPlug/plugin.py'
2022-01-25 09:28:13.197 Error: Toon: (Toon) ----> Line 322 in '/home/domoticz/domoticz/plugins/RootedToonPlug/plugin.py'-
pvdgulik
- Domoticz version: 2023.1
Goodmorning,
I have a Rooted Toon2 working fine, and connected with Domoticz, with these settings. I do see the devices created by the plugin. I deactivated the ones which do not function because the boiler does not give the info, and I use a P1 meter, so not interested in double info
about Gas and Electricity.
In the log I constantly see these error.
I does not help to activate devices which I deactivated, so that's not the solution.
Please help, thanks
2022-01-25 09:11:50.065 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 09:19:35.077 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 09:32:10.086 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 09:32:10.086 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.Please help, thanks
ronalddehaan
Solved my problem cosmetically by turning off the error logging. Everything seemed to be working fine, so for the time being, this will do for meronalddehaan wrote: Tuesday 25 January 2022 9:31 Hey guys,
I've installed the plugin as described and everything seems to be working however I get these error lines every 10 seconds, any idea how to fix this?![]()
Edit: I do have the boiler pressure app installed on the ToonCode: Select all
2022-01-25 09:28:13.197 Error: Toon: (Toon) 'onMessage' failed 'ValueError':'cannot convert float NaN to integer'. 2022-01-25 09:28:13.197 Error: Toon: (Toon) ----> Line 449 in '/home/domoticz/domoticz/plugins/RootedToonPlug/plugin.py' 2022-01-25 09:28:13.197 Error: Toon: (Toon) ----> Line 377 in '/home/domoticz/domoticz/plugins/RootedToonPlug/plugin.py' 2022-01-25 09:28:13.197 Error: Toon: (Toon) ----> Line 322 in '/home/domoticz/domoticz/plugins/RootedToonPlug/plugin.py'
pvdgulik
Update:
Since 16:43 the connection is lost with the RootedToon. Don't no what happened.
A restart of the RootedToon solved the connection-problem, and the errors are gone for now. But I'm sure the errors will come back!
So filtering Errors in the log is not a good idea.
Any help appreciated!
Update 2: As I said, the errors will come back, even while the devices are still working:
Filtering does not seem to be the best option to solve this.
Any help is appreciated
update 3: still errors in the log:
Anybody a idea?
2022-01-25 20:13:33.093 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 20:54:28.068 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 20:54:28.069 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 20:56:33.071 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 21:42:53.087 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 22:20:28.081 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 22:22:33.065 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 23:33:03.090 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-25 23:33:03.090 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.Any help is appreciated
2022-01-27 03:09:33.054 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 04:08:03.064 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 06:15:13.071 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 06:15:13.072 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 06:17:18.090 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 06:17:18.091 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 07:02:43.052 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 07:04:48.085 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 09:17:23.088 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 09:17:23.089 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 09:50:03.084 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 10:29:38.094 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 10:43:23.068 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 10:52:39.089 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 13:16:14.100 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 13:18:19.069 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 13:28:09.083 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.
2022-01-27 13:28:09.083 Error: CConnection_connect, connect request from 'RootedToon' ignored. Transport is connecting.-
appelflap
Hi, I'm having exactly the same issue as pvdgulik. On a freshly rooted Toon. Has anyone fixed this?
- madpatrick
Guys,
I've cloned the plugin and made a small update
- Change : Devices are created automatically
- Change : New device : Boiler status
- Change : small name changes
I hope to make a update on the Toon Scenes based on the temperature change
If somebody has pyhton scripting experience i need all the help there is
Location of the plugin : https://github.com/MadPatrick/domoticz_toon
The best is to start with a clean install
PeJeWe
- Domoticz version: Latest
Is there a option to select witch sensor we want to use or not.
I use a Toon V1 with thermostat on/off mode.
And i have an external P1 port reading.
In domoticz there are several devices created by the plugin i do not use Humidity and system pressure.
when i delete them the script creates them again.
by the way it is working fine and nice work
- madpatrick
Not at the momentPeJeWe wrote: Thursday 12 January 2023 14:58 Is there a option to select witch sensor we want to use or not.
by the way it is working fine and nice work![]()
It is quit difficult to make too many option in a plugin.
You can always disable the device is the section Devices in Domoticz.
Also there difference between v1 en v2. And also per version there differences
PeJeWe
When I disable them I get errors in the log section.
Can't auto create device because " auto add hardware" is off
Can I disable it in the python script?
Update:
I have managed to adapt the python script to disable the creating of the unnecessary sensors and disable the error giving in domoticz
Update:
- EdwinK
- Domoticz version: BETA
Thanks for that, at least now I can do some things again with my antiquated Toon V1madpatrick wrote: Saturday 31 December 2022 17:17 Guys,
<snip>
Guess that is something to figure out tomorrow
Users browsing this forum: Bing [Bot] and 0 guests
