zigate tuya siren
marktn
Re: zigate tuya siren
Post by marktn »
The log of domoticz as attachment.
Thanks for your support!
logdomoticz.txt
(66.34 KiB) Downloaded 84 times
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
keros
Post by keros »
You can turn off the tuya debug : don't need to have those logs all the time.
I can not help you more. My knowledge stops there.
Please wait until Pipiche comes back or an another expert can answer you.
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
marktn
Post by marktn »
keros wrote: Sunday 12 September 2021 14:13 You can turn off the tuya debug : don't need to have those logs all the time.
Thanks so far! I will wait for Pipiche.
pipiche
Post by pipiche »
marktn wrote: Sunday 12 September 2021 10:12
keros wrote: Sunday 12 September 2021 10:03 I think your plugin is still not up to date > git pull
You are right, did again a git pull, Plugin: 5.1.009
But the problem is still there.
Siren 1 en 3 not working, Siren 2 works.
A strange behaviour is, when selecting a alarm of siren 1 or 3, the switch stays on.
I had a look to your log file and the export, and I'm not able to identify the reason why it is not working.
between the 3 , 2 of them are the same model/same firmware version and the 3rd is same model/ with a different firmware. and in the 2 with the same firmware, 1 is working and the other not.
Have you try to repair one of the non-working since you have the latest firmware/plugin ? Todo that, you need to remove the associated Widgets in domoticz so then the reference to this device do not exist anymore in the Domoticz and Plugin device list.
marktn
Post by marktn »
Hi Pipiche,
I removed al 3 sirens, restart domoticz.
Add siren1, not working, and removed it again, restart domoticz.
Add siren 3, not working, and removed it again, restart domoticz.
Add siren 2, working.
Also did a test with batteries and/without USB cable.
Thanks,
Mark.
marktn
Post by marktn »
Any update on this issue?
pipiche
Post by pipiche »
Looks like there is something wrong or new somewhere. I have a second user experiencing the same issue.
I'll see if he is happy to send it to me, so I could debug what is wrong
marktn
Post by marktn »
pipiche wrote: Sunday 03 October 2021 9:29 Looks like there is something wrong or new somewhere. I have a second user experiencing the same issue.
Thanks. I could also send it, but the last experience was not that good ;)
I will for your respond! Thank so far.
pfloryann
Post by pfloryann »
I received Tuya siren Neo Coolcam NAS-AB02...in domoticz and zigate he sees it as TS0601-sirene, but doesn't work...the deveice light blinking all the time and he's not get the command. If i'll attach raw json can it help to solve?
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
pipiche
Post by pipiche »
Did you try to repair it once ?
If you can drop the raw json that would help
marktn
Post by marktn »
Looks like the same problem I have. Did the other user send you the siren?
pipiche
Post by pipiche »
Nope:-(
pfloryann
Post by pfloryann »
pipiche wrote: Monday 22 November 2021 20:22 Did you try to repair it once ?
I tried with repair but is same.
I will attach the json here, this siren is the last device from the list.
Thank you!
export(1).zip
(25.82 KiB) Downloaded 60 times
pfloryann
Post by pfloryann »
I re-attached the correct raw file
export(1).zip
(25.82 KiB) Downloaded 71 times
pfloryann
Post by pfloryann »
no solution?
pipiche
Post by pipiche »
I have received one. I’ll have some time next week
pipiche
Post by pipiche »
Thanks to @marktn whom was kind to ship one siren to me.
Indeed I'm having the same issue. The Siren get paired with Zigate and plugin, but continuously flashing and not able to be manged by Domoticz/Plugin.
I'll work on that as of tomorrow.
So stay tune
pipiche
Post by pipiche »
can you please get the latest beta branch and redo the pairing after removing all widget created
pfloryann
Post by pfloryann »
Hi Pipiche i tested, now pairing works, temperature and humidity works, melodies/songs works but volume level is low and haven't melody/sound for alert, like short pairing sound or something like this. Switch alert for humidity and temperature doesn't work.
Thank you!
Last edited by pfloryann on Monday 06 December 2021 16:08, edited 1 time in total.
pfloryann
Post by pfloryann »
Another thing ...all 4 songs stop after 5 seconds and name of song is not correct all the time
