Page 4 of 10
Re: Dashticz Dial - Features, Fixes & Updates
Posted: Wednesday 15 July 2020 12:44
by EdwinK
Okay. I was offline for a few hours. I think I found out what my problem is.
The group I had created in domoticz is using groups from the Hue. Somehow that doesn't work. Going to change so it works with the IDX of the lights instead of the Hue group.
Posted: Saturday 18 July 2020 8:46
by madpatrick
clinkadink wrote: Wednesday 15 July 2020 12:26
madpatrick wrote: Wednesday 15 July 2020 12:17
I have some room under the dials if possible
As a workaround for now, you can set a blank title in the block, and perhaps add a title block below. Just an idea?
The title block worked out nicely.
Is it possible that the dimmer button looks the same as the on/off when it is switched of ?
the needle for the dimmer is very small on my tablet (resolution 1280x800). May a bit longer and if you change the dimmer the number changes by a decimal (0.1)
If 1 lamp in the group is switch on, the button shows "off". In Domoticz you will "mixed" and the "On" button
Posted: Saturday 18 July 2020 14:13
by clinkadink
madpatrick wrote: Saturday 18 July 2020 8:46
No, as they are completely different dials.
You can change the size of the dial-center with css.
- Spoiler: show
.dial-center {
height: 65%!important;
width: 65%!important;
Good catch. I will fix this.
OK, will need to look at this. I am still new to groups.
Posted: Saturday 18 July 2020 14:59
by madpatrick
clinkadink wrote: Saturday 18 July 2020 14:13
- Spoiler: show
.dial-center {
Worked !!
Posted: Saturday 25 July 2020 17:47
by Scotty
Thanks for working on this Clinkadink. I've just updated to the latest beta but your work is surely appreciated.
Posted: Sunday 26 July 2020 18:37
by madpatrick
Is it possible to change the color of the dial when it is turned on better visable ?
The color is now gradient and not very clear on a smaller device like a tablet.
Posted: Sunday 26 July 2020 22:40
by clinkadink
Scotty wrote: Saturday 25 July 2020 17:47
You are more than welcome
Posted: Sunday 26 July 2020 22:41
by clinkadink
madpatrick wrote: Sunday 26 July 2020 18:37
Do you mean the glow around the dial center with dial button when switched on?
Posted: Sunday 26 July 2020 22:53
by madpatrick
Yes. That s the one
Posted: Sunday 26 July 2020 23:08
by clinkadink
madpatrick wrote: Sunday 26 July 2020 22:53
Yes. That s the one
Not sure if this helps, but this class styles the "on" state for the dial button.
.dial-center.on {
background: red!important;
Posted: Monday 27 July 2020 9:16
by madpatrick
it helps, but it is still a small ring.
Posted: Tuesday 04 August 2020 15:25
by gielie
I can't get this code to work
.dial-needle::before {
border-bottom-color: lime!important;
if i use the prefix for [data-id='temp_hum_baro'] a specific dial it does work.
So i want to use 1 piece of code to change all the needles.
Posted: Sunday 06 September 2020 8:47
by zenit
I really like the styling of a dashboard with these dials. For some sensors I have the possibility to read 2 values ' temp + humidity', this is working perfect with the dials! But I also have some sensors with only a 'temp' value. When I use these it shows ' NaN' in the dial.
So after a while looking into "dial.js" I found the code for temperature-only sensors and changed / added a line in the js code:
case d.Type === 'Temp':
case d.Type === 'Temp + Humidity':
case d.Type === 'Temp + Humidity + Baro':
Now these temp-sensors are working too, it only shows a NaN-value for humidity, needs some fiddeling too
I also have a rain-meter which needs to alter the dials.js to get it to work. In no way I'm a coder or developer, just trial en error.
Is it possible to merge this or even more features to these functions of the dials ?
Thanks in advance!
Posted: Sunday 06 September 2020 11:28
by Lokonli
zenit wrote: Sunday 06 September 2020 8:47
Thanks in advance!
Thanks for the feedback. I've added it to the list.
Posted: Tuesday 08 September 2020 6:36
by lzwfkv
Thanks in advance!
@zenit: until "Temp"-only devices are added to dials in dashticz, If in the meanwhile you still want to use your modified dials.js for them and don't want to show that NaN message/value, then you can use a simple work-around by adding to custom.css this section to hide Humidity and other extra data:
.dial[data-id='dial_name'] .extra {
display: none;
where 'dial_name' is the name of your dial block as defined in CONFIG.js ( blocks['dial_name'] = { type: 'dial',... ).
Otherwise, it would be more complicated to change the dials.js code further, by introducing a control that would prevent sending extra information in the "info" field to the dial template when the device is "Temp" only.
Posted: Wednesday 09 September 2020 11:54
by cduijker
Is it possible to change the icon (power-off) on the on/off switch dial to another icon?
Posted: Wednesday 09 September 2020 17:59
by zenit
lzwfkv wrote: Tuesday 08 September 2020 6:36
Thanks in advance!
display: none;
Thanks ! working perfect. Indeed it's better to solve it in the css-file.
I hope some new dials will be released (Rain-gauge, Barometer with pressure value BIG in the center of the dial). Maybe if I fiddle with the custom css a lot more is possible without 'breaking' the dials.js
Posted: Thursday 01 October 2020 15:14
by Bochelork
HI, I like the dials, but now some meters can and some meters can't be displayed with dials. Isn't it possible to create a custom dial with any value? Just using the value of in input and a minimum/maximum value for the scale of the gauge? It would be nice to display any watt/kwh meter with dials.
Thanks for making dashticz great!
Posted: Thursday 01 October 2020 15:27
by Lokonli
Almost ready ...
Posted: Thursday 01 October 2020 20:32
by Lokonli
ok.
beta 3.6.3
Give it a try
See:
https://dashticz.readthedocs.io/en/beta ... neric-dial
- more-dials.jpg (105.66 KiB) Viewed 2631 times
