When i press the button in the "Groups" section it works
If i press the buton in "Setting/devices" the lights doesn't switch on/off
(this is only with the Machinon theme, other themes work)
But the dial won't work, despite the theme selection
madpatrick wrote: Tuesday 14 July 2020 20:27
I have just enabled Machinon theme in my Domoticz, and tested dials in Dashticz and have no issues. Which is what I would expect, as Machinon is a CSS theme for Domoticz and would not interfere with the Dashticz dial.
If you click the 3 dots above your switch in Domoticz, you can see what the "Switch Type" is. To use the Dial "Switch", it must be set to "On/Off" in Domoticz.
I don't use groups, so i can't comment. I can't even see it in Domoticz. I can see you have Groups in your screenshot, but I don't. Where do you add them?
Ok, so I have found how to "Add Group" .. it was on the Scenes tab, which was disabled on my Domoticz. I don't use Scenes and I definitely don't use Groups. I haven't got a clue how they work.
Do any of you have a device with Switch Type "On/Off" that is not in a group, that you can check for me?
I am guessing that the Group functionality allows you to turn on and off all switches at the same time. If that is true, then I can say now that the dial button does not do that. It targets the device directly.
great.
The 4th switch is working. See the picture in my previous post
In the group there are several switches which you can turn on/off with 1 button.
In Setting/devices the group has een idx number and is clickable on/off
only not responding the idx number with the dials
OK, glad the dial button is working for a single device.
I have just added a group and 2 on/off switches to it. That gives me something to play with. I can now see there is little difference between switching a device on/off and switching a group on/off. It will be easy enough to accomodate this.
clinkadink wrote: Wednesday 15 July 2020 0:36
Ok, if you pull the latest beta - updated just now, and give it a try with groups. It seems to work fine for me, with 1 group and 2 on/off switches.
It uses the same "Idx" naming as the standard Dashticz switch, i.e. the idx is a string prefixed by "s". See below.
This is working.
The only point is that the text is too small on a tablet to read at a block width of 3
I've a 8" tablet, so the space is to not much
Is there a possibility to have the text under the dial ?
Or in a circle around the icon ?
@EdwinK - please check your config. Dial button for Groups works for me and madpatrick.
@madpatrick - I will have a look and see if anything can be done about the text under the dial.
clinkadink wrote: Wednesday 15 July 2020 10:46
So it works for madpatrick but not for EdwinK.
Great.
I have some room under the dials if possible
