I managed to add the internal temperature for shelly1pm device AND I renamed the devicename for current and total in KwH:
# ShellyCloudPlugin
# Author: Mario Peters
<plugin key="ShellyCloudPlugin" name="Shelly Cloud Plugin" author="Mario Peters" version="1.0.0" wikilink="https://github.com/mario-peters/ShellyCloudPlugin/wiki" externallink="https://github.com/mario-peters/ShellyCloudPlugin">
<description>
<h2>Shelly Cloud Plugin</h2><br/>
Plugin for controlling Shelly devices.
<h3>Configuration</h3>
<ul style="list-style-type:square">
<li>IP Address is the IP Address of the Shelly device. Default value is 127.0.0.1</li>
<li>Username</li>
<li>Password</li>
<li>Type is the type of Shelly device you want to add. Shelly 1, Shelly PM, Shelly 2.5, Shelly Dimmer, Shelly RGBW2 (only color), Shelly Bulb, Shelly Door/Window 2 and Shelly Plug-S are currently supported</li>
</ul>
<br/><br/>
</description>
<params>
<param field="Address" label="IP Address" width="200px" required="true" default="127.0.0.1"/>
<param field="Username" label="Username" width="200px" required="true"/>
<param field="Password" label="Password" width="200px" required="true" password="true"/>
<param field="Mode1" label="Type" width="200px" required="true">
<options>
<option label="Shelly 1" value="SHSW-1"/>
<option label="Shelly PM" value="SHSW-PM"/>
<option label="Shelly 2.5" value="SHSW-25"/>
<option label="Shelly Dimmer" value="SHDM-1"/>
<option label="Shelly RGBW2" value="SHRGBW2"/>
<option label="Shelly Bulb" value="SHBLB-1"/>
<option label="Shelly Door/Window 2" value="SHDW-2"/>
<option label="Shelly Plug" value="SHPLG-S"/>
</options>
</param>
</params>
</plugin>
import Domoticz
import requests
import json
class BasePlugin:
#mode = None
mode = "color"
def __init__(self):
return
def onStart(self):
Domoticz.Log("onStart called")
Domoticz.Heartbeat(30)
if len(Devices) == 0:
if Parameters["Mode1"] == "SHDW-2":
createSHDW2()
else:
headers = {'content-type':'application/json'}
try:
response_shelly = requests.get("http://"+Parameters["Address"]+"/settings",headers=headers, auth=(Parameters["Username"], Parameters["Password"]), timeout=(10,10))
json_items = json.loads(response_shelly.text)
response_shelly.close()
if Parameters["Mode1"] == "SHSW-1":
createSHSW1(json_items)
elif Parameters["Mode1"] == "SHSW-PM":
createSHSWPM(json_items)
elif Parameters["Mode1"] == "SHSW-25":
createSHSW25(json_items)
elif Parameters["Mode1"] == "SHDM-1":
createSHDM1(json_items)
elif Parameters["Mode1"] == "SHRGBW2" or Parameters["Mode1"] == "SHBLB-1":
createSHRGBW2(self,json_items)
elif Parameters["Mode1"] == "SHPLG-S":
createSHPLG(json_items)
else:
Domoticz.Log("Type: "+Parameters["Mode1"])
except requests.exceptions.Timeout as e:
Domoticz.Error(str(e))
def onStop(self):
Domoticz.Log("onStop called")
def onConnect(self, Connection, Status, Description):
Domoticz.Log("onConnect called")
def onMessage(self, Connection, Data):
Domoticz.Log("onMessage called")
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Log("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
if Parameters["Mode1"] != "SHDW-2":
url = "http://"+Parameters["Address"]
if Parameters["Mode1"] == "SHSW-1" or Parameters["Mode1"] == "SHPLG-S" or Parameters["Mode1"] == "SHSW-PM":
url = url + "/relay/" + str(Unit-1)
url = url + "/relay/" + str(Unit-2)
url = url + "/light/" + str(Unit-1)
if self.mode == "color":
url = url +"/color/" + str(Unit-1)
if self.mode == "white":
url = url +"/white/" + str(Unit-1)
if str(Command) == "On":
url = url + "?turn=on"
elif str(Command) == "Off":
url = url + "?turn=off"
elif str(Command) == "Set Level":
if self.mode == "color" and Parameters["Mode1"] != "SHDM-1":
url = url + "?turn=on&gain=" + str(Level)
elif self.mode == "white" or Parameters["Mode1"] == "SHDM-1":
url = url + "?turn=on&brightness=" + str(Level)
elif str(Command) == "Set Color":
Domoticz.Debug(str(Devices[Unit].Color))
Domoticz.Debug(str(Hue))
color_info=json.loads(Hue)
r=color_info["r"]
g=color_info["g"]
b=color_info["b"]
m=color_info["m"]
cw=color_info["cw"]
ww=color_info["ww"]
Domoticz.Debug(str(color_info))
url = url +"&red="+str(r)+"&green="+str(g)+"&blue="+str(b)+"&white="+str(cw)+"&gain="+str(Level)
url = url +"&white="+str(cw)+"&brightness="+str(Level)
else:
Domoticz.Log("Unknown command: "+str(Command))
Domoticz.Log("url: "+url)
try:
response = requests.get(url,headers=headers, auth=(Parameters["Username"], Parameters["Password"]), timeout=(10,10))
Domoticz.Debug(response.text)
response.close()
Devices[Unit].Update(nValue=1,sValue="On")
Devices[Unit].Update(nValue=0,sValue="Off")
Devices[Unit].Update(nValue=1,sValue=str(Level))
#Devices[Unit].Update(nValue=1,sValue=str(Level), Color=str(Hue))
Devices[Unit].Update(nValue=1,sValue=str(Level), Color=json.dumps(Hue))
else:
else:
def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
Domoticz.Log("Notification: " + Name + "," + Subject + "," + Text + "," + Status + "," + str(Priority) + "," + Sound + "," + ImageFile)
def onDisconnect(self, Connection):
Domoticz.Log("onDisconnect called")
def onHeartbeat(self):
Domoticz.Log("onHeartbeat called")
try:
request_shelly_status = requests.get("http://"+Parameters["Address"]+"/status",headers=headers, auth=(Parameters["Username"], Parameters["Password"]), timeout=(10,10))
Domoticz.Debug(request_shelly_status.text)
json_request = json.loads(request_shelly_status.text)
if Parameters["Mode1"] == "SHSW-1" or Parameters["Mode1"] == "SHPLG-S":
updateSHSW1(json_request)
updateSHSWPM(json_request)
updateSHSW25(json_request)
updateSHDM1(json_request)
updateSHRGBW2(self, json_request)
request_shelly_status.close()
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
global _plugin
_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
global _plugin
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
global _plugin
_plugin.onDisconnect(Connection)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
def createSHSW1(json_items):
relays = None
for key, value in json_items.items():
if key == "relays":
relays = value
count = 0
for relay in relays:
name = createRelay(relay, count)
meter={"power":0,"total":0}
createMeter(name, meter, count)
count = count + 1
def createSHSWPM(json_items):
Domoticz.Device("Temperature", Unit=31, Used=1, TypeName="Temperature").Create()
relays = None
if key == "relays":
relays = value
count = 0
count = count + 1
def createSHSW25(json_items):
relays = None
rollers = None
mode = None
num_meters = None
if key == "relays":
relays = value
if key == "rollers":
rollers = value
if key == "mode":
mode = value
#if key == "meters":
#meters = value
if key == "num_meters":
num_meters = value
Domoticz.Device("Temperature", Unit=1, Used=1, TypeName="Temperature").Create()
if mode == "relay":
count = 1
#meter = meters[1-count]
meter = {"power":0,"total":0}
count = count + 1
elif mode == "roller":
count = 1
def createSHPLG(json_items):
relays = None
if key == "relays":
relays = value
count = 0;
count = count + 1
def createSHDM1(json_items):
lights = []
meters = None
brightness = None
if key == "lights":
lights = value
if key == "meters":
meters = value
if key == "brightness":
brightness = value
count = 0
for light in lights:
name = createLight(light, count)
count = count + 1
def createSHRGBW2(self,json_items):
lights = []
if key == "lights":
lights = value
if key == "mode":
self.mode = value
ison = False
if key == "ison":
ison = value
self.mode="color"
Domoticz.Device(Name="RGBW", Unit=1, Used=1, Type=241, Subtype=1).Create()
Domoticz.Device(Name="RGBW_power", Unit=11, Used=1, Type=248, Subtype=1).Create()
Devices[11].Update(nValue=0, sValue="0")
createTotal("RGBW", 0, 0, 0)
elif self.mode == "white":
Domoticz.Device(Name="White", Unit=1, Used=1, Type=241, Subtype=3).Create()
Domoticz.Device(Name="White_power", Unit=11, Used=1, Type=248, Subtype=1).Create()
createTotal("White", 0, 0, 0)
else:
Domoticz.Log("Unknown mode: "+str(self.mode))
if ison == True:
Devices[1].Update(nValue=1, sValue="On")
def createSHDW2():
Domoticz.Device(Name="SHDW2", Unit=1, Used=1, Type=244, Subtype=73, Switchtype=11).Create()
def createLight(light, count):
name = ""
ison = False
for key, value in light.items():
if key == "name":
name = value
if key == "ison":
ison = value
if name == "" or name is None:
name = "Light"+str(count)
Domoticz.Device(Name=name, Unit=1+count, Used=1, Type=244, Subtype=73, Switchtype=7).Create()
if ison == True:
Devices[1+count].Update(nValue=1, sValue="On")
return name
def createRelay(relay, count):
name = ""
ison = False
for key, value in relay.items():
if key == "name":
name = value
if key == "ison":
ison = value
name = "Relay"+str(count)
Domoticz.Device(Name=name, Unit=1+count, Used=1, Type=244, Subtype=73).Create()
if ison == True:
return name
def createMeter(name, meter, count):
power = 0.0
for key, value in meter.items():
if key == "power":
power = value
createPower(name, power, count)
if key == "total":
createTotal(name, power, value, count)
def createPower(name, power, count):
Domoticz.Device(Name=name+"_current", Unit=11+count, Used=1, Type=248, Subtype=1).Create()
Devices[11+count].Update(nValue=0, sValue=str(power))
def createTotal(name, power, value, count):
Domoticz.Device(Name=name+"_total in kWh", Unit=21+count, Used=1, Type=243, Subtype=29).Create()
total = int(value)
total = total/60
total = int(total)
Devices[21+count].Update(nValue=0,sValue=str(power)+";"+str(total))
def updateSHSW1(json_request):
relays = None
meters = None
for key, value in json_request.items():
if key == "relays":
relays = value
if key == "meters":
meters = value
count = 0
updateRelay(relay, count)
updateMeter(meters[count], count)
count = count + 1
def updateSHSWPM(json_request):
relays = None
meters = None
if key == "relays":
relays = value
if key == "meters":
meters = value
if key == "temperature":
Devices[31].Update(nValue=Devices[31].nValue, sValue=str(value))
count = 0
count = count + 1
def updateSHSW25(json_request):
relays = None
meters = None
if key == "relays":
relays = value
if key == "meters":
meters = value
Devices[1].Update(nValue=Devices[1].nValue, sValue=str(value))
count = 1
updateMeter(meters[count-1], count)
count = count + 1
def updateSHDM1(json_request):
lights = []
meters = None
if key == "lights":
lights = value
if key == "meters":
meters = value
count = 0
#Devices[1].Update(nValue=1, sValue="50")
updateLight(light, count)
count = count + 1
def updateSHRGBW2(self, json_request):
lights = []
meters = []
if key == "lights":
lights = value
if key == "meters":
meters = value
count = 0
count = count + 1
def updateRGBLight(self,light,count):
m = 0
r = 0
g = 0
b = 0
ww = 0
cw = 0
if key == "mode":
if value == "color":
m = 3
if value == "white":
m = 1
if key == "red":
r = value
if key == "green":
g = value
if key == "blue":
b = value
if key == "white":
ww = value
ww = value * 255 / 100
if key == "cw":
cw = value
color = json.dumps({
'm': m, #mode 3: RGB
'r': r,
'g': g,
'b': b,
'ww': ww,
'cw': cw
Devices[count].Update(nValue=1,sValue="1", Color=str(color))
def updateLight(light, count):
if key == "ison":
if value:
if Devices[1+count].nValue != 1:
Devices[1+count].Update(nValue=1, sValue=Devices[1+count].sValue)
else:
Devices[1+count].Update(nValue=0, sValue=Devices[1+count].sValue)
Devices[1+count].Update(nValue=Devices[1+count].nValue, sValue=str(value))
def updateRelay(relay, count):
if key == "ison":
if value:
else:
Devices[1+count].Update(nValue=0, sValue="Off")
def updateMeter(meter, count):
power = ""
if key == "power":
power = str(value)
Devices[11+count].Update(nValue=0,sValue=power)
if key == "total":
total=int(value)
total=total/60
total=int(total)
Devices[21+count].Update(nValue=0,sValue=power+";"+str(total))
Next thing I would like to have is Shelly SW2.5 in rollermode.
