Page 4 of 4
Re: watermeter Elster V200 PR6P:1
Posted: Friday 27 May 2016 21:13
by thecosmicgate
Please anybody??
Sent from my SM-G935F using Tapatalk
Posted: Friday 27 May 2016 21:22
by Keptenkurk
Probably not what you would like to hear but is the ticking noise proportional to the flow? Could these ticks be counted by a simple microphone, amplifier, schmidt-trigger circuit?
Just thinking out of the box...
/paul
Re: RE: Re: watermeter Elster V200 PR6P:1
Posted: Saturday 11 June 2016 16:06
by thecosmicgate
Keptenkurk wrote:Probably not what you would like to hear but is the ticking noise proportional to the flow? Could these ticks be counted by a simple microphone, amplifier, schmidt-trigger circuit?
/paul
Seems that the sensors was the problem received one other and it's detecting. But now the wrong sensors BX instead of BY
Posted: Sunday 26 June 2016 14:41
by thecosmicgate
Finaly got a working sensors !
When connected to a terminal it detects [00], but when connected to domo as a p0 device nothing happens ? When I turn in the water the led lights up when it must be but domo doesn't detect or displays anything.
I connecter this sensor to a profilic usb to serial cable/convertor .
What did I do wrong ?
Posted: Sunday 02 April 2017 0:23
by iMars
I also got this watermeter. I can't figure out which sensor is used for this. Anyone who can tell me?
Posted: Saturday 13 May 2017 11:04
by zboblamont
If you are still trying to resolve this issue, check out MeterProvida in the UK who among other things supply Elster heads.
I have no connection with the company but sourced my V200 and an Elster Gas Meter pulser from them well over a month ago, probably lowest prices I found.
I have an outstanding order for a PR6 pulse head from them for the V200, stock was expected this week.
Posted: Friday 25 August 2017 16:53
by dk78
iMars wrote: Sunday 02 April 2017 0:23
Did you manage to read your watermeter? I have the same watermeter and want to try to get it in Domoticz.
Posted: Monday 19 February 2018 19:58
by Jeff
dk78 wrote: Friday 25 August 2017 16:53
Looks like a RF version of the PR6P (the one with the magnetic sensor on top of the red dial. A quick
google search on the code printed on the meter shows a RF version of the Flacon PR6 wired sensor module.
I have a PR6P meter installed with the wired sensor and been using this for quite a while now, Only remark is that for some reason the pulses aren't correctly measured after a while. Still no cause for this.
Posted: Wednesday 21 March 2018 20:47
by SjoerdNLD
This sensor, LJ18A3-8-Z/BX 8mm, detects the printed circuit when passing by.
I made the same construction with a hose clamp and iron holder.
Working fine on 12V.
It is rather large, but no downside so far;
https://nl.aliexpress.com/item/LJ18A3-8 ... Title=true
Electrical connection attached.
Using a step-up 3.3v -> 12v and using a optocouper 12v->3.3v for the input.
Software done according to wiki, only modified the idx and gpio port of the script.
https://www.domoticz.com/wiki/GPIO_meter
Posted: Friday 11 May 2018 16:35
by RobdeGr
Just received a new water meter and want to connect it to my Domoticz. I have a sensor type LJ12A3-4-Z/BX, doens anybody know if I can use this ? My Meter also has a printed circuit in the red marker..
Posted: Tuesday 04 December 2018 22:30
by mistysnip
Jeff wrote: Monday 19 February 2018 19:58
Hey Jeff,
Do you still have this issue with your V200+PR6P? I was considering this solution. but not if I might get those errors.
Posted: Wednesday 06 February 2019 18:37
by TheChief
RobdeGr wrote:Just received a new water meter and want to connect it to my Domoticz. I have a sensor type LJ12A3-4-Z/BX, doens anybody know if I can use this ? My Meter also has a printed circuit in the red marker..
Do you have make it work? I have the same sensor..
Verstuurd vanaf mijn SM-N950F met Tapatalk
Posted: Wednesday 08 May 2019 22:48
by Jeff
mistysnip wrote: Tuesday 04 December 2018 22:30
Hey Jeff,
Haven't been active for a while...
Currently rebuilding domoticz from scratch since it got corrupted.
Expect to have a answer to this in the next few hours / days. Don't currently know how it's going to react.
Stay tuned!
Posted: Monday 26 August 2019 12:13
by Justino
Jeff wrote: Wednesday 08 May 2019 22:48
Hey Jeff,
Stay tuned!
Hi Jeff,
Any news? I just received the new meter today and would really like to order some parts to read it.
Kind regards,
Justin
Did you figure it out? I got the same one, with the coil on your picture on top of the red thingy
Posted: Sunday 12 January 2020 17:28
by Martinvdm
Keptenkurk wrote: Wednesday 25 December 2013 16:12
Today i mounted and connected the proximity sensor and got it all working.
So now we are singing "Let it flow, let it flow, let it flow"
Merry Christmas to you all and a big THANK YOU to all involved with Domoticz.
/paul
EDIT: Changed the schematic to use a reed relay instead of the 2N7000 Mosfet
I am trying to understand your drawing. Can you clearify to connections on the reed relais? The proximity sensor pull downs to ground if i am right but the reed switch does need power also isn't?
