Blockly examples
SilentScreamer
Re: Blockly examples
Thanks, that worked very well, thanks for the unreal fast response!
shamie
I cannot figure out why my blockly isnt working, i hope you guys can give me some advice..
i want to close my suncreen (zonnescherm) when it's in state of Open and when its 22:00 (in case i am not home and i forget to close the screen by myself.)
when it closes i want it to send out an message to Kodi and an e-mail and mentioned in the log.
what is wrong here?
what is wrong here?
- StanHD
Try formating like this:-shamie wrote:I cannot figure out why my blockly isnt working, i hope you guys can give me some advice..
what is wrong here?
If [Switch = State] and [Time = ??:??]
Python:- Broadlink RM2, Sonos
cobra045
- Domoticz version: 3.4834
Try this
Cobra045
Cobra045
shamie
StanHD wrote: Wednesday 20 June 2018 22:48Try formating like this:-shamie wrote:I cannot figure out why my blockly isnt working, i hope you guys can give me some advice..
what is wrong here?
Thank you both, that helped me out a lot, its a logical thing after all
it didn't work for the first time, the sunscreen didnt go up, but i did get a mail, sow the part before "Do" worked.
after some testing i decided to use the group where the sunscreen belongs to.
so now i have this working:
i don't understand why the suncreen goes to "close" but turning the group to "off" works
tozzke
- Domoticz version: Stable
You'll probably have to use 'Open'/'Closed' in the If statement and 'On'/'Off' in the Do section
shamie
yeah maybe i will give that a shot as well.tozzke wrote: Friday 22 June 2018 17:49 You'll probably have to use 'Open'/'Closed' in the If statement and 'On'/'Off' in the Do section
Benneton
Working on similar script, to have my screens closed when it is after 07:30 and before 18:00.
Script checks if screen is open, then time check followed by actual status of light sensor. when bigger then 1100lux screen to close.
This is what I made of it:
It works for the part that the screen needs to close.
I also have a script that opens the screen at 19:00 hours.
When screens are closed the script opens them. Problem is that the script to close the screens then closes them and I get looped in open /close.
It appears that the time statement is not working in the screens_neer script.
Below what I made to open the screens
Any ideas what I am overlooking or not understanding correctly?
Help much appreciated.
Bernard
Bernard
Benneton
Looking at it I believe I have worked it out.
In the time statement it sould be AND instead of OR.
Will change and see if it works tomorrow.
Bernard
Bernard
Benneton
That did the trick
- EdddieN
- Domoticz version: 4.9700
Has anyone got read power working?
I'm trying to do this: I have a wall tablet with an inline aeon smart relay. When the tablet is charging, it usually charges over 10 Watts. I want to disconnect the power of the power supply after 1h when its power consumption drops below 10 Watts (about getting fully charged).
I have this tablet always on and charging, and I'm having problems with it I think due to overheating (always powered to the power supply).
The first part of it: if power < 10 does not seem to work in blockly for me, is there a way to get the power reading?
11101101 - www.machinon.com
henk99
I'm trying blocky to have domoticz send me a notification when the outside temperature gets below the temperature inside the house, so I have to start opening doors and windows. I'm using blocky as I have no idea how to program in Lua. However, I can't get it to work properly.
I have setup a virtual switch (Woonkamer_Temp) that is set to ON when outside_temp < livingroom_temp AND time is between 18.00-2330 hrs
In the virtual switch (Woonkamer_Temp) I have setup a notification when it switches to ON
The switching part works like a charm, however I keep getting notification every minute or so. I can see in the log that the 'Woonkamer_Temp' switch is polled all the time, hence sending a new notification every time. How can I prevent domoticz from doing that? I just want to have a notification one time. Can't get it to work in blocky.
Version 1 Version 2
Version 1 Version 2
- Blocky3.JPG (47.2 KiB) Viewed 5529 times
- Blocky2.JPG (38.46 KiB) Viewed 5529 times
- EdddieN
Make sure you select the right trigger event (device, time, etc...) on your blockly diagram
henk99
I'm sorry, can you elaborate? I'm fairly new to this. What I would like doesn't seem too difficult in my mind, but the blockys I made don't work. They keep repeating. I just want domoticz to send me one notification...it sounds so simple, and in Lua it is perhaps, but I can't figure out programming like that, i'm sorry. So, I'm either hoping for someone to show me what is wrong in my blocky or someone that can show me a lua script for me to figure out.EdddieN wrote: Thursday 02 August 2018 16:30 Make sure you select the right trigger event (device, time, etc...) on your blockly diagram
- waaren
Your blockly does switch your notification triggerdevice every time the temperature condition evaluates to true.henk99 wrote: Thursday 02 August 2018 16:26 I'm trying blocky to have domoticz send me a notification when the outside temperature gets below the temperature inside the house, so I have to start opening doors and windows. I'm using blocky as I have no idea how to program in Lua. However, I can't get it to work properly.
Using the checkFirst option in dzVents you can prevent that . This small dzVents script should do the job.
-- activateNotificationSwitch.lua
on = { timer = {"every minute between 16:00 and 23:30 on 15/4-15/9"}}, -- during spring and summer
execute = function(domoticz)
if domoticz.time.matchesRule("at 16:00-23:28") then
if domoticz.devices("Buiten temperatuur").temperature <= domoticz.devices("Woonkamer").temperature then
domoticz.devices("Woonkamer_Temp").switchOn().checkFirst()
domoticz.devices("Woonkamer_Temp").switchOff().checkFirst()
}Debian buster, bullseye on RPI-4, Intel NUC.
- EdddieN
No worries! Here, under blockly you have many options there how to trigger the eventhenk99 wrote: Thursday 02 August 2018 17:11I'm sorry, can you elaborate? I'm fairly new to this. What I would like doesn't seem too difficult in my mind, but the blockys I made don't work. They keep repeating. I just want domoticz to send me one notification...it sounds so simple, and in Lua it is perhaps, but I can't figure out programming like that, i'm sorry. So, I'm either hoping for someone to show me what is wrong in my blocky or someone that can show me a lua script for me to figure out.EdddieN wrote: Thursday 02 August 2018 16:30 Make sure you select the right trigger event (device, time, etc...) on your blockly diagram
henk99
Hi Waaren. thank you so much! I have implemented it in my domoticz and it worked like a charm. Very happy with this!waaren wrote: Thursday 02 August 2018 18:08 Your blockly does switch your notification triggerdevice every time the temperature condition evaluates to true.
Using the checkFirst option in dzVents you can prevent that . This small dzVents script should do the job.Code: Select all
-- activateNotificationSwitch.lua return { on = { timer = {"every minute between 16:00 and 23:30 on 15/4-15/9"}}, -- during spring and summer execute = function(domoticz) if domoticz.time.matchesRule("at 16:00-23:28") then if domoticz.devices("Buiten temperatuur").temperature <= domoticz.devices("Woonkamer").temperature then domoticz.devices("Woonkamer_Temp").switchOn().checkFirst() end else domoticz.devices("Woonkamer_Temp").switchOff().checkFirst() end end }
Hoekies
Is the last piece of the code not. The else is for the temperature check,henk99 wrote: Friday 03 August 2018 11:21 Your blockly does switch your notification triggerdevice every time the temperature condition evaluates to true.
end-
henk99
One question/request on this. As this script is setting a virtual switch, I found out it remains switched on until I switch it off manually. I didn't know this, which results in the script thinking that it has already sent me the message. Is there a way that this script switches off the switch at midnight so it's off again the next day?waaren wrote: Thursday 02 August 2018 18:08Your blockly does switch your notification triggerdevice every time the temperature condition evaluates to true.henk99 wrote: Thursday 02 August 2018 16:26 I'm trying blocky to have domoticz send me a notification when the outside temperature gets below the temperature inside the house, so I have to start opening doors and windows. I'm using blocky as I have no idea how to program in Lua. However, I can't get it to work properly.
Hoekies
Place the end before the else statement behind the statement. Then the problem is solved.henk99 wrote: Monday 06 August 2018 13:26One question/request on this. As this script is setting a virtual switch, I found out it remains switched on until I switch it off manually. I didn't know this, which results in the script thinking that it has already sent me the message. Is there a way that this script switches off the switch at midnight so it's off again the next day?waaren wrote: Thursday 02 August 2018 18:08Your blockly does switch your notification triggerdevice every time the temperature condition evaluates to true.henk99 wrote: Thursday 02 August 2018 16:26 I'm trying blocky to have domoticz send me a notification when the outside temperature gets below the temperature inside the house, so I have to start opening doors and windows. I'm using blocky as I have no idea how to program in Lua. However, I can't get it to work properly.
