Blockly examples
SilentScreamer
Re: Blockly examples
Post by SilentScreamer »
Thanks, that worked very well, thanks for the unreal fast response!
shamie
Post by shamie »
I cannot figure out why my blockly isnt working, i hope you guys can give me some advice..
i want to close my suncreen (zonnescherm) when it's in state of Open and when its 22:00 (in case i am not home and i forget to close the screen by myself.)
when it closes i want it to send out an message to Kodi and an e-mail and mentioned in the log.
what is wrong here?
StanHD
Post by StanHD »
shamie wrote:I cannot figure out why my blockly isnt working, i hope you guys can give me some advice..
what is wrong here?
Try formating like this:-
If [Switch = State] and [Time = ??:??]
Python:- Broadlink RM2, Sonos
cobra045
Domoticz version: 3.4834
Post by cobra045 »
Try this
Cobra045
shamie
Post by shamie »
StanHD wrote: Wednesday 20 June 2018 22:48
what is wrong here?
cobra045 wrote: Thursday 21 June 2018 10:35 Try this
Cobra045
Thank you both, that helped me out a lot, its a logical thing after all 8-)
it didn't work for the first time, the sunscreen didnt go up, but i did get a mail, sow the part before "Do" worked.
after some testing i decided to use the group where the sunscreen belongs to.
so now i have this working:
i don't understand why the suncreen goes to "close" but turning the group to "off" works :D
tozzke
Domoticz version: Stable
Post by tozzke »
You'll probably have to use 'Open'/'Closed' in the If statement and 'On'/'Off' in the Do section
shamie
Post by shamie »
tozzke wrote: Friday 22 June 2018 17:49 You'll probably have to use 'Open'/'Closed' in the If statement and 'On'/'Off' in the Do section
yeah maybe i will give that a shot as well.
Benneton
Post by Benneton »
Working on similar script, to have my screens closed when it is after 07:30 and before 18:00.
Script checks if screen is open, then time check followed by actual status of light sensor. when bigger then 1100lux screen to close.
This is what I made of it:
It works for the part that the screen needs to close.
I also have a script that opens the screen at 19:00 hours.
When screens are closed the script opens them. Problem is that the script to close the screens then closes them and I get looped in open /close.
It appears that the time statement is not working in the screens_neer script.
Below what I made to open the screens
Any ideas what I am overlooking or not understanding correctly?
Help much appreciated.
Bernard
Benneton
Post by Benneton »
Looking at it I believe I have worked it out.
In the time statement it sould be AND instead of OR.
Will change and see if it works tomorrow.
Bernard
Benneton
Post by Benneton »
That did the trick :)
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
Has anyone got read power working?
I'm trying to do this:
Screen Shot 2018-07-31 at 21.46.03.png (29.71 KiB) Viewed 5676 times
I have a wall tablet with an inline aeon smart relay. When the tablet is charging, it usually charges over 10 Watts. I want to disconnect the power of the power supply after 1h when its power consumption drops below 10 Watts (about getting fully charged).
I have this tablet always on and charging, and I'm having problems with it I think due to overheating (always powered to the power supply).
The first part of it: if power < 10 does not seem to work in blockly for me, is there a way to get the power reading?
11101101 - www.machinon.com
henk99
Post by henk99 »
I'm trying blocky to have domoticz send me a notification when the outside temperature gets below the temperature inside the house, so I have to start opening doors and windows. I'm using blocky as I have no idea how to program in Lua. However, I can't get it to work properly.
I have setup a virtual switch (Woonkamer_Temp) that is set to ON when outside_temp < livingroom_temp AND time is between 18.00-2330 hrs
In the virtual switch (Woonkamer_Temp) I have setup a notification when it switches to ON
The switching part works like a charm, however I keep getting notification every minute or so. I can see in the log that the 'Woonkamer_Temp' switch is polled all the time, hence sending a new notification every time. How can I prevent domoticz from doing that? I just want to have a notification one time. Can't get it to work in blocky.
Version 1
Version 2
EdddieN
Post by EdddieN »
Make sure you select the right trigger event (device, time, etc...) on your blockly diagram
henk99
Post by henk99 »
EdddieN wrote: Thursday 02 August 2018 16:30 Make sure you select the right trigger event (device, time, etc...) on your blockly diagram
I'm sorry, can you elaborate? I'm fairly new to this. What I would like doesn't seem too difficult in my mind, but the blockys I made don't work. They keep repeating. I just want domoticz to send me one notification...it sounds so simple, and in Lua it is perhaps, but I can't figure out programming like that, i'm sorry. So, I'm either hoping for someone to show me what is wrong in my blocky or someone that can show me a lua script for me to figure out.
henk99 wrote: Thursday 02 August 2018 16:26 I'm trying blocky to have domoticz send me a notification when the outside temperature gets below the temperature inside the house, so I have to start opening doors and windows. I'm using blocky as I have no idea how to program in Lua. However, I can't get it to work properly.
Your blockly does switch your notification triggerdevice every time the temperature condition evaluates to true.
Using the checkFirst option in dzVents you can prevent that . This small dzVents script should do the job.
--  activateNotificationSwitch.lua
         on = {   timer   =   {"every minute between 16:00 and 23:30 on 15/4-15/9"}}, -- during spring and summer
    execute = function(domoticz)
        if  domoticz.time.matchesRule("at 16:00-23:28") then
           if domoticz.devices("Buiten temperatuur").temperature <= domoticz.devices("Woonkamer").temperature then
                domoticz.devices("Woonkamer_Temp").switchOn().checkFirst()
            domoticz.devices("Woonkamer_Temp").switchOff().checkFirst()
EdddieN
Post by EdddieN »
henk99 wrote: Thursday 02 August 2018 17:11
No worries! Here, under blockly you have many options there how to trigger the event
Screen Shot 2018-08-02 at 20.41.09.png (53.65 KiB) Viewed 5550 times
henk99
Post by henk99 »
waaren wrote: Thursday 02 August 2018 18:08 Your blockly does switch your notification triggerdevice every time the temperature condition evaluates to true.
Hi Waaren. thank you so much! I have implemented it in my domoticz and it worked like a charm. Very happy with this!
Hoekies
Post by Hoekies »
henk99 wrote: Friday 03 August 2018 11:21 Your blockly does switch your notification triggerdevice every time the temperature condition evaluates to true.
Is the last piece of the code not. The else is for the temperature check,
henk99
Post by henk99 »
One question/request on this. As this script is setting a virtual switch, I found out it remains switched on until I switch it off manually. I didn't know this, which results in the script thinking that it has already sent me the message. Is there a way that this script switches off the switch at midnight so it's off again the next day?
Hoekies
Post by Hoekies »
henk99 wrote: Monday 06 August 2018 13:26
Place the end before the else statement behind the statement. Then the problem is solved.
