How to install Domoticz on a Synology NAS
arkoko
Re: How to install Domoticz on a Synology NAS
Post by arkoko »
Much better now (tested on evansport). Thank you. Donation on the way ;)
Version: 2020.2 (build 12213)
Build Hash: be4889e5d-modified
Compile Date: 2020-07-08 22:31:18
dzVents Version: 3.0.11
Python Version: 3.5.1 (default, Jan 29 2018, 14:16:25) [GCC 4.9.3 20150311 (prerelease)]
jumbotroll
Post by jumbotroll »
arkoko wrote: Thursday 09 July 2020 8:26 Much better now (tested on evansport). Thank you. Donation on the way ;)
Thanks for feedback, then I will start build packages for all archs.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Atis
Post by Atis »
jumbotroll wrote: Wednesday 08 July 2020 22:54
Atis wrote: Tuesday 07 July 2020 9:37 Hello, I have a 1019+ syno NAS. Python 3 plugin installed. I download the last domoticz version with python plugin.
I copy the py file to var/plugins/NUT_UPS folder.
Domoticz and NAS restart but I can not see in hardware list. What is wrong?
I think the error that the upload domoticz file not include python:
Version: 2020.2 (build 12192)
Build Hash: 8f82b73ff-modified
Compile Date: 2020-06-29 16:15:42
dzVents Version: 3.0.9
Python Version: None
Sorry, I think something went wrong with python module i the last build.
I will start with uploading new Apollolake DS1019+ beta version later tonight or tomorrow.
Remember you also need to install the official Python3 package from synology to make domoticz with python to work.
https://global.download.synology.com/do ... 1-0108.spk
Working, thank you!
arkoko
Post by arkoko »
jumbotroll wrote: Thursday 09 July 2020 8:56 Thanks for feedback, then I will start build packages for all archs.
Oeh... It seems that it's not so easy. Trying to use plugin ends with python crash :(
I'm not sure is it Domoticz or plugin (in this example Zwave BatteryLevel plugin used):
2020-07-09 09:54:43.232  Error: #0  /usr/local/domoticz/bin/domoticz() [0x82f0a49]
2020-07-09 09:54:43.232  Error: #1  /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x275 [0x82f14c5]
2020-07-09 09:54:43.233  Error: #2  linux-gate.so.1 : __kernel_rt_sigreturn + 0 [0xffffe40c]
2020-07-09 09:54:43.233  Error: #3  linux-gate.so.1 : __kernel_vsyscall + 0x10 [0xffffe424]
2020-07-09 09:54:43.233  Error: #4  /lib/libpthread.so.0 : raise + 0x3e [0xb72c1f7e]
2020-07-09 09:54:43.233  Error: #5  /lib/libpython3.5m.so :  + 0x18178f [0xb6d8c78f]
2020-07-09 09:54:43.233  Error: #6  linux-gate.so.1 : __kernel_sigreturn + 0 [0xffffe400]
2020-07-09 09:54:43.233  Error: #7  linux-gate.so.1 : __kernel_vsyscall + 0x10 [0xffffe424]
2020-07-09 09:54:43.233  Error: #8  /lib/libc.so.6 : gsignal + 0x4f [0xb6fed95f]
2020-07-09 09:54:43.233  Error: #9  /lib/libc.so.6 : abort + 0x160 [0xb6fef370]
2020-07-09 09:54:43.233  Error: #10 /lib/libc.so.6 :  + 0x6f139 [0xb702f139]
2020-07-09 09:54:43.234  Error: #11 /lib/libc.so.6 :  + 0x75579 [0xb7035579]
2020-07-09 09:54:43.234  Error: #12 /lib/libc.so.6 :  + 0x75d9f [0xb7035d9f]
2020-07-09 09:54:43.234  Error: #13 /lib/libcrypto.so.1.0.0 : CRYPTO_free + 0x33 [0xa1f103d3]
2020-07-09 09:54:43.234  Error: #14 /lib/libcrypto.so.1.0.0 : FIPS_free + 0x19 [0xa1f0e579]
2020-07-09 09:54:43.234  Error: #15 /lib/libcrypto.so.1.0.0 : FIPS_md_ctx_cleanup + 0xa3 [0xa1f0d483]
2020-07-09 09:54:43.234  Error: #16 /lib/libcrypto.so.1.0.0 : EVP_MD_CTX_cleanup + 0x42 [0xa1fa0252]
2020-07-09 09:54:43.234  Error: #17 /volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload/_hashlib.cpython-35m-i386-linux-gnu.so :  + 0x2913 [0xb0837913]
2020-07-09 09:54:43.234  Error: #18 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x6790 [0xb6d078f0]
2020-07-09 09:54:43.235  Error: #19 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x71da [0xb6d0833a]
2020-07-09 09:54:43.235  Error: #20 /lib/libpython3.5m.so :  + 0xff3d1 [0xb6d0a3d1]
2020-07-09 09:54:43.235  Error: #21 /lib/libpython3.5m.so : PyEval_EvalCode + 0x30 [0xb6d0a530]
2020-07-09 09:54:43.235  Error: #22 /lib/libpython3.5m.so :  + 0xf36e0 [0xb6cfe6e0]
2020-07-09 09:54:43.235  Error: #23 /lib/libpython3.5m.so : PyCFunction_Call + 0xda [0xb6c8fc6a]
To be honest I not used python versions before. It's my first attempt.
jumbotroll
arkoko wrote: Thursday 09 July 2020 9:01
I don't use any python plugin myself, so I can't test. I know if you have an older database file, this can happend. Did you do a clean install or did you update.
You can try to do a clean.
Jumbotroll
arkoko
Post by arkoko »
It was update. A lot of stuff needs to be restore after clean install. But I can try to do clean install and test some python plugins to watch results. Probably later I restore my configuration from backup.
UPD:
Unfortunally python plugins with clean install did not work too, at least for me (DS214play).
2020-07-09 13:36:40.653  Status: (ZM) Started.
2020-07-09 13:36:41.478  Error: Domoticz(pid:22382, tid:22387('PluginMgr')) received fatal signal 6 (Aborted)
2020-07-09 13:36:41.478  Error: siginfo address=0x576e, address=0xffffe424
2020-07-09 13:36:41.492  Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-07-09 13:36:41.505  Error: #0  /usr/local/domoticz/bin/domoticz() [0x82f0a49]
2020-07-09 13:36:41.505  Error: #1  /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x275 [0x82f14c5]
2020-07-09 13:36:41.505  Error: #2  linux-gate.so.1 : __kernel_rt_sigreturn + 0 [0xffffe40c]
joshua
Post by joshua »
I have the same problem on my DS916+
I did a clean install, but Python plugins are not showing up.
jbartoli
Post by jbartoli »
First, thanks for your work.
Install was smooth, and all great.
Still got a quick question.
i'm currently using an auto-backup script.
How can I access file on my NAS, to get access to specific file? (such as .db file, etc?)
GilbertvH
Post by GilbertvH »
jbartoli wrote: Monday 13 July 2020 10:35 Hello,
I'm using WinSCP. Should be a mandatory ;)
jbartoli
Post by jbartoli »
GilbertvH wrote: Monday 13 July 2020 11:01 I'm using WinSCP. Should be a mandatory ;)
Yup, my bad, I asked before a real search.
Went with Putty, but still same result.
If anyone wonder, here how it goes to me.
Backups and database are saved on /var folder (not like on raspberry)
So you'll need to search under
/volume1/@appstore/domoticz/var/
(And volume1 is w<here I've chooser to install the package, of course)
Then, i've just make an auto-copy of my file throught Task Scheduler on a Share folder, and then, auto-sync take the lead. (to upload to Google drive folder)
If needed, I'm using this script.
cp /volume1/@appstore/domoticz/* /volume1/homes/Bart/backup-"`date +"%d-%m-%Y"`"
arkoko
Post by arkoko »
Without need to playing to guess correct volume number it's possible to find domoticz files under /usr/local/domoticz , which is a symlink to the actual volume.
Pandabeer
Domoticz version: 10265
Post by Pandabeer »
Hi all / Jumbotroll
I tried to install the App on my Synology DS215j – I’m running DSM 6.2.3-25426 Update 2 (also older version this morning was not working) – as well domoticz_armada375-6.2_2020.2.12213-8.Spk as domoticz_armada375-6.2_2020.1.11804-8.Spk are not running. The installation went well but within package center I have to run the Domoticz app – after waiting a long time (the ‘hourglass’ stopped turning) the same information in Package Center – I’ve to run the application but it keeps on saying that I have to start/run Domoticz
What am I doing wrong?
Little expert running Domoticz on a Raspberry Pi
Toon Thermostat | Mi-Light | Z-Wave Thermostat valves and CO2 / fire detection units | KiKa | Heat-IT Zwave thermostat |
jumbotroll
Pandabeer wrote: Wednesday 22 July 2020 14:58 Hi all / Jumbotroll
Python 3 package from synology is required if you choose domoticz with python plugin support.
If you have problem with python version, test if domoticz without wor on your NAS.
Jumbotroll
mees40
Post by mees40 »
I'm using Domoticz on a DS214. However I'm moving to a DS220+. Is a Domoticz package already available for a Synology DS220+?
jumbotroll
mees40 wrote: Sunday 02 August 2020 16:06 I'm using Domoticz on a DS214. However I'm moving to a DS220+. Is a Domoticz package already available for a Synology DS220+?
The toolchain and kernel source is not released from synology, but you can test this modified version.
Not sure the driver inside the package will work, but you can uninstall the package if it's not working.
NOT TESTED!
Test version Domoticz Beta for Geminilake.
Download here:
http://www.jadahl.com/synospk/domoticz_ ... 2221-8.spk
Jumbotroll
Sjaakios
Post by Sjaakios »
jumbotroll wrote: Sunday 02 August 2020 16:19
NOT TESTED!
Download here:
Ive installed it on my DS220+, most things seem to work for me. Hardware works fine (tested harmony, mysensors, onkyo, weather, kodi), dzevents work fine.
Only thing im unable to get started are my plugins. Im unable to see them in the list of hardware types.
In the log, im also missing this line; which i do have in my other domoticz installation:
2020-08-03 10:04:45.970 Status: PluginSystem: Entering work loop.
jumbotroll
Sjaakios wrote: Monday 03 August 2020 10:08
NOT TESTED!
Download here:
This testversion does not support Python plugins, if that was the plugin you testet?
Jumbotroll
Sjaakios
Post by Sjaakios »
Ok, that explains. Yes it was a python plugin indeed.
mees40
Post by mees40 »
NOT TESTED!
Download here:
Many thanks, I'll test it when my new DS220+ is installed.
sandeman684
Post by sandeman684 »
jumbotroll wrote: Sunday 02 August 2020 16:19 The toolchain and kernel source is not released from synology, but you can test this modified version.
NOT TESTED!
Thanks a lot, a donation is on its way. Domoticz seems to work properly on my new DS920+. RFXCOM works, did not test ZWAVE yet.
