Version: 2020.2 (build 12213)
Build Hash: be4889e5d-modified
Compile Date: 2020-07-08 22:31:18
dzVents Version: 3.0.11
Python Version: 3.5.1 (default, Jan 29 2018, 14:16:25) [GCC 4.9.3 20150311 (prerelease)]
Thanks for feedback, then I will start build packages for all archs.arkoko wrote: ↑Thursday 09 July 2020 8:26 Much better now (tested on evansport). Thank you. Donation on the wayCode: Select all
Version: 2020.2 (build 12213) Build Hash: be4889e5d-modified Compile Date: 2020-07-08 22:31:18 dzVents Version: 3.0.11 Python Version: 3.5.1 (default, Jan 29 2018, 14:16:25) [GCC 4.9.3 20150311 (prerelease)]
Working, thank you!jumbotroll wrote: ↑Wednesday 08 July 2020 22:54Sorry, I think something went wrong with python module i the last build.Atis wrote: ↑Tuesday 07 July 2020 9:37 Hello, I have a 1019+ syno NAS. Python 3 plugin installed. I download the last domoticz version with python plugin.
I copy the py file to var/plugins/NUT_UPS folder.
Domoticz and NAS restart but I can not see in hardware list. What is wrong?
I think the error that the upload domoticz file not include python:
Version: 2020.2 (build 12192)
Build Hash: 8f82b73ff-modified
Compile Date: 2020-06-29 16:15:42
dzVents Version: 3.0.9
Python Version: None
I will start with uploading new Apollolake DS1019+ beta version later tonight or tomorrow.
Remember you also need to install the official Python3 package from synology to make domoticz with python to work.
https://global.download.synology.com/do ... 1-0108.spk
Oeh... It seems that it's not so easy. Trying to use plugin ends with python crashjumbotroll wrote: ↑Thursday 09 July 2020 8:56 Thanks for feedback, then I will start build packages for all archs.
2020-07-09 09:54:43.232 Error: #0 /usr/local/domoticz/bin/domoticz() [0x82f0a49]
2020-07-09 09:54:43.232 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x275 [0x82f14c5]
2020-07-09 09:54:43.233 Error: #2 linux-gate.so.1 : __kernel_rt_sigreturn + 0 [0xffffe40c]
2020-07-09 09:54:43.233 Error: #3 linux-gate.so.1 : __kernel_vsyscall + 0x10 [0xffffe424]
2020-07-09 09:54:43.233 Error: #4 /lib/libpthread.so.0 : raise + 0x3e [0xb72c1f7e]
2020-07-09 09:54:43.233 Error: #5 /lib/libpython3.5m.so : + 0x18178f [0xb6d8c78f]
2020-07-09 09:54:43.233 Error: #6 linux-gate.so.1 : __kernel_sigreturn + 0 [0xffffe400]
2020-07-09 09:54:43.233 Error: #7 linux-gate.so.1 : __kernel_vsyscall + 0x10 [0xffffe424]
2020-07-09 09:54:43.233 Error: #8 /lib/libc.so.6 : gsignal + 0x4f [0xb6fed95f]
2020-07-09 09:54:43.233 Error: #9 /lib/libc.so.6 : abort + 0x160 [0xb6fef370]
2020-07-09 09:54:43.233 Error: #10 /lib/libc.so.6 : + 0x6f139 [0xb702f139]
2020-07-09 09:54:43.234 Error: #11 /lib/libc.so.6 : + 0x75579 [0xb7035579]
2020-07-09 09:54:43.234 Error: #12 /lib/libc.so.6 : + 0x75d9f [0xb7035d9f]
2020-07-09 09:54:43.234 Error: #13 /lib/libcrypto.so.1.0.0 : CRYPTO_free + 0x33 [0xa1f103d3]
2020-07-09 09:54:43.234 Error: #14 /lib/libcrypto.so.1.0.0 : FIPS_free + 0x19 [0xa1f0e579]
2020-07-09 09:54:43.234 Error: #15 /lib/libcrypto.so.1.0.0 : FIPS_md_ctx_cleanup + 0xa3 [0xa1f0d483]
2020-07-09 09:54:43.234 Error: #16 /lib/libcrypto.so.1.0.0 : EVP_MD_CTX_cleanup + 0x42 [0xa1fa0252]
2020-07-09 09:54:43.234 Error: #17 /volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload/_hashlib.cpython-35m-i386-linux-gnu.so : + 0x2913 [0xb0837913]
2020-07-09 09:54:43.234 Error: #18 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x6790 [0xb6d078f0]
2020-07-09 09:54:43.235 Error: #19 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x71da [0xb6d0833a]
2020-07-09 09:54:43.235 Error: #20 /lib/libpython3.5m.so : + 0xff3d1 [0xb6d0a3d1]
2020-07-09 09:54:43.235 Error: #21 /lib/libpython3.5m.so : PyEval_EvalCode + 0x30 [0xb6d0a530]
2020-07-09 09:54:43.235 Error: #22 /lib/libpython3.5m.so : + 0xf36e0 [0xb6cfe6e0]
2020-07-09 09:54:43.235 Error: #23 /lib/libpython3.5m.so : PyCFunction_Call + 0xda [0xb6c8fc6a]
I don't use any python plugin myself, so I can't test. I know if you have an older database file, this can happend. Did you do a clean install or did you update.arkoko wrote: ↑Thursday 09 July 2020 9:01Oeh... It seems that it's not so easy. Trying to use plugin ends with python crashjumbotroll wrote: ↑Thursday 09 July 2020 8:56 Thanks for feedback, then I will start build packages for all archs.
I'm not sure is it Domoticz or plugin (in this example Zwave BatteryLevel plugin used):To be honest I not used python versions before. It's my first attempt.Code: Select all
2020-07-09 09:54:43.232 Error: #0 /usr/local/domoticz/bin/domoticz() [0x82f0a49] 2020-07-09 09:54:43.232 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x275 [0x82f14c5] 2020-07-09 09:54:43.233 Error: #2 linux-gate.so.1 : __kernel_rt_sigreturn + 0 [0xffffe40c] 2020-07-09 09:54:43.233 Error: #3 linux-gate.so.1 : __kernel_vsyscall + 0x10 [0xffffe424] 2020-07-09 09:54:43.233 Error: #4 /lib/libpthread.so.0 : raise + 0x3e [0xb72c1f7e] 2020-07-09 09:54:43.233 Error: #5 /lib/libpython3.5m.so : + 0x18178f [0xb6d8c78f] 2020-07-09 09:54:43.233 Error: #6 linux-gate.so.1 : __kernel_sigreturn + 0 [0xffffe400] 2020-07-09 09:54:43.233 Error: #7 linux-gate.so.1 : __kernel_vsyscall + 0x10 [0xffffe424] 2020-07-09 09:54:43.233 Error: #8 /lib/libc.so.6 : gsignal + 0x4f [0xb6fed95f] 2020-07-09 09:54:43.233 Error: #9 /lib/libc.so.6 : abort + 0x160 [0xb6fef370] 2020-07-09 09:54:43.233 Error: #10 /lib/libc.so.6 : + 0x6f139 [0xb702f139] 2020-07-09 09:54:43.234 Error: #11 /lib/libc.so.6 : + 0x75579 [0xb7035579] 2020-07-09 09:54:43.234 Error: #12 /lib/libc.so.6 : + 0x75d9f [0xb7035d9f] 2020-07-09 09:54:43.234 Error: #13 /lib/libcrypto.so.1.0.0 : CRYPTO_free + 0x33 [0xa1f103d3] 2020-07-09 09:54:43.234 Error: #14 /lib/libcrypto.so.1.0.0 : FIPS_free + 0x19 [0xa1f0e579] 2020-07-09 09:54:43.234 Error: #15 /lib/libcrypto.so.1.0.0 : FIPS_md_ctx_cleanup + 0xa3 [0xa1f0d483] 2020-07-09 09:54:43.234 Error: #16 /lib/libcrypto.so.1.0.0 : EVP_MD_CTX_cleanup + 0x42 [0xa1fa0252] 2020-07-09 09:54:43.234 Error: #17 /volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload/_hashlib.cpython-35m-i386-linux-gnu.so : + 0x2913 [0xb0837913] 2020-07-09 09:54:43.234 Error: #18 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x6790 [0xb6d078f0] 2020-07-09 09:54:43.235 Error: #19 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x71da [0xb6d0833a] 2020-07-09 09:54:43.235 Error: #20 /lib/libpython3.5m.so : + 0xff3d1 [0xb6d0a3d1] 2020-07-09 09:54:43.235 Error: #21 /lib/libpython3.5m.so : PyEval_EvalCode + 0x30 [0xb6d0a530] 2020-07-09 09:54:43.235 Error: #22 /lib/libpython3.5m.so : + 0xf36e0 [0xb6cfe6e0] 2020-07-09 09:54:43.235 Error: #23 /lib/libpython3.5m.so : PyCFunction_Call + 0xda [0xb6c8fc6a]
2020-07-09 13:36:40.653 Status: (ZM) Started.
2020-07-09 13:36:41.478 Error: Domoticz(pid:22382, tid:22387('PluginMgr')) received fatal signal 6 (Aborted)
2020-07-09 13:36:41.478 Error: siginfo address=0x576e, address=0xffffe424
2020-07-09 13:36:41.492 Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-07-09 13:36:41.505 Error: #0 /usr/local/domoticz/bin/domoticz() [0x82f0a49]
2020-07-09 13:36:41.505 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x275 [0x82f14c5]
2020-07-09 13:36:41.505 Error: #2 linux-gate.so.1 : __kernel_rt_sigreturn + 0 [0xffffe40c]
I'm using WinSCP. Should be a mandatory
Yup, my bad, I asked before a real search.
/volume1/@appstore/domoticz/var/
cp /volume1/@appstore/domoticz/* /volume1/homes/Bart/backup-"`date +"%d-%m-%Y"`"
Toon Thermostat | Mi-Light | Z-Wave Thermostat valves and CO2 / fire detection units | KiKa | Heat-IT Zwave thermostat |
Python 3 package from synology is required if you choose domoticz with python plugin support.Pandabeer wrote: ↑Wednesday 22 July 2020 14:58 Hi all / Jumbotroll
I tried to install the App on my Synology DS215j – I’m running DSM 6.2.3-25426 Update 2 (also older version this morning was not working) – as well domoticz_armada375-6.2_2020.2.12213-8.Spk as domoticz_armada375-6.2_2020.1.11804-8.Spk are not running. The installation went well but within package center I have to run the Domoticz app – after waiting a long time (the ‘hourglass’ stopped turning) the same information in Package Center – I’ve to run the application but it keeps on saying that I have to start/run Domoticz
What am I doing wrong?
The toolchain and kernel source is not released from synology, but you can test this modified version.
Ive installed it on my DS220+, most things seem to work for me. Hardware works fine (tested harmony, mysensors, onkyo, weather, kodi), dzevents work fine.jumbotroll wrote: ↑Sunday 02 August 2020 16:19The toolchain and kernel source is not released from synology, but you can test this modified version.
Not sure the driver inside the package will work, but you can uninstall the package if it's not working.
NOT TESTED!
Test version Domoticz Beta for Geminilake.
Download here:
http://www.jadahl.com/synospk/domoticz_ ... 2221-8.spk
This testversion does not support Python plugins, if that was the plugin you testet?Sjaakios wrote: ↑Monday 03 August 2020 10:08Ive installed it on my DS220+, most things seem to work for me. Hardware works fine (tested harmony, mysensors, onkyo, weather, kodi), dzevents work fine.jumbotroll wrote: ↑Sunday 02 August 2020 16:19The toolchain and kernel source is not released from synology, but you can test this modified version.
NOT TESTED!
Download here:
Only thing im unable to get started are my plugins. Im unable to see them in the list of hardware types.
In the log, im also missing this line; which i do have in my other domoticz installation:
2020-08-03 10:04:45.970 Status: PluginSystem: Entering work loop.
Many thanks, I'll test it when my new DS220+ is installed.jumbotroll wrote: ↑Sunday 02 August 2020 16:19The toolchain and kernel source is not released from synology, but you can test this modified version.
NOT TESTED!
Download here:
Thanks a lot, a donation is on its way. Domoticz seems to work properly on my new DS920+. RFXCOM works, did not test ZWAVE yet.jumbotroll wrote: ↑Sunday 02 August 2020 16:19 The toolchain and kernel source is not released from synology, but you can test this modified version.
NOT TESTED!
