Version: 2020.2 (build 12213)
Build Hash: be4889e5d-modified
Compile Date: 2020-07-08 22:31:18
dzVents Version: 3.0.11
Python Version: 3.5.1 (default, Jan 29 2018, 14:16:25) [GCC 4.9.3 20150311 (prerelease)]Moderator: leecollings
Python Version: 3.5.1 (default, Jan 29 2018, 14:16:25) [GCC 4.9.3 20150311 (prerelease)]Thanks for feedback, then I will start build packages for all archs.arkoko wrote: Thursday 09 July 2020 8:26 Much better now (tested on evansport). Thank you. Donation on the way![]()
Version: 2020.2 (build 12213) Build Hash: be4889e5d-modified Compile Date: 2020-07-08 22:31:18 dzVents Version: 3.0.11 Python Version: 3.5.1 (default, Jan 29 2018, 14:16:25) [GCC 4.9.3 20150311 (prerelease)]
Working, thank you!jumbotroll wrote: Wednesday 08 July 2020 22:54Sorry, I think something went wrong with python module i the last build.Atis wrote: Tuesday 07 July 2020 9:37 Hello, I have a 1019+ syno NAS. Python 3 plugin installed. I download the last domoticz version with python plugin.
I copy the py file to var/plugins/NUT_UPS folder.
Domoticz and NAS restart but I can not see in hardware list. What is wrong?
I think the error that the upload domoticz file not include python:
Version: 2020.2 (build 12192)
Build Hash: 8f82b73ff-modified
Compile Date: 2020-06-29 16:15:42
dzVents Version: 3.0.9
Python Version: None
I will start with uploading new Apollolake DS1019+ beta version later tonight or tomorrow.
Remember you also need to install the official Python3 package from synology to make domoticz with python to work.
https://global.download.synology.com/do ... 1-0108.spk
Oeh... It seems that it's not so easy. Trying to use plugin ends with python crashjumbotroll wrote: Thursday 09 July 2020 8:56 Thanks for feedback, then I will start build packages for all archs.
2020-07-09 09:54:43.232 Error: #0 /usr/local/domoticz/bin/domoticz() [0x82f0a49]
2020-07-09 09:54:43.232 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x275 [0x82f14c5]
2020-07-09 09:54:43.233 Error: #2 linux-gate.so.1 : __kernel_rt_sigreturn + 0 [0xffffe40c]
2020-07-09 09:54:43.233 Error: #3 linux-gate.so.1 : __kernel_vsyscall + 0x10 [0xffffe424]
2020-07-09 09:54:43.233 Error: #4 /lib/libpthread.so.0 : raise + 0x3e [0xb72c1f7e]
2020-07-09 09:54:43.233 Error: #5 /lib/libpython3.5m.so : + 0x18178f [0xb6d8c78f]
2020-07-09 09:54:43.233 Error: #6 linux-gate.so.1 : __kernel_sigreturn + 0 [0xffffe400]
2020-07-09 09:54:43.233 Error: #7 linux-gate.so.1 : __kernel_vsyscall + 0x10 [0xffffe424]
2020-07-09 09:54:43.233 Error: #8 /lib/libc.so.6 : gsignal + 0x4f [0xb6fed95f]
2020-07-09 09:54:43.233 Error: #9 /lib/libc.so.6 : abort + 0x160 [0xb6fef370]
2020-07-09 09:54:43.233 Error: #10 /lib/libc.so.6 : + 0x6f139 [0xb702f139]
2020-07-09 09:54:43.234 Error: #11 /lib/libc.so.6 : + 0x75579 [0xb7035579]
2020-07-09 09:54:43.234 Error: #12 /lib/libc.so.6 : + 0x75d9f [0xb7035d9f]
2020-07-09 09:54:43.234 Error: #13 /lib/libcrypto.so.1.0.0 : CRYPTO_free + 0x33 [0xa1f103d3]
2020-07-09 09:54:43.234 Error: #14 /lib/libcrypto.so.1.0.0 : FIPS_free + 0x19 [0xa1f0e579]
2020-07-09 09:54:43.234 Error: #15 /lib/libcrypto.so.1.0.0 : FIPS_md_ctx_cleanup + 0xa3 [0xa1f0d483]
2020-07-09 09:54:43.234 Error: #16 /lib/libcrypto.so.1.0.0 : EVP_MD_CTX_cleanup + 0x42 [0xa1fa0252]
2020-07-09 09:54:43.234 Error: #17 /volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload/_hashlib.cpython-35m-i386-linux-gnu.so : + 0x2913 [0xb0837913]
2020-07-09 09:54:43.234 Error: #18 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x6790 [0xb6d078f0]
2020-07-09 09:54:43.235 Error: #19 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x71da [0xb6d0833a]
2020-07-09 09:54:43.235 Error: #20 /lib/libpython3.5m.so : + 0xff3d1 [0xb6d0a3d1]
2020-07-09 09:54:43.235 Error: #21 /lib/libpython3.5m.so : PyEval_EvalCode + 0x30 [0xb6d0a530]
2020-07-09 09:54:43.235 Error: #22 /lib/libpython3.5m.so : + 0xf36e0 [0xb6cfe6e0]
2020-07-09 09:54:43.235 Error: #23 /lib/libpython3.5m.so : PyCFunction_Call + 0xda [0xb6c8fc6a]
I don't use any python plugin myself, so I can't test. I know if you have an older database file, this can happend. Did you do a clean install or did you update.arkoko wrote: Thursday 09 July 2020 9:01Oeh... It seems that it's not so easy. Trying to use plugin ends with python crashjumbotroll wrote: Thursday 09 July 2020 8:56 Thanks for feedback, then I will start build packages for all archs.
I'm not sure is it Domoticz or plugin (in this example Zwave BatteryLevel plugin used):To be honest I not used python versions before. It's my first attempt.Code: Select all
2020-07-09 09:54:43.232 Error: #0 /usr/local/domoticz/bin/domoticz() [0x82f0a49] 2020-07-09 09:54:43.232 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x275 [0x82f14c5] 2020-07-09 09:54:43.233 Error: #2 linux-gate.so.1 : __kernel_rt_sigreturn + 0 [0xffffe40c] 2020-07-09 09:54:43.233 Error: #3 linux-gate.so.1 : __kernel_vsyscall + 0x10 [0xffffe424] 2020-07-09 09:54:43.233 Error: #4 /lib/libpthread.so.0 : raise + 0x3e [0xb72c1f7e] 2020-07-09 09:54:43.233 Error: #5 /lib/libpython3.5m.so : + 0x18178f [0xb6d8c78f] 2020-07-09 09:54:43.233 Error: #6 linux-gate.so.1 : __kernel_sigreturn + 0 [0xffffe400] 2020-07-09 09:54:43.233 Error: #7 linux-gate.so.1 : __kernel_vsyscall + 0x10 [0xffffe424] 2020-07-09 09:54:43.233 Error: #8 /lib/libc.so.6 : gsignal + 0x4f [0xb6fed95f] 2020-07-09 09:54:43.233 Error: #9 /lib/libc.so.6 : abort + 0x160 [0xb6fef370] 2020-07-09 09:54:43.233 Error: #10 /lib/libc.so.6 : + 0x6f139 [0xb702f139] 2020-07-09 09:54:43.234 Error: #11 /lib/libc.so.6 : + 0x75579 [0xb7035579] 2020-07-09 09:54:43.234 Error: #12 /lib/libc.so.6 : + 0x75d9f [0xb7035d9f] 2020-07-09 09:54:43.234 Error: #13 /lib/libcrypto.so.1.0.0 : CRYPTO_free + 0x33 [0xa1f103d3] 2020-07-09 09:54:43.234 Error: #14 /lib/libcrypto.so.1.0.0 : FIPS_free + 0x19 [0xa1f0e579] 2020-07-09 09:54:43.234 Error: #15 /lib/libcrypto.so.1.0.0 : FIPS_md_ctx_cleanup + 0xa3 [0xa1f0d483] 2020-07-09 09:54:43.234 Error: #16 /lib/libcrypto.so.1.0.0 : EVP_MD_CTX_cleanup + 0x42 [0xa1fa0252] 2020-07-09 09:54:43.234 Error: #17 /volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload/_hashlib.cpython-35m-i386-linux-gnu.so : + 0x2913 [0xb0837913] 2020-07-09 09:54:43.234 Error: #18 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x6790 [0xb6d078f0] 2020-07-09 09:54:43.235 Error: #19 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x71da [0xb6d0833a] 2020-07-09 09:54:43.235 Error: #20 /lib/libpython3.5m.so : + 0xff3d1 [0xb6d0a3d1] 2020-07-09 09:54:43.235 Error: #21 /lib/libpython3.5m.so : PyEval_EvalCode + 0x30 [0xb6d0a530] 2020-07-09 09:54:43.235 Error: #22 /lib/libpython3.5m.so : + 0xf36e0 [0xb6cfe6e0] 2020-07-09 09:54:43.235 Error: #23 /lib/libpython3.5m.so : PyCFunction_Call + 0xda [0xb6c8fc6a]
2020-07-09 13:36:40.653 Status: (ZM) Started.
2020-07-09 13:36:41.478 Error: Domoticz(pid:22382, tid:22387('PluginMgr')) received fatal signal 6 (Aborted)
2020-07-09 13:36:41.478 Error: siginfo address=0x576e, address=0xffffe424
2020-07-09 13:36:41.492 Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-07-09 13:36:41.505 Error: #0 /usr/local/domoticz/bin/domoticz() [0x82f0a49]
2020-07-09 13:36:41.505 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x275 [0x82f14c5]
2020-07-09 13:36:41.505 Error: #2 linux-gate.so.1 : __kernel_rt_sigreturn + 0 [0xffffe40c]
...I'm using WinSCP. Should be a mandatoryjbartoli wrote: Monday 13 July 2020 10:35 Hello,
First, thanks for your work.
Install was smooth, and all great.
Still got a quick question.
i'm currently using an auto-backup script.
How can I access file on my NAS, to get access to specific file? (such as .db file, etc?)
Yup, my bad, I asked before a real search.
/volume1/@appstore/domoticz/var/Code: Select all
cp /volume1/@appstore/domoticz/* /volume1/homes/Bart/backup-"`date +"%d-%m-%Y"`"Code: Select all
Toon Thermostat | Mi-Light | Z-Wave Thermostat valves and CO2 / fire detection units | KiKa | Heat-IT Zwave thermostat |Python 3 package from synology is required if you choose domoticz with python plugin support.Pandabeer wrote: Wednesday 22 July 2020 14:58 Hi all / Jumbotroll
I tried to install the App on my Synology DS215j – I’m running DSM 6.2.3-25426 Update 2 (also older version this morning was not working) – as well domoticz_armada375-6.2_2020.2.12213-8.Spk as domoticz_armada375-6.2_2020.1.11804-8.Spk are not running. The installation went well but within package center I have to run the Domoticz app – after waiting a long time (the ‘hourglass’ stopped turning) the same information in Package Center – I’ve to run the application but it keeps on saying that I have to start/run Domoticz
What am I doing wrong?
The toolchain and kernel source is not released from synology, but you can test this modified version.mees40 wrote: Sunday 02 August 2020 16:06 I'm using Domoticz on a DS214. However I'm moving to a DS220+. Is a Domoticz package already available for a Synology DS220+?
Ive installed it on my DS220+, most things seem to work for me. Hardware works fine (tested harmony, mysensors, onkyo, weather, kodi), dzevents work fine.jumbotroll wrote: Sunday 02 August 2020 16:19The toolchain and kernel source is not released from synology, but you can test this modified version.mees40 wrote: Sunday 02 August 2020 16:06 I'm using Domoticz on a DS214. However I'm moving to a DS220+. Is a Domoticz package already available for a Synology DS220+?
Not sure the driver inside the package will work, but you can uninstall the package if it's not working.
NOT TESTED!
Test version Domoticz Beta for Geminilake.
Download here:
http://www.jadahl.com/synospk/domoticz_ ... 2221-8.spk
This testversion does not support Python plugins, if that was the plugin you testet?Sjaakios wrote: Monday 03 August 2020 10:08Ive installed it on my DS220+, most things seem to work for me. Hardware works fine (tested harmony, mysensors, onkyo, weather, kodi), dzevents work fine.jumbotroll wrote: Sunday 02 August 2020 16:19The toolchain and kernel source is not released from synology, but you can test this modified version.mees40 wrote: Sunday 02 August 2020 16:06 I'm using Domoticz on a DS214. However I'm moving to a DS220+. Is a Domoticz package already available for a Synology DS220+?
NOT TESTED!
Download here:
Only thing im unable to get started are my plugins. Im unable to see them in the list of hardware types.
In the log, im also missing this line; which i do have in my other domoticz installation:
2020-08-03 10:04:45.970 Status: PluginSystem: Entering work loop.
Many thanks, I'll test it when my new DS220+ is installed.jumbotroll wrote: Sunday 02 August 2020 16:19The toolchain and kernel source is not released from synology, but you can test this modified version.mees40 wrote: Sunday 02 August 2020 16:06 I'm using Domoticz on a DS214. However I'm moving to a DS220+. Is a Domoticz package already available for a Synology DS220+?
NOT TESTED!
Download here:
Thanks a lot, a donation is on its way. Domoticz seems to work properly on my new DS920+. RFXCOM works, did not test ZWAVE yet.jumbotroll wrote: Sunday 02 August 2020 16:19 The toolchain and kernel source is not released from synology, but you can test this modified version.
NOT TESTED!
