[MyDomoAtHome] Support thread
epierre
Re: [MyDomoAtHome] Support thread
Post by epierre »
rafal wrote:second question how i can use these commands in docker on synology????:
Check running docker processes
docker ps
Stoping a docker process
docker stop mdah
Those are from the Synology interface, I give this for those running it under command line interfacer (CLI)
To modify the conf just edit config.json ... but take the image as I added the possibility to have a local conf in the latest image on dockerhub.
As I don't have the docker interface, I suggest this tutorial maybe removing the -it parameter:
http://blog.pavelsklenar.com/how-to-ins ... -synology/
It looks like you should put this in the "Docker Run Parser" parameters:
docker run --name=mdah --env DOMO="http://your_ip:8080" -it --rm -p 3002:3002 epierre/mdah"
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
rafal
Domoticz version: latest
Post by rafal »
Hello again :)
Thank You for answer and very good link now we know on synology in docker you commands can't working because:
Docker run supports the below parameters:
"d", "detach"
"e", "env"
"link"
"m", "memory"
"name"
"P", "publish-all"
"p", "publish"
"privileged"
"v", "volume"
in Synology in the "Docker Run Parser" i removed -it -rm but not working ;/ buuuuuut i find KItematic Docker for windows and all you commnad under CLI WORKING !! :) and i don't know what's next?????....take a look
https://drive.google.com/file/d/0B5vmlS ... sp=sharing
epierre
Post by epierre »
ok let's try this:
docker run --name=mdah --net=host --env DOMO="http://your_ip:8080" -d -p 3002:3002 epierre/mdah
rafal
Post by rafal »
--net unsupported options ;/
i can give you access to my synology for test this command if you want ofcourse
epierre
Post by epierre »
some sait it should run, and without ?
docker run --name=mdah --env DOMO="http://your_ip:8080" -d -p 3002:3002 epierre/mdah
rgouyet
Post by rgouyet »
I sucessfuly ran the docker image on my synology box.
I used the assistant.
nothing on links page
rafal
Post by rafal »
Thank You rgouyet it's works :)
and now what i what should i do to connect from the imperihome on android galaxy s5 to domoticz .
i have installed app imperri home ->setting-> ImperiHomeStandard System wizard-> localAPI base URL: http://192.168.0.11:8084 and null
donoticz is on 192.168.0.11:8084 on synology
gate is configured for domoticz it is??????
no login and possword in domoticz
rafal
Post by rafal »
epierre wrote:some sait it should run, and without ?
i can add, but if you want switch on is error about API
i delete -d and - p and both :) a still same msgbox :x about API
bdormael
Post by bdormael »
bdormael wrote:Is there any chance that MyDomoAtHome can support the new "Selector" switch so that it will show up in Imperihome also as a multi select switch ?
Or does Imperihome not support Multi Select switches ?
Just wanted to check if there is still a possibility that mydomoathome would support the select switches from Domoticz?
I know that Imperihome has such a switch, but for now Imperihome does not detect the switches I made in Domoticz.
raym
Re: RE: Re: [MyDomoAtHome] Support thread
Post by raym »
Check out the new NodeJS version which is currently in development. This supports multi-state switches:
http://www.domoticz.com/forum/viewtopic ... 012#p62012
epierre
Post by epierre »
@all if you don't bother not to have curves, please go to the new version that has all the features here, installation path described here:
https://github.com/empierre/MyDomoAtHome/tree/nodejs
For support send me you email to [email protected] to have a slack access (best) or use the following thread
viewtopic.php?p=62012#p62012
bdormael
Post by bdormael »
Working perfect now with the new nodejs version, thx for the support
hendrik6073
Post by hendrik6073 »
hendrik6073 wrote:used search cannot find anything on this issue
i added 8 test dummy tekst devices. i use them to post the heater thermostat schedule information . I want to display the devices using ImperiHome.
In ImperiHome the dummy text devices are not visible (http://imperihome:5001/devices) ? should i do some extra ?
thanks
this is fixed, MyDomoAtHome did not 'see' this devices, MyDomoAtHome team did solve this
epierre
Post by epierre »
Hi All,
Now the Node JS is the preferred version, testing have been concluant so far.
Now you can install/upgrade through apt-get following the wiki
http://domoticz.com/wiki/ImperiHome#Ins ... ckage_.deb
raym
Post by raym »
@epierre - thanks for all your hard work getting this new version together. It's really shaping up to be a great release!
SchattenMann
Post by SchattenMann »
@epierre - fantastic work on this release, congrats!
on a side note i seem to be having a problem dimming "dimmers" in Imperihome, dimmer slider doesn't seem to work at all - no records of a dimming request on Domoticz logs, MQTT etc...
Any idea where I should start looking for troubleshooting this?
SchattenMann
nvm, sudo apt-get upgrade fixed it :D
Although I do have one question/suggestion. Given that domoticz creates a separate device for kWh (power consumption) Imperihome is unable to show power consumption on the "light device".
any chance we can have an option to "aggregate" both devices (lets say dimmer + power consumption) so that MDAH can report both as a single device for Imperihome?
Makes sense?
epierre
Post by epierre »
@SchattenMann you're right and I have the same issue as I have power switch 6 nodes three of them... and vera does it, and imperihome supports it...
looks it can be done as through ID and HardwareID it seems possible, have to add it in my todo
https://github.com/empierre/MyDomoAtHome/issues/73
epierre
Post by epierre »
SchattenMann wrote:nvm, sudo apt-get upgrade fixed it :D
I don't remember but a sliding blind inverted has still an issue, to be verified
SchattenMann
next step is to add Fibaro Roller Shutter controllers so lets ee how it goes ;)
epierre wrote:@SchattenMann you're right and I have the same issue as I have power switch 6 nodes three of them... and vera does it, and imperihome supports it...
Yeah it's quite odd how Domoticz handles Power Monitoring devices, a Qubino Flush Dimmer Plus creates 10+ devices where at least 3 seem to be related with Power Meter...not to mention the Aeon Clamp who seems to be a mess :(
Speaking of Aeon Clamp Imperihome is crashing when I try to open the Aeon Clamp graph - this was working fine yesterday with Vera. Anything I can do to help diagnose what the problem could be?
A similar thing happens with Temp/Hum graphs who either show an empty graph or returns an error.
