Dashticz - Module - Calendar
sammyke007
Domoticz version: 2022.1
Re: Dashticz - Module - Calendar
Post by sammyke007 »
TapNL wrote: Tuesday 04 February 2020 20:46 I am trying to combine three calendars. Don't seem to get this work.
Is this supported, or is the calendars.combined topped at two?
You can combine more than 2 calendars without a problem! You probably missed a "," or so at the end...
Here's my example:
calendars.sammy = { maxitems: 5, icalurl: 'https://calendar.google.com/calendar/ical/PRIVE1/basic.ics' }
calendars.vero = { maxitems: 5, icalurl: 'https://calendar.google.com/calendar/ical/PRIVE2/basic.ics' }
calendars.dr = { maxitems: 5, icalurl: 'https://calendar.google.com/calendar/ical/PRIVE3/basic.ics' }
calendars.fran = { calFormat: 1, maxitems: 2, icalurl: 'https://vblcal.wisseq.eu/vblcalsync/calsync.aspx?guid=BVBL1197G10002' }
calendars.vic = { calFormat: 1, maxitems: 2, icalurl: 'http://www.foot24.be/nl/ical/kvk-svelta-melsele/2g9r-60.ics' }
calendars.combined = {}
calendars.combined.maxitems = 5;
calendars.combined.calFormat = 1;
calendars.combined.calendars = [
   { color:'white',calendar:calendars.sammy },
   { color:'#ccc',calendar:calendars.vero },
   { color:'#00f',calendar:calendars.dr }
calendars.combined.url = 'https://calendar.google.com/calendar';
I combined the first 3 calendars in 1 block. The last two calendars are shown apart.
Maybe share yours and I'll try to help you out!
TapNL
Post by TapNL »
Okay, not sure what I did wrong, yesterday. I spend some time on it, it must have been a "," or something.
Got it working, now. Thanks for looking into it and for your support!
toro
Post by toro »
Rob67ert wrote: Friday 17 January 2020 16:46 Is there a way to only show the start time of a calendar event?
I don't think it is an option right now.
But I also would like that, especially for the F1 calendar.
I worked around it by changing the calender.js file (I have only 1 calendar)
Change the line almost at the bottom of calendar.js:
Change:
	var widget = '<div style="color:' + item1['color'] + '">' + item1['startdate'] + "" + item1['enddate'] + ' - <b>' + item1['title'] + '</b></div>';
to:
	var widget = '<div style="color:' + item1['color'] + '">' + item1['startdate'] + "" + ' : <b>' + item1['title'] + '</b></div>';
Of course, you need to do this again after every update.
Maybe it is possible to do a feature request for this.
Lokonli
Post by Lokonli »
I'll add it to the feature request list.
It would be great if some people would like to contribute to Dashticz as well. In case you have some programming skills, please contact me, and I'll show you how to contribute to the Dashticz community.
Lokonli
Post by Lokonli »
toro wrote: Thursday 06 February 2020 0:38
Change:
to:
Merged into beta.
set the 'startonly' block parameter to display the start time only.
toro
Post by toro »
Lokonli, this is great!
I did update the beta and added startonly:1 to the calendar line in config.js.
It works like a charm. There is now way I could fix this myself, so thank you very much.
A very usefull addition to the calendar
GilbertvH
Post by GilbertvH »
Even though I tried all kind of solutions I still can't seem to get my Google calendar in my dashboard. It just says "Laden..." (Loading... for non-Dutch people). Here is my config.js script. Maybe not the most decent one but it works (except for the calendar):
var config = {}
config['language'] = 'nl_NL';
config['domoticz_ip'] = 'http://192.168.178.24:8085';
config['app_title'] = 'xxx';
config['default_news_url'] = 'https://cors-anywhere.herokuapp.com/http://www.nu.nl/rss';
config['news_scroll_after'] = '4';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = 'https://calendar.google.com/calendar/ical/xxx.calendar.google.com/public/basic.ics';
config['last_update'] = 0;
config['hide_topbar'] = 1;
//OWM parameters
config['owm_api'] = 'xxx';
config['owm_city'] = 'xxx';
config['owm_name'] = 'xxx';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '4';
config['owm_min'] = true;
config['owm_days'] = true;
//Vuilnis Module
	config['garbage_company'] = 'deafvalapp';
	config['garbage_icalurl'] = 0;
	config['garbage_zipcode'] = xxxx;
	config['garbage_street'] = 'xxx';
	config['garbage_housenumber'] = 'xx';
	config['garbage_maxitems'] = '3';
	config['garbage_use_names'] = true;
	config['garbage_use_colors'] = true;
	config['garbage_icon_use_colors'] = true;
	config['garbage_use_cors_prefix'] = false;
	config['garbage'] = {
		gft: {kliko: 'green', 		code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
		pmd: {kliko: 'orange', 		code: '#db5518', name: 'PLASTIC', icon: 'img/garbage/kliko_orange.png'},
		rest: {kliko: 'grey', 		code: '#7CFC00', name: 'Restafval', icon: 'img/garbage/kliko_green.png'},
		papier: {kliko: 'blue', 	code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
		kca: {kliko: 'red', 		code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
		brown: {kliko: 'brown', 	code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
		black: {kliko: 'black', 	code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
		milieu: {kliko: 'yellow', 	code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
		kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},}
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
{"track":2,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
var calendars = {}
	calendars.private = { maxitems: 10, icalurl: 'https://calendar.google.com/calendar/ical/xxx.calendar.google.com/public/basic.ics' }
	calendars.formule1 = { maxitems: 15, icalurl: 'https://calendar.google.com/calendar/ical/ekqk1nbdusr1baon1ic42oeeik%40group.calendar.google.com/public/basic.ics' }
// Frames
var frames = {}
frames.weather = {
  frameurl:"//forecast.io/embed/#lat=xxx&lon=xxx&name=xxx&color=#00aaff&font=Helvetica&fontColor=#ffffff&units=si&text-color=#fff&",
  height: 250     //height of the block in pixels
frames.buienradar = {
  frameurl:"https://api.buienradar.nl/image/1.0/RadarMapNL?w=256&h=256",
    height: 256     //height of the block in pixels
// Blocks
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Temperatuur';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Stroomverbruik';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Netto Stroom / Zonnepanelen';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Gasverbruik';
blocks['blocktitle_5'] = {}
blocks['blocktitle_5']['type'] = 'blocktitle';
blocks['blocktitle_5']['title'] = 'Zonnepanelen';
blocks['blocktitle_6'] = {}
blocks['blocktitle_6']['type'] = 'blocktitle';
blocks['blocktitle_6']['title'] = 'Afval';
blocks['blocktitle_7'] = {}
blocks['blocktitle_7']['type'] = 'blocktitle';
blocks['blocktitle_7']['title'] = 'Waterlekkage sensor';
blocks['blocktitle_8'] = {}
blocks['blocktitle_8']['type'] = 'blocktitle';
blocks['blocktitle_8']['title'] = 'Sonos';
blocks['blocktitle_9'] = {}
blocks['blocktitle_9']['type'] = 'blocktitle';
blocks['blocktitle_9']['title'] = 'Verlichting';
blocks['blocktitle_10'] = {}
blocks['blocktitle_10']['type'] = 'blocktitle';
blocks['blocktitle_10']['title'] = 'Smart Plugs';
blocks['blocktitle_11'] = {}
blocks['blocktitle_11']['type'] = 'blocktitle';
blocks['blocktitle_11']['title'] = 'Gezinsagenda';
// Status devices
//Zwembadpomp
blocks[60] = {};
blocks[60]['title'] = 'Zwembadpomp';
blocks[60]['show_lastupdate'] = false;
blocks[60]['width'] = 5
blocks[60]['hide_data'] = true
blocks[60]['icon'] = 'fas fa-water'
//TV Lamp
blocks[68] = {};
blocks[68]['title'] = 'Lamp TV';
blocks[68]['show_lastupdate'] = false;
blocks[68]['width'] = 5
blocks[68]['hide_data'] = true
blocks[68]['icon'] = 'far fa-lightbulb'
//Lamp dressoir
blocks[65] = {};
blocks[65]['title'] = 'Lamp dressoir';
blocks[65]['show_lastupdate'] = false;
blocks[65]['width'] = 5
blocks[65]['hide_data'] = true
blocks[65]['icon'] = 'far fa-lightbulb'
//Alle lampen uit
blocks['s1'] = {};
blocks['s1']['title'] = 'Alle lampen aan / uit';
blocks['s1']['show_lastupdate'] = false;
blocks['s1']['width'] = 5
blocks['s1']['hide_data'] = true
blocks['s1']['icon'] = 'fas fa-power-off'
//Waterlekkage sensor
blocks[35] = {};
blocks[35]['title'] = 'Water Leak Detector';
blocks[35]['show_lastupdate'] = false;
blocks[35]['width'] = 5
blocks[35]['hide_data'] = true
blocks[35]['icon'] = 'fas fa-faucet'
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',29,31,2,'blocktitle_2',44,45,'blocktitle_4',40,'blocktitle_5',42,43,'blocktitle_3',15_1, 'graph_36']
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_11',calendars.formule1,calendars.private,frames.weather,'blocktitle_7',35,'blocktitle_9',65,68,'s1','blocktitle_10',60]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [frames.buienradar,'streamplayer','blocktitle_6','garbage','blocktitle_8',50,51,52]
columns[3]['width'] = 3;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big_owm']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg10.jpg';
blocks['calendars.private'] = {
   type: 'calendar',
   layout: 1,
   icalurl: 'https://calendar.google.com/calendar/ical/xxxx.calendar.google.com/public/basic.ics'
blocks['graph_36'] = {
    title: 'Totaaloverzicht',
    devices: [36],
    graph: ['line','bar','bar'],
    custom : {
         "last 2 weeks": {
            range: 'month',
            filter: '14 days',
            data: {
                Netto: 'd.v_36+d.v2_36-d.r1_36-d.r2_36',
                Verbruik: 'd.v_36+d.v2_36',
                Opgewekt: '-d.r1_36-d.r2_36'
       "last day": {
            range: 'day',
            filter: '24 hours',
            data: {
    legend: true,
    datasetColors:['blue','red','yellow']
EDIT: Fixed! I found: Open ./vendor/dashticz/ical/index.php. Change the debug variable from 0 to 1 on line 42
Lokonli
Post by Lokonli »
With debug=1 the 'old' ical module is used, which probably gives some issues on recurring events. But if it's working for you that's fine of course!
Still, I would like to know why the new ical module is not working. Could you do a small test?
Set debug back to 0. Open DevTools (F12). Refresh Dashticz. Filter in DevTools network tab on 'ical' and post the result of the network request here. That will help me in the debugging.
GilbertvH
Post by GilbertvH »
Lokonli wrote: Wednesday 01 July 2020 17:39 With debug=1 the 'old' ical module is used, which probably gives some issues on recurring events. But if it's working for you that's fine of course!
I'm not sure if I post the right values but here we go... Filter on ical on Network tab gives me 3 results:
RuntimeException: Can't open filehttps://calendar.google.com/calendar/ical/*knip*.calendar.google.com/public/basic.ics for reading in /volume1/web/dashticz/vendor/dashticz/ical/vendor/om/icalparser/src/IcalParser.php:54
Stack trace:
#0 /volume1/web/dashticz/vendor/dashticz/ical/index.php(65): om\IcalParser->parseFile('https://calenda...')
#1 {main}
RuntimeException: Can't open filehttps://calendar.google.com/calendar/ical/[email protected]/public/basic.ics for reading in /volume1/web/dashticz/vendor/dashticz/ical/vendor/om/icalparser/src/IcalParser.php:54
Stack trace:
#1 {main}
Third code is too big for forum so I put it in a file.
debug.txt
(78.78 KiB) Downloaded 131 times
Lokonli
Post by Lokonli »
GilbertvH wrote: Monday 06 July 2020 11:06
Stack trace:
#1 {main}
Stack trace:
#1 {main}
Third code is too big for forum so I put it in a file.debug.txt
The third code is not relevant.
The first two indicate a reading error. I've tried the F1 calendar on my system, and it's working.
You are running the latest Dashticz master (or beta)?
You've installed Dashticz on a Synology NAS? Did you enable 'curl' and 'openssl' PHP extensions in the Synology PHP configuration page?
GilbertvH
Post by GilbertvH »
Lokonli wrote: Monday 06 July 2020 21:18
Stack trace:
#1 {main}
Stack trace:
#1 {main}
You rock! I already enabled 'curl' but not 'openssl'. That was the solution! Thanks!
Lokonli
Post by Lokonli »
Glad to know it works. Openssl is required for the https connections.
FreakNL
Post by FreakNL »
For me, the calendar just keeps loading....
My Apache error log states:
[Fri Aug 14 14:25:16.220630 2020] [php7:notice] [pid 1532:tid 2064] [client 192.168.0.108:59352] PHP Notice: Undefined index: DESCRIPTION in D:\\websites\blabla\\dashticz-master-1eopzet\\vendor\\dashticz\\ical\\index.php on line 81, referer: http://www.xxxxxxx.nl/dashticz-master-1eopzet/
[Fri Aug 14 14:26:26.108974 2020] [php7:notice] [pid 1532:tid 2072] [client 192.168.0.108:59423] PHP Notice: Undefined index: history in D:\\websites\blabla\\Dashticz-Beta\\vendor\\dashticz\\ical\\index.php on line 37, referer: http://www.xxxxxxx.nl/dashticz-beta/
[Fri Aug 14 14:26:26.171458 2020] [php7:notice] [pid 1532:tid 2028] [client 192.168.0.108:59417] PHP Notice: Undefined index: history in D:\\websites\blabla\\Dashticz-Beta\\vendor\\dashticz\\ical\\index.php on line 37, referer: http://www.xxxxxxx.nl/dashticz-beta/
[Fri Aug 14 14:27:02.365002 2020] [php7:notice] [pid 1532:tid 2028] [client 127.0.0.1:55755] PHP Notice: Undefined index: history in D:\\websites\blabla\\dashticz-master-1eopzet\\vendor\\dashticz\\ical\\index.php on line 37, referer: http://www.xxxxxxx.nl/dashticz-master-1eopzet/
[Fri Aug 14 14:31:26.111392 2020] [php7:notice] [pid 1532:tid 2072] [client 192.168.0.108:59675] PHP Notice: Undefined index: history in D:\\websites\blabla\\Dashticz-Beta\\vendor\\dashticz\\ical\\index.php on line 37, referer: http://www.xxxxxxx.nl/dashticz-beta/
[Fri Aug 14 14:31:26.236409 2020] [php7:notice] [pid 1532:tid 2028] [client 192.168.0.108:59676] PHP Notice: Undefined index: history in D:\\websites\blabla\\Dashticz-Beta\\vendor\\dashticz\\ical\\index.php on line 37, referer: http://www.xxxxxxx.nl/dashticz-beta/
[Fri Aug 14 14:32:02.372755 2020] [php7:notice] [pid 1532:tid 2072] [client 127.0.0.1:55873] PHP Notice: Undefined index: history in D:\\websites\blabla\\dashticz-master-1eopzet\\vendor\\dashticz\\ical\\index.php on line 37, referer: http://www.xxxxxxx.nl/dashticz-master-1eopzet/
[Fri Aug 14 14:36:26.639462 2020] [php7:notice] [pid 1532:tid 2064] [client 192.168.0.108:59944] PHP Notice: Undefined index: history in D:\\websites\blabla\\Dashticz-Beta\\vendor\\dashticz\\ical\\index.php on line 37, referer: http://www.xxxxxxx.nl/dashticz-beta/
[Fri Aug 14 14:36:26.701981 2020] [php7:notice] [pid 1532:tid 2072] [client 192.168.0.108:59943] PHP Notice: Undefined index: history in D:\\websites\blabla\\Dashticz-Beta\\vendor\\dashticz\\ical\\index.php on line 37, referer: http://www.xxxxxxx.nl/dashticz-beta/
[Fri Aug 14 14:37:02.374358 2020] [php7:notice] [pid 1532:tid 2064] [client 127.0.0.1:55995] PHP Notice: Undefined index: history in D:\\websites\blabla\\dashticz-master-1eopzet\\vendor\\dashticz\\ical\\index.php on line 37, referer: http://www.xxxxxxx.nl/dashticz-master-1eopzet/
I don't know how to proceed...
XML and Curl is loaded in PHP....
I'm on Windows btw...
Running both beta and master....
my (test) config:
var calendars = {}
calendars.me = { maxitems: 10,
icon:'far fa-lightbulb',
icalurl: 'http://www.foot24.be/nl/ical/kvk-svelta ... g9r-60.ics'
calendars.f1 = {
maxitems: 6,
url: 'https://www.f1calendar.com/#!/timezone/Europe-Amsterdam',
icalurl: 'http://www.f1calendar.com/download/f1-c ... arm-20.ics',
calFormat: 1
columns[2] = {};
columns[2]['blocks'] = ['bt_1',17,269,18,19,271,342,564,570,521,255,'bt_4',262,282,calendars.me,calendars.f1];
/edit:"
Just installed apache in ubuntu
sudo apt-get update
sudo apt-get install apache2 php php-xml php-curl libapache2-mod-php
sudo systemctl restart apache2
Now I have the F1 calender working! Will continue to work on this then.
riko
Post by riko »
htilburgs wrote: Sunday 21 May 2017 10:44 I've made a combined calendar, Icon doesn't work, but the css for larger font does, it is:
.col-xs-12.items {
   font-size: 15px;
I am trying to adjust the font size of my calendar with a combined agenda (two google calendar agendas and a holidays calendar) by using the above line in my css. But this is not working. Any ideas solutions?
This is the code for the calendar:
blocks['my_calendar'] = {
        type: 'calendar',
        maxitems: 5,
        layout: 1,
        url: 'https://calendar.google.com/calendar/u/0/r',
        icalurl: {
                        Gezamenlijk: {
                                ics: 'https://calendar.google.com/calendar/ical/xx%40gmail.com/private-xx/basic.ics',
                                color: 'white'
                        School: {
                                ics: 'https://calendar.google.com/calendar/ical/xx.google.com/private-xx/basic.ics',
                                color: '#e6e6d1'
        holidayurl: 'https://www.calendarlabs.com/ical-calendar/ics/75/NL_Holidays.ics',
        startonly: true,
        weeks: 5,
        lastweek: false,
        isoweek: false,
        width: 12,
        fixAllDay: true,
        //title: 'Agenda',
HansieNL
Post by HansieNL »
Can you try if the following code works for you:
[data-id='my_calendar'] .dt_content {
   font-size: 15px;
Blah blah blah
riko
Post by riko »
HansieNL wrote: Thursday 10 November 2022 16:46 Can you try if the following code works for you:
   font-size: 15px;
Yes, this one works! Thanks
Krenstik
Post by Krenstik »
last couple days I miss google cal.
All calendars show without appointments. Default: 'Geen afspraken'
Any other with same issue?
Lokonli
Post by Lokonli »
Krenstik wrote: Sunday 15 January 2023 18:04 last couple days I miss google cal.
Mine is working.
Can you open DevTools by pressing F12. Refresh Dashticz.
In the DevTools Network tab filter on 'index.php'
You should see the google network request.
Click on the network request, tab 'Preview'
Any information there? Can you post it here?
Krenstik
Post by Krenstik »
Two calendars, and I do not understand why:
infoMessage('Calendar not found', calendar.ics);
console.error('Error in response from calendar with icalurl ' + url);
I regenerate link for my one but same result.....
Krenstik
Post by Krenstik »
my fault, missing php and apache....
