Ginlong, Omnik Solar, Solarman and Trannergy Inverters Topic is solved
Derik
Re: Ginlong, Omnik Solar, Solarman and Trannergy Inverters
Post by Derik »
galadril wrote:Hmm lijkt erop dat de api url niet meer werkt voor Omnik Solar..
Do you think you get this working again??
underscore4
Post by underscore4 »
nwessels wrote:Hi,
@underscore4 or someone else: did you solved your problem? I have the same problem. like to hear your solution.
Grtz Niels
I let it working with setup:
#!/usr/bin/python
import urllib, urllib2, hashlib
from xml.etree import ElementTree as ET
#config
username = 'username'' #your portal username
password = 'mypassword' #your portal password
baseURL = 'http://www.ginlongmonitoring.com' #base url
stationid = '1' #station id, get this via the station python script
# example: Working base urls:
# http://www.ginlongmonitoring.com:10000/
# http://www.omnikportal.com:10000/
# http://log.trannergy.com:10000/
# http://www.solarmanpv.com:10000/
#domoticz settings
domoticz_host = '127.0.0.1'
domoticz_port = '8080'
domoticz_url = 'json.htm'
domoticz_ActualPower = 'Id on domoticz' #idx of new device
m = hashlib.md5()
m.update(password)
#building url
requestURL = baseURL+'/serverapi/?method=Login&username='+username+'&password='+m.hexdigest()+'&key=apitest&client=iPhone'
#login call
root = ET.parse(urllib.urlopen(requestURL)).getroot()
token = root.find('token').text
print 'Logged In: '+username
#info url
infoURL = baseURL+'/serverapi/?method=Data&username='+username+'&stationid='+stationid+'&token='+token+'&key=apitest'
print 'Getting Info... '
#login call
infoRoot = ET.parse(urllib.urlopen(infoURL)).getroot()
income = infoRoot.find('income')
TodayIncome = income.find('TodayIncome').text
ActualPower = income.find('ActualPower').text
etoday = income.find('etoday').text
etotal = income.find('etotal').text
multiply='1000.0'
etotal1000 = float(etotal) * float(multiply)
TotalIncome = income.find('TotalIncome').text
etotalstr=str(etotal1000)
#logging values
print 'TodayIncome: '+TodayIncome
print 'ActualPower: '+ActualPower
print 'etoday: '+etoday
print 'etotal: '+etotal
print 'etotal 1000: '+etotalstr
#uploading values to domoticz
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=udevice&idx=" + domoticz_ActualPower+ "&nvalue=0&svalue=" + ActualPower+ ";" + etotalstr)
urllib.urlopen(url)
Derik
Post by Derik »
mmm Will give this a try ...
Do i need crontab?
Just change the ip port
Replace the url:port? or where do you use the port? [ not in the example..
Station id part i do not understand..
Hope for your support
underscore4
here my answare:
Yes, please set crontab, i have every 5 minutes
It work with no port, probably it open directly and automatic.
station id, it's just in device, after description of harware of domoticz or you could use script (code shoud be on first page).
Let me know.
sincze
Domoticz version: 2024.4
Post by sincze »
Sweet ;-) :D Let me try it as well.
Getting Info...
TodayIncome: 6.918
ActualPower: 872.00
etoday: 30.08
etotal: 14534.0
etotal 1000: 14534000.0
Well if we are this far with the python script it should be possible to get it working as an official hardware plugin in domoticz right? :D
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Derik
Post by Derik »
linaro@odroidxu4:~/domoticz/scripts/python$ ./SofarSolar.py
  File "./SofarSolar.py", line 34, in <module>
  File "/usr/lib/python2.7/urllib.py", line 87, in urlopen
    return opener.open(url)
  File "/usr/lib/python2.7/urllib.py", line 210, in open
    return self.open_unknown(fullurl, data)
  File "/usr/lib/python2.7/urllib.py", line 222, in open_unknown
    raise IOError, ('url error', 'unknown url type', type)
IOError: [Errno url error] unknown url type: 'www.solarmanpv.com'
Still got errors....
Where do i go wrong.?
Did try this in the cli with manual activate.
Copy paste all script.
And change my locals..
sincze
Post by sincze »
Please post your full file please.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Derik
Post by Derik »
#!/usr/bin/python
#config
username = '[email protected]' #your portal username
password = 'Changed' #your portal password
baseURL = 'www.solarmanpv.com/' #base url
stationid = '17608' #station id, get this via the station python script
#domoticz settings
domoticz_host = '192.168.5.70'
domoticz_ActualPower = '3905' #idx of new device
m = hashlib.md5()
m.update(password)
#building url
#login call
#info url
#login call
multiply='1000.0'
#logging values
urllib.urlopen(url)
Changed something... :-)
Ps:
Do i need to install some packages?
sincze
Post by sincze »
Mmm what happens if you change:
to:
baseURL = 'http://www.solarmanpv.com' #base url
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Post by sincze »
I wanted to have the script working with python 3 so
Here we go: Stationid.py
#!/usr/bin/python
import urllib, hashlib
from urllib.request import urlopen
#config
username          = '' #your portal username
password          = '' #your portal password
baseURL          = 'http://www.omnikportal.com:10000' #base url
# Working base urls:
m = hashlib.md5()
m.update(password.encode('utf-8'))
#building url
#login call
root = ET.parse(urlopen(requestURL)).getroot()
print ('Logged In: '+username)
#info url
infoURL = baseURL+'/serverapi/?method=Powerstationslist&username='+username+'&token='+token+'&key=apitest'
print ('Getting station id(s)... ')
#login call
infoRoot = ET.parse(urlopen(infoURL)).getroot()
for elem in infoRoot.findall('power'):
    print ("StationID: "+elem.find('stationID').text)
And the other one:
Here we go: Omnik.py
#!/usr/bin/python
#config
stationid = '' #station id, get this via the station python script
#domoticz settings
m = hashlib.md5()
#building url
#login call
#info url
print ('Getting Info... ')
#login call
multiply='1000.0'
#logging values
print ('TodayIncome: '+TodayIncome)
print ('ActualPower: '+ActualPower)
print ('etoday: '+etoday)
print ('etotal: '+etotal)
print ('etotal 1000: '+etotalstr)
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=udevice&idx=" + domoticz_ActualPower+"&nvalue=0&svalue=" + $
urlopen(url)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Derik
Post by Derik »
sincze wrote:Mmm what happens if you change:
to:
Thanks..
Looks this do the job: [ pvo has a problem on this moment ]
baseURL = 'http://www.solarmanpv.com:10000' #base url
What is the output in the log??
Is there a option to change this somewhere?
galadril
Domoticz version: latest
Post by galadril »
Should I change the script on the op?
Verstuurd vanaf mijn SM-T713 met Tapatalk
underscore4
I tried to look up about your error and i believe i have found the problem.
Well, system try to connect to the Ginlong or other manufactur cloud and download the data. I have tried to change the DNS using my internet provider default and after 2 days i got this error. Using back Google DNS or Open DNS i solved soon the problem again. Would you please try to take a look?
sincze
Post by sincze »
If you open:http://www.solarmanpv.com:10000/
Do you get:
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
underscore4
Remove port 10000, you don't need to writ it.
sincze
Post by sincze »
devros wrote:hello, any chance to support this portal
im using invertor with limiter and USB-PLUG (witch is registred to this page)
http://www.shinemonitor.com/main.html
looks similar to omnik
tried restfull page http://www.shinemonitor.com:10000/
but number is propablly diferent.... any idea how to find right number?
thanks
Currently working on the Shinemonitor and able to retrieve the following data from their API.
I was able to retrieve the data using PHP and Python3.
Why Python3. well I'm trying to figure out how to build a native-domoticz plugin :D and that one seems to require Python3.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
devros
Post by devros »
wow you made my day :) thanks a lot
thats perfect news..., i did my own python sihinemonitor scraper, but is really buggy and works only for current watt. Can you share script that you already have? Im quite curios how did you managed to get json data.
Native domoticz plugin is not so important but would be also great.
BTW: Did you noticed, that shinemonitor.com have quite often conection problems (error 502) ?
sincze
Post by sincze »
devros wrote:wow you made my day :) thanks a lot
:D That was the idea.
devros wrote:thats perfect news..., i did my own python sihinemonitor scraper, but is really buggy and works only for current watt. Can you share script that you already have? Im quite curios how did you managed to get json data.
Well at the moment my script is in as-is fase meaning you need to enter a lot of values or login to the shinemonitor website to retrieve a few. The guy on the other side of the world is implementing http://api.shinemonitor.com, but he speaks Chineese.
usr=''				#your username
pwd=''			#your password
companykey=''		#your companykey
# needed to retrieve data, can be obtained from portal
pn=''				#your plant id
sn=''				#your serial number
devros wrote: BTW: Did you noticed, that shinemonitor.com have quite often conection problems (error 502) ?
O yes I did, first I thought that it was me, but they are experiencing some problems and are working on it.
And now the piece you have been waiting for.
#!/usr/bin/python3
from pprint import pprint			#we only need this one for debugging
import requests
import json
import time as time_ 				#make sure we don't override time
def salt():
    return int(round(time_.time() * 1000))
#config
baseURL = 'http://api.shinemonitor.com'
# Password is in SHA1 format, so we need to convert it.
passwd=hashlib.sha1()				#create a sha1 type hashlib
passwd.update(pwd.encode('utf-8'))	#update the value with the password
#domoticz settings
domoticz_host = '127.0.0.1'		#or the official IP adres
domoticz_port = '8080'			#domoticz port defaul 8080
domoticz_ActualPower = '' 		#idx of virtual domoticz device
domoticz_DCVoltage1 = '' 		#idx of virtual domoticz device
domoticz_DCcurrent1 = '' 		#idx of virtual domoticz device
domoticz_gridvoltageA = '' 		#idx of virtual domoticz device
domoticz_gridcurrentA = '' 		#idx of virtual domoticz device
#building url
salt=salt()						#we need a salt
action= '&action=auth&usr=' + usr + '&company-key=' + companykey
pwdaction= str(salt) + str(passwd.hexdigest()) + action		#this complete string needs sha1 encryption
# A little more hasing is needed to create a sign.
auth_sign=hashlib.sha1()
auth_sign.update(pwdaction.encode('utf-8'))
sign = str(auth_sign.hexdigest())
solarurl= baseURL+'/public/?sign='+ sign + '&salt=' + str(salt) + action
# Process results to variables
r = requests.get(solarurl)
#r.json()
token=r.json()['dat']['token']
secret=r.json()['dat']['secret']
expire=r.json()['dat']['expire']
# We now have a token and secret so start collecting values.
#salt=salt()
action= '&action=queryDeviceLastData&i18n=en_US&pn=' + pn + '&devcode=684&devaddr=1&sn=' + sn
reqaction= str(salt) + secret + token + action
req_sign=hashlib.sha1()
req_sign.update(reqaction.encode('utf-8'))
sign = str(req_sign.hexdigest())
requrl= baseURL+'/public/?sign='+ sign + '&salt=' + str(salt) + '&token=' + token + '&action=queryDeviceLastData&i18n=en_US&pn=' + pn + '&devcode=684&devaddr=1&sn=' + sn
# Process results into variables
r = requests.get(requrl)
#r.json()
# pprint(r.json()) 							#Uncomment to see a nice output
ratepower= r.json()['dat'][9]['val']
ratevoltage= r.json()['dat'][10]['val']
todayenergy= r.json()['dat'][13]['val']
totalenergy= r.json()['dat'][14]['val']
activepower= r.json()['dat'][15]['val']
DCvoltage1= r.json()['dat'][16]['val']
DCvoltage2= r.json()['dat'][17]['val']
DCcurrent1= r.json()['dat'][18]['val']
DCcurrent2= r.json()['dat'][19]['val']
gridvoltageA= r.json()['dat'][20]['val']
gridcurrentA= r.json()['dat'][21]['val']
gridfrequency= r.json()['dat'][22]['val']
powerfactor= r.json()['dat'][23]['val']
multiply= 1000.1
etotalstr = str(float(totalenergy)*float(multiply))
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=udevice&idx=" + domoticz_ActualPower+ "&nvalue=0&svalue=" + activepower+ ";" + etotalstr)
urlopen(url)
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=udevice&idx=" + domoticz_DCVoltage1+ "&nvalue=0&svalue=" + DCvoltage1)
urlopen(url)
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=udevice&idx=" + domoticz_DCcurrent1+ "&nvalue=0&svalue=" + DCcurrent1)
urlopen(url)
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=udevice&idx=" + domoticz_gridvoltageA+ "&nvalue=0&svalue=" + gridvoltageA)
urlopen(url)
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=udevice&idx=" + domoticz_gridcurrentA+ "&nvalue=0&svalue=" + gridcurrentA)
urlopen(url)
Let me know what you think. This code will not win 12 points in a contest however it can retrieve data :D .
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
devros
Post by devros »
thanks all looks good but im litte lost where to find company number....
tried to fetch some json from my login page but cant, find that number
thanks
sincze
Post by sincze »
So forum member devros and myself have been playing around to see if we could modify the initial shinemonitor script in such a way that it should work for all kinds of inverters that report their data to shinemonitor.
Kudo's to the devros and his wireshark skills. :D
Pay special attention to the following values:
pn= on your wifi stick or can be found on the shinemonitor portal after signing in the regular way
sn= the serial number of your inverter. Can also be found on the official portal
devcode= this tricky number you have to extract using for example chrome f12 (under network) to see an initial string between your browser and shinemonitor. It seems every brand has its own devcode.
Just run with Python3 as cronjob every 5 minutes or so.
Have fun!!.
devros & sincze.
#!/usr/bin/python3
import requests
def salt():
devcode=''			#your devcode, can be obtained from json string
baseURL = 'http://www.shinemonitor.com'
URL_API = 'http://api.shinemonitor.com'
#domoticz settings
domoticz = 0						#set to 1 after IDx have been defined!
domoticz_host = '192.168.*.*'      	#or the official IP adres
#building url
print ('SALT:' + (str(salt)))
print ('SHA1:' + (str(passwd.hexdigest())))
action= '&action=authV2&user='+usr
solarurl= baseURL+'/ws?sign='+ sign + '&salt=' + str(salt) + action # WS
print (solarurl)
print (r.json())
print ('CONECTION OK')
# # We now have a token and secret so start collecting values.
action= '&action=queryDeviceLastData&i18n=en_US&pn=' + pn + '&devcode='+ devcode + '&devaddr=1&sn=' + sn
requrl= URL_API + '/public/?sign='+ sign + '&salt=' + str(salt) + '&token=' + token + '&action=queryDeviceLastData&i18n=en_US&pn=' + pn + '&devcode=' + devcode + '&devaddr=1&sn=' + sn
print (requrl)
multiply= 1000.1
if domoticz == 1:
	print ('domoticz output')
	urlopen(url)
	print (url)
	urlopen(url)
	urlopen(url)
	urlopen(url)
	urlopen(url)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
