#2215 Custom Icons uploader Implemented
gizmocuz
Re: #2215 Custom Icons uploader Implemented
Post by gizmocuz »
That's not the case with the above zip.
The problem is that the icons/definition in the zip where inside a folder.
But the next beta will allow that, and also multiple folders, each folder should contain a definition file
gizmocuz
Post by gizmocuz »
new beta (#2793, 0fcd396)
- Fixed: Icon Uploader, uploading went wrong with large files
- Implemented: Icon Uploader, now possible to upload zip files with multiple folders
- Implemented: Icon Uploader, now possible to edit name and description
Folder structure can be
[zip file]
 icons.txt
or
[zip file]
 - [folder 1]
     icons.txt
 - [folder 2]
     icons.txt
 - [folder xx]
     icons.txt
sylvainsjc
Post by sylvainsjc »
Great it works now :D
It remains a small problem with icon size in the visualization.
Although my reference icons are 16x16 size, they are too big in the visualization.
Here is a screenshot :
Raspberry + Raspian + Domoticz Beta + Rfxcom433e + heater control with Chacon 54755 + sensors TS34C + OWL160 + Z-Wave Everspring/Fibaro
Complete Backup script using "dd" to remote hard disk
gizmocuz
Post by gizmocuz »
I think your On/Off icons are not 48x48 ?
Will be solved in the next beta, but try using the recommended sizes (16 for small, 48x48 for big)
Ricky74
Post by Ricky74 »
Hello Gizmocuz,
I've created a new icon for on off switch.
But I have problem for modify them after their upload.
If I delete it and upload the modified zip, I never see the modifications. I have to rename files to see change...
I try to delete cache (chrome), restart domoticz, but nothing changes !
Do you have an idea?
Is it normal?
krazny
Post by krazny »
Ricky74 wrote:Hello Gizmocuz,
Is it normal?
That indeed happens sometimes and gets fixed over time. Somehow the 'old' icon keeps appearing in Chrome.
If you try IE for example its probable OK?
Raspberry Pi, Aeon Z-Stick, Fibaro Motion Sensor, 4x Fibaro Wall Plug, 2x Fibaro Dimmer, Netatmo Weatherstation
Moppersmurf
Domoticz version: Lat.Beta
Post by Moppersmurf »
Hi Gizmocuz,
Currently only supported for On/Off switches (as it is now), and probably later for other types as well
Any change you will update it to work for other types in the future?
Like it a lot and have some Icons I want to change.
I made Plex icons and will mail them to [email protected]
plex.zip
(5.46 KiB) Downloaded 397 times
Last edited by Moppersmurf on Thursday 17 December 2015 21:47, edited 1 time in total.
jarwis
Domoticz version: 2.3530
Post by jarwis »
I've created custom icons for AIRAM Christmas Window decorative lighting.
[ENG] AIRAM Christmas Window
[FIN] AIRAM Jouluikkuna
[SWE] AIRAM Julfönster
The Airam_jouluikkuna.zip contains the following files:
  • icons.txt
  • Jouluikkuna.png (16x16)
  • Jouluikkuna48_On.png (48x48)
  • Jouluikkuna48_Off.png (48x48)
I've also sent the icons to [email protected].
AIRAM Jouluikkuna icons
(7.45 KiB) Downloaded 364 times
Moppersmurf
I've go an uplighter and made a icon for it. I think it looks ok.
I'll also send it to the known e-email address.
Uplighter.zip
(5.22 KiB) Downloaded 424 times
hansrune
Post by hansrune »
What is the easiest way to replicate all icon collections from one Domoticz instance to another one? I'd like to keep them the same.
Sent from my iPad using Tapatalk
Moppersmurf
http://domoticz.com/forum/viewtopic.php?f=8&t=7749
Check this out how to copy your icons.
Moppersmurf
I've made a blacklight icon for a blacklight tube. Will send it to the known e-mailbox.
Blacklight.zip
(6.26 KiB) Downloaded 268 times
Moppersmurf
I've also made icons for a Ikea Pax light URSHULT.
Will mail them as well.
Paxkast.zip
(5.02 KiB) Downloaded 415 times
nayr
Domoticz version: github
Post by nayr »
I get error saying: Error uploading Iconset: Error writing zip to disk
Where do I have to give write permission to stash the upload?
*edit*
set the following in main/SQLHelper.cpp
std::string outputfile = "/tmp/custom_icons.zip";
and it worked, perhaps have a check to see if wherever its trying to write is writable, and if not try /tmp? IMHO a temporary file should not be arbitrary saved relative to how the program was launched.
I am starting domoticz with systemD, no idea what directory it runs from.. probably root given the errors.
[Unit]
Description=domoticz service
After=network.target
[Service]
Type=simple
User=domoticz
Group=domoticz
ExecStart=/home/domoticz/domoticz/domoticz -log /home/domoticz/domoticz.log
StandardOutput=null
Restart=always
RestartSec=30
[Install]
WantedBy=multi-user.target
nayr
Post by nayr »
Icons for the AndroidTV (Nexus Player/Amazon Fire/Nvidia Shield/etc)
android-tv.zip
android tv icons
(5.13 KiB) Downloaded 357 times
g0llem
Post by g0llem »
Icons for a "rolluik"
In my case On is "open" and Off is "closed". Adjust the name of the icons when you need to reverse the on/off situation.
Rolluik.zip
Rolluik open - closed
(1.85 KiB) Downloaded 556 times
Rolluik.zip
Moppersmurf
Since my son never listens when he needs to go to sleep, I made a icon set for the Wifi router.
Tomorrow i'll let it switch off and see how he likes that :twisted:
Wifi router.zip
(3.36 KiB) Downloaded 530 times
Wifi router48_Off.png (758 Bytes) Viewed 11401 times
Wifi router48_On.png (1.01 KiB) Viewed 11401 times
Derik
Post by Derik »
almost update the icons Drive..
There are some new:)
When i have tie there are some more in my mail..
Fainted
Post by Fainted »
Made a washing machine icon :)
tvatt.zip
(14.09 KiB) Downloaded 394 times
Fainted
Post by Fainted »
New Camera icon :)
camera3.zip
(6.71 KiB) Downloaded 508 times
