#2215 Custom Icons uploader Implemented
- gizmocuz
Re: #2215 Custom Icons uploader Implemented
That's not the case with the above zip.
The problem is that the icons/definition in the zip where inside a folder.
But the next beta will allow that, and also multiple folders, each folder should contain a definition file
- gizmocuz
new beta (#2793, 0fcd396)
- Fixed: Icon Uploader, uploading went wrong with large files
- Implemented: Icon Uploader, now possible to upload zip files with multiple folders
- Implemented: Icon Uploader, now possible to edit name and description
Folder structure can be
or
[zip file]
icons.txt
[zip file]
- [folder 1]
icons.txt
- [folder 2]
icons.txt
- [folder xx]
icons.txt
sylvainsjc
Great it works now
It remains a small problem with icon size in the visualization.
Although my reference icons are 16x16 size, they are too big in the visualization.
Here is a screenshot :
Raspberry + Raspian + Domoticz Beta + Rfxcom433e + heater control with Chacon 54755 + sensors TS34C + OWL160 + Z-Wave Everspring/Fibaro
Complete Backup script using "dd" to remote hard disk
- gizmocuz
I think your On/Off icons are not 48x48 ?
Will be solved in the next beta, but try using the recommended sizes (16 for small, 48x48 for big)
Ricky74
Hello Gizmocuz,
I've created a new icon for on off switch.
But I have problem for modify them after their upload.
If I delete it and upload the modified zip, I never see the modifications. I have to rename files to see change...
I try to delete cache (chrome), restart domoticz, but nothing changes !
Do you have an idea?
Is it normal?
Is it normal?
- krazny
That indeed happens sometimes and gets fixed over time. Somehow the 'old' icon keeps appearing in Chrome.Ricky74 wrote:Hello Gizmocuz,
Is it normal?
If you try IE for example its probable OK?
Raspberry Pi, Aeon Z-Stick, Fibaro Motion Sensor, 4x Fibaro Wall Plug, 2x Fibaro Dimmer, Netatmo Weatherstation
- Moppersmurf
- Domoticz version: Lat.Beta
Hi Gizmocuz,
Currently only supported for On/Off switches (as it is now), and probably later for other types as well
Any change you will update it to work for other types in the future?
Like it a lot and have some Icons I want to change.
I made Plex icons and will mail them to [email protected]
- Plex48_On.png (3.34 KiB) Viewed 9895 times
- plex.zip
- (5.46 KiB) Downloaded 323 times
Last edited by Moppersmurf on Thursday 17 December 2015 21:47, edited 1 time in total.
jarwis
- Domoticz version: 2.3530
I've created custom icons for AIRAM Christmas Window decorative lighting.
[ENG] AIRAM Christmas Window
[FIN] AIRAM Jouluikkuna
[SWE] AIRAM Julfönster
The Airam_jouluikkuna.zip contains the following files:
- icons.txt
- Jouluikkuna.png (16x16)
- Jouluikkuna48_On.png (48x48)
- Jouluikkuna48_Off.png (48x48)
- Airam_jouluikkuna.zip
- AIRAM Jouluikkuna icons
- (7.45 KiB) Downloaded 282 times
- Moppersmurf
I've go an uplighter and made a icon for it. I think it looks ok.
I'll also send it to the known e-email address.
- Uplighter48_Off.png (1.93 KiB) Viewed 9896 times
- Uplighter48_On.png (2.11 KiB) Viewed 9896 times
- Uplighter.zip
- (5.22 KiB) Downloaded 335 times
hansrune
What is the easiest way to replicate all icon collections from one Domoticz instance to another one? I'd like to keep them the same.
Sent from my iPad using Tapatalk
- Moppersmurf
- Moppersmurf
I've made a blacklight icon for a blacklight tube. Will send it to the known e-mailbox.
- Blacklight48_On.png (4.58 KiB) Viewed 9629 times
- Blacklight48_Off.png (756 Bytes) Viewed 9629 times
- Blacklight.zip
- (6.26 KiB) Downloaded 186 times
- Moppersmurf
I've also made icons for a Ikea Pax light URSHULT.
Will mail them as well.
- Paxkast.zip
- (5.02 KiB) Downloaded 330 times
- Paxkast48_On.png (2.11 KiB) Viewed 9614 times
- Paxkast48_Off.png (1.85 KiB) Viewed 9614 times
- nayr
- Domoticz version: github
I get error saying: Error uploading Iconset: Error writing zip to disk
Where do I have to give write permission to stash the upload?
*edit*
set the following in main/SQLHelper.cpp
and it worked, perhaps have a check to see if wherever its trying to write is writable, and if not try /tmp? IMHO a temporary file should not be arbitrary saved relative to how the program was launched.
I am starting domoticz with systemD, no idea what directory it runs from.. probably root given the errors.
*edit*
std::string outputfile = "/tmp/custom_icons.zip";I am starting domoticz with systemD, no idea what directory it runs from.. probably root given the errors.
[Unit]
Description=domoticz service
After=network.target
[Service]
Type=simple
User=domoticz
Group=domoticz
ExecStart=/home/domoticz/domoticz/domoticz -log /home/domoticz/domoticz.log
StandardOutput=null
Restart=always
RestartSec=30
[Install]
WantedBy=multi-user.targetDebian Jessie: CuBox-i4 (Primary) w/Static Routed IP and x509 / BeagleBone with OpenSprinkler / BeagleBone Planted Aquarium / 3x Raspbery Pi2b GPIO Slaves
- nayr
Icons for the AndroidTV (Nexus Player/Amazon Fire/Nvidia Shield/etc)
- android-tv48_On.png (2.54 KiB) Viewed 9495 times
- android-tv.zip
- android tv icons
- (5.13 KiB) Downloaded 271 times
g0llem
Icons for a "rolluik"
In my case On is "open" and Off is "closed". Adjust the name of the icons when you need to reverse the on/off situation.
- Rolluik48_On.png (540 Bytes) Viewed 9452 times
- Rolluik48_Off.png (496 Bytes) Viewed 9452 times
- Moppersmurf
Since my son never listens when he needs to go to sleep, I made a icon set for the Wifi router.
Tomorrow i'll let it switch off and see how he likes that
- Wifi router.zip
- (3.36 KiB) Downloaded 430 times
- Wifi router48_Off.png (758 Bytes) Viewed 8635 times
- Wifi router48_On.png (1.01 KiB) Viewed 8635 times
Derik
- Domoticz version: BETA
almost update the icons Drive..
There are some new:)
When i have tie there are some more in my mail..
Fainted
Made a washing machine icon
- tvattmaskin648_On.png (4.59 KiB) Viewed 8584 times
- tvatt.zip
- (14.09 KiB) Downloaded 321 times
Fainted
New Camera icon
- camera448_On.png (3.47 KiB) Viewed 8551 times
- camera3.zip
- (6.71 KiB) Downloaded 425 times
