Of course this may be a valve fault, I'll be checking it later today.
Smartwares introduces 433 thermostat valve
- blackdog65
Re: Smartwares introduces 433 thermostat valve
Not with mine
and the valve has stopped opening too
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
mschut
- Domoticz version: V3.5613
Thanks, will play with is soon.
But really, idx 954?
- StanHD
Yep, 966 now. But there are gaps. It's actually only @ 100 entries in the devices table
Python:- Broadlink RM2, Sonos
mschut
I have connected the Smartware thermostat to Domoticz. Two items appear in domoticz, one switch (on/off) and one in Utility. With the item in utility I am able to set a certain temperature, also with timers. However, the item appears red for not having any recent actions. The tempertature shown by the item is not the last temperature send to the radiator.
Also in the log noithing appears, it's completely empty although the commands are succesfully send.
Is this normal behaviour of this valve, or should this be able to work?
- Egregius
- Domoticz version: v2024.7
Any updates on this? I'm expecting my valves back from RMA soon.
Do I see it right that I can only send on/off from domoticz? And I cannot set a temperature?
- Egregius
I think I found a bug:
When adding a Smarwares to the dashboard as favorite I can click it to set the temperature. The signal is sent to the valve but isn't updated on the screen or in the database.
If I choose 'edit' on the other switches panel (where you change the name etc) and set a temperature, the signal is sent AND updated on the dashboard.
This is also true when updating the device with the json udevice command.
DutchHans
Are there any updates concerning the Logfile from the Smartwares thermostat?
Or the bug that has been reported?
Nothing since may 14..
Regards, Hans
Regards, Hans
- gizmocuz
Plz try #2692
The switching between day/night is now logged, and the setpoint value, timeout is disabled as there is no feedback/input from the device
@DutchHans, thanks for lending the device!!
- Egregius
Great
Now figuring out a way to display the setpoint and the real temperature in one graph
- gizmocuz
you probably can do this with the custom graph
is there a temperature feedback from this sensor ?
- Egregius
No, it's a seperate thermometer in the room.
- Egregius
Just fixed it in my own temperature graph
SELECT t.Date, t.Temperature as Temperature, s.Temperature as Setpoint
FROM Temperature t
JOIN Temperature s ON t.Date = s.Date
WHERE t.DeviceRowID = $sensor AND s.DeviceRowID = $setpoint- gizmocuz
Nice, where/how did you do this ?
- Egregius
It's in the file temp.php from my floorplan.
See http://www.domoticz.com/forum/viewtopic.php?f=8&t=7551
- gizmocuz
Cant download the zip, receive:Egregius wrote:It's in the file temp.php from my floorplan.
http://goo.gl/Hzh2I9 – this goo.gl shortlink has been disabled. It was found to be violating our Terms of Service. Click here and here for more information about our terms and policies respectively.
- Egregius
Oh, didn't know there are rules for Googles URL shortner. I use it to view it's animo about it.
Anyway, here it is: http://egregius.be/files/floorplan20150809.zip
Also updated the other topic
mistysnip
- Domoticz version: 2024.7
I received my valve but I can't seem to add it to Domoticz. Could you share the step-by-step instructions, please? I have an RFLink, BTW
ubfssF
- Domoticz version: 2.2364
I can ad the thermostat by using the remote, using LEARN, and by using MANUAL from Domoticz. Both work, for switching on and off. Directly after successful connecting I have adjusted both to a thermostat-type instead of an on-off-switch.
However, with both ways no thermostat entry is created within the Utilities tab!
I am using a desktop browser, so that shouldn't be a problem. Domoticz-version is 2.3564 and it's running on Ubuntu.
The only thing I can think off is that I have to added through MANUAL with a different type. But I've used on-of because I see no other reasonable option in that pull-down list. Only afterwards I can change it to a thermostat-type......
Can anyone indicate what kind of adding ons has to do?
Thnx,
Joop
Thnx,
Joop
rammstan
Im new on this forum and domoticZ. I think i ll be more present here, cause i just bought a new house, the rfxcom and enocean usb 300
. I have first questions:
- Did you experience the battery life?
- Is it PID regulation in the smartwares?
RPi 2 + UPS Pico + enOcean + RFXCOM ext 250
