Smartwares introduces 433 thermostat valve
Shaggie_NB
Post by Shaggie_NB »
Smartwares introduces 433 thermostat device for Homewizard.
http://www.homewizard.nl/smartwares-dra ... kraan.html
Where there were only thermostatic valves for zwave. Now we have an 433Mhz equivalent.
I hope it will be supported by my RFXTRX433!
SweetPants
Re: Smartwares introduces 433 thermostat valve
Post by SweetPants »
Ask Bert of RFXcom first, it al starts there. If The RFXcom does not support it, Domoticz won't either.
drogert
Post by drogert »
Also cheap! I hope it will be supported...
RPI 3b+, PiFace 2, RFcom, Aeon Zwave USB, Aeon Home Energy Meter Gen 5, several Shelly switches, several ESP8266 sensors.
Shaggie_NB
SweetPants wrote:Ask Bert of RFXcom first, it al starts there. If The RFXcom does not support it, Domoticz won't either.
I follow a lot of forums and when there is a question related to rfxcom, Bert always reacts in a very short time...
So I think he reads almost everything about domotics. So I don't worry.... If he thinks it's interesting then it will be supported. ;)
gizmocuz
Post by gizmocuz »
Page not found.... (fixed the link)
But always nice to ask directly at RFXCom support department, maybe donate a device ?
Shaggie_NB
gizmocuz wrote:Page not found.... (fixed the link)
And when he decides not to support this device....Then the device is useless (for me). You gonna buy it???
gizmocuz
Post by gizmocuz »
marktplaats/ebay ?
markk
Post by markk »
Ooooh. Everything crossed for this one :)
grant
Post by grant »
Did anyone find out if these work?
BigDog
Domoticz version: V3.9269
Post by BigDog »
Very interesting wanted te buy them if its suported afcourse :)
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
gizmocuz
Post by gizmocuz »
grant wrote:Did anyone find out if these work?
delivery time is 4 weeks, so i guess not ;)
BigDog
Post by BigDog »
Wow i am so exited about this
I hope its compactable :)
nitpicker
Domoticz version: 2022.2
Post by nitpicker »
I hope so too!
markk
Post by markk »
BigDog wrote:Wow i am so exited about this
+1
I nearly wet myself when I first saw the original post :)
Raspberry Piet
Post by Raspberry Piet »
Heisenberg
Post by Heisenberg »
Something to consider before purchasing this product: if you want to use it in the bedroom then be aware that it makes some noise because it constantly changes the temp wheel. So if you're a light sleeper then maybe it's not suitable for the bedroom.
Last edited by Heisenberg on Thursday 01 January 2015 3:12, edited 1 time in total.
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
sylvled
Post by sylvled »
I received it today and ... yes, it is noisy.
Too much for me to put it in a bedroom, I will not say it is suitable for a bedroom.
Fairly tested until now, I could say remote is only to put the device in Day or Night mode (and progrmmation is on the device itself for the temperature of night or day).
Until now, I could receive the lighting 2 frame in Domoticz, but I couldn't set the remote from domoticz because there is not yet the "SmartWares" protocole as far as I know.
In rfxmgr, there is a Smartwares command, but I couldn't find the correct ID and unit code...
I will spend some time in the following days on that and will keep you informed.
Yours. Sylvain.
Raspberry Piet
Thanks for this feedback.
So better not for bedroom.
My question: doesn't all electronic thermostate valves produce some noise?
gizmocuz
Post by gizmocuz »
sylvled wrote:Hello,
Yours. Sylvain.
You have to use the latest beta version, and manually add the smartwares radiator (manual light/switch), choose smartwares as protocol
You then receive two sensors, a switch to turn it to day/night, and a thermostat setpoint (utility tab), that you can use to time/set the setpoint
Is it 24/7 noisy ? or only when you change the temperature? (or when it wants to change the temperature)
sylvled
Post by sylvled »
Yes, it is noisy when it wants to change temperature. The motor itself is noisy.
But not only.
It reacts with a BIP to each command sent by the rfxcom OR the remote.
So if you keep the internal programming running, no problem, you will have only the motor. But if you want full remote (forcing night, forcing day or giving a target), you will have the bip.
I have the rfxtrx433 AND the rfxtrx433E, and both trapped the remote : Lighting 2 AC Off 6
I could toggle night / day with either the 433 or the 433E device with domoticz 2.2139.
in order to have the target temperature, i will try tomorrow the beta.
