Smartwares introduces 433 thermostat valve
blackdog65
Re: Smartwares introduces 433 thermostat valve
Post by blackdog65 »
Not with mine :cry: and the valve has stopped opening too :shock:
Of course this may be a valve fault, I'll be checking it later today.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
mschut
Domoticz version: V3.5613
Post by mschut »
Thanks, will play with is soon.
But really, idx 954?
StanHD
Post by StanHD »
Yep, 966 now. But there are gaps. It's actually only @ 100 entries in the devices table :)
Python:- Broadlink RM2, Sonos
mschut
Post by mschut »
I have connected the Smartware thermostat to Domoticz. Two items appear in domoticz, one switch (on/off) and one in Utility. With the item in utility I am able to set a certain temperature, also with timers. However, the item appears red for not having any recent actions. The tempertature shown by the item is not the last temperature send to the radiator.
Screenshot 2015-03-21 at 10.01.50.png (18.99 KiB) Viewed 5845 times
Also in the log noithing appears, it's completely empty although the commands are succesfully send.
Screenshot 2015-03-21 at 10.02.06.png (132.23 KiB) Viewed 5845 times
Is this normal behaviour of this valve, or should this be able to work?
Egregius
Domoticz version: v2024.7
Post by Egregius »
Any updates on this? I'm expecting my valves back from RMA soon.
Do I see it right that I can only send on/off from domoticz? And I cannot set a temperature?
Egregius
Post by Egregius »
I think I found a bug:
When adding a Smarwares to the dashboard as favorite I can click it to set the temperature. The signal is sent to the valve but isn't updated on the screen or in the database.
If I choose 'edit' on the other switches panel (where you change the name etc) and set a temperature, the signal is sent AND updated on the dashboard.
This is also true when updating the device with the json udevice command.
DutchHans
Post by DutchHans »
Are there any updates concerning the Logfile from the Smartwares thermostat?
Or the bug that has been reported?
Nothing since may 14..
Regards, Hans
gizmocuz
Post by gizmocuz »
Plz try #2692
The switching between day/night is now logged, and the setpoint value, timeout is disabled as there is no feedback/input from the device
@DutchHans, thanks for lending the device!! :mrgreen:
Egregius
Post by Egregius »
Great :)
Now figuring out a way to display the setpoint and the real temperature in one graph :mrgreen:
gizmocuz
Post by gizmocuz »
you probably can do this with the custom graph
is there a temperature feedback from this sensor ?
Egregius
Post by Egregius »
No, it's a seperate thermometer in the room.
gizmocuz
Post by gizmocuz »
Ahh ok
Egregius
Post by Egregius »
Just fixed it in my own temperature graph :)
SELECT t.Date, t.Temperature as Temperature, s.Temperature as Setpoint
FROM Temperature t
JOIN Temperature s ON t.Date = s.Date
WHERE t.DeviceRowID = $sensor AND s.DeviceRowID = $setpoint
gizmocuz
Post by gizmocuz »
Nice, where/how did you do this ?
Egregius
Post by Egregius »
It's in the file temp.php from my floorplan.
See http://www.domoticz.com/forum/viewtopic.php?f=8&t=7551
gizmocuz
Post by gizmocuz »
Egregius wrote:It's in the file temp.php from my floorplan.
Cant download the zip, receive:
http://goo.gl/Hzh2I9 – this goo.gl shortlink has been disabled. It was found to be violating our Terms of Service. Click here and here for more information about our terms and policies respectively.
Egregius
Post by Egregius »
Oh, didn't know there are rules for Googles URL shortner. I use it to view it's animo about it.
Anyway, here it is: http://egregius.be/files/floorplan20150809.zip
Also updated the other topic ;)
mistysnip
Domoticz version: 2024.7
Post by mistysnip »
I received my valve but I can't seem to add it to Domoticz. Could you share the step-by-step instructions, please? I have an RFLink, BTW
ubfssF
Domoticz version: 2.2364
Post by ubfssF »
I can ad the thermostat by using the remote, using LEARN, and by using MANUAL from Domoticz. Both work, for switching on and off. Directly after successful connecting I have adjusted both to a thermostat-type instead of an on-off-switch.
However, with both ways no thermostat entry is created within the Utilities tab!
I am using a desktop browser, so that shouldn't be a problem. Domoticz-version is 2.3564 and it's running on Ubuntu.
The only thing I can think off is that I have to added through MANUAL with a different type. But I've used on-of because I see no other reasonable option in that pull-down list. Only afterwards I can change it to a thermostat-type......
Can anyone indicate what kind of adding ons has to do?
Thnx,
Joop
rammstan
Post by rammstan »
Im new on this forum and domoticZ. I think i ll be more present here, cause i just bought a new house, the rfxcom and enocean usb 300 :D . I have first questions:
- Did you experience the battery life?
- Is it PID regulation in the smartwares?
RPi 2 + UPS Pico + enOcean + RFXCOM ext 250
