Page 3 of 8
Re: ShellyCloudPlugin
Posted: Thursday 01 October 2020 22:22
by Xavier82
hi,
reading this thread with much interest.
I have 12 blinds (rolluiken) controlled by shelly2.5 in roller mode.
Would be great if this app would support shelly2.5 in rollermode. Is there any chance to devellop this?
greetz,
Xavier
Posted: Friday 02 October 2020 0:02
by Xavier82
I installed the plugin and tried to add 1 shelly dimmer.
In the logging I have these errors:
2020-10-01 23:57:37.469 Error: (ShellyCloudPlugin) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/ShellyCloud/:/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2020-10-01 23:57:37.469 Error: (Keukenlamp) Module Import failed, exception: 'ModuleNotFoundError'
2020-10-01 23:57:37.469 Error: (Keukenlamp) Module Import failed: ' Name: requests'
2020-10-01 23:57:37.469 Error: (Keukenlamp) Error Line details not available.
I'm running Domoticz on a RPi with Python3.7 installed.
Could you please help?
UPDATE:
Found the answer:
on Rpi go to CLI
Then do:
pip install requests
and then do
pip3 install requests
Posted: Friday 02 October 2020 0:30
by Xavier82
mariopeters wrote: Tuesday 29 September 2020 18:13 I understand your point, but I am still thinking about the practical details.
How do you envision that Domoticz finds the different Shelly devices when adding 1 hardware?
With a Domoticz plugin you can only use text fields (or a dropdown list) for configuration.
One solution would be a text field with a list of ip addresses (";" separated).
However, the Shelly devices must all have the same username and password.
Do you see this as a workable solution?
Can't the Shelly Cloud API key be a solution:
https://shelly.cloud/documents/develope ... access.pdf
Shelly can also be discoverd with mDNS Discovery:
https://shelly-api-docs.shelly.cloud/#mdns-discovery
Maybe it is possible with these functions to create 1 hardware device and X devices.
Unfortunatly I'm not a programmer but maybe this information can help?
Posted: Saturday 03 October 2020 14:57
by Xavier82
So I tried to add the Shelly1PM.
I came as this far:
# ShellyCloudPlugin
# Author: Mario Peters
<plugin key="ShellyCloudPlugin" name="Shelly Cloud Plugin" author="Mario Peters" version="1.0.0" wikilink="https://github.com/mario-peters/ShellyCloudPlugin/wiki" externallink="https://github.com/mario-peters/ShellyCloudPlugin">
    <description>
        <h2>Shelly Cloud Plugin</h2><br/>
        Plugin for controlling Shelly devices.
        <h3>Configuration</h3>
        <ul style="list-style-type:square">
            <li>IP Address is the IP Address of the Shelly device. Default value is 127.0.0.1</li>
            <li>Username</li>
            <li>Password</li>
            <li>Type is the type of Shelly device you want to add. Shelly 1, Shelly PM, Shelly 2.5 (only relay), Shelly Dimmer, Shelly RGBW2 (only color), Shelly Bulb, Shelly Door/Window 2 and Shelly Plug-S are currently supported</li>
        </ul>
        <br/><br/>
    </description>
    <params>
        <param field="Address" label="IP Address" width="200px" required="true" default="127.0.0.1"/>
        <param field="Username" label="Username" width="200px" required="true"/>
        <param field="Password" label="Password" width="200px" required="true" password="true"/>
        <param field="Mode1" label="Type" width="200px" required="true">
            <options>
               <option label="Shelly 1" value="SHSW-1"/>
			   <option label="Shelly PM" value="SHSW-PM"/>
               <option label="Shelly 2.5" value="SHSW-25"/>
               <option label="Shelly Dimmer" value="SHDM-1"/>
               <option label="Shelly RGBW2" value="SHRGBW2"/>
               <option label="Shelly Bulb" value="SHBLB-1"/>
               <option label="Shelly Door/Window 2" value="SHDW-2"/>
               <option label="Shelly Plug" value="SHPLG-S"/>
            </options>
        </param>
    </params>
</plugin>
import Domoticz
import requests
import json
class BasePlugin:
    #mode = None
    mode = "color"
    def __init__(self):
        return
    def onStart(self):
        Domoticz.Log("onStart called")
        Domoticz.Heartbeat(30)
        if len(Devices) == 0:
            if Parameters["Mode1"] == "SHDW-2":
                createSHDW2()
            else:
                headers = {'content-type':'application/json'}
                try:
                    response_shelly = requests.get("http://"+Parameters["Address"]+"/settings",headers=headers, auth=(Parameters["Username"], Parameters["Password"]), timeout=(10,10))
                    json_items = json.loads(response_shelly.text)
                    response_shelly.close()
                    if Parameters["Mode1"] == "SHSW-1":
                        createSHSW1(json_items)
                    elif Parameters["Mode1"] == "SHSW-25":
                        createSHSW25(json_items)
                    elif Parameters["Mode1"] == "SHSW-PM":
                        createSHSWPM(json_items)
                    elif Parameters["Mode1"] == "SHDM-1":
                        createSHDM1(json_items)
                    elif Parameters["Mode1"] == "SHRGBW2" or Parameters["Mode1"] == "SHBLB-1":
                        createSHRGBW2(self,json_items)
                    elif Parameters["Mode1"] == "SHPLG-S":
                        createSHPLG(json_items)
                    else:
                        Domoticz.Log("Type: "+Parameters["Mode1"])
                except requests.exceptions.Timeout as e:
                    Domoticz.Error(str(e))
    def onStop(self):
        Domoticz.Log("onStop called")
    def onConnect(self, Connection, Status, Description):
        Domoticz.Log("onConnect called")
    def onMessage(self, Connection, Data):
        Domoticz.Log("onMessage called")
    def onCommand(self, Unit, Command, Level, Hue):
        Domoticz.Log("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
        if Parameters["Mode1"] != "SHDW-2":
            url = "http://"+Parameters["Address"]
            if Parameters["Mode1"] == "SHSW-1" or Parameters["Mode1"] == "SHPLG-S":
                url = url + "/relay/" + str(Unit-1)
                url = url + "/relay/" + str(Unit-2)
                url = url + "/light/" + str(Unit-1)
                if self.mode == "color":
                    url = url +"/color/" + str(Unit-1)
                if self.mode == "white":
                    url = url +"/white/" + str(Unit-1)
            if str(Command) == "On":
                url = url + "?turn=on"
            elif str(Command) == "Off":
                url = url + "?turn=off"
            elif str(Command) == "Set Level":
                if self.mode == "color" and Parameters["Mode1"] != "SHDM-1":
                    url = url + "?turn=on&gain=" + str(Level)
                elif self.mode == "white" or Parameters["Mode1"] == "SHDM-1":
                    url = url + "?turn=on&brightness=" + str(Level)
            elif str(Command) == "Set Color":
                Domoticz.Debug(str(Devices[Unit].Color))
                Domoticz.Debug(str(Hue))
                color_info=json.loads(Hue)
                r=color_info["r"]
                g=color_info["g"]
                b=color_info["b"]
                m=color_info["m"]
                cw=color_info["cw"]
                ww=color_info["ww"]
                Domoticz.Debug(str(color_info))
                    url = url +"&red="+str(r)+"&green="+str(g)+"&blue="+str(b)+"&white="+str(cw)+"&gain="+str(Level)
                    url = url +"&white="+str(cw)+"&brightness="+str(Level)
            else:
                Domoticz.Log("Unknown command: "+str(Command))
            Domoticz.Log("url: "+url)
            try:
                response = requests.get(url,headers=headers, auth=(Parameters["Username"], Parameters["Password"]), timeout=(10,10))
                Domoticz.Debug(response.text)
                response.close()
            Devices[Unit].Update(nValue=1,sValue="On")
            Devices[Unit].Update(nValue=0,sValue="Off")
            Devices[Unit].Update(nValue=1,sValue=str(Level))
                #Devices[Unit].Update(nValue=1,sValue=str(Level), Color=str(Hue))
                Devices[Unit].Update(nValue=1,sValue=str(Level), Color=json.dumps(Hue))
            else:
        else:
    def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
        Domoticz.Log("Notification: " + Name + "," + Subject + "," + Text + "," + Status + "," + str(Priority) + "," + Sound + "," + ImageFile)
    def onDisconnect(self, Connection):
        Domoticz.Log("onDisconnect called")
    def onHeartbeat(self):
        Domoticz.Log("onHeartbeat called")
            try:
                request_shelly_status = requests.get("http://"+Parameters["Address"]+"/status",headers=headers, auth=(Parameters["Username"], Parameters["Password"]), timeout=(10,10))
                Domoticz.Debug(request_shelly_status.text)
                json_request = json.loads(request_shelly_status.text)
                    updateSHSW1(json_request)
                    updateSHSWPM(json_request)
                    updateSHSW25(json_request)
                    updateSHDM1(json_request)
                    updateSHRGBW2(self, json_request)
                request_shelly_status.close()
global _plugin
_plugin = BasePlugin()
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
def onConnect(Connection, Status, Description):
    global _plugin
    _plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
    global _plugin
    _plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
    global _plugin
    _plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
    global _plugin
    _plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
    global _plugin
    _plugin.onDisconnect(Connection)
def onHeartbeat():
    global _plugin
    _plugin.onHeartbeat()
    # Generic helper functions
def DumpConfigToLog():
    for x in Parameters:
        if Parameters[x] != "":
            Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
    Domoticz.Debug("Device count: " + str(len(Devices)))
    for x in Devices:
        Domoticz.Debug("Device:           " + str(x) + " - " + str(Devices[x]))
        Domoticz.Debug("Device ID:       '" + str(Devices[x].ID) + "'")
        Domoticz.Debug("Device Name:     '" + Devices[x].Name + "'")
        Domoticz.Debug("Device nValue:    " + str(Devices[x].nValue))
        Domoticz.Debug("Device sValue:   '" + Devices[x].sValue + "'")
        Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
    return
def createSHSW1(json_items):
    relays = None
    for key, value in json_items.items():
        if key == "relays":
            relays = value
    count = 0
    for relay in relays:
        name = createRelay(relay, count)
        for key, value in relay.items():
            if key == "power":
                createPower(name, value, count)
        count = count + 1
def createSHSWPM(json_items):
    relays = None
    mode = None
    meters = None
        if key == "relays":
            relays = value
        if key == "mode":
            mode = value
        if key == "meters":
            meters = value
        if mode == "relay":
            count = 1
        meters = {"power":0,"total":0}
        createMeter(name, meters, count)
        count = count + 1
def createSHSW25(json_items):
    relays = None
    rollers = None
    mode = None
    num_meters = None
        if key == "relays":
            relays = value
        if key == "rollers":
            rollers = value
        if key == "mode":
            mode = value
        #if key == "meters":
            #meters = value
        if key == "num_meters":
            num_meters = value
    Domoticz.Device("Temperature", Unit=1, Used=1, TypeName="Temperature").Create()
    if mode == "relay":
       count = 1
           #meter = meters[1-count]
           meter = {"power":0,"total":0}
           createMeter(name, meter, count)
           count = count + 1
def createSHPLG(json_items):
    relays = None
        if key == "relays":
            relays = value
    count = 0;
        count = count + 1
def createSHDM1(json_items):
    lights = []
    meters = None
    brightness = None
        if key == "lights":
            lights = value
        if key == "meters":
            meters = value
        if key == "brightness":
            brightness = value
    count = 0
    for light in lights:
        name = createLight(light, count)
        count = count + 1
def createSHRGBW2(self,json_items):
    lights = []
        if key == "lights":
            lights = value
        if key == "mode":
            self.mode = value
    ison = False
        if key == "ison":
            ison = value
    self.mode="color"
        Domoticz.Device(Name="RGBW", Unit=1, Used=1, Type=241, Subtype=1).Create()
        Domoticz.Device(Name="RGBW_power", Unit=11, Used=1, Type=248, Subtype=1).Create()
        Devices[11].Update(nValue=0, sValue="0")
        createTotal("RGBW", 0, 0, 0)
    elif self.mode == "white":
        Domoticz.Device(Name="White", Unit=1, Used=1, Type=241, Subtype=3).Create()
        Domoticz.Device(Name="White_power", Unit=11, Used=1, Type=248, Subtype=1).Create()
        createTotal("White", 0, 0, 0)
    else:
        Domoticz.Log("Unknown mode: "+str(self.mode))
    if ison == True:
        Devices[1].Update(nValue=1, sValue="On")
def createSHDW2():
    Domoticz.Device(Name="SHDW2", Unit=1, Used=1, Type=244, Subtype=73, Switchtype=11).Create()
def createLight(light, count):
    name = ""
    ison = False
    for key, value in light.items():
        if key == "name":
            name = value
        if key == "ison":
            ison = value
    if name == "" or name is None:
        name = "Light"+str(count)
    Domoticz.Device(Name=name, Unit=1+count, Used=1, Type=244, Subtype=73, Switchtype=7).Create()
    if ison == True:
        Devices[1+count].Update(nValue=1, sValue="On")
    return name
def createRelay(relay, count):
    name = ""
    ison = False
        if key == "name":
            name = value
        if key == "ison":
            ison = value
        name = "Relay"+str(count)
    Domoticz.Device(Name=name, Unit=1+count, Used=1, Type=244, Subtype=73).Create()
    if ison == True:
    return name
def createMeter(name, meter, count):
    power = 0.0
    for key, value in meter.items():
        if key == "power":
            power = value
            createPower(name, power, count)
        if key == "total":
            createTotal(name, power, value, count)
def createPower(name, power, count):
    Domoticz.Device(Name=name+"_power", Unit=11+count, Used=1, Type=248, Subtype=1).Create()
    Devices[11+count].Update(nValue=0, sValue=str(power))
def createTotal(name, power, value, count):
    Domoticz.Device(Name=name+"_kWh", Unit=21+count, Used=1, Type=243, Subtype=29).Create()
    total = int(value)
    total = total/60
    total = int(total)
    Devices[21+count].Update(nValue=0,sValue=str(power)+";"+str(total))
def updateSHSW1(json_request):
    relays = None
    meters = None
    for key, value in json_request.items():
        if key == "relays":
            relays = value
        if key == "meters":
            meters = value
    count = 0
        updateRelay(relay, count)
        updateMeter(meters[count], count)
        count = count + 1
def updateSHSWPM(json_request):
    relays = None
    meters = None
        if key == "relays":
            relays = value
        if key == "meters":
            meters = value
        count = 0
        count = count + 1
def updateSHSW25(json_request):
    relays = None
    meters = None
        if key == "relays":
            relays = value
        if key == "meters":
            meters = value
        if key == "temperature":
            Devices[1].Update(nValue=Devices[1].nValue, sValue=str(value))
    count = 1
        updateMeter(meters[count-1], count)
        count = count + 1
def updateSHDM1(json_request):
    lights = []
    meters = None
        if key == "lights":
            lights = value
        if key == "meters":
            meters = value
    count = 0
    #Devices[1].Update(nValue=1, sValue="50")
        updateLight(light, count)
        count = count + 1
def updateSHRGBW2(self, json_request):
    lights = []
    meters = []
        if key == "lights":
            lights = value
        if key == "meters":
            meters = value
    count = 0
        count = count + 1
def updateRGBLight(self,light,count):
    m = 0
    r = 0
    g = 0
    b = 0
    ww = 0
    cw = 0
        if key == "mode":
            if value == "color":
                m = 3
            if value == "white":
                m = 1
        if key == "red":
            r = value
        if key == "green":
            g = value
        if key == "blue":
           b = value
        if key == "white":
           ww = value
           ww = value * 255 / 100
        if key == "cw":
           cw = value
    color = json.dumps({
      'm': m, #mode 3: RGB
      'r': r,
      'g': g,
      'b': b,
      'ww': ww,
      'cw': cw
    Devices[count].Update(nValue=1,sValue="1", Color=str(color))
def updateLight(light, count):
        if key == "ison":
            if value:
                if Devices[1+count].nValue != 1:
                    Devices[1+count].Update(nValue=1, sValue=Devices[1+count].sValue)
            else:
                Devices[1+count].Update(nValue=0, sValue=Devices[1+count].sValue)
            Devices[1+count].Update(nValue=Devices[1+count].nValue, sValue=str(value))
def updateRelay(relay, count):
        if key == "ison":
            if value:
            else:
                Devices[1+count].Update(nValue=0, sValue="Off")
def updateMeter(meters, count):
    power = ""
    for key, value in meters.items():
        if key == "power":
            power = str(value)
            Devices[11+count].Update(nValue=0,sValue=power)
        if key == "total":
            total=int(value)
            total=total/60
            total=int(total)
            Devices[21+count].Update(nValue=0,sValue=power+";"+str(total))
But in the logging I receive which I can't fix:
Error: (Licht Voordeur) 'onHeartbeat' failed 'KeyError'.
Error: (Licht Voordeur) ----> Line 216 in '/home/pi/domoticz/plugins/ShellyCloud/plugin.py', function onHeartbeat
Error: (Licht Voordeur) ----> Line 181 in '/home/pi/domoticz/plugins/ShellyCloud/plugin.py', function onHeartbeat
Error: (Licht Voordeur) ----> Line 428 in '/home/pi/domoticz/plugins/ShellyCloud/plugin.py', function updateSHSWPM
Error: (Licht Voordeur) ----> Line 538 in '/home/pi/domoticz/plugins/ShellyCloud/plugin.py', function updateMeter
Any help would be appriciated.
I own Shelly 1PM's, Shelly2.5 (in rollermode) ShellyDimmer.
If settings or status could be of any help I would be pleased to share them.
Posted: Sunday 04 October 2020 17:02
by DarkG
I have the same Errorlog with Shelly 1. With 2.5 no errors
2020-10-04 17:01:23.670 Error: (küche) ----> Line 209 in '/home/pi/domoticz/plugins/ShellyCloudPlugin-master/plugin.py', function onHeartbeat
2020-10-04 17:01:23.670 Error: (küche) ----> Line 174 in '/home/pi/domoticz/plugins/ShellyCloudPlugin-master/plugin.py', function onHeartbeat
2020-10-04 17:01:23.670 Error: (küche) ----> Line 388 in '/home/pi/domoticz/plugins/ShellyCloudPlugin-master/plugin.py', function updateSHSW1
2020-10-04 17:01:23.671 Error: (küche) ----> Line 497 in '/home/pi/domoticz/plugins/ShellyCloudPlugin-master/plugin.py', function updateMeter
Posted: Sunday 04 October 2020 17:22
by mariopeters
@DarkG, @Xavier82,
Can you both send the result (from the browser) of "http: //<ip shelly device>/status" to me in a private message.
Then I will investigate the problem.
Posted: Monday 05 October 2020 9:51
by Xavier82
@mariopeters:
Done
Posted: Monday 05 October 2020 10:43
by Xavier82
@mariopeters:
Btw I think when you resolve the issues of Shelly 1 the errors are also fixed for 1PM about this because I copied some code from Shelly1 to create shelly 1PM.....
Posted: Monday 05 October 2020 20:15
by Xavier82
Thanks @mariopeters !
Shelly1PM works now :)
ShellyDimmer (version 1) works also great
Posted: Monday 05 October 2020 20:19
by mariopeters
Thanks Xavier82.
@DarkG, Xavier82 also confirmed that with the new code the error is gone.
Perhaps you should delete your device, update the code and try again?
By the way I haven't found any error.
If you still have this error, then perhaps you could answer my private message.
Posted: Monday 05 October 2020 23:48
by DarkG
The Shelly 1 has no power Output like 2.5 or 1 PM
Posted: Tuesday 06 October 2020 8:31
by Xavier82
I also found this:
https://github.com/StyraHem/pyShelly
and
https://pypi.org/project/pyShelly/#modal-close
perhaps this can be of any help?
Posted: Wednesday 07 October 2020 14:39
by darrepac
Hi I have an issue today...
My energy graph is showing 0Wh while my sensor is correctly accumulated the energy, strange
2020-10-07 14_35_23-Window.png (6.19 KiB) Viewed 3070 times
2020-10-07 14_35_13-Window.png (81.92 KiB) Viewed 3070 times
Posted: Friday 09 October 2020 16:23
by darrepac
Other issue that I have.
The sensor indicate
1.890kWh
2020-10-09 16_22_12-Window.png (6.29 KiB) Viewed 3057 times
But in LUA I get 7688kWh, strange!
LUA: 274.05;7688
Posted: Monday 12 October 2020 16:20
by Xavier82
Could you please add temperature (internal) for the Shelly1PM.
Shelly1 doesn't have internal temperature.
Posted: Tuesday 13 October 2020 17:22
by Xavier82
Xavier82 wrote: Monday 12 October 2020 16:20 Could you please add temperature (internal) for the Shelly1PM.
I have now added the temp device for Shelly1PM. I added
Domoticz.Device("Temperature", Unit=31, Used=1, TypeName="Temperature").Create()
in
    relays = None
        if key == "relays":
            relays = value
    count = 0
        meter={"power":0,"total":0}
        count = count + 1
Device is being created in Domoticz but is not being updated.
I have now:
    relays = None
    meters = None
        if key == "relays":
            relays = value
        if key == "meters":
            meters = value
    count = 0
        count = count + 1
Should there be a "def createTemperature" and a "def updateTemperature" created?
Posted: Thursday 15 October 2020 21:00
by CronoS
Xavier82 wrote: Friday 02 October 2020 0:02 I installed the plugin and tried to add 1 shelly dimmer.
UPDATE:
Found the answer:
on Rpi go to CLI
Then do:
and then do
I have got the same issue. Also have Python 3.x installed, but these commands does not seems to work. Anyone got an idea?
2020-10-15 20:41:12.785 Error: (ShellyCloudPlugin) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/ShellyCloudPlugin-master/:/usr/local/domoticz/lib/python37.zip:/usr/local/domoticz/lib/python3.7:/usr/local/domoticz/lib/python3.7/lib-dynload:/usr/local/domoticz/lib/python3.7/site-packages'.
2020-10-15 20:41:12.785 Error: (Shelly Cloud Plugin) Module Import failed, exception: 'ModuleNotFoundError'
2020-10-15 20:41:12.785 Error: (Shelly Cloud Plugin) Module Import failed: ' Name: requests'
Posted: Friday 16 October 2020 8:03
by Xavier82
CronoS wrote: Thursday 15 October 2020 21:00
UPDATE:
Found the answer:
on Rpi go to CLI
Then do:
and then do
did you tried the commands with sudo?
Posted: Friday 16 October 2020 13:10
by DarkG
Yes it must execute with sudo. Did have the same problem.
Posted: Friday 16 October 2020 14:38
by CronoS
DarkG wrote: Friday 16 October 2020 13:10 Yes it must execute with sudo. Did have the same problem.
I am one step further. I was able to executy the pip3 command with ./pip3 in front
The installation seems to work; but it uses Python 3.5 I think
The plugin then still failed. It seems it needs that this stuff needs to be installed on Python 3.7. I was able to install PIP for Python 3.7, but now it still doesn't work because it seems to search in the Domoticz folder. Any idea how I can modify it, or install PIP here?
Shelly Cloud Plugin) Started.
2020-10-16 14:35:56.219 Error: (ShellyCloudPlugin) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/ShellyCloudPlugin-master/:/usr/local/domoticz/lib/python37.zip:/usr/local/domoticz/lib/python3.7:/usr/local/domoticz/lib/python3.7/lib-dynload:/usr/local/domoticz/lib/python3.7/site-packages'.
2020-10-16 14:35:56.219 Error: (Shelly Cloud Plugin) Module Import failed, exception: 'ModuleNotFoundError'
2020-10-16 14:35:56.219 Error: (Shelly Cloud Plugin) Module Import failed: ' Name: requests'
2020-10-16 14:35:56.219 Error: (Shelly Cloud Plugin) Error Line details not available.
