- Spoiler: show
{ "ActTime" : 1585559024, "AstrTwilightEnd" : "22:12", "AstrTwilightStart" : "05:20", "CivTwilightEnd" : "20:47", "CivTwilightStart" : "06:46", "DayLength" : "12:53", "NautTwilightEnd" : "21:28", "NautTwilightStart" : "06:04", "ServerTime" : "2020-03-30 11:03:44", "SunAtSouth" : "13:46", "Sunrise" : "07:20", "Sunset" : "20:13", "app_version" : "2020.1", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "Counter" : "14260.272", "CounterDeliv" : "3768.435", "CounterDelivToday" : "0.241 kWh", "CounterToday" : "3.470 kWh", "CustomImage" : 0, "Data" : "7129707;7130565;1139873;2628562;0;297", "Description" : "", "Favorite" : 1, "HardwareID" : 3, "HardwareName" : "Slimme Meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "0001", "LastUpdate" : "2020-03-30 11:03:42", "Name" : "Energie", "Notifications" : "false", "PlanID" : "2", "PlanIDs" : [ 2 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Energy", "SwitchTypeVal" : 0, "Timers" : "false", "Type" : "P1 Smart Meter", "TypeImg" : "counter", "Unit" : 1, "Usage" : "0 Watt", "UsageDeliv" : "297 Watt", "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "2" } ], "status" : "OK", "title" : "Devices" }
Dashticz Graphs - Features, Fixes & Updates
Boattailman
- Domoticz version: 2020.2
Re: Dashticz Graphs - New Features, Fixes & Updates
- Spoiler: show
- clinkadink
Sorry, that's the Domoticz device data. I meant the debug JSON from the graph. See here.
https://www.domoticz.com/forum/viewtopi ... 60#p237106
Boattailman
Sorry, next try:
- Spoiler: show
- clinkadink
Thanks. I notice you have:
graph: ["bar", "bar"]Code: Select all
"24 uur": {
"range": "day",
"filter": "24 hours",
"data": {
"Verbruik": "d.v_2+d.v2_2",
"Opbrengst": "-d.r1_2-d.r2_2"
"graph": ["bar", "bar"] <---- should not be here
},"UI is the saddle, the stirrups, & the reins. UX is the feeling you get being able to ride the horse."
Boattailman
Done, the double bar was a result of some testing, but after the removal its still not working
houtumj
How can I change the popup graph from line to bar 3.4.1
I tried:
blocks['graph_2447'] = {
devices: [2447],
title: 'Zonnestroom',
graph: ["bar"],
datasetColors: ['yellow'],
legend: {
'v': 'Zonnestroom',
Please help.
What am I doing wrong?
I tried:
devices: [2447],
graph: ["bar"],
legend: {
'v': 'Zonnestroom',
Please help.
- clinkadink
Please see corrected block config below.houtumj wrote: Monday 30 March 2020 13:44 How can I change the popup graph from line to bar 3.4.1
I tried:
devices: [2447],
graph: ["bar"],
legend: {
'v': 'Zonnestroom',
Please help.
blocks["zonnestroom_graph"] = {
devices: [2447],
title: "Zonnestroom",
graph: "bar",
datasetColors: "yellow",
legend: {
"v_2447": "Zonnestroom"
};"UI is the saddle, the stirrups, & the reins. UX is the feeling you get being able to ride the horse."
houtumj
Dear clinkadink,
I did a copy and paste, But no bar only a line graph.
So I think it has to be something else
Thanks anyway.
Thanks anyway.
- clinkadink
Hmmm, odd. Try adding this to your graph's block config ...houtumj wrote: Monday 30 March 2020 14:23 Dear clinkadink,
Thanks anyway.
graphTypes: ['v'],"UI is the saddle, the stirrups, & the reins. UX is the feeling you get being able to ride the horse."
- clinkadink
OK, found the issue and will be submitting a fix shortly.Boattailman wrote: Monday 30 March 2020 13:07 Done, the double bar was a result of some testing, but after the removal its still not working
Boattailman
Thx for the effort so far!clinkadink wrote: Monday 30 March 2020 14:31OK, found the issue and will be submitting a fix shortly.Boattailman wrote: Monday 30 March 2020 13:07 Done, the double bar was a result of some testing, but after the removal its still not working
- clinkadink
The stacked issue has now been resolved in the latest beta update, 3.4.1. Please apply and let me know if this has worked. ThanksBoattailman wrote: Monday 30 March 2020 15:30Thx for the effort so far!clinkadink wrote: Monday 30 March 2020 14:31OK, found the issue and will be submitting a fix shortly.Boattailman wrote: Monday 30 March 2020 13:07 Done, the double bar was a result of some testing, but after the removal its still not working
Boattailman
- clinkadink
Cheers!
- clinkadink
Great news, glad you like it
I have just now updated the latest beta's tooltip for any graph that is "stacked". It will now automatically display a "Total" figure in the tooltip, i.e. the sum of all stacked values.
- clinkadink
The latest beta (today) includes some updates to graphs.
We can now update the block with the customHeader object as shown below:
The object accepts key value pairs. Standard Javascript or Jquery code can be used, where 'data' is the data you want to change.
- Graph header current values are now updated as soon as new data is received
- The graph block now accepts the 'flash' property, which will make the graph header data flash when new data is received (like with blocks)
- There is a new graph block property (object) that allows users to customise their graph header values, called customHeader.
blocks['bathroom_wetroom'] = {
title: 'Bathroom vs Wetroom',
devices: [12, 13],
customHeader: {
12: 'data.split(",").slice(0,2)', <---- update/format the data for idx 12
13: 'data.split(",").slice(0,2)', <---- update/format the data for idx 13
x: '(data.12-data.13).toFixed(2) + " C"', <---- append custom data based on idx 12 and idx 13
toolTipStyle: true,
graph: "line",
legend: true
}- To format/update the data being displayed by a device, use the idx (number) as the key.
- To add a new 'custom value' that is a calculation of existing device data, use any letter as the key.
- Minglarn
- Domoticz version: v3.8153
Great work with graphs...
Can put away my PHP generated scripts now....
However, there is one thing that bother me...
When choosing "month" view, it says "Njuk" instead of Mars .. What am I missing?
Using SE in config..
config['language'] = 'sv_SE'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SE- Attachments
- iframe6.JPG (44.51 KiB) Viewed 2726 times
- clinkadink
Thanks, its still work in progress, so I am very grateful for any feedback to help make it better
I have just looked at the graph code, please can you try adding this to your config.js?
I am not sure why it is using the 'calendar language', and not the 'language'. I can correct that, but for now, if you can test the above line, that would be great.
config["calendarlanguage"] = 'sv_SE';"UI is the saddle, the stirrups, & the reins. UX is the feeling you get being able to ride the horse."
- Minglarn
Unfortunately its the same..
No change, did try Chrome in incognito mode and it's same...
