Ring 2 Doorbell
PeterFleur
Domoticz version: 2.4739
Re: Ring 2 Doorbell
Post by PeterFleur »
You mean this one don't you? https://github.com/tchellomello/python-ring-doorbell
Peter
RaspberryPI
ZWave
RFXtrx433E
Egregius
Domoticz version: v2024.7
Re: Ring 2 Doorbell
Post by Egregius »
Yes:
# Installing latest development
$ pip install \
git+https://github.com/tchellomello/python- ... ell@master
DdeR
Re: Ring 2 Doorbell
Post by DdeR »
The script works like a chime! thnx!
the script now also triggers on motion but I really just want it to trigger when the doorbell is pressed.
can someone help me get that done?
Egregius
Re: Ring 2 Doorbell
Post by Egregius »
You got a up to date screenshot? Or on old one?
Post your code please, much easier to help.
Doudy
Re: Ring 2 Doorbell
Post by Doudy »
First best wishes
For me pip install git+https://github.com/username/repo.git
don't working !
$ pip install git+https://github.com/username/repo.git
File "/usr/bin/pip", line 9, in <module>
from pip._internal import main
File "/usr/lib/python2.7/dist-packages/pip/_internal/__init__.py", line 19, in <module>
from pip._vendor.urllib3.exceptions import DependencyWarning
File "/usr/lib/python2.7/dist-packages/pip/_vendor/__init__.py", line 64, in <module>
vendored("cachecontrol")
File "/usr/lib/python2.7/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
__import__(modulename, globals(), locals(), level=0)
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in <module>
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in <module>
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in <module>
File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in <module>
File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in <module>
File "/usr/lib/python2.7/dist-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
EOFError: EOF read where object expected
Idem with :
pip install git+https://github.com/tche ... ell@master
url =
pip install git+https://github.com/tchellomello/python-ring-doorbell@master
an idea ?
Re: Ring 2 Doorbell
Doudy wrote: Sunday 10 January 2021 9:06 For me pip install git+https://github.com/username/repo.git
don't working !
an idea ?
Maybe you should use pip3 in your environment..
sudo pip3 install git+https://github.com/tchellomello/python-ring-doorbell@master
Collecting git+https://github.com/tchellomello/python-ring-doorbell@master
  Cloning https://github.com/tchellomello/python-ring-doorbell (to revision master) to /tmp/pip-req-build-x631bj6a
  Running command git clone -q https://github.com/tchellomello/python-ring-doorbell /tmp/pip-req-build-x631bj6a
Collecting oauthlib<4,>=3.0.0
  Downloading oauthlib-3.1.0-py2.py3-none-any.whl (147 kB)
     |████████████████████████████████| 147 kB 3.2 MB/s
Requirement already satisfied: pytz in /usr/lib/python3/dist-packages (from ring-doorbell==0.6.2) (2020.5)
Collecting requests-oauthlib<2,>=1.3.0
  Downloading requests_oauthlib-1.3.0-py2.py3-none-any.whl (23 kB)
Requirement already satisfied: requests>=2.0.0 in /usr/lib/python3/dist-packages (from ring-doorbell==0.6.2) (2.25.1)
Building wheels for collected packages: ring-doorbell
  Building wheel for ring-doorbell (setup.py) ... done
  Created wheel for ring-doorbell: filename=ring_doorbell-0.6.2-py3-none-any.whl size=23087 sha256=e3a385f95e37193835878bce3a09b2102ea2a6ceada46dd79fb0f71cc4f5f242
  Stored in directory: /tmp/pip-ephem-wheel-cache-r4s8_ocd/wheels/8c/2f/dd/a1724238560e6986f002eece36e51ad9993d509ac1f6d1be75
Successfully built ring-doorbell
Installing collected packages: oauthlib, requests-oauthlib, ring-doorbell
Successfully installed oauthlib-3.1.0 requests-oauthlib-1.3.0 ring-doorbell-0.6.2
Doudy
Re: Ring 2 Doorbell
Post by Doudy »
I tried with pip3
$ sudo pip3 install git+https://github.com/tchellomello/python-ring-doorbell@master
  File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
    __import__(vendored_name, globals(), locals(), level=0)
ModuleNotFoundError: No module named 'pip._vendor.pkg_resources'
During handling of the above exception, another exception occurred:
  File "/usr/bin/pip3", line 9, in <module>
  File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in <module>
  File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 77, in <module>
    vendored("pkg_resources")
  File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 668, in _load_unlocked
  File "<frozen importlib._bootstrap>", line 638, in _load_backward_compatible
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 3191, in <module>
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 3175, in _call_aside
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 3204, in _initialize_master_working_set
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 574, in _build_master
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 567, in __init__
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 623, in add_entry
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2033, in find_on_path
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2103, in distributions_from_metadata
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2560, in from_location
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2935, in _reload_version
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2524, in _version_from_file
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2714, in _get_metadata
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 1416, in get_metadata_lines
  File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 1413, in get_metadata
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe5 in position 1039: invalid continuation byte
Re: Ring 2 Doorbell
Doudy wrote: Sunday 10 January 2021 16:13 ModuleNotFoundError: No module named 'pip._vendor.pkg_resources'
Google is your friend ..
Doudy
Re: Ring 2 Doorbell
Post by Doudy »
I tried all fixes on this page https://stackoverflow.com/questions/494 ... -resources and it didn't work.
Doudy
Re: Ring 2 Doorbell
Post by Doudy »
I completely reinstall my SD card
grecof973
Re: Ring 2 Doorbell
Post by grecof973 »
someone help me to understand this script how it works ???
Doudy
Re: Ring 2 Doorbell
Post by Doudy »
grecof973 wrote: Monday 28 June 2021 19:27 someone help me to understand this script how it works ???
That's a good idea :!: ;)
Doudy
Re: Ring 2 Doorbell
Post by Doudy »
Doudy wrote: Tuesday 29 June 2021 7:11
Nobody ?
grecof973
Re: Ring 2 Doorbell
Post by grecof973 »
I do not know!! I see that some have succeeded, but in the end I think the script is stopped !!
I still want to try asking the developer a question on his page, maybe he doesn't read here
Doudy
Re: Ring 2 Doorbell
Post by Doudy »
grecof973 wrote: Saturday 10 July 2021 19:48 I still want to try asking the developer a question on his page, maybe he doesn't read here
okay
Please let us know if you have any news
nigels0
Domoticz version: 3.8153
Re: Ring 2 Doorbell
Post by nigels0 »
I've just come back to this and re-installed with the new libraries - and things were busted from the original script.
Try this one now
import json
import getpass
from pathlib import Path
from pprint import pprint
from ring_doorbell import Ring, Auth, RingDoorBell
from oauthlib.oauth2 import MissingTokenError
from time import sleep
import urllib.request as urllib2
#import urllib2
from datetime import datetime
cache_file = Path("/home/pi/domoticz/scripts/test_token.cache")
videopath = '/mnt/synology/Doorbell/'
def token_updated(token):
    cache_file.write_text(json.dumps(token))
def otp_callback():
    auth_code = input("2FA code: ")
    return auth_code
def main():
    if cache_file.is_file():
        auth = Auth("Ring/1.0", json.loads(cache_file.read_text()), token_updated)
    else:
        username = "XXXXXXXXXXXX"
        password = "XXXXXXXXXXXX"
        auth = Auth("Ring/1.0", None, token_updated)
        try:
            auth.fetch_token(username, password)
        except MissingTokenError:
            auth.fetch_token(username, password, otp_callback())
    myring = Ring(auth)
    myring.update_data()
    devices = myring.devices()
    pprint(devices)
    doorbell = devices['doorbots'][0]
    recordings = doorbell.history(limit=100, kind='ding')
    while(True):
     myring.update_dings()
     data = myring.active_alerts()
     if data !=[]:
       urllib2.urlopen('http://192.168.10.50:8080/json.htm?type=command&param=switchlight&idx=1096&switchcmd=On')
       urllib2.urlopen('http://192.168.10.50:8080/json.htm?type=command&param=switchlight&idx=1209&switchcmd=On')
       timestamp = datetime.now().strftime("%d:%m_%H.%M.%S")
       for event in recordings:
        print('Downloading {} event recorded on {} lasting {}s'.format(
            event['kind'], event['created_at'].strftime("%d/%m/%Y at %H:%M:%S"), event['duration'])
        videotime = event['created_at'].strftime("%Y%m%d_%H%M%S")
        doorbell.recording_download(
            event['id'], filename=videopath + 'Door_' + videotime + '.mp4', override=False
    print('Download complete')
if __name__ == "__main__":
    main()
Note that you need to run this with python3 now.
note you have to change the location for the cache_file and add your own Ring username and password - and also change the video path to where you want to store the recordings.
Note that on the first run through, it will ask for a 2FA (you should have set that up previously) - enter the key then run again and it should list your devices.
grecof973
Re: Ring 2 Doorbell
Post by grecof973 »
Excuse me .... But can you give us a guide on how to start on this Plug-In I'm just zero on the matter, and like me others here on the forum .... It would be very welcome
Doudy
Re: Ring 2 Doorbell
Post by Doudy »
grecof973 wrote: Tuesday 09 November 2021 22:00 Excuse me .... But can you give us a guide on how to start on this Plug-In I'm just zero on the matter, and like me others here on the forum .... It would be very welcome
It would indeed be very interesting.
For me too !
How to install completely?
At home the old version it is installed in /home/pi/domoticz/scripts/python/python-ring-doorbell-master/
How to proceed ?
Which files to modify?
Doudy
Re: Ring 2 Doorbell
Post by Doudy »
I have tested this nex vesion.
Results :
pi@raspberrypi:~/domoticz/scripts/python $ sudo python3.7 ring-doorbell.py
2FA code: xxxxxx
  File "ring-doorbell.py", line 63, in <module>
    main()
  File "ring-doorbell.py", line 38, in main
  File "/usr/local/lib/python3.7/dist-packages/ring_doorbell/__init__.py", line 58, in update_data
    self.update_groups()
  File "/usr/local/lib/python3.7/dist-packages/ring_doorbell/__init__.py", line 99, in update_groups
    for group in data["device_groups"]:
TypeError: 'NoneType' object is not iterable
test_token.cache created
:shock: For me it's Chinese! :?
Doudy
Re: Ring 2 Doorbell
Post by Doudy »
Nobody ?
