Ring 2 Doorbell
PeterFleur
- Domoticz version: 2.4739
Re: Ring 2 Doorbell
RaspberryPI
ZWave
RFXtrx433E
ZWave
RFXtrx433E
- Egregius
- Domoticz version: v2024.7
Re: Ring 2 Doorbell
Yes:
# Installing latest development
$ pip install \
git+https://github.com/tchellomello/python- ... ell@master
$ pip install \
DdeR
Re: Ring 2 Doorbell
The script works like a chime! thnx!
the script now also triggers on motion but I really just want it to trigger when the doorbell is pressed.
can someone help me get that done?
- Egregius
Re: Ring 2 Doorbell
You got a up to date screenshot? Or on old one?
Post your code please, much easier to help.
Re: Ring 2 Doorbell
First best wishes
For me pip install git+https://github.com/username/repo.git
don't working !
First best wishes
don't working !
$ pip install git+https://github.com/username/repo.git
File "/usr/bin/pip", line 9, in <module>
from pip._internal import main
File "/usr/lib/python2.7/dist-packages/pip/_internal/__init__.py", line 19, in <module>
from pip._vendor.urllib3.exceptions import DependencyWarning
File "/usr/lib/python2.7/dist-packages/pip/_vendor/__init__.py", line 64, in <module>
vendored("cachecontrol")
File "/usr/lib/python2.7/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
__import__(modulename, globals(), locals(), level=0)
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in <module>
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in <module>
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in <module>
File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in <module>
File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in <module>
File "/usr/lib/python2.7/dist-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
EOFError: EOF read where object expected
Idem with :
pip install git+https://github.com/tche ... ell@master
url =an idea ?Code: Select all
pip install git+https://github.com/tchellomello/python-ring-doorbell@master
- waaren
Re: Ring 2 Doorbell
Maybe you should use pip3 in your environment..Doudy wrote: Sunday 10 January 2021 9:06 For me pip install git+https://github.com/username/repo.git
don't working !
an idea ?
sudo pip3 install git+https://github.com/tchellomello/python-ring-doorbell@master
Collecting git+https://github.com/tchellomello/python-ring-doorbell@master
Cloning https://github.com/tchellomello/python-ring-doorbell (to revision master) to /tmp/pip-req-build-x631bj6a
Running command git clone -q https://github.com/tchellomello/python-ring-doorbell /tmp/pip-req-build-x631bj6a
Collecting oauthlib<4,>=3.0.0
Downloading oauthlib-3.1.0-py2.py3-none-any.whl (147 kB)
|████████████████████████████████| 147 kB 3.2 MB/s
Requirement already satisfied: pytz in /usr/lib/python3/dist-packages (from ring-doorbell==0.6.2) (2020.5)
Collecting requests-oauthlib<2,>=1.3.0
Downloading requests_oauthlib-1.3.0-py2.py3-none-any.whl (23 kB)
Requirement already satisfied: requests>=2.0.0 in /usr/lib/python3/dist-packages (from ring-doorbell==0.6.2) (2.25.1)
Building wheels for collected packages: ring-doorbell
Building wheel for ring-doorbell (setup.py) ... done
Created wheel for ring-doorbell: filename=ring_doorbell-0.6.2-py3-none-any.whl size=23087 sha256=e3a385f95e37193835878bce3a09b2102ea2a6ceada46dd79fb0f71cc4f5f242
Stored in directory: /tmp/pip-ephem-wheel-cache-r4s8_ocd/wheels/8c/2f/dd/a1724238560e6986f002eece36e51ad9993d509ac1f6d1be75
Successfully built ring-doorbell
Installing collected packages: oauthlib, requests-oauthlib, ring-doorbell
Successfully installed oauthlib-3.1.0 requests-oauthlib-1.3.0 ring-doorbell-0.6.2
Re: Ring 2 Doorbell
I tried with pip3
I tried with pip3
$ sudo pip3 install git+https://github.com/tchellomello/python-ring-doorbell@master
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
__import__(vendored_name, globals(), locals(), level=0)
ModuleNotFoundError: No module named 'pip._vendor.pkg_resources'
During handling of the above exception, another exception occurred:
File "/usr/bin/pip3", line 9, in <module>
File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in <module>
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 77, in <module>
vendored("pkg_resources")
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 668, in _load_unlocked
File "<frozen importlib._bootstrap>", line 638, in _load_backward_compatible
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 3191, in <module>
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 3175, in _call_aside
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 3204, in _initialize_master_working_set
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 574, in _build_master
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 567, in __init__
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 623, in add_entry
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2033, in find_on_path
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2103, in distributions_from_metadata
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2560, in from_location
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2935, in _reload_version
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2524, in _version_from_file
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2714, in _get_metadata
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 1416, in get_metadata_lines
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 1413, in get_metadata
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe5 in position 1039: invalid continuation byte
- waaren
Re: Ring 2 Doorbell
Google is your friend ..Doudy wrote: Sunday 10 January 2021 16:13 ModuleNotFoundError: No module named 'pip._vendor.pkg_resources'
Re: Ring 2 Doorbell
I tried all fixes on this page https://stackoverflow.com/questions/494 ... -resources and it didn't work.
Re: Ring 2 Doorbell
I completely reinstall my SD card
grecof973
Re: Ring 2 Doorbell
someone help me to understand this script how it works ???
Re: Ring 2 Doorbell
grecof973 wrote: Monday 28 June 2021 19:27 someone help me to understand this script how it works ???
That's a good idea
Re: Ring 2 Doorbell
Nobody ?
grecof973
Re: Ring 2 Doorbell
I do not know!! I see that some have succeeded, but in the end I think the script is stopped !!
I still want to try asking the developer a question on his page, maybe he doesn't read here
Re: Ring 2 Doorbell
okaygrecof973 wrote: Saturday 10 July 2021 19:48 I still want to try asking the developer a question on his page, maybe he doesn't read here
Please let us know if you have any news
nigels0
- Domoticz version: 3.8153
Re: Ring 2 Doorbell
I've just come back to this and re-installed with the new libraries - and things were busted from the original script.
Try this one now
Note that you need to run this with python3 now.
note you have to change the location for the cache_file and add your own Ring username and password - and also change the video path to where you want to store the recordings.
Note that on the first run through, it will ask for a 2FA (you should have set that up previously) - enter the key then run again and it should list your devices.
Try this one now
import json
import getpass
from pathlib import Path
from pprint import pprint
from ring_doorbell import Ring, Auth, RingDoorBell
from oauthlib.oauth2 import MissingTokenError
from time import sleep
import urllib.request as urllib2
#import urllib2
from datetime import datetime
cache_file = Path("/home/pi/domoticz/scripts/test_token.cache")
videopath = '/mnt/synology/Doorbell/'
def token_updated(token):
cache_file.write_text(json.dumps(token))
def otp_callback():
auth_code = input("2FA code: ")
return auth_code
def main():
if cache_file.is_file():
auth = Auth("Ring/1.0", json.loads(cache_file.read_text()), token_updated)
else:
username = "XXXXXXXXXXXX"
password = "XXXXXXXXXXXX"
auth = Auth("Ring/1.0", None, token_updated)
try:
auth.fetch_token(username, password)
except MissingTokenError:
auth.fetch_token(username, password, otp_callback())
myring = Ring(auth)
myring.update_data()
devices = myring.devices()
pprint(devices)
doorbell = devices['doorbots'][0]
recordings = doorbell.history(limit=100, kind='ding')
while(True):
myring.update_dings()
data = myring.active_alerts()
if data !=[]:
urllib2.urlopen('http://192.168.10.50:8080/json.htm?type=command¶m=switchlight&idx=1096&switchcmd=On')
urllib2.urlopen('http://192.168.10.50:8080/json.htm?type=command¶m=switchlight&idx=1209&switchcmd=On')
timestamp = datetime.now().strftime("%d:%m_%H.%M.%S")
for event in recordings:
print('Downloading {} event recorded on {} lasting {}s'.format(
event['kind'], event['created_at'].strftime("%d/%m/%Y at %H:%M:%S"), event['duration'])
videotime = event['created_at'].strftime("%Y%m%d_%H%M%S")
doorbell.recording_download(
event['id'], filename=videopath + 'Door_' + videotime + '.mp4', override=False
print('Download complete')
if __name__ == "__main__":
main()
grecof973
Re: Ring 2 Doorbell
Excuse me .... But can you give us a guide on how to start on this Plug-In I'm just zero on the matter, and like me others here on the forum .... It would be very welcome
Re: Ring 2 Doorbell
It would indeed be very interesting.grecof973 wrote: Tuesday 09 November 2021 22:00 Excuse me .... But can you give us a guide on how to start on this Plug-In I'm just zero on the matter, and like me others here on the forum .... It would be very welcome
For me too !
How to install completely?
At home the old version it is installed in /home/pi/domoticz/scripts/python/python-ring-doorbell-master/
How to proceed ?
Which files to modify?
Re: Ring 2 Doorbell
I have tested this nex vesion.
Results :
test_token.cache created
For me it's Chinese!
Results :
pi@raspberrypi:~/domoticz/scripts/python $ sudo python3.7 ring-doorbell.py
2FA code: xxxxxx
File "ring-doorbell.py", line 63, in <module>
main()
File "ring-doorbell.py", line 38, in main
File "/usr/local/lib/python3.7/dist-packages/ring_doorbell/__init__.py", line 58, in update_data
self.update_groups()
File "/usr/local/lib/python3.7/dist-packages/ring_doorbell/__init__.py", line 99, in update_groups
for group in data["device_groups"]:
TypeError: 'NoneType' object is not iterable
Re: Ring 2 Doorbell
Nobody ?
