Ring 2 Doorbell
nigels0
Domoticz version: 3.8153
Ring 2 Doorbell
Post by nigels0 »
I’ve connected my Ring 2 doorbell with Domoticz by using a python library from here:
https://github.com/tchellomello/python-ring-doorbell
I have a dummy doorbell switch set up called doorbell (in this case idx 1096) and I use a python app running continually (as a service) to poll for a push on the doorbell
from ring_doorbell import Ring
from time import sleep
import urllib2
ringUsername='MyUsername’
ringPassword='MyPassword'
myring = Ring(ringUsername,ringPassword)
# Now loop infinitely
while(1):
 data = myring.doorbells[0].check_alerts()
 if data==True:
   urllib2.urlopen('http://192.168.0.52:8080/json.htm?type=command&param=switchlight&idx=1096&switchcmd=On’)
   sleep(1)
   urllib2.urlopen('http://192.168.0.52:8080/json.htm?type=command&param=switchlight&idx=1096&switchcmd=Off’)
 # Loop around
 sleep(1)
The library has other functions, but I only needed to register the doorbell push with Domoticz
For info how to start this python script as a service have a butchers at:
https://www.raspberrypi-spy.co.uk/2015/ ... g-systemd/
It's possible to grab the video with
import urllib2
from datetime import datetime
ringUsername='myUsername'
ringPassword='myPassword'
doorbell = myring.doorbells[0]
while(1):
    data = doorbell.check_alerts()
    if data==True:
      urllib2.urlopen('http://192.168.0.52:8080/json.htm?type=command&param=switchlight&idx=1096&sw$
      sleep(1)
      timestamp = datetime.now().strftime("%d:%m_%H.%M.%S")
      doorbell.recording_download(doorbell.history(limit=100, kind='ding')[0]['id'],
                     filename='/mnt/synology/Doorbell/'+timestamp+'.mp4',override=True)
    sleep(1)
but I'm finding that I'm getting the last video - not the current one. I've tried a pause for 40 seconds, but then no file is written.
felix63
Domoticz version: 2020.1
Re: Ring 2 Doorbell
Post by felix63 »
Very useful post, thank you! By the way if you already have PM2 running you can simply add this script to PM2 to make sure its running all the time.
djoeney
Re: Ring 2 Doorbell
Post by djoeney »
Thanks for sharing, this is very helpful to create a action based on on trigger. Is it possible to switch on a dummy switch when motion is detected?
Compute RPi 2 : Domoticz latest beta, Synology : Domoticz tested beta on failover system.
Peripherals RFXCOM - RFXtrx433, Z-Wave.Me ZME_UZB1 USB Stick,P1 cable on smartmeter, Logitech Harmony Hub, 3 IP camera's
jvmaanen
Re: Ring 2 Doorbell
Post by jvmaanen »
That would be very useful, to switch on a dummy switch when motion is detected.
sach
Re: Ring 2 Doorbell
Post by sach »
nigels0 wrote: Monday 26 November 2018 22:44 I’ve connected my Ring 2 doorbell with Domoticz by using a python library from here:
import urllib2
while(1):
 if data==True:
   sleep(1)
 # Loop around
 sleep(1)
https://thepihut.com/blogs/raspberry-pi ... 937476d22b
import urllib2
while(1):
    if data==True:
      sleep(1)
    sleep(1)
Nice work, but shame I have no idea how to implement. :-(
Only function i'm really after is to create a switch to turn my floodlight lights on and off.
Can then add this to imperihome to control from my wallmounted kitchen tablet.
Would you be able to help me achieve this? ;)
JoshDinsdale
Re: Ring 2 Doorbell
Post by JoshDinsdale »
Just implemented this with my newly installed Ring Doorbell 1 and works really nicely.
According to the python-ring-doorbell code, the check_alerts function is triggered by both doorbell pushes and motion events which is good to know. However, does anyone know if there is a way to separate these so we could trigger two seperate switches in Domoticz?
JuanUil
Domoticz version: 4.11083
Re: Ring 2 Doorbell
Post by JuanUil »
This is what I was waiting for!! Thnx very much!
joepadmiraal
Re: Ring 2 Doorbell
Post by joepadmiraal »
This looks great.
Can you tell me a bit about the response time you ar seeing?
So how much time does it take before you see your switch flipped in Domoticz after someone presses the doorbell?
Thanks,
Joep
leecollings
Re: Ring 2 Doorbell
Post by leecollings »
Does anyone know if this would also be able to work with a Floodlight Cam?
nigels0
Re: Ring 2 Doorbell
Post by nigels0 »
joepadmiraal wrote: Wednesday 05 June 2019 8:01 This looks great.
Thanks,
Joep
I'm seeing about 1-2 sec delay - so hardly noticeable.
dizzeenl
Re: Ring 2 Doorbell
Post by dizzeenl »
Hy,
im not so familiar with python jet and get constantly syntax errors and "no module named ring_doorbell" when using the script above in my python folder of domoticz :(
is there an step-by-step guide for this somewhere?
felix63
Re: Ring 2 Doorbell
Post by felix63 »
Did you install the python-ring-doorbell library? See https://github.com/tchellomello/python-ring-doorbell?
dizzeenl
Re: Ring 2 Doorbell
Post by dizzeenl »
yes i did, but i forgot i used the pip3 version :(, now it works like a charm :roll:
felix63
Re: Ring 2 Doorbell
Post by felix63 »
<knip>
Did you ever find a workaround for this?
nigels0
Re: Ring 2 Doorbell
Post by nigels0 »
Nope.
capslocker
Re: Ring 2 Doorbell
Post by capslocker »
Hi all
I am looking to buy a Ring doorbell. If I understand correct, this script allows to record video when someone rings ?
PeterFleur
Domoticz version: 2.4739
Re: Ring 2 Doorbell
Post by PeterFleur »
Did anyone get this working now that Ring has MFA as requirement?
Peter
RaspberryPI
ZWave
RFXtrx433E
clinkadink
Re: Ring 2 Doorbell
Post by clinkadink »
PeterFleur wrote: Sunday 31 May 2020 15:56 Did anyone get this working now that Ring has MFA as requirement?
Yes, it works with 2FA. The first time you run the script, it prompts you for your 2FA code (received via email/text). Once entered, Ring adds your device to the trusted section of your Ring.com account.
nigels0 wrote: Monday 26 November 2018 22:44 but I'm finding that I'm getting the last video - not the current one. I've tried a pause for 40 seconds, but then no file is written.
A slightly late response ... but it may help others. That's because you are only selecting one event from the history. Look at your code below, you have "[0]" which is only every selecting the first event in your list of events.
    doorbell.history(limit=100, kind='ding')[0]['id'], filename='/mnt/synology/Doorbell/'+timestamp+'.mp4',override=True
Try this ...
videopath = '/home/clinkadink/ring/'
recordings = doorbell.history(limit=100, kind='ding')
for event in recordings:
        print('Downloading {} event recorded on {} lasting {}s'.format(
            event['kind'], event['created_at'].strftime("%d/%m/%Y at %H:%M:%S"), event['duration'])
        videotime = event['created_at'].strftime("%Y%m%d_%H%M%S")
            event['id'], filename=videopath + 'ring_video_' + videotime + '.mp4', override=False
print('Download complete')
migila
Re: Ring 2 Doorbell
Post by migila »
I got lot's of error's. I think i fixed them but the following i can't seem to fix. I'm not known with programming. I first had an error "SyntaxError: Non ASCII character" Then i had the next error: SyntaxError EOL while scanning string literal. Then the next error: Module not found: urllib2
The last error i don't seem to fix:
TypError: __init__() takes 2 positional arguments but 3 were given
How can i solve this?
Alain
Domoticz version: 2022.1
Re: Ring 2 Doorbell
Post by Alain »
For the life of me, I can't work this out. I got the installation part done, but then when I get to "Initializing your ring object" I have no idea how to proceed. Where do I put that script? Do I run it once?
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
