SolarEdge in Latest Beta / Port Number
jannl
Domoticz version: 2026.1.x
Re: SolarEdge in Latest Beta / Port Number
Post by jannl »
Looks like the data from the solaredge is only presented when the data can be forwarded to the solaredge portal. At the moment I get no data in my Domoticz setup and no data in Solaredge. My brother who only uses Solaredge has no data either. Is this intentionally?
Jantje1972
Domoticz version: 2.2336
Post by Jantje1972 »
Same here no data on either one ?
Pietertje
Domoticz version: latest
Post by Pietertje »
hi to all,
Same here no connection/data from SE 2200 after shutdown yseterdat evening, system running on Smartmeter, I thought complete system is down , but it is only communication to Raspberry.
jannl
Post by jannl »
Looks like a problem at solaredge. Would be nice though if Domoticz would present the data no matter what the connection with Solaredge is.
Pietertje
Post by Pietertje »
Yes Jan,
I agree, stupid sytem when we are depending from Solar Edge completely to log figures.
To avoid misunderstanding I'm talking about the SolarEdge sytem, server SA was down so we are not able to logdate. Limitations from producer and thats stupid.
antwan
Domoticz version: Latest
Post by antwan »
jan_nl wrote:Looks like a problem at solaredge. Would be nice though if Domoticz would present the data no matter what the connection with Solaredge is.
Do we have a volunteer to implement this?
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
AvdB
Post by AvdB »
I would sure like to help, but first I have to finish some exams this week...
collinneke
Post by collinneke »
Data on domoticz not realtime it's now 10.39 and the data are from 10.03 and to the solaredge layout 10.38 can anyone helping me whit this.
antwan
Post by antwan »
collinneke wrote:Data on domoticz not realtime it's now 10.39 and the data are from 10.03 and to the solaredge layout 10.38 can anyone helping me whit this.
Can you be more specific? Read you own post again and use intonations!
As far as i can see right now, all works fine.
collinneke
Sorry for my bad english,
When i take look by domoticz on the solaredge device can i sea: Last turn on: 2015-04-07 16:07:57
when i take a look to the monitor of solaredge (http://www.solaredge.com) is the last that i can sea 16:53
domoticz monitor do not update the real time when they send to solaredge
The solaredge inverter send to domoticz and domoticz to http://www.solaredge.com/
I hope that you can now understand me
antwan
Post by antwan »
I know how it Works, because we made it.
The Inverter sends iTS data to the solaredge portal and we show this in Domoticz. These info is correct (at least on my System, and some other users). I checked this multiple times since we have this working.
Can you show some logs/foto's/print screens to clarify your issue?
collinneke
I have now two print sceenes maked
Look at the time.
antwan
Post by antwan »
No problem here.
collinneke
How have you connect the solaredge inverter with wifi or lan, and what are you settings, my connecting are wifi.
My inverter are se5000.
AvdB
Post by AvdB »
Mine is connected through WiFi and it is a SE3000, but don't see anything in Domoticz...
Jantje1972
My inverter is SE7000, upload through Domoticz to Solaredge monitoring works perfect, but after a few weeks still no extra devices are created in Domoticz ?
jannl
Post by jannl »
Do you have rhe allow new devices enabled in the settings?
Jantje1972
Yes, and all the new z-wave devices i added afterwards are all working properly, only solar edge gives no new devices, beats me?
Pietertje
Post by Pietertje »
hi,
After changing from the SE2200 to the SE3000, logging is not working anymore.
SE3000 is detected once with the folowing remarks in logging.
Error: SolarEdge: Unknown Type: 1408
Error: SolarEdge: Something not handled correctly, having extra bytes!
Tried everything but not show in devices sytem running now is beta 2382.
figures are forwarded to Solar Edge but not showing up in domoticz
Devices detecting is on, changed ip adres etc. Please advice
Pietertje
Post by Pietertje »
Made some more testing, reinstalled the SE2200 again and within 5 minutes up and running in Domoticz, again changed to the SE3000 but no way to get contact.
After restart of the SE3000 once till now it was registrated but that's it. It seems that the latest SolarEdges have newer firmware, so this will be the difference.
All the data is forwarded to SolarEdge but only not registrated in Domoticz. So if I can help you developers with some data or trials please instruct me what to do.
Update :
System is sometimes registrating the data, early in the morning and late in the evening and allso when the power is very low on the panels, perhaps ythis info helps.
2015-04-24 11:06:30.072 Hardware Monitor: Fetching data (System sensors)
2015-04-24 11:07:00.099 Hardware Monitor: Fetching data (System sensors)
2015-04-24 11:07:30.128 Hardware Monitor: Fetching data (System sensors)
2015-04-24 11:07:44.787 (Solar) Energy (SolarMain)
2015-04-24 11:07:44.792 (Solar) Temp (SolarTemp)
2015-04-24 11:07:44.798 (Solar) General/Percentage (SolarHz)
2015-04-24 11:07:44.803 (Solar) General/Voltage (SolarAC)
2015-04-24 11:07:44.808 (Solar) General/Voltage (SolarDC)
2015-04-24 11:08:00.158 Hardware Monitor: Fetching data (System sensors)
2015-04-24 11:08:30.185 Hardware Monitor: Fetching data (System sensors)
2015-04-24 11:09:00.213 Hardware Monitor: Fetching data (System sensors)
Allso found system which is logging through RS485 SolarEdge => Sunprofit perhaps something for the developers to cooperate
