Is is definitely faster to setup compared to the also working 100% 'node' solution described in the beginning of this post.
Tnx for sharing.
OTGW: connected to: 127.0.0.1:7689A bit of a bump after 4 years, but the OTGW firmware got an update to v5 with extra fields in the PS=1 command, can this be adapted for the nodejs app? I've looked myself but I don't understand it completely.
I read through the script and I came across a line that verifies that there are 25 responses. I think that as soon as you change that to the new 34, it is supposed to work againLizard wrote:A bit of a bump after 4 years, but the OTGW firmware got an update to v5 with extra fields in the PS=1 command, can this be adapted for the nodejs app? I've looked myself but I don't understand it completely.
This script allows users to exchange what they want to show up in the ps=1 string. For myself I have exchanged an unused parameter for my solar boiler temperature. I don't think that the new order matters here. That is taken care of in domoticz by the normal OTGW hardwarekiddigital wrote:It is not only that the V5 firmware now has 34 instead of 25 fields, also the order of the fields has changed (still the order is the OpenTherm MsgIDs but some new MsgIDs have been added in between)
I updated my Opentherm Gateway over the weekend to 5.2. I couldn't find the previous version, but I expected 5.0 or 5.1.jake wrote:This script allows users to exchange what they want to show up in the ps=1 string. For myself I have exchanged an unused parameter for my solar boiler temperature. I don't think that the new order matters here. That is taken care of in domoticz by the normal OTGW hardwarekiddigital wrote:It is not only that the V5 firmware now has 34 instead of 25 fields, also the order of the fields has changed (still the order is the OpenTherm MsgIDs but some new MsgIDs have been added in between)
