[MyDomoAtHome] Support thread
hanor
Re: [MyDomoAtHome] Support thread
it works !
thank you very much !
johansson
Thanks for the advice, unfortunately no luck yet. Set the ports as above, but trying ./start2.sh results in an error (well, row of errors, actually):epierre wrote:1) domo_path is the http address to reach your domoticz so http://192.168.1.50:8080
2) if on the same machine, 8080 port is already for domoticz, so starting MDAH will not be possible if the port is already binded to another application, leave 3001 here to test, and try ./start2.sh to validate it can start
pi@raspberrypi:~/domoticz/MyDomoAtHome$ ./start2.sh
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
YAML Warning: Duplicate map key found. Ignoring.
Code: YAML_LOAD_WARN_DUPLICATE_KEY
Line: 17
Document: 1
at /usr/share/perl5/YAML/Mo.pm line 24
YAML::Mo::__ANON__('YAML::Loader=HASH(0x1f775a0)', 'YAML_LOAD_WARN_DUPLICATE_KEY') called at /usr/share/perl5/YAML/Loader.pm line 359
YAML::Loader::_parse_mapping('YAML::Loader=HASH(0x1f775a0)', '') called at /usr/share/perl5/YAML/Loader.pm line 168
YAML::Loader::_parse_node('YAML::Loader=HASH(0x1f775a0)') called at /usr/share/perl5/YAML/Loader.pm line 103
YAML::Loader::_parse('YAML::Loader=HASH(0x1f775a0)') called at /usr/share/perl5/YAML/Loader.pm line 25
YAML::Loader::load('YAML::Loader=HASH(0x1f775a0)', '# appdir/environments/development.yml
# configuration file fo...') called at /usr/share/perl5/YAML.pm line 34
YAML::Load('# appdir/environments/development.yml
# configuration file fo...') called at /usr/share/perl5/YAML.pm line 75
YAML::LoadFile('/home/pi/domoticz/MyDomoAtHome/environments/development.yml') called at /usr/share/perl5/Dancer/Config.pm line 201
eval {...} called at /usr/share/perl5/Dancer/Config.pm line 201
Dancer::Config::load_settings_from_yaml('/home/pi/domoticz/MyDomoAtHome/environments/development.yml') called at /usr/share/perl5/Dancer/Config.pm line 182
Dancer::Config::load('Dancer::Config') called at /usr/share/perl5/Dancer.pm line 258
Dancer::import('Dancer') called at bin/app.pl line 19
Plack::Sandbox::bin_2fapp_2epl::BEGIN() called at bin/app.pl line 19
eval {...} called at bin/app.pl line 19
require bin/app.pl called at (eval 7) line 3
eval 'package Plack::Sandbox::bin_2fapp_2epl;
my $app = do $_file;
if ( !$app && ( my $error = $@ || $! )) { die $error; }
$app;
;' called at /usr/share/perl5/Plack/Util.pm line 118
Plack::Util::_load_sandbox('bin/app.pl') called at /usr/share/perl5/Plack/Util.pm line 155
Plack::Util::load_psgi('bin/app.pl') called at /usr/share/perl5/Plack/Runner.pm line 176
Plack::Runner::__ANON__() called at /usr/share/perl5/Plack/Runner.pm line 23
Plack::Runner::__ANON__() called at /usr/share/perl5/Plack/Loader.pm line 59
Plack::Loader::preload_app('Plack::Loader=HASH(0x1847a98)', 'CODE(0x187eb28)') called at /usr/share/perl5/Plack/Runner.pm line 260
Plack::Runner::run('Plack::Runner=HASH(0x1714818)') called at /usr/bin/plackup line 10
Error while loading bin/app.pl: Can't locate Time/Moment.pm in @INC (@INC contains: /home/pi/domoticz/MyDomoAtHome/bin/../lib /home/pi/domoticz/MyDomoAtHome/lib /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm line 31.
BEGIN failed--compilation aborted at /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm line 31.
Compilation failed in require at bin/app.pl line 20.
BEGIN failed--compilation aborted at bin/app.pl line 20.-
johansson
The "sudo cpanm Time::Moment" fixed the above as well. Excellent, now it's up and running.
- epierre
Thanks for pointing this, I have updated the installation procedure to avoid this issue.hanor wrote:it works !
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
lowca
What about room's..
I'd like to have some of temp sensors in custom room ,. add room 'piwnica' id domotocz (PlanID =2)
So i add some code :
in get 'rooms'
and ..
get '/devices'
so my question is , is there an easiest way ..
in get 'rooms'
{ "id"=> "Piwnica", "name"=> "Piwnica" },
get '/devices'
#debug("DBG:".$f->{"idx"}.":".$f->{"Type"}.":".$f->{"SubType"}."\n");
debug("DBG:".$f->{"idx"}.":".$f->{"Type"}.":".$f->{"SubType"}.":PlanID:".$f->{"PlanID"}."\n");
my $PlanID = $f->{"PlanID"};
if ($PlanID == 2) {
$feeds={params =>[],"room" => "Piwnica","type" => "DevTemperature","name" => $name, "id" =>$
} else {
$feeds={params =>[],"room" => "Temp","type" => "DevTemperature","name" => $name, "id" => $f$
- epierre
Hello,lowca wrote:What about room's..
Is PlanID a new feature ? if so I could automatize that.
It looks like I cannot do it on a mibile phone so I may have tocheck that. I would be interrested in your domoticz.d to see if that can be used for everyone using or not planID
lowca
Yes, Please ..Hello,
Plan is get rooms from :
json.htm?type=plans&order=name&used=true
"result" : [
"Devices" : 3,
"Name" : "Piwnica",
"Order" : "1",
"idx" : "2" --> ( PlanID in /json.htm?type=devices )
get '/rooms' => sub {
#Room list
return {"rooms" => [
{ "id"=> "Switches", "name"=> "Switches" },
{ "id"=> "Scenes", "name"=> "Scenes" },
{ "id"=> "Temp", "name"=> "Temperature" },
{ "id"=> "Weather", "name"=> "Weather" },
{ "id"=> "Utility", "name"=> "Utility" },
Im new in domoticz , and don't have too much time, but i try to help
I can change it now manually , but i think i it could be a good feature ,.
raym
Hi guys, what would it take to show last tripped/updated time for motion sensors?
- epierre
it takes only the time of refresh you can set in the imperihome parameters.raym wrote:Hi guys, what would it take to show last tripped/updated time for motion sensors?
raym
Re: RE: Re: [MyDomoAtHome] Support thread
Thanks for the reply. Could you explain in more detail though please?epierre wrote:it takes only the time of refresh you can set in the imperihome parameters.raym wrote:Hi guys, what would it take to show last tripped/updated time for motion sensors?
Please see screen shot attached...
I have "Garage Motion" set up in a Vera system. I see the time the sensor was last tripped under the security widget.
In my DZ/mdah setup, I have a similar sensor called " Office Motion" which shows either "ALARM!" when tripped or "OK". I don't ever see last tripped info. When I tap and hold the widget and tap "Details" - the last tripped info on the details page reads: "unknown".
Thanks.
- uploadfromtaptalk1454360461621.png (76.69 KiB) Viewed 2536 times
- epierre
I'll have to take a look, just remember the on/off is the triggering in Vera as there is no difference of this sort in Domoticz. Maybe I'll need your domoticz.db to see if they are both the same device or not.
I don't remeber if this was you, but someone asket about using vera as a "dongle", I've started the article
http://www.domoticz.com/wiki/VERA
raym
Thanks. Understand about on/off being a Vera thing and I"m not interested in that - just the last tripped time. I'm transitioning from Vera to Domoticz and will eventually switch it offepierre wrote:Hello,
Let me know if you'd like my db or anything else to assist you.
Than you.
- epierre
@raym yes I'll test your db please, send it to [email protected] thanks
stuiow
- Domoticz version: 3.6857
I've just installed Imperihome and have MyDomoAtHome with domoticz.
I'm missing some sensors in Imperihome at the moment though, and that's all related to Evohome.
Any chance of getting those imported and able to change them as well please?
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
- epierre
@stuiow as it is a hardware sensor, I need your database domoticz.db to be able to test it
stuiow
I sent over my DB file for you.epierre wrote:@stuiow as it is a hardware sensor, I need your database domoticz.db to be able to test it
Was that sufficient?
Many thanks
- epierre
well a kernel update broke my nvidia xorg ... not possible to test at this time...stuiow wrote:I sent over my DB file for you.epierre wrote:@stuiow as it is a hardware sensor, I need your database domoticz.db to be able to test it
stimpy
I'm having a small problem with one of my power graphs in Imperihome, connected through MDAH to Domoticz. Running latest versions of MDAH, Domoticz and Imperihome but I've noticed this for a few months now.
The above screenshot shows the widgets for my solar panels. On the left hand side (instant power, top left and daily kWh bottom left) and then in the centre are the graphs (centre top, instant power and centre bottom, daily kWh).
The first problem is that the instant power graph seems to have a very low resolution (only very few data points) whereas the data in domoticz is captured every 6 minutes or so, and domoticz shows it as a detailed graph (below): I have other graphs in Imperhome (e.g. temperature) that are working fine and have a good resolution.
Secondly, the daily kWh graph widget is created ok, then when clicked on, it results in an error.
Any help would be appreciated.
Stimpy
Stimpy
- epierre
@stimpy I would need your domoticz.db but a fresh one for the data graphs, so wait till I have resolved my computer issue before sending.
lrybak
yes please, I'm really looking forward for such featureepierre wrote:lowca wrote:Is PlanID a new feature ? if so I could automatize that.
HW: HP dc7900 USD running ESXi, RaspberryPi (few of it), AEON S2 USB stick, Fibaro modules (Dimmers, switches), 1-wire (DS18B20, DS2423), DSC Alarm with Envisalink ethernet module, MySensors, RFLink
