Page 18 of 26
Re: Python Plugin: TUYA
Posted: Wednesday 01 September 2021 20:58
by Xenomes
adelafug wrote: Wednesday 01 September 2021 19:28
{"payload":{
"devices":[],"scenes":[]},"header":{"code":"SUCCESS","payloadVersion":1}}
The devices string of the api is empty so there is noting for the plug-in to detect. Tuya is developing a new api
tuya-iot-python-sdk maybe there is a programmer that will create a Tuya plug-in around it. I only have one Tuya device left to phase out then I have only Zigbee and Tasmota converted devices.
Posted: Thursday 02 September 2021 8:58
by adelafug
Its posible flash with tasmota this device?
| PGST PB69 Tuya inteligente WiFi en casa Sensor de puerta App Ventana de notificación de protección de seguridad alerta de alarma de seguridad
https://a.aliexpress.com/_vPlJxU
Posted: Monday 13 September 2021 12:31
by rolandtwilt
I don't know if I'm good on this topic?
but I have the following question:
I bought a Tuya Zigbee gateway and connected it to Domoticz via the plugin (Tuya Cloud).
https://github.com/guino/tuyaha) followed all instructions and it seems to work....
however when starting Domoticz I get the following message:
2021-09-12 10:08:01.535 Tuya: (Tuya) Device count: 0
And so no devices were found, anyone have an idea?
Posted: Monday 13 September 2021 19:32
by Xenomes
rolandtwilt wrote: Monday 13 September 2021 12:31
The plug-in is working with the first version of the Tuya API, this version does not work with the Zigbee gateway.
Posted: Tuesday 14 September 2021 12:44
by rolandtwilt
Thanks for your comment!
Are there multiple versions?
And where can I find the right one?
Posted: Saturday 02 October 2021 9:11
by kalinkamaen
Hello i am trying to get Tuya plugin to work, but I am stuck now
I am using windows 10 PC,
About Domoticz
Version: 2021.1 (build 13669) (beta)
Build Hash: f30dc726c
Compile Date: 2021-10-01 18:47:35
dzVents Version: 3.1.8
Python Version: 3.5.2 (v3.5.2:4def2a2901a5, Jun 25 2016, 22:01:18) [MSC v.1900 32 bit (Intel)]
Domoticz find my Python but when I try to open Tuya plugin i get this error message:
2021-10-02 09:08:02.221 Error: Smartlife: (tuya) failed to load 'plugin.py', Python Path used was 'C:\Program Files (x86)\Domoticz\plugins\tuyaha-master\;C:\Program Files (x86)\Python35-32\python35.zip;C:\Program Files (x86)\Python35-32\Lib\;C:\Program Files (x86)\Python35-32\DLLs\;C:\Program Files (x86)\Domoticz;C:\Program Files (x86)\Python35-32;C:\Program Files (x86)\Python35-32\lib\site-packages'.
2021-10-02 09:08:02.221 Error: Smartlife: (Smartlife) Module Import failed, exception: 'ImportError'
2021-10-02 09:08:02.221 Error: Smartlife: (Smartlife) Module Import failed: ' Name: requests'
2021-10-02 09:08:02.221 Error: Smartlife: (Smartlife) Error Line details not available.
2021-10-02 09:08:02.221 Error: Smartlife: (Smartlife) Exception traceback:
2021-10-02 09:08:02.221 Error: Smartlife: (Smartlife) ----> Line 57 in 'C:\Program Files (x86)\Domoticz\plugins\tuyaha-master\plugin.py', function <module>
2021-10-02 09:08:02.221 Error: Smartlife: (Smartlife) ----> Line 2 in 'C:\Program Files (x86)\Domoticz\plugins\tuyaha-master\tuyaha\__init__.py', function <module>
2021-10-02 09:08:02.221 Error: Smartlife: (Smartlife) ----> Line 5 in 'C:\Program Files (x86)\Domoticz\plugins\tuyaha-master\tuyaha\tuyaapi.py', function <module>
Also a guestion, do I need gateway to make this work?
Posted: Saturday 02 October 2021 10:05
If you used this Tuya plugin
https://github.com/Xenomes/Domoticz-TUYA-Plugin (there are others) you need to install the python module "requests" too.
Posted: Saturday 02 October 2021 10:52
by kalinkamaen
I did nopt use this plugin. But now I have tried this plugin that you linked me, and installed requests with command promt pr installation guide.
And now i get this error:
2021-10-02 10:49:41.537 Error: Smart life 2: (tuya) failed to load 'plugin.py', Python Path used was 'C:\Program Files (x86)\Domoticz\plugins\Tuya\;C:\Program Files (x86)\Python35-32\python35.zip;C:\Program Files (x86)\Python35-32\Lib\;C:\Program Files (x86)\Python35-32\DLLs\;C:\Program Files (x86)\Domoticz;C:\Program Files (x86)\Python35-32;C:\Program Files (x86)\Python35-32\lib\site-packages'.
2021-10-02 10:49:41.557 Error: Smart life 2: (Smart life 2) Module Import failed, exception: 'ImportError'
2021-10-02 10:49:41.568 Error: Smart life 2: (Smart life 2) Module Import failed: ' Name: tuyaha'
2021-10-02 10:49:41.638 Error: Smart life 2: (Smart life 2) Error Line details not available.
2021-10-02 10:49:41.689 Error: Smart life 2: (Smart life 2) Exception traceback:
2021-10-02 10:49:41.729 Error: Smart life 2: (Smart life 2) ----> Line 65 in 'C:\Program Files (x86)\Domoticz\plugins\Tuya\plugin.py', function <module>
Could it be that my Tuya devices are not compatible with this plugin?
https://www.aliexpress.com/item/1005002 ... 4c4dCa0nZs
Posted: Saturday 02 October 2021 15:51
by Xenomes
kalinkamaen wrote: Saturday 02 October 2021 10:52
The Tuyaha module is missing, you need to install it see
https://github.com/Xenomes/Domoticz-TUY ... stallation
That one is unknown, some devices work with the old api some don't.
Posted: Saturday 02 October 2021 16:20
by kalinkamaen
Xenomes wrote: Saturday 02 October 2021 15:51
There is install guide for Linux. But I am using windows. WHat and how do I copy paste the files in to plugin directory?
Posted: Saturday 02 October 2021 19:42
by Xenomes
kalinkamaen wrote: Saturday 02 October 2021 16:20
You don't need to put something in the plug-in directory
install pip for python in your windows.
https://phoenixnap.com/kb/install-pip-windows then install the modules with the pip install command.
Posted: Sunday 03 October 2021 10:02
by kalinkamaen
Xenomes wrote: Saturday 02 October 2021 19:42
Thank you guys, I have managed to make it work.I am a noob so I did not know about pip. I had to download TUYA plugin, put it in directory and pip install it from directory. I was not able to install it from github.
Posted: Sunday 03 October 2021 18:36
by kalinkamaen
Any plugins for door sensors and or temperatur sensor?
Posted: Sunday 03 October 2021 22:26
by manjh
I am using TUYA Plugin v.1.0.6, this has worked flawless for several months. But suddenly I have weird problems: lamps no longer react, and the log show strange messages:
2021-10-03 22:24:53.155 (Tuya_devices) onHeartbeat called time=1633292693.1554873
2021-10-03 22:24:53.157 (Tuya_devices) in handlethread
2021-10-03 22:24:53.312 Error: (Tuya_devices) handleThread: Expecting value: line 1 column 1 (char 0) line 198
When I try to enable and disable the plugin, it freezes Domoticz. Have to go into the Pi thru Putty, stop/start Domoticz to resolve. Also strange: Domoticz restart does not work, it has to be stop/start!
Any clues?
edit: the weird part is that Domoticz was doing OK when switching the devices on earlier this evening. The problem developed during the evening!
The Tuya Smart app that I used to pair the lamps does work, although it takes several seconds before I can see the status of the lamps.
Could there be a problem in the Tuya server somehow?
Posted: Sunday 03 October 2021 22:46
by EdwinK
I just read that there was some problems with the Tuya servers.
Posted: Sunday 03 October 2021 22:47
by manjh
EdwinK wrote: Sunday 03 October 2021 22:46
Ah, that's a relief. I thought I was going crazy..
Where did you read that? Is there a way to get a status update> Would be great to know when the problem is fixed!
Posted: Monday 04 October 2021 11:24
by manjh
Looks like the Tuya people fixed the problem. This morning the app worked again, although I had to change the password. After changing it in Domoticz as well, everything was OK.
Posted: Monday 04 October 2021 20:58
by gorstj
Given server outage yesterday it highlight fragility of using the cloud
It looks like there is a new HA Tuya v2 API that may be a replacement for the python module that this plugin utilises?
https://peyanski.com/home-assistant-tuy ... -official/
It looks like it is more reliable, more features and will soon have built in local control
Will this plugin migrate to using this backend?
Posted: Monday 04 October 2021 22:06
by Xenomes
gorstj wrote: Monday 04 October 2021 20:58
I won't be creating a new plug-in with the new Tuya_V2 API and DomoticzEX, I phased out Tuya devices in my environment.
Posted: Monday 04 October 2021 22:42
by manjh
I fully agree, and I wouldgreatly appreciate a plugin that controls the Tuya devices locally, so without involving a cloud server. I know about flashing deices with Tasmota, but also read about the ongoing battle between Tuya-convert and Tuya (trying to prohibit flashing their devices).
So until there is a simple way to achieve this, I will stick to the current Tuya plugin.
I noticed a post from the author of the plugin (Xenomes) that the Tuya devices have been phased out of his house... so I guess we will have to live current version....
