lister1308
Post by lister1308 »
I have the same problem, using a minimal config. Automatic positioning also not working. I am running dashticz on a linux system with apache webserver and have domoticz running on a raspberry pi. Did you got it working?
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SE
config['domoticz_ip'] = 'http://192.168.xx.xx:8080';
config['user_name'] = 'xxxxx';
config['pass_word'] = 'xxxxx';
config['auto_positioning'] = 1;
config['use_favorites'] = 1;
config['last_update'] = 1;
config['domoticz_refresh'] = 5;
config['dashticz_refresh'] = 60;
var blocks = {}
blocks['blocktitle_domoticz'] = {}
blocks['blocktitle_domoticz']['type'] = 'blocktitle';
blocks['blocktitle_domoticz']['title'] = 'Schakelaars' ;
blocks[154] = {}
blocks[154]['title']= 'Woonkamer bank';
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_domoticz',154]
columns[1]['width'] = 3 ;
RPi with Domoticz and RFlink on USB
Fedora Linux server for web functionality
RPi with Pi-camera and connected to Domoticz
qwerk
Post by qwerk »
I am running the latest beta: 2.2
The fullscreen option is working fine. but after a dashticz reload it is back to normal size.
Is there a setting so that it starts in full screen? I could not find it in an discussion on this board.
thanks in advance
jake
Post by jake »
qwerk wrote: Saturday 10 March 2018 17:45 I am running the latest beta: 2.2
thanks in advance
I have the same issue, only Kiosk Browser is really full screen. However that browser seems to take more resources, which makes a swipe to the next page on my Tab 2 very slow in reaction.
tontze
Domoticz version: Beta Ch
Post by tontze »
Hi, dashticz is responding very slowly when switching devices from somewhere else that in dashticz, sometimes states does not update at all ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
EdwinK
Post by EdwinK »
It doesn't respond at all. Just the basic things are there atm. Weather, flipclock and the trash information. Nothing has changed on the config.
Aussi
Post by Aussi »
Hi everybody,
just installed this very nice feature on my Raspberry Pi2 to have another interface than the oldskool domoticz one.
It seems to pick up all my favorites from domoticz, very nice looking.
But now I want to do some editing of the interface. But that doesnt seem to be saved....
For example I want to change the weather location to Utrecht and setup the garbage pickup dates. I set those , save them and F5 the site
but nothing is saved. The weather location goes back to Amsterdam and my garbage details are empty again.
Any one got an idea how to troubleshoot this ? I started the interface with an almost clear CONFIG.js:
var config = {}
config['domoticz_ip'] = 'https://192.168.0.13:443';
And even after saving the interface the CONFIG.js stays the same like above. Altho the interface is showing my domoticz favorites.... :/
May be some one can give me some tips and tricks :D
htilburgs
Post by htilburgs »
Hardware:
Aussi
Post by Aussi »
htilburgs wrote: Wednesday 14 March 2018 9:07 Have you tried the Wiki :D - http://www.domoticz.com/wiki/Dashticz_V2
Yes and I found out that php needs to be enabled. Altho I am also reading that php cant be enabled within domoticz on the RPi to be used for dashticz.
so that's kind of the struggle ;) or maybe its not true what I just mentioned?
aiolos
Domoticz version: stable
Post by aiolos »
hsvt wrote: Sunday 25 February 2018 20:07
joostnl wrote: Monday 19 February 2018 22:07
Wob76 wrote: Friday 16 February 2018 3:22
Is this possible yet?
+1 would really safe space
This should be really nice.
In Domoticz it is one block.
In the latest beta it is possible to combine Temp/Humidity/Barometer in one block. There is a configuration option per block, for example:
blocks[3441] = {single_block: true};
will combine the values in one block for idx 3441.
There is no general setting to change this for all blocks.
Let me know if there are any issues with it.
Contributor to Dashticz
More on my Github profile
Aussi
Post by Aussi »
So have been struggling some more with how to implement dashticz.
Got some more succes with it but also lost my domoticz page :/
Managed to get it working by installing apache server on my raspberry but that also kicked the domoticz page out :/
I cannot believe this is the good way to go because this stuff is also not mentioned on the Wiki?
I also want to reach the Dashticz interface from outside my home network so that might also be a though one
any one got any bright tips :D?
pollefinario
Post by pollefinario »
Hi All,
Been using Dashticz for a while now and its great.
However since a coupe of days it won't load any devices. It's running on my home server. I've tried a fresh install but that gives the same results.
This are the errors I could find:
Domoticz runs on the latest Beta and nothing is changed with regards to the domoticz url.
Any thoughts? Thanks!
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Hi Folks,
I am trying to get this wonderful dashboard to work.
Followed the wiki to install, altered ip and port but I get no Favourite switches.
it keeps on saying Loading.
What do I do wrong?
my config:
var config = {}
config['domoticz_ip'] = 'http://xx.xxx.xx:8080';
config['pass_word'] = 'xxxxxxx';
config['loginEnabled'] = 1;
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var _STREAMPLAYER_TRACKS  	= [
	{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
	{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
	{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
	{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.nunl = {key: 'nunl',  width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos',  width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Example';
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather','garbage']
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',tvguide.dutch,publictransport.ovinfobus]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise','streamplayer',buttons.nunl,buttons.nos]
columns[3]['width'] = 2;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
any help is highly appreciated
JuanUil
Post by JuanUil »
Nobody can help me? :roll:
pollefinario
Juan, Our errors look more or less the same. Not getting any data from domoticz...
What does your Inspector say? (in chrome on windows ctrl - shift - I ), same errors as me?
DewGew
Domoticz version: V4.10618
Post by DewGew »
You can delete this:
var trashnames = {}
Its not in use anymore. Might not help you but its a start.
dennis075
Post by dennis075 »
Got the same problems as pollefinario, domoticz error. Running the latest beta. Is there a fix for this problem?
DewGew
Post by DewGew »
This is could be a security issue with Domoticz. Login on your browser in Domoticz and then try to use Dashticz in same tab.
JuanUil
Post by JuanUil »
Tried that already but no success. Also tried another browser also no success
pollefinario
No results for me either...
JuanUil
Post by JuanUil »
Are there more members with this problem?
Locked
