Page 17 of 17
Re: Alexicz - FREE Domoticz to Alexa Integration
Posted: Tuesday 01 August 2023 16:36
by vco1
Jorn wrote: Tuesday 28 February 2023 20:32 For the ones that are also getting the "Is not responding" response when activating/deactivating groups/scene's I found a solution.
In AlexaSmartHome.py on line 454 and 466 change
'timestamp': '%sZ' % (datetime.utcnow().isoformat(),)
into
'timestamp': '%sZ' % (datetime.utcnow().isoformat(sep='T', timespec='seconds'),)
It has to do that Python also puts in the microseconds in the time format and Alexa expects a response in a format without it.
I found it in this thread: https://github.com/home-assistant/core/pull/56469
Thank you. Working like a charm!
Posted: Friday 11 August 2023 17:55
by RhondaGreen
Hello!
It has to do it Python also puts microseconds in the time format and Alexa expects the response in a format that doesn't have it.
I found it in this thread: [url=https://.com/hole-house-apk]hole house apk español[/url]
This post should be on the wiki, moderators please add it.
Posted: Tuesday 22 August 2023 11:03
by cogliostrio
Im trying to migrate from controlicz, and have followed the v3 guide. But Im getting an error when running the discovery test in the lambda function. Does anyone have any pointers as to what the issue might be?
  "errorMessage": "'directive'",
  "errorType": "KeyError",
  "requestId": "592ffb65-c1e4-442c-847b-4c0bbaf1b383",
  "stackTrace": [
    "  File \"/var/task/lambda.py\", line 49, in event_handler\n    response =  AlexaSmartHome.handle_message(dzRemote, request)\n",
    "  File \"/var/task/AlexaSmartHome.py\", line 320, in handle_message\n    message = message[API_DIRECTIVE]\n"
Posted: Saturday 26 August 2023 8:31
by Deanm
I had that same problem.
Are you running the inbuilt discovery? You need to cut and past the JSON Config from the install guide.
Deanm
Posted: Thursday 07 December 2023 11:26
by andromo
Hello everyone.
I have been using the beautiful Alexicz Lambda for a few years.
Suddenly it starts to fail. Some basic on/off commands timed out (alexa says the device is not responding). But when I try again, it eventually works.
Do you know if something has changed in AWS? I don't know why it doesn't work consistently. I have removed my port knocking strategy (3 tcp ports in a row) and opened the port to domoticz to simplify communication, but no better results.
I can see in my router firewall nat rules that when the timeout happens the packets don't reach my home, so: something is failing in the lambda?. Any ideas?
Thank you
Posted: Tuesday 12 December 2023 12:59
by andromo
Ok, never mind. It looks like after few days, the things have come to normal and it works well. ¿?
Posted: Saturday 08 June 2024 2:26
by juankar
I've been using this integration for my domoticz system for years, but a week ago it stopped working: Server doesn't respond
Domoticz works ok, from local and remote.
Then I created the skill again, but now I cannot activate the skill in my alexa app. It says that needs link an account, I follow every step, login Amazon but at the end I receive the message it was not possible to link the account with Alexa.
My amazon developer and aws are the same account.
Does anyone know where can be the error?
Thanks.
Posted: Saturday 08 June 2024 12:14
by juankar
Well, I cannot link to skill so I cannot use with my alexa :(
But testing in aws I get an internal error:
START RequestId: 45ff56eb-eb0b-48d9-bdf0-20959c07751d Version: $LATEST
Domoticz API call %s https://myexternalacces.com/json.htm?ty ... &used=true
Domoticz API call %s https://myexternalacces.com/json.htm?type=scenes
File "/var/task/AlexaSmartHome.py", line 336, in invoke
return operator.attrgetter(name)(self)(request)
File "/var/task/AlexaSmartHome.py", line 347, in Discover
endpoints = self.handler.getEndpoints()
File "/var/task/DomoticzHandler.py", line 389, in getEndpoints
scenes= response['result']
KeyError: 'result'
END RequestId: 45ff56eb-eb0b-48d9-bdf0-20959c07751d
REPORT RequestId: 45ff56eb-eb0b-48d9-bdf0-20959c07751d Duration: 757.81 ms Billed Duration: 758 ms Memory Size: 128 MB Max Memory Used: 49 MB
When I access with chrome I didn't get any error
Posted: Saturday 08 June 2024 18:26
by juankar
i've fixed the last error. Setting scenes to false. I have not scenes so the script throw an error, instead of send an empty response or so.
No I get all th devices in test script inside skill, but....
The linkng account.... it's impodsible. I cant link my account with the skill and so I cant use it from my alexa. :(
Th log show this error when I try to link the skill from alexa
2024-06-08T11:44:54.553Z START RequestId: b94e69a7-a139-4caa-827f-4ba0be12d8f5 Version: $LATEST
2024-06-08T11:44:54.772Z [ERROR] 2024-06-08T11:44:54.772Z b94e69a7-a139-4caa-827f-4ba0be12d8f5 Can't process Alexa.Authorization/AcceptGrant
2024-06-08T11:44:54.792Z END RequestId: b94e69a7-a139-4caa-827f-4ba0be12d8f5
Does anyone know a solution or any idea about his error?
Posted: Wednesday 19 March 2025 15:35
by DrMacabre
Hello everyone,
I've been using alexicz fo years without any particular issue but all of a sudden after having recently updated domoticz, i've lost the ability to interrogate my temps sensor with alexa. The sensor are still present in domoticz and fully functional but they appear broken in alexa. I tried rediscovering and they don't even show up anymore.
Had anyone else experienced something similar ? My setup is rather old and i don't know exactly where to start to look for the issue.
Posted: Wednesday 19 March 2025 16:38
by philchillbill
I’d start out by examining the Cloudwatch Logs for the skill to see if the skill is even being invoked. Do the thermostats show up int the Alexa app after you ask to discover devices?
Posted: Wednesday 19 March 2025 16:43
by DrMacabre
philchillbill wrote: Wednesday 19 March 2025 16:38 I’d start out by examining the Cloudwatch Logs for the skill to see if the skill is even being invoked. Do the thermostats show up int the Alexa app after you ask to discover devices?
The rest of the switches still works within the skill, the thermostats don't show up anymore after discovery.
Posted: Monday 12 May 2025 15:01
by vco1
For me discovery of new switches stopped completely.
Posted: Monday 12 May 2025 15:04
by vco1
juankar wrote: Saturday 08 June 2024 18:26 i've fixed the last error. Setting scenes to false. I have not scenes so the script throw an error, instead of send an empty response or so.
I found this on the (old) Alexicz (dz_smatyhome) Github page.
Replace following (#) in DomoticzHandler.py to use with a current (2025) domoticz version:
#response = self.api('type=devices&used=true')
response = self.api('type=command&param=getdevices&used=true')
#return self.api('type=devices&rid=%s'%idx)['result'][0]
return self.api('type=command&param=getdevices&rid=%s'%idx)['result'][0]
Posted: Tuesday 13 May 2025 11:39
by vco1
vco1 wrote: Monday 12 May 2025 15:01 For me discovery of new switches stopped completely.
Fixed.
In DomoticzHandler.py make the following change:
# response = self.api('type=scenes')
response = self.api('type=command&param=getscenes')
Posted: Tuesday 13 May 2025 12:02
by DrMacabre
vco1 wrote: Tuesday 13 May 2025 11:39
Fixed.
where do you find domoticzhandler.py ?
Posted: Tuesday 13 May 2025 22:25
by vco1
DrMacabre wrote: Tuesday 13 May 2025 12:02 where do you find domoticzhandler.py ?
In your AWS Lambda function.
Posted: Sunday 02 November 2025 3:19
by dwmw2
I'd been using Madgeni's original alexa_domo for years, but the Smart Home API v2 is finally being turned off next week so I've spent some time updating it. And making it use the OAuth2 server that Domoticz now has built-in, so the account linking can log in directly to Domoticz instead of having to set up a fake Amazon login. https://git.infradead.org/?p=users/dwmw ... ;a=summary
