Page 14 of 16
RE: Python Plugin: GoodWe solar inverter via SEMS API
Posted: Tuesday 30 December 2025 10:56
Jeweettoch13 wrote: Tuesday 30 December 2025 10:36 Hello fellow members.
For some reason i got some errors today when requesting the data from the Goodwe SEMS plugin. Do you guys know what this means?
Update the plugin, see also https://github.com/JanJaapKo/domoticz-G ... /issues/30
Re: RE: Python Plugin: GoodWe solar inverter via SEMS API
Posted: Tuesday 30 December 2025 11:04
by Jeweettoch13
waltervl wrote: Tuesday 30 December 2025 10:56
Replaced the file in Domoticz plugins, but no luck:
2025-12-30 11:03:41.058 Error: (FindModule) Domoticz and DomoticzEx modules both found in interpreter, use one or the other.
2025-12-30 11:03:41.058 Error: Goodwe SEMS: Call to function 'onHeartbeat' failed, exception details:
2025-12-30 11:03:41.059 Error: Goodwe SEMS: Traceback (most recent call last):
2025-12-30 11:03:41.059 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 459, in onHeartbeat
2025-12-30 11:03:41.059 Error: Goodwe SEMS: _plugin.onHeartbeat()
2025-12-30 11:03:41.059 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 370, in onHeartbeat
2025-12-30 11:03:41.059 Error: Goodwe SEMS: elif len(Parameters["Mode1"]) == 0:
2025-12-30 11:03:41.059 Error: Goodwe SEMS: ^^^^^^^^^^
2025-12-30 11:03:41.059 Error: Goodwe SEMS: NameError: name 'Parameters' is not defined
Re: Python Plugin: GoodWe solar inverter via SEMS API
Posted: Tuesday 30 December 2025 11:11
Did you restart Domoticz?
Posted: Tuesday 30 December 2025 11:15
by Jeweettoch13
waltervl wrote: Tuesday 30 December 2025 11:11 Did you restart Domoticz?
Yes i did. Only copy paste the file. Don't know if that's sufficient.
Posted: Tuesday 30 December 2025 11:23
What file? The plugin.py or the Goodwe.py or both?
In your case it looks like Domoticz is confused now about the plugin.py.
You are running Domoticz in Docker it looks like so not sure how to restart properly.
Posted: Tuesday 30 December 2025 11:26
by Jeweettoch13
waltervl wrote: Tuesday 30 December 2025 11:23 What file? The plugin.py or the Goodwe.py or both?
I copied the one provided by jeannot171 (GoodWe.py)
also copied just the plugin file,It's working :).
I see on a sidenote that new sensors have been made, but need the old log on the new sensors. Is this achieved by restoring the backup data?
Posted: Tuesday 30 December 2025 11:52
Jeweettoch13 wrote: Tuesday 30 December 2025 11:26
You could use the device replace function to move the history in the new device: https://wiki.domoticz.com/Managing_Devi ... ace_device
Posted: Tuesday 30 December 2025 12:06
by Jeweettoch13
waltervl wrote: Tuesday 30 December 2025 11:52
That should work indeed, if not turning the complete system haywire:
2025-12-30 12:03:17.255 Error: Goodwe SEMS: ~~~~~~~~~~~~~~~~~~~~~^^^^^^
2025-12-30 12:03:17.255 Error: Goodwe SEMS: KeyError: 2
2025-12-30 12:03:27.742 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/2) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/4) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/5) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/6) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/14) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/7) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/8) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/15) already exists in Domoticz.
2025-12-30 12:03:27.747 Error: Goodwe SEMS: Call to function 'onHeartbeat' failed, exception details:
2025-12-30 12:03:27.749 Error: Goodwe SEMS: Traceback (most recent call last):
2025-12-30 12:03:27.749 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 519, in onHeartbeat
2025-12-30 12:03:27.749 Error: Goodwe SEMS: _plugin.onHeartbeat()
2025-12-30 12:03:27.749 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 413, in onHeartbeat
2025-12-30 12:03:27.749 Error: Goodwe SEMS: self.startDeviceUpdateV2()
2025-12-30 12:03:27.754 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 175, in startDeviceUpdateV2
2025-12-30 12:03:27.754 Error: Goodwe SEMS: self.updateDevices(DeviceData)
2025-12-30 12:03:27.755 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 199, in updateDevices
2025-12-30 12:03:27.755 Error: Goodwe SEMS: UpdateDevice(inverter["sn"], theInverter.outputCurrentUnit, 0, str(inverter["output_current"]), AlwaysUpdate=True)
2025-12-30 12:03:27.755 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 559, in UpdateDevice
2025-12-30 12:03:27.755 Error: Goodwe SEMS: logging.debug("Updating device '"+Devices[Device].Units[Unit].Name+ "' with current sValue '"+Devices[Device].Units[Unit].sValue+"' to '" +sValue+"'")
Luckily a backed up the database so can convert back easily.
Edit* Got it working. I restart the container per edit, and that works. Tnx for the help :)
Posted: Wednesday 23 September 2026 15:45
by Jeweettoch13
Hello all,
i got a error on the Sems plugin again (maybe because they went to Sems+ a short while ago)
Began around 4:20AM this morning.
From the Sems+ portal the data is visible.
I'm on v5.0 plugin
Posted: Wednesday 23 September 2026 17:59
by JanJaap
I'm aware of the issue, it has something to do with the authentication on the Goodwe server. Looking for a solution....
See Github - issue 36
Posted: Thursday 24 September 2026 9:44
by RNEE
Same problem here, but I can't fix it.
This is a known issue, and this post might help us out: https://www.zonstraal.be/forum/viewtopic.php?p=352091
The GoodWe API documentation is available here: https://openapi.goodwe.com/#api/doc-10a71afe72c271
Do I understand correctly that a fixed authentication token must now be included?
Posted: Thursday 24 September 2026 17:37
by Jeweettoch13
RNEE wrote: Thursday 24 September 2026 9:44 Same problem here, but I can't fix it.
Seems that the Anton version is working, but where to put the code?
Posted: Thursday 24 September 2026 17:51
by RNEE
I (and Ai) have now a dzVents script what the total load in a parameter with idx 2954.
Connection and data retrieval works now !
But I have to work more things out.
        timer = {
            'every 1 minutes' -- Haalt elke 1 minuten data op
    logging = {
        level = domoticz.LOG_INFO,
        marker = 'SEMS_PLUS'
        -- CONFIGURATIE (PAS DIT AAN JOUW GEGEVENS AN)
        local semsUser     = 'user@sems'
        local semsPassword = 'password_of_user'
        local domoticzIdx  = 2954 -- Het Idx nummer van het virtuele apparaat
        local inverterNo   = 0  -- 0 = eerste omvormer, 1 = tweede, etc.
        -- De correcte Europese Gateway endpoints voor SEMS+
        local baseUrl  = 'https://eu-gateway.semsportal.com'
        local loginUrl = baseUrl .. '/web/sems/sems-user/api/v1/auth/cross-login'
        local dataUrl  = baseUrl .. '/web/sems/sems-plant/api/web/device/centralized/page'
        domoticz.log('Starten met ophalen van de gegevens via SEMS+...', domoticz.LOG_INFO)
        -- 1. Wachtwoord versleutelen (MD5 -> Base64) via de Linux terminal
        local cmdEncrypt = 'echo -n "' .. semsPassword .. '" | md5sum | cut -d" " -f1 | tr -d "\\n" | base64 | tr -d "\\n"'
        local handleEnc = io.popen(cmdEncrypt)
        local encryptedPassword = handleEnc:read("*a"):gsub("%s+", "")
        handleEnc:close()
        -- 2. Inloggen en Token ophalen
        local loginPayload = domoticz.utils.toJSON({
            account = semsUser,
            pwd = encryptedPassword,
            isChinese = false,
            agreement = 1,
            isLocal = true
        -- Schone curl-aanroep voor inloggen
        local cmdLogin = 'curl --silent --insecure --location --request POST "' .. loginUrl .. '" ' ..
                         '--header "Content-Type: application/json" ' ..
                         '--header "Accept: application/json, */*" ' ..
                         '--header "token: {\\"uid\\":\\"\\",\\"timestamp\\":0,\\"token\\":\\"\\",\\"client\\":\\"semsPlusWeb\\",\\"version\\":\\"\\",\\"language\\":\\"en\\"}" ' ..
                         '--data \'' .. loginPayload .. '\''
        local handleLogin = io.popen(cmdLogin)
        local loginResult = handleLogin:read("*a")
        handleLogin:close()
        -- Controleer of er een netwerkrespons is
        if (not loginResult or loginResult == "") then
            domoticz.log('Geen netwerkrespons ontvangen van de inlogserver.', domoticz.LOG_ERROR)
            return
        local loginJson = domoticz.utils.fromJSON(loginResult)
        -- Controleer of de login succesvol is verwerkt (Code 00000)
        if (loginJson and loginJson.code == '00000' and loginJson.data) then
            domoticz.log('Login op de EU Gateway succesvol! Token gegenereerd.', domoticz.LOG_INFO)
            local d = loginJson.data
            local tokenHeader = domoticz.utils.toJSON({
                uid = d.uid,
                timestamp = d.timestamp,
                token = d.token,
                client = "semsPlusWeb",
                version = d.version or "",
                language = d.language or "en",
                region = d.region or ""
            -- 3. Data opvragen met het verkregen token uit Stap 2
            local dataPayload = '{"deviceTypeList":["INVERTER"],"current":1,"size":10}'
            local cmdData = 'curl --silent --insecure --location --request POST "' .. dataUrl .. '" ' ..
                            '--header "token: ' .. tokenHeader:gsub('"', '\\"') .. '" ' ..
                            '--data \'' .. dataPayload .. '\''
            local handleData = io.popen(cmdData)
            local dataResult = handleData:read("*a")
            handleData:close()
            local dataJson = domoticz.utils.fromJSON(dataResult)
            -- 4. Gegevens valideren en wegschrijven naar de Domoticz sensor
            if (dataJson and dataJson.code == '00000' and dataJson.data and dataJson.data.dataList) then
                local dataList = dataJson.data.dataList
                -- Correcte navigatie door de SEMS+ array: dataList[1] -> children[1]
                if (dataList[1] and dataList[1].children and dataList[1].children[1]) then
                    local dev = dataList[1].children[1]
                    local pAc       = tonumber(dev.pAc) or 0         -- Actueel vermogen (kW)
                    local proToday  = tonumber(dev.proToday) or 0    -- Dagopbrengst (kWh)
                    -- Omrekenen naar Watts en Watt-uren voor Domoticz
                    local wattActueel = math.floor(pAc * 1000)
                    local whTotaal    = math.floor(proToday * 1000)
                    domoticz.log('SEMS+ Data succesvol verwerkt -> Actueel: ' .. wattActueel .. ' W | Vandaag: ' .. proToday .. ' kWh', domoticz.LOG_INFO)
                    -- Update de virtuele sensor (Formaat: ActueelVermogen;TotaalWh)
                    domoticz.devices(domoticzIdx).updateElectricity(wattActueel, whTotaal)
                    domoticz.log('Geen actieve installatie of omvormer gevonden in dataList structure.', domoticz.LOG_ERROR)
                domoticz.log('Fout bij het ophalen van de installatiedata. Response: ' .. tostring(dataResult), domoticz.LOG_ERROR)
            domoticz.log('Inloggen op SEMS+ geweigerd. Response van server: ' .. tostring(loginResult), domoticz.LOG_ERROR)
Posted: Thursday 24 September 2026 17:58
by Jeweettoch13
RNEE wrote: Thursday 24 September 2026 17:51 I (and Ai) have now a dzVents script what the total load in a parameter with idx 2954.
        timer = {
    logging = {
        handleEnc:close()
            account = semsUser,
            isChinese = false,
            agreement = 1,
            isLocal = true
        handleLogin:close()
            return
                uid = d.uid,
                token = d.token,
            handleData:close()
Is this piece of code anywhere to put in a current .py file?
Posted: Thursday 24 September 2026 18:47
by RNEE
It is a standalone dzVents script. It is put in Events. It is not a python .py program.
Now this works maybe JanJaap can use the info from the script to change it to the plugin.
Posted: Thursday 24 September 2026 23:31
by JanJaap
I just pushed an update. But if I read the other blogs correctly, there is no data when the inverters are not active. And it is now 23:30.... I'll check tomorrow morning but likely only have time to fix tomorrow evening. Feel free to pull latest version of plugin and test
Posted: Friday 25 September 2026 0:19
by RNEE
JanJaap wrote: Thursday 24 September 2026 23:31 I just pushed an update. But if I read the other blogs correctly, there is no data when the inverters are not active. And it is now 23:30.... I'll check tomorrow morning but likely only have time to fix tomorrow evening. Feel free to pull latest version of plugin and test
Thank you for your work!
I will test it tomorrow.
Posted: Friday 25 September 2026 6:27
by Jeweettoch13
Much appreciated!
The inverter is in waiting mode but not present in Domoticz at the moment
Posted: Friday 25 September 2026 8:27
by JanJaap
Same here, so I guess I need to give Copilot some more instructions.....
At least the amount of error loglines has been reduced :ugeek:
Posted: Friday 25 September 2026 9:57
by RNEE
Update indeed not working. :x
I used Google AI to make the dzVents script but i had many repeating faults / corrections to make in the process and more detailed instructions to give before it worked.
I think my dzVents script can be used to instruct Copilot ?
I know the dzVents script is not ready for production but it is a start.
