Update the plugin, see also https://github.com/JanJaapKo/domoticz-G ... /issues/30Jeweettoch13 wrote: Tuesday 30 December 2025 10:36 Hello fellow members.
For some reason i got some errors today when requesting the data from the Goodwe SEMS plugin. Do you guys know what this means?
Python Plugin: GoodWe solar inverter via SEMS API
- Domoticz version: 2025.1
RE: Python Plugin: GoodWe solar inverter via SEMS API
Jeweettoch13
- Domoticz version: 2025.2
Re: RE: Python Plugin: GoodWe solar inverter via SEMS API
Replaced the file in Domoticz plugins, but no luck:waltervl wrote: Tuesday 30 December 2025 10:56Update the plugin, see also https://github.com/JanJaapKo/domoticz-G ... /issues/30Jeweettoch13 wrote: Tuesday 30 December 2025 10:36 Hello fellow members.
2025-12-30 11:03:41.058 Error: (FindModule) Domoticz and DomoticzEx modules both found in interpreter, use one or the other.
2025-12-30 11:03:41.058 Error: Goodwe SEMS: Call to function 'onHeartbeat' failed, exception details:
2025-12-30 11:03:41.059 Error: Goodwe SEMS: Traceback (most recent call last):
2025-12-30 11:03:41.059 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 459, in onHeartbeat
2025-12-30 11:03:41.059 Error: Goodwe SEMS: _plugin.onHeartbeat()
2025-12-30 11:03:41.059 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 370, in onHeartbeat
2025-12-30 11:03:41.059 Error: Goodwe SEMS: elif len(Parameters["Mode1"]) == 0:
2025-12-30 11:03:41.059 Error: Goodwe SEMS: ^^^^^^^^^^
2025-12-30 11:03:41.059 Error: Goodwe SEMS: NameError: name 'Parameters' is not defined
Re: Python Plugin: GoodWe solar inverter via SEMS API
Did you restart Domoticz?
Jeweettoch13
Yes i did. Only copy paste the file. Don't know if that's sufficient.
What file? The plugin.py or the Goodwe.py or both?
In your case it looks like Domoticz is confused now about the plugin.py.
You are running Domoticz in Docker it looks like so not sure how to restart properly.
Jeweettoch13
I copied the one provided by jeannot171 (GoodWe.py)waltervl wrote: Tuesday 30 December 2025 11:23 What file? The plugin.py or the Goodwe.py or both?
also copied just the plugin file,It's working
I see on a sidenote that new sensors have been made, but need the old log on the new sensors. Is this achieved by restoring the backup data?
You could use the device replace function to move the history in the new device: https://wiki.domoticz.com/Managing_Devi ... ace_deviceJeweettoch13 wrote: Tuesday 30 December 2025 11:26I copied the one provided by jeannot171 (GoodWe.py)waltervl wrote: Tuesday 30 December 2025 11:23 What file? The plugin.py or the Goodwe.py or both?
also copied just the plugin file,It's working.
Jeweettoch13
That should work indeed, if not turning the complete system haywire:waltervl wrote: Tuesday 30 December 2025 11:52You could use the device replace function to move the history in the new device: https://wiki.domoticz.com/Managing_Devi ... ace_deviceJeweettoch13 wrote: Tuesday 30 December 2025 11:26I copied the one provided by jeannot171 (GoodWe.py)waltervl wrote: Tuesday 30 December 2025 11:23 What file? The plugin.py or the Goodwe.py or both?
2025-12-30 12:03:17.255 Error: Goodwe SEMS: ~~~~~~~~~~~~~~~~~~~~~^^^^^^
2025-12-30 12:03:17.255 Error: Goodwe SEMS: KeyError: 2
2025-12-30 12:03:27.742 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/2) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/4) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/5) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/6) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/14) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/7) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/8) already exists in Domoticz.
2025-12-30 12:03:27.743 Error: Goodwe SEMS: (Goodwe SEMS) Unit creation failed, Hardware/DeviceID/Unit combination (5/56000DTS205W0092/15) already exists in Domoticz.
2025-12-30 12:03:27.747 Error: Goodwe SEMS: Call to function 'onHeartbeat' failed, exception details:
2025-12-30 12:03:27.749 Error: Goodwe SEMS: Traceback (most recent call last):
2025-12-30 12:03:27.749 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 519, in onHeartbeat
2025-12-30 12:03:27.749 Error: Goodwe SEMS: _plugin.onHeartbeat()
2025-12-30 12:03:27.749 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 413, in onHeartbeat
2025-12-30 12:03:27.749 Error: Goodwe SEMS: self.startDeviceUpdateV2()
2025-12-30 12:03:27.754 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 175, in startDeviceUpdateV2
2025-12-30 12:03:27.754 Error: Goodwe SEMS: self.updateDevices(DeviceData)
2025-12-30 12:03:27.755 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 199, in updateDevices
2025-12-30 12:03:27.755 Error: Goodwe SEMS: UpdateDevice(inverter["sn"], theInverter.outputCurrentUnit, 0, str(inverter["output_current"]), AlwaysUpdate=True)
2025-12-30 12:03:27.755 Error: Goodwe SEMS: File "/opt/domoticz/userdata/plugins/domoticz-GoodWeSEMS/plugin.py", line 559, in UpdateDevice
2025-12-30 12:03:27.755 Error: Goodwe SEMS: logging.debug("Updating device '"+Devices[Device].Units[Unit].Name+ "' with current sValue '"+Devices[Device].Units[Unit].sValue+"' to '" +sValue+"'")
Luckily a backed up the database so can convert back easily.
Edit* Got it working. I restart the container per edit, and that works. Tnx for the help
