Domoticz Google Assistant integration with node-red Easy Free Controlicz alternative!
Alexa, Google Home and Siri
FireWizard
Re: Domoticz Google Assistant integration with node-red Easy Free Controlicz alternative!
Post by FireWizard »
Hello @manjh
I now have Nora running for five devices. If I install Google-SmartHome on a separate Pi, will these two work in parallel?
I assume, you mean SmartNora and not the old Nora.
Do they work in parallel?
That will depend on the names, you use.
You can't have e.g. two Switches, both called "Switch" in your "Living Room", but you can have "Switch1" and "Switch2" in the "Living Room"
If you are satisfied, you can delete the SmartNora "Switch" and then rename the other "Switch".
manjh
Domoticz version: 2025.2
Post by manjh »
FireWizard wrote: Monday 27 March 2023 15:11 Hello @manjh
No, I meant the "old" free Nora version...
Hans
FireWizard
Hi @manjh,
This is the same. I'm surprised that the old Nora still works.
Use different names and you will not run into problems.
CronoS
Post by CronoS »
Setup Smart Nora and worked with little effort I must say. I am a free Nora user, so I can only control 5 devices with this license, but for me that is more then enough because I use Google Assistant only for some devices.
