Domoticz Google Assistant integration with node-red Easy Free Controlicz alternative!
Alexa, Google Home and Siri
legacy1981
Post by legacy1981 »
Hi Guys,
I found a new node for node-red which enables Google home integration very very easy and free!!.
https://flows.nodered.org/node/node-red-contrib-nora
I'm not a programmer. But i managed to get it working with MQTT in and out. So it works both ways. You just bind your google account to the node and add NORA to your google home app. Next the numbers in the switches and the "topic" in the node needs to match the domoticz IDX which you want to control.
You can add as many google assistant devices as you want. Works like a charm!!
Here is my example flow.
[{"id":"4528e53.782fb1c","type":"mqtt in","z":"fd35c454.ee407","name":"","topic":"domoticz/out","qos":"2","broker":"34e4d2fc.90d346","x":70,"y":440,"wires":[["3e9a9a76.9cb2f6"]]},{"id":"3e9a9a76.9cb2f6","type":"json","z":"fd35c454.ee407","name":"","property":"payload","action":"","pretty":false,"x":230,"y":440,"wires":[["681631c8.dbc208","738ce63c.4f5c3"]]},{"id":"681631c8.dbc208","type":"switch","z":"fd35c454.ee407","name":"","property":"payload.switchType","propertyType":"msg","rules":[{"t":"cont","v":"On/Off","vt":"str"},{"t":"eq","v":"Dimmer","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":440,"wires":[["f9798848.30054"],["e3793bc5.9aa94"]]},{"id":"f9798848.30054","type":"function","z":"fd35c454.ee407","name":"Function In on/off","func":"msg.topic = msg.payload.idx\nif (msg.payload.nvalue == 1)\n{\n    msg.payload = true\n}\nelse if (msg.payload.nvalue === 0)\n{\n    msg.payload = false\n}\n    return msg;\n","outputs":1,"noerr":0,"x":550,"y":380,"wires":[["c7d42d19.b2e198"]]},{"id":"e3793bc5.9aa94","type":"function","z":"fd35c454.ee407","name":"Function Dimmer","func":"msg.topic = msg.payload.idx\nvar brightness = msg.payload.svalue1\nif (msg.payload.nvalue === 1)\n{\n    msg.payload = 100\n}\nelse if (msg.payload.nvalue === 0)\n{\n    msg.payload = 0\n}\nelse if (msg.payload.nvalue === 2)\n{\n    msg.payload = brightness\n}\n    return msg;\n\n","outputs":1,"noerr":0,"x":550,"y":480,"wires":[["b8c784d7.203388"]]},{"id":"c7d42d19.b2e198","type":"switch","z":"fd35c454.ee407","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"158","vt":"str"},{"t":"eq","v":"168","vt":"str"},{"t":"eq","v":"620","vt":"str"},{"t":"eq","v":"176","vt":"str"},{"t":"eq","v":"365","vt":"str"},{"t":"eq","v":"482","vt":"str"},{"t":"eq","v":"349","vt":"str"},{"t":"eq","v":"530","vt":"str"},{"t":"eq","v":"336","vt":"str"}],"checkall":"true","repair":false,"outputs":9,"x":750,"y":260,"wires":[["2829642d.fb748c"],["9a731c14.437d5"],["3e545d4c.299352"],["39746777.4cd46"],["72282919.51404"],["ff689805.dc7098"],["160ad1c9.3c1426"],["b1ca6005.2e93f"],["d100ba7b.ea6938"]]},{"id":"b8c784d7.203388","type":"switch","z":"fd35c454.ee407","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"113","vt":"str"},{"t":"eq","v":"516","vt":"str"},{"t":"eq","v":"92","vt":"str"},{"t":"eq","v":"144","vt":"str"},{"t":"eq","v":"610","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":750,"y":800,"wires":[["257f1795.0e50f8"],["dba00889.f2775"],["c67e2421.cbd0d"],["c9ac25c4.1eaaf"],["e7f419af.b6062"]]},{"id":"257f1795.0e50f8","type":"nora-light","z":"fd35c454.ee407","devicename":"Keuken","lightcolor":false,"brightnesscontrol":true,"passthru":false,"statepayload":false,"brightnessoverride":"100","roomhint":"Keuken","name":"Keuken","nora":"48bacfcb.9887b8","topic":"113","onvalue":"true","onvalueType":"bool","offvalue":"false","offvalueType":"bool","x":920,"y":780,"wires":[["a1c7a6cf.d4bcb"]]},{"id":"39746777.4cd46","type":"nora-switch","z":"fd35c454.ee407","devicename":"het Haardvuur","roomhint":"Woonkamer","name":"Haardvuur","passthru":false,"nora":"48bacfcb.9887b8","topic":"176","onvalue":"true","onvalueType":"bool","offvalue":"false","offvalueType":"bool","x":930,"y":300,"wires":[["805526ff.cf4d08"]]},{"id":"805526ff.cf4d08","type":"function","z":"fd35c454.ee407","name":"Function out On/Off","func":"var idx = parseInt(msg.topic);\nif ( msg.payload === true )\n{\nmsg.payload = { \"command\": \"switchlight\", \"idx\": idx, \"switchcmd\": \"On\" };\n}\nelse if ( msg.payload === false )\n{\nmsg.payload = { \"command\": \"switchlight\", \"idx\": idx, \"switchcmd\": \"Off\" };\n}\nreturn msg\n","outputs":1,"noerr":0,"x":1380,"y":280,"wires":[["7d584545.8c9544"]]},{"id":"a1c7a6cf.d4bcb","type":"function","z":"fd35c454.ee407","name":"Function out Dimmer","func":"var idx = parseInt(msg.topic)\nvar brightness = msg.payload\nif ( msg.payload === 0 )\n{\nmsg.payload = { \"command\": \"switchlight\", \"idx\": idx, \"switchcmd\": \"Off\" };\nreturn [msg, null]\n}\nelse\n{\nmsg.payload = { \"command\": \"switchlight\", \"idx\": idx, \"switchcmd\": \"Set Level\", \"level\": brightness };\nreturn [null, msg]\n}\n\n\n","outputs":2,"noerr":0,"x":1300,"y":700,"wires":[["7d584545.8c9544"],["7d584545.8c9544"]]},{"id":"55a04197.0e6f9","type":"nora-scene","z":"fd35c454.ee407","devicename":"beveiliging","roomhint":"","scenereversible":true,"name":"beveiliging","nora":"48bacfcb.9887b8","topic":"5","onvalue":"true","onvalueType":"bool","offvalue":"false","offvalueType":"bool","x":920,"y":1180,"wires":[["e63a5889.fbb5b8"]]},{"id":"e63a5889.fbb5b8","type":"function","z":"fd35c454.ee407","name":"Function Scene","func":"var idx = parseInt(msg.topic)\nif ( msg.payload === true )\n{\nmsg.payload = { \"command\": \"switchscene\", \"idx\": idx, \"switchcmd\": \"On\" };\nreturn msg\n}\n\n","outputs":1,"noerr":0,"x":1320,"y":820,"wires":[["7d584545.8c9544"]]},{"id":"7d584545.8c9544","type":"json","z":"fd35c454.ee407","name":"","property":"payload","action":"","pretty":false,"x":1630,"y":580,"wires":[["caefbcc2.78bf18"]]},{"id":"caefbcc2.78bf18","type":"mqtt out","z":"fd35c454.ee407","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"34e4d2fc.90d346","x":1870,"y":580,"wires":[]},{"id":"34e4d2fc.90d346","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"48bacfcb.9887b8","type":"nora-config","z":"","name":"nora config","group":""}]
Let me know what you think!
pabloalcantara
Re: Domoticz Google Assistant integration with node-red Easy Free Controlicz alternative!
Post by pabloalcantara »
Works perfectly - in less than one hour I migrate from Controlicz 20 itens.
thsi
Post by thsi »
(sorry for my bad English because I am French).
Hello, first of all, thank you for this topic. I do not understand why we do not talk about it anymore.
This solution is perfect. I got your code and it works perfectly.
By cons I have temperature probes in domoticz and I would like to integrate in Google Assistant in the form of thermostat that will indicate only the temperature and humidity.
I tried several manipulations, but I can not do it. (I'm really bad at code)
Would it be possible to have a sample code to be able to do what I want.
Thank you in advance.
Phantom
Domoticz version: 4.11652
Post by Phantom »
This works great :)
And thanks for the example flow that helped a lot.
legacy1981
thsi wrote: Tuesday 07 May 2019 10:18 (sorry for my bad English because I am French).
Humidity is not supported with NORA. I tried something. You can display the temperature in home. And ask assistant how hot it is in the livingroom.
Just change the idx for the sensor in the switch.
[{"id":"611b7dec.63fc14","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"4b97fb74.2597c4","type":"mqtt in","z":"611b7dec.63fc14","name":"","topic":"domoticz/out","qos":"2","broker":"34e4d2fc.90d346","x":650,"y":360,"wires":[["63ac7659.1bb328"]]},{"id":"63ac7659.1bb328","type":"json","z":"611b7dec.63fc14","name":"","property":"payload","action":"","pretty":false,"x":850,"y":360,"wires":[["fee6befc.05fce8"]]},{"id":"fee6befc.05fce8","type":"switch","z":"611b7dec.63fc14","name":"","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"588","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1030,"y":360,"wires":[["b8351a5c.9a5278"]]},{"id":"bfeeb6f.76ca648","type":"nora-thermostat","z":"611b7dec.63fc14","devicename":"Thermostat","roomhint":"","name":"","modes":"off","unit":"C","topic":"","passthru":false,"nora":"48bacfcb.9887b8","x":1490,"y":380,"wires":[[]]},{"id":"b8351a5c.9a5278","type":"function","z":"611b7dec.63fc14","name":"Function In on/off","func":"temperature = msg.payload.svalue1\nmsg.payload.temperature = temperature\nreturn msg\n","outputs":1,"noerr":0,"x":1250,"y":380,"wires":[["bfeeb6f.76ca648"]]},{"id":"34e4d2fc.90d346","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"48bacfcb.9887b8","type":"nora-config","z":"","name":"nora config","group":""}]
Bob123bob
Post by Bob123bob »
How are the blinds working ? I tried to connect one on the dimmer function as they work with level % as well but it was not working :(
Can you help ?
edwin1234
Domoticz version: 2021.1
Post by edwin1234 »
How do i switch a light i have a lamp on idx12
And its commands are send by rfxcom trough domoticz.
Can someone give me an example flow please?
Edwin
serfer
Post by serfer »
Welcome
I have such errors as in the attached file.
will you help?
Jofre
Domoticz version: Latest
Post by Jofre »
@serfer,
Line 10 should read: return msg;
pvklink
Domoticz version: latest b
Post by pvklink »
works great!
only a switch with the property name "TV Lamp links" does not work, google does not recognize the device because off the used spaces.
a propertyname "TVLamplinks" (without spaces) does work but google does not recognize the voice command for this...
Jablotron connection, Ikea
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
looks great will try this
domogijs
Post by domogijs »
Hi i would really lik this to work.
did all the steps but i do not understand the last one.
please provide a screenshot with this step: Next the numbers in the switches and the "topic" in the node needs to match the domoticz IDX which you want to control.
Greets Gijs
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
quazar
Post by quazar »
Great, a small howto for Dummies would be much appreciated...
DAVIZINHO
Post by DAVIZINHO »
hello,
Can someone detail this? it will be interesting. But i dont understand the basics :-(
freijn
Domoticz version: Stable
Post by freijn »
much interested as well. please the dummies version ?
salvacalatayud
Post by salvacalatayud »
freijn wrote: Wednesday 28 August 2019 13:27 much interested as well. please the dummies version ?
+1
domogijs
Post by domogijs »
Hi Guys
This is what i did so far.
Copy this code. Go to the node red. --> hamburger menu upper right. -->Select import. --> Paste clipbord.
Hopes this helps.
[/quote]
To understand how it works i made this one. (not sophisticated but works for me..)
[{"id":"a87d68b.8d28498","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"8429a357.ecfe","type":"inject","z":"a87d68b.8d28498","name":"Muurlamp uit","topic":"domoticz/in","payload":"{\"command\": \"switchlight\", \"idx\": 793, \"switchcmd\": \"Off\" }","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":120,"wires":[["94505c26.ae7dd"]]},{"id":"67fbb756.e36e18","type":"mqtt in","z":"a87d68b.8d28498","name":"","topic":"domoticz/#","qos":"2","datatype":"auto","broker":"bc4b9707.63ee58","x":120,"y":580,"wires":[["8e00c342.8b497"]]},{"id":"8e00c342.8b497","type":"debug","z":"a87d68b.8d28498","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":490,"y":620,"wires":[]},{"id":"94505c26.ae7dd","type":"mqtt out","z":"a87d68b.8d28498","name":"","topic":"","qos":"","retain":"","broker":"bc4b9707.63ee58","x":570,"y":100,"wires":[]},{"id":"c187aecf.0bd52","type":"nora-light","z":"a87d68b.8d28498","devicename":"Muurlamp","lightcolor":false,"brightnesscontrol":false,"passthru":false,"statepayload":true,"brightnessoverride":"","roomhint":"Woonkamer","name":"Muurlamp","nora":"45fbca16.592194","topic":"domoticz/in","onvalue":"{\"command\": \"switchlight\", \"idx\": 793, \"switchcmd\": \"On\" }","onvalueType":"str","offvalue":"{\"command\": \"switchlight\", \"idx\": 793, \"switchcmd\": \"Off\" }","offvalueType":"str","x":160,"y":180,"wires":[["94505c26.ae7dd"]]},{"id":"df99a830.c52af8","type":"nora-scene","z":"a87d68b.8d28498","devicename":"Sleep","roomhint":"Woonkamer","scenereversible":false,"name":"Sleep","nora":"45fbca16.592194","topic":"domoticz/in","onvalue":"{\"command\": \"switchscene\", \"idx\": 2, \"switchcmd\": \"On\" }","onvalueType":"str","offvalue":"false","offvalueType":"bool","x":150,"y":240,"wires":[["94505c26.ae7dd"]]},{"id":"f7dfc4cf.952ed8","type":"nora-scene","z":"a87d68b.8d28498","devicename":"Scene","roomhint":"Woonkamer","scenereversible":false,"name":"avond","nora":"45fbca16.592194","topic":"domoticz/in","onvalue":"{\"command\": \"switchscene\", \"idx\": 1, \"switchcmd\": \"On\" }","onvalueType":"str","offvalue":"false","offvalueType":"bool","x":140,"y":320,"wires":[["94505c26.ae7dd"]]},{"id":"bc4b9707.63ee58","type":"mqtt-broker","z":"","name":"Domoticz mqqt client","broker":"http://192.168.178.19","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"45fbca16.592194","type":"nora-config","z":"","name":"nora config","group":"","notify":false}]
Please share your solutions.
andersbz
Post by andersbz »
I've got lamps and switches working but I don't get scenes to work. Can anyone give any tips? The scene never gets connected.
Problem solved. It should never show connect. The icon for the scene appears in Google Assistant and can only be activated by voice
andersbz
Post by andersbz »
I want Domoticz to update the status of a device in node-red when a change occurs in Domoticz, for example, when a lamp switches on. As it is now, node-red is not updated and then it is not possible to switch off a lamp thru node-red (via Google Home) when the status in node-red is off but in Domoticz it is on. Anyone have a solution for this?
xury
Post by xury »
Its very simple. You must do feedback from domoticz/out, as in following example:
        "id": "76efc51b.db2e8c",
        "type": "mqtt in",
        "z": "46580878.ba4bd8",
        "name": "",
        "topic": "domoticz/out",
        "qos": "0",
        "datatype": "auto",
        "broker": "9748a36f.44bdd",
        "x": 230,
        "y": 240,
        "wires": [
                "ed9342a4.d56ec"
        "id": "ed9342a4.d56ec",
        "type": "json",
        "name": "",
        "property": "payload",
        "action": "",
        "pretty": false,
        "x": 370,
        "y": 240,
        "wires": [
                "ebe7e2e1.4a69d"
        "id": "ebe7e2e1.4a69d",
        "type": "function",
        "name": "Function In on/off",
        "func": "msg.topic = msg.payload.idx\nif (msg.payload.nvalue === 1)\n{\n    msg.payload = true\n}\nelse if (msg.payload.nvalue === 0)\n{\n    msg.payload = false\n}\n    return msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 570,
        "y": 240,
        "wires": [
                "cd626796.602738"
        "id": "cd626796.602738",
        "type": "switch",
        "name": "",
        "property": "topic",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "112",
                "vt": "str"
                "t": "eq",
                "v": "92",
                "vt": "str"
                "t": "eq",
                "v": "42",
                "vt": "str"
                "t": "eq",
                "v": "151",
                "vt": "str"
                "t": "eq",
                "v": "66",
                "vt": "str"
                "t": "eq",
                "v": "169",
                "vt": "str"
                "t": "eq",
                "v": "170",
                "vt": "str"
                "t": "eq",
                "v": "171",
                "vt": "str"
                "t": "eq",
                "v": "172",
                "vt": "str"
                "t": "eq",
                "v": "173",
                "vt": "str"
                "t": "eq",
                "v": "174",
                "vt": "str"
                "t": "eq",
                "v": "53",
                "vt": "str"
                "t": "eq",
                "v": "155",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 13,
        "x": 750,
        "y": 240,
        "wires": [
                "89c0375f.018278"
        "id": "89c0375f.018278",
        "type": "nora-light",
        "devicename": "Dining table",
        "lightcolor": false,
        "brightnesscontrol": false,
        "passthru": false,
        "statepayload": true,
        "brightnessoverride": "",
        "roomhint": "Living room",
        "name": "Dining table",
        "nora": "4aa17da2.220c54",
        "topic": "169",
        "onvalue": "true",
        "onvalueType": "bool",
        "offvalue": "false",
        "offvalueType": "bool",
        "x": 910,
        "y": 220,
        "wires": [
                "d4f7bf20.d6a37"
        "id": "d4f7bf20.d6a37",
        "type": "function",
        "name": "Funkcja ON/OFF",
        "func": "var idx = msg.topic\nif ( msg.payload === true )\n{\nmsg.payload = { \"command\": \"switchlight\", \"idx\": idx, \"switchcmd\": \"On\" };\n}\nelse if ( msg.payload === false )\n{\nmsg.payload = { \"command\": \"switchlight\", \"idx\": idx, \"switchcmd\": \"Off\" };\n}\nreturn msg\n",
        "outputs": 1,
        "noerr": 0,
        "x": 1130,
        "y": 220,
        "wires": [
                "bf3249c4.4cabd8"
        "id": "bf3249c4.4cabd8",
        "type": "template",
        "name": "Gen MQTT On/Off",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "{\"command\": \"switchlight\", \"idx\": {{payload.idx}}, \"switchcmd\": \"{{payload.switchcmd}}\" }",
        "output": "str",
        "x": 1350,
        "y": 220,
        "wires": [
                "152b62fe.c8183d"
        "id": "152b62fe.c8183d",
        "type": "mqtt out",
        "name": "",
        "topic": "domoticz/in",
        "qos": "",
        "retain": "",
        "x": 1410,
        "y": 300,
        "wires": []
        "id": "9748a36f.44bdd",
        "type": "mqtt-broker",
        "z": "",
        "broker": "localhost",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "compatmode": true,
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "willTopic": "",
        "willQos": "0",
        "willPayload": ""
        "id": "4aa17da2.220c54",
        "type": "nora-config",
        "z": "",
        "name": "nora config",
        "group": "",
        "notify": false
