Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
phtinix
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by phtinix »
Oh and i have 5 google homes, same for all so..
tjabas
Post by tjabas »
phtinix wrote: Sunday 19 April 2020 21:15 Oh and i have 5 google homes, same for all so..
try to reset and install one of them and see if it helps, if it does, reset them all..
phtinix
Post by phtinix »
I reset it, same problem
phtinix
Post by phtinix »
Now it works back as before, but i did nothing.. Except for scenes : no action, all google home are complaining about controlicz when i try any scenes
Madgeni
Post by Madgeni »
Hi -
nothing has changed with Controlicz - there have been some intermittent issues with the retrieval and responses from the Google cloud to the Home devices which I cannot control - these seem to have been resolved.
However, if you are still having issues after resetting your Google device (or creating a new Home in the Home app and trying to relink your Controlicz account) then please mail me from your Controlicz profile and i'll investigate directly.
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Madgeni wrote: Friday 20 March 2020 16:02 Battery devices can now be queried - "What is the <devicename> battery level?"
Also, I have provided some new discovery behaviours. Not all devices discover as you would like, and you've asked for the ability to override these - now you can. From the FAQs:
you can provide a specific type of device: Light/Switch/Outlet/Fan/Thermostat/TempSensor/Security/Lock/Sensor/Battery/Selector/Blinds/Vacuum.
for example - Simply put TypeControl: Light in the device description field and sync/discover your devices and Controlicz will treat the device accordingly
Product Release notes updated
Enjoy
How do you need to seperate this in the description field? i know have: Controlicz: Gordijnen; TypeControl: Blinds
But the blinds still not show up in the controlicz devices list(the are in a roomplam) after several sync requests. Other stuff like a scene i just addes pops right up.
Madgeni
Post by Madgeni »
You should be ok - let me explore this. Can you try removing the Controlicz: piece and just use TypeControl: Blinds - does that work?
I'm assuming the device is added to the User as well?
Skippiemanz
Madgeni wrote:You should be ok - let me explore this. Can you try removing the Controlicz: piece and just use TypeControl: Blinds - does that work?
Shit... you've got me.. problem was in adding it to the user. Its now in the devices list and shown as blinds.
Verstuurd vanaf mijn SM-G981B met Tapatalk
driekes
Post by driekes »
Hi, i'm using Domoticz for a while and would like to link it to Google Home as well. I have now setup a reverse proxy with Apache, so the url is domain.com/domoticz/. It looks like it doesn't work with Controlicz, can anyone confirm? Or share his/her settings?
Madgeni
Post by Madgeni »
hi - think you contacted me via Controlicz but this does work - just put the url in as the hostname and the port number as 9999
maxtrash
Post by maxtrash »
I have recently bought a Daikin aircondition multi split unit which works with wifi. I can control it via the app and domoticz. Via controlicz the thermostat device is also controlable in google home.
The thermostat device in google home also shows the mode (heating, cooling, off). If I change it the log tells me this:
User: controlicz initiated a switch command (784/Slaapkamer - Airco Thermostat/cool)
Device 784 is the thermostat. The "mode" is a separate "selector switch" device with idx 783.
Is this a limitation of domoticz? Does a combined Thermostat / selector switch device exist or is it a limitation of the Daikin hardware driver in Domoticz.
Alternatively, would controlicz be able to map one google home device to two domoticz devices?
Madgeni
Post by Madgeni »
Anyone having issues controlling Scenes - please 'sync my devices' - This will fix it, apologies for any inconvenience
TheCondor
Post by TheCondor »
Hi Madgeni, any news on my trouble with the switch level of the fan? Thanks.
Madgeni
Post by Madgeni »
Sorry, can you email me from your Controlicz profile and I’ll investigate
markjgabb
Domoticz version: 3.8153
Post by markjgabb »
haha, glad to see the issue with non responsive devices is more widely spread and not on our side but on googles :D
just curious about something... i created a user for use with controlicz, called controlicz and specified this in my controlicz profile for connections.
however when i activate a switch from google home it states the following in Domoticz logs
2020-07-28 20:42:12.892 Status: Incoming connection from: 35.178.116.149
2020-07-28 20:42:32.319 (Virtual) Light/Switch (Hall Rear)
2020-07-28 20:42:32.311 Status: User: Admin initiated a switch command (11/Hall Rear/On)
2020-07-28 20:42:47.639 (Virtual) Light/Switch (Hall Rear)
2020-07-28 20:42:47.631 Status: User: Admin initiated a switch command (11/Hall Rear/Off)
2020-07-28 20:43:00.840 (Virtual) Light/Switch (Hall Rear)
2020-07-28 20:43:00.836 Status: User: Admin initiated a switch command (11/Hall Rear/On)
2020-07-28 20:43:08.632 (Virtual) Light/Switch (Hall Rear)
2020-07-28 20:43:08.624 Status: User: Admin initiated a switch command (11/Hall Rear/Off)
should this show up as user: Controlicz. trying to work out where the issues could be.
does this appear the same for anyone else?
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
Madgeni
Post by Madgeni »
can you restart Domoticz, and see what happens when you try again?
markjgabb
Post by markjgabb »
still the exact same, ive double checked the controlicz profile and im definatly using controlicz as the user to link into my profile.
im thinking this more a possible issue on the domoticz side of things?
2020-07-28 21:03:13.723 Status: Incoming connection from: 35.178.116.149
2020-07-28 21:03:17.293 (Virtual) Light/Switch (Hall Rear)
2020-07-28 21:03:17.265 Status: User: Admin initiated a switch command (11/Hall Rear/Off)
2020-07-28 21:03:22.471 (Virtual) Light/Switch (Hall Rear)
2020-07-28 21:03:22.449 Status: User: Admin initiated a switch command (11/Hall Rear/On)
2020-07-28 21:03:26.199 (Virtual) Light/Switch (Hall Rear)
2020-07-28 21:03:26.189 Status: User: Admin initiated a switch command (11/Hall Rear/Off)
2020-07-28 21:03:27.220 Kodi: Restarting I/O service thread.
2020-07-28 21:03:28.268 (Virtual) Light/Switch (Hall Rear)
2020-07-28 21:03:28.260 Status: User: Admin initiated a switch command (11/Hall Rear/On)
2020-07-28 21:03:32.940 (Virtual) Light/Switch (Hall Rear)
2020-07-28 21:03:32.932 Status: User: Admin initiated a switch command (11/Hall Rear/Off)
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
markjgabb wrote: Tuesday 28 July 2020 13:05 still the exact same, ive double checked the controlicz profile and im definatly using controlicz as the user to link into my profile.
if you added 35.178.116.149 to [ Local Networks (no username/password): ] it will always show as admin
markjgabb
Post by markjgabb »
i currently have 10.0.0.*
as my current internal network is 10.0.0.x
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
markjgabb
Post by markjgabb »
waaren wrote: Tuesday 28 July 2020 13:10 if you added 35.178.116.149 to [ Local Networks (no username/password): ] it will always show as admin
i have no made every connection require a login from every source
i can see contrilcz successfully login, but is still always admin initiated an action
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
