Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
phtinix
Oh and i have 5 google homes, same for all so..
tjabas
try to reset and install one of them and see if it helps, if it does, reset them all..
phtinix
I reset it, same problem
phtinix
Now it works back as before, but i did nothing.. Except for scenes : no action, all google home are complaining about controlicz when i try any scenes
Madgeni
Hi -
nothing has changed with Controlicz - there have been some intermittent issues with the retrieval and responses from the Google cloud to the Home devices which I cannot control - these seem to have been resolved.
However, if you are still having issues after resetting your Google device (or creating a new Home in the Home app and trying to relink your Controlicz account) then please mail me from your Controlicz profile and i'll investigate directly.
Skippiemanz
- Domoticz version: 4.10233
How do you need to seperate this in the description field? i know have: Controlicz: Gordijnen; TypeControl: BlindsMadgeni wrote: Friday 20 March 2020 16:02 Battery devices can now be queried - "What is the <devicename> battery level?"
Also, I have provided some new discovery behaviours. Not all devices discover as you would like, and you've asked for the ability to override these - now you can. From the FAQs:
you can provide a specific type of device: Light/Switch/Outlet/Fan/Thermostat/TempSensor/Security/Lock/Sensor/Battery/Selector/Blinds/Vacuum.
for example - Simply put TypeControl: Light in the device description field and sync/discover your devices and Controlicz will treat the device accordingly
Product Release notes updated
Enjoy
But the blinds still not show up in the controlicz devices list(the are in a roomplam) after several sync requests. Other stuff like a scene i just addes pops right up.
Madgeni
You should be ok - let me explore this. Can you try removing the Controlicz: piece and just use TypeControl: Blinds - does that work?
I'm assuming the device is added to the User as well?
Skippiemanz
Shit... you've got me.. problem was in adding it to the user. Its now in the devices list and shown as blinds.Madgeni wrote:You should be ok - let me explore this. Can you try removing the Controlicz: piece and just use TypeControl: Blinds - does that work?
Verstuurd vanaf mijn SM-G981B met Tapatalk
Hi, i'm using Domoticz for a while and would like to link it to Google Home as well. I have now setup a reverse proxy with Apache, so the url is domain.com/domoticz/. It looks like it doesn't work with Controlicz, can anyone confirm? Or share his/her settings?
Madgeni
hi - think you contacted me via Controlicz but this does work - just put the url in as the hostname and the port number as 9999
I have recently bought a Daikin aircondition multi split unit which works with wifi. I can control it via the app and domoticz. Via controlicz the thermostat device is also controlable in google home.
The thermostat device in google home also shows the mode (heating, cooling, off). If I change it the log tells me this:
User: controlicz initiated a switch command (784/Slaapkamer - Airco Thermostat/cool)
Device 784 is the thermostat. The "mode" is a separate "selector switch" device with idx 783.
Is this a limitation of domoticz? Does a combined Thermostat / selector switch device exist or is it a limitation of the Daikin hardware driver in Domoticz.
Alternatively, would controlicz be able to map one google home device to two domoticz devices?
Madgeni
Anyone having issues controlling Scenes - please 'sync my devices' - This will fix it, apologies for any inconvenience
Hi Madgeni, any news on my trouble with the switch level of the fan? Thanks.
Madgeni
Sorry, can you email me from your Controlicz profile and I’ll investigate
markjgabb
- Domoticz version: 3.8153
haha, glad to see the issue with non responsive devices is more widely spread and not on our side but on googles
just curious about something... i created a user for use with controlicz, called controlicz and specified this in my controlicz profile for connections.
however when i activate a switch from google home it states the following in Domoticz logs
should this show up as user: Controlicz. trying to work out where the issues could be.
does this appear the same for anyone else?
2020-07-28 20:42:12.892 Status: Incoming connection from: 35.178.116.149
2020-07-28 20:42:32.319 (Virtual) Light/Switch (Hall Rear)
2020-07-28 20:42:32.311 Status: User: Admin initiated a switch command (11/Hall Rear/On)
2020-07-28 20:42:47.639 (Virtual) Light/Switch (Hall Rear)
2020-07-28 20:42:47.631 Status: User: Admin initiated a switch command (11/Hall Rear/Off)
2020-07-28 20:43:00.840 (Virtual) Light/Switch (Hall Rear)
2020-07-28 20:43:00.836 Status: User: Admin initiated a switch command (11/Hall Rear/On)
2020-07-28 20:43:08.632 (Virtual) Light/Switch (Hall Rear)
2020-07-28 20:43:08.624 Status: User: Admin initiated a switch command (11/Hall Rear/Off)
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
RFlink 334 mhz
mysensors
broadlink
Madgeni
can you restart Domoticz, and see what happens when you try again?
markjgabb
still the exact same, ive double checked the controlicz profile and im definatly using controlicz as the user to link into my profile.
im thinking this more a possible issue on the domoticz side of things?
2020-07-28 21:03:13.723 Status: Incoming connection from: 35.178.116.149
2020-07-28 21:03:17.293 (Virtual) Light/Switch (Hall Rear)
2020-07-28 21:03:17.265 Status: User: Admin initiated a switch command (11/Hall Rear/Off)
2020-07-28 21:03:22.471 (Virtual) Light/Switch (Hall Rear)
2020-07-28 21:03:22.449 Status: User: Admin initiated a switch command (11/Hall Rear/On)
2020-07-28 21:03:26.199 (Virtual) Light/Switch (Hall Rear)
2020-07-28 21:03:26.189 Status: User: Admin initiated a switch command (11/Hall Rear/Off)
2020-07-28 21:03:27.220 Kodi: Restarting I/O service thread.
2020-07-28 21:03:28.268 (Virtual) Light/Switch (Hall Rear)
2020-07-28 21:03:28.260 Status: User: Admin initiated a switch command (11/Hall Rear/On)
2020-07-28 21:03:32.940 (Virtual) Light/Switch (Hall Rear)
2020-07-28 21:03:32.932 Status: User: Admin initiated a switch command (11/Hall Rear/Off)
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
- waaren
if you added 35.178.116.149 to [ Local Networks (no username/password): ] it will always show as adminmarkjgabb wrote: Tuesday 28 July 2020 13:05 still the exact same, ive double checked the controlicz profile and im definatly using controlicz as the user to link into my profile.
markjgabb
i currently have 10.0.0.*
as my current internal network is 10.0.0.x
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
markjgabb
i have no made every connection require a login from every sourcewaaren wrote: Tuesday 28 July 2020 13:10 if you added 35.178.116.149 to [ Local Networks (no username/password): ] it will always show as admin
i can see contrilcz successfully login, but is still always admin initiated an action
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
