terrorsource
Post by terrorsource »
kmccor wrote: Wednesday 25 October 2017 13:59 Hi, I get a battery low warning from one of my Xiaomi temp sensors, even though it's not that old and the temp/humidy battery level on the same device is showing 80%.
Is anyone else experiencing this and if so is there a fix? It changes state as well, the temp/hum is currently not showing any battery level and temp is showing 100%?? I have tried removing and re-adding the device from Domoticz and the Xiaomi gateway a few times to no avail.
Cheers
Karl
got the same issue with all of my Aqara/Xiaomi sensors.
Just added a few Aqara Human Body Sensor v2's and the battery status in Domoticz is:
Sensor = 85%
Lux = 100%
While both of the sensors are from 1 physical device.
Does anyone has a fix for measuring Lux with these sensors yet? Looks like the sensors are only measuring really low lux values and not real lux values like Fibaro Motion Sensors can do.
joebar
Post by joebar »
Same here with different Battery levels. Regarding Lux levels, yes but it is a very tiny sensor, 1mm and the ambient light is send to it indirectly through a tube. So it probably will be hard to get better results.
I have a script that triggers a low light lower than 3 lux (and that is around 50lux with a better sensor) and daylight above 7 lux.
Between 7 and 3 it is somewhat a grey area and can’t be trusted. No matter, its is working fine for controlling the house lights now.
IDANIT
Post by IDANIT »
terrorsource wrote: Friday 27 October 2017 20:15
Cheers
Karl
Sensor = 85%
Lux = 100%
Same here, with all of my aqara devices.
corederoma82
Post by corederoma82 »
just a question.
I would buy Xiaomi Gateway, but in website the only options that I can select is the Chinese flag (and not Europe flag); what is the difference? Will I have the words in chinese language?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
CaesarPL
Post by CaesarPL »
Gateway is not officially supported outside China. Application is translated, let's say that fully. But for example when pairing devices Gateway speaks beautiful Chinese :)
Stanleyk
Post by Stanleyk »
Yesterday on evening , stop update my temperature sensors. all switches work fine also door sensors are fine etc. just temperature..
Have somebody same problem ?
mvveelen
Post by mvveelen »
mvveelen wrote: Thursday 26 October 2017 11:19 No fix yet for the battery status in the Beta version of Domoticz? Anyone?
Is there really nobody who knows if this is going to be fixed in a future release of Domoticz, or intentionally deleted from Domoticz for whatever reason ?
sgeaglef15
Post by sgeaglef15 »
Tried adding additional Xiaomi Gateway but what I notice was after introducing 2nd gateway this error start to appear whenever I trigger a switch?
1.The light will not turn on on first attempt, press again it will work.
2. Error in picture will appear “error sending sw command..”
3. log show those error
2017-11-02 19:56:09.770 User: User1 initiated a switch command (75/Master Room bed light/Off)
2017-11-02 19:56:09.924 Error: XiaomiGateway: unable to write command - Invalid Key
2017-11-02 19:56:09.924 XiaomiGateway: SendMessageToGateway failed on first attempt, will try again
2017-11-02 19:56:10.180 Error: XiaomiGateway: unable to write command - Invalid Key
2017-11-02 19:56:16.769 User: User1 initiated a switch command (75/Master Room bed light/Off)
2017-11-02 19:56:16.931 (Xiaomi Gateway) Light/Switch (Master Room bed light)
2017-11-02 19:56:17.554 (Xiaomi Gateway) Light/Switch (Master Room bed light)
4. If I disable 2nd gateway all goes back to normal?
5. All gateway are given static IP on router.
Derik
Post by Derik »
Dear all..
I do have some new sensor for my gateway... [ use 8 devices on the gateway ]
Try them to add with the android app.
Only not working.
See i need a update from 4.2.5 to 5.0.6 with the app.
Only how i try the app will not update.
Are there other people that have problems with add a device?
And some one have a solution to update the app to version 5.0.6?
IDANIT
Post by IDANIT »
Derik wrote: Friday 03 November 2017 17:39 Dear all..
Only not working.
https://www.apkmirror.com/apk/xiaomi-inc/mihome/ clean app cache after installation
matteos1
Post by matteos1 »
today my xiaomi gateway don't work anymore with domoticz and the message in log is 2017-11-03 23:53:52.391 Error: XiaomiGateway: unable to write command - Invalid key
2017-11-03 23:53:52.642 Error: XiaomiGateway: unable to write command - Invalid key
2017-11-03 23:54:00.522 Error: XiaomiGateway: unable to write command - No device
i try to change password in mihome app but always appears this message.
before of today xiaomi work with domoticz
sincze
Domoticz version: 2024.4
Post by sincze »
Did you update the app and firmware ?
What version is it currently using?
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
snadwich
Post by snadwich »
I'm jumping in the Domoticz / Xiaomi combination train.. Then i have a cobination of Milight,Xiaoimi yi light,Sonoffs with ESPeasy on it and a home made P1 cable.
The Xiaomi Window/Door Sensor v2 is now €5,22 with discount code:11.11GB10
Derik
Post by Derik »
mm thanks for the apk..
Did update my gateway..
Only strange thing ...
When i open the app, and i will ad new hardware manually is get a error no zigbee gateway found..
The strange part, the gateway is working fine.
Other strange thing i can add directly on the gateway new sensors.
Push the button for a few seconds until the lady says something in Chinees..
Then i push the sensor button, the lady talk again..
And i see new device in Domoticz..
Only why is the app not working anaymore??
mvveelen
Post by mvveelen »
mvveelen wrote: Wednesday 01 November 2017 17:58
Other strange thing I have, is that the LUX from the gateway isn't registered anymore. I tried another password/code, but no result. Any ideas ?
Derik
Post by Derik »
mvveelen wrote: Sunday 05 November 2017 0:10
I do have the same problem..
papoo
Domoticz version: 4.10
Post by papoo »
hello
I added 2 probes temperature hygrometry barometer aquara.
everything goes well with the temperature and hygrometry.
the problem concerns the barometer. In the app MIHOME I have 97.5 kPA (0.975 bar) while in domoticz I have 975 bar.
can we change the units somewhere in dz to fix that?
furthermore the barometer device is found in the measurement tab instead of the weather tab?
domoticz Version: 3.8666
mvveelen
Post by mvveelen »
Suddenly the LUX of the Xiaomi gateway started giving me values again. Haven't changed anything, so that's strange. The battery values are stil......dead.....
Edit: using Domoticz V3.8701 Beta at the moment.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Anyone has a link where to buy Xiaomi stuff?
I ordered some items on Aliexpress but none of them got delivered...
Derik
Post by Derik »
Egregius wrote: Wednesday 08 November 2017 19:49 Anyone has a link where to buy Xiaomi stuff?
banggood
Ebay.com
lightinthebox
Only i ordered much stuff on Ali...
everything is arrived.
Make a case...
