Is it gonna rain within the next X minutes?
tlpeter
Re: Is it gonna rain within the next X minutes?
Post by tlpeter »
Hi MArk,
Sure but keep in mind that my script is totally different.
It is based on Wunderground where you can choose a weather station near by.
I do not have any integration with buienradar.
I also added a switch where i can override the script partly (except for hard wind, rain and night)
Here it is:
--Weatherstation data:
sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues['Barometer']:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWeatherTemp = tonumber(sWeatherTemp);
sWeatherHumidity = tonumber(sWeatherHumidity);
sWeatherPressure = tonumber(sWeatherPressure);
sWeatherUV = tonumber(sWeatherUV);
sWeatherUV2 = tonumber(sWeatherUV2);
print("______________________________________________________________________________________")
print("Weather station: Temperature is " .. sWeatherTemp .. " ");
print("Weather station: Humidity is " .. sWeatherHumidity .. " ");
print("Weather station: Pressure is " .. sWeatherPressure .. " ");
print("Weather station: UV is " .. sWeatherUV .. " ");
print("Weather station: UV2 is " .. sWeatherUV2 .. " ");
--Windmeter data:
sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues['Wind']:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWindDirectionDegrees = tonumber(sWindDirectionDegrees);
sWindDirection = (sWindDirection);
sWindSpeed = tonumber(sWindSpeed);
sWindGust = tonumber(sWindGust);
sWindTemperature = tonumber(sWindTemperature);
sWindFeel = tonumber(sWindFeel);
print("Windmeter: Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ");
print("Windmeter: Winddirection is: " .. sWindDirection .. " ");
print("Windmeter: Windspeed is: " .. sWindSpeed .. " ");
print("Windmeter: Windgust is: " .. sWindGust .. " ");
print("Windmeter: Windtemperature is: " .. sWindTemperature .. " ");
print("Windmeter: Windfeel is: " .. sWindFeel .. " ");
--Rainmeter data:
sRainmeterCurrent, sRainmeterTotal = otherdevices_svalues['Regen']:match("([^;]+);([^;]+)")
sRainmeterCurrent = tonumber(sRainmeterCurrent);
sRainmeterTotal = tonumber(sRainmeterTotal);
print("Rainmeter: Actual rain is: " .. sRainmeterCurrent .. " ");
print("Rainmeter: Total rain is: " .. sRainmeterTotal .. " ");
--UV data:
sSolar = otherdevices_svalues['Solar']:match("([^;]+)")
--sUV = tonumber(sUV);
sSolar = tonumber(sSolar);
--print("UV: UV Strength is: " .. sUV .." ");
print("UV: Solar radiation is: " .. sSolar .." ");
--Sunscreen thresholds:
        -- Windspeed            = 100.0 (value is multiplied by 100)
        -- Rain                 =  0.0
        -- UV                   =  2.0
        -- Temperature          = 12.0
        -- Closed       = Down  = On
        -- Open         = Up    = Off
if (timeofday['Daytime'])
        then
                print('It is past sunrise, monitoring variables for sunscreen')
        if (otherdevices['Zonnescherm'] == 'Open' )
        then
                print ('Sunscreen is up')
                print ('Sunscreen is down')
if (otherdevices['Zonnescherm manual override']  == 'Off')
		then
				print('Manual override is turned off, follow the rest of the script')
				print('Manual override is turned on, goto the end of the script and do nothing')
				goto done
		and sRainmeterCurrent   == 0
        and sWeatherTemp        > 12.0
		and sSolar				> 100
        and sWindSpeed          < 50
        and sWindGust           < 150)
then
        print ('Sun is shining, all thresholds OK, lowering sunscreen')
		print('______________________________________________________________________________________')
        commandArray['SendNotification']='Sunscreen#Sunscreen down --> Sun is shining'
        commandArray['Zonnescherm']='On'
				elseif (otherdevices['Zonnescherm'] == 'Closed' and sRainmeterCurrent > 0)
                then
                print ('It is raining, raising sunscreen')
                commandArray['SendNotification']='Sunscreen#Sunscreen up --> It is raining'
                commandArray['Zonnescherm']='Off'
        elseif (otherdevices['Zonnescherm'] == 'Closed' and sWeatherTemp <11.0 and otherdevices['Zonnescherm manual override'] == 'Off')
                then
                print ('Temperature too low, raising sunscreen')
                commandArray['SendNotification']='Sunscreen#Sunscreen up --> It is too cold'
       elseif (otherdevices['Zonnescherm'] == 'Closed' and sSolar < 80 and otherdevices['Zonnescherm manual override'] == 'Off')
                then
                print ('Sun not shining too bright, raising sunscreen')
                commandArray['SendNotification']='Sunscreen#Sunscreen up --> Sunshine not too bright'
        elseif (otherdevices['Zonnescherm'] == 'Closed' and sWindSpeed > 50)
                then
                print ('Windspeed too high, raising sunscreen')
                commandArray['SendNotification']='Sunscreen#Sunscreen up --> Windspeed too high'
        elseif (otherdevices['Zonnescherm'] == 'Closed' and sWindGust > 150)
                then
                print ('Windgust too high, raising sunscreen')
                commandArray['SendNotification']='Sunscreen#Sunscreen up --> Windgust too high'
        print('Sunscreen status OK --> No action')
::done::
		print("At the end of the script")
elseif (timeofday['Nighttime']
        and otherdevices['Zonnescherm'] == 'Closed')
        then
                print('It is night, raising sunscreen')
                commandArray['SendNotification']='Sunscreen#Sunscreen up --> It is night'
                print('Sunscreen already up --> No action')
mikeoo
Post by mikeoo »
roblom wrote:I added also a text device and filled it with the text from this script.
function round(num, idp)
	local mult = 10^(idp or 0)
	return math.floor(num * mult + 0.5) / mult
-- CommandArray
	minuten=15
	RainPrediction = IsItGonnaRain(minuten)
	RainmmHour=10^((RainPrediction-109)/32)
	if (RainPrediction > 0  ) then
		verw = 3
		RainPredictionText=('Regen verwacht binnen '..minuten..' minuten, met ' ..round(RainmmHour, 1).. ' mm/uur')
		verw = 2
		RainPredictionText=('Geen regen verwacht binnen '..minuten..' minuten.')
	commandArray[1] = {['UpdateDevice'] = RainDeviceIDX .. '|'..tostring(RainPrediction)..'|'..tostring(verw)}
	commandArray[2] = {['UpdateDevice'] = RainTextIDX .. '|0|' .. tostring(RainPredictionText)}
	print('-- Regen verwacht(0-255 hoe hoger hoe meer regen): '..RainPrediction..' binnen '..minuten..' minuten.')
	print('-- ' .. RainPredictionText )
RainTextIDX = the IDX of the text device.
And added a round function to display only 1 digit.
Do i need to replace RainTextIDX with only the IDX number.
like:
 commandArray[2] = {['UpdateDevice'] = 97 .. '|0|' .. tostring(RainPredictionText)}
And where is RainDeviceIDX for?
I add a Dummy switch file with sensor type: TEXT with the name: regen
create a regen.lua and put it in /home/pi/domoticz/scripts/lua
Add the IDX from the TEXT sensor.
But nothing happens and only get Hello World in the switch.
roblom
Post by roblom »
You can create a parameter and fill it with the IDX of your text device, like below:
local RainTextIDX = 97
Where "97" is your IDX.
And then keep the code below;
Or replace the complete parameter, like below:
 commandArray[2] = {['UpdateDevice'] = '97|0|' .. tostring(RainPredictionText)}
mikeoo
Post by mikeoo »
roblom wrote:You can create a parameter and fill it with the IDX of your text device, like below:
Thanks for you answer bus I do something wrong. There is no update of the switch and still mention Hello World.
Update:
When i check the log file i get an error
Error: /home/pi/domoticz/scripts/lua/script_time_regen.lua:11: attempt to call global 'IsItGonnaRain' (a nil value)
Do you use this as a separate script of did you add it to the buienrader script? Bacuase in the script IsItGonnaRain gets calculated.
Buienrader script i use have the name: script_time_rain.lua
And this script: script_time_regen.lua
My Script (script_time_regen.lua) look now like
    -- CommandArray
       minuten=15
          verw = 3
          verw = 2
tlpeter
Post by tlpeter »
I have a question, i see this line once in a while:
LUA: Regen verwacht(0-255 hoe hoger hoe meer regen): nan binnen 1 minuten.
Error: no such column: nan
Where is that "nan" coming from?
For the test i am running this script every minute.
I will change this to 10 or 15 when i am sure that it works.
Mediacj
Post by Mediacj »
I think you have by accidence changed this line in the script:
print('Regen verwacht(0-255 hoe hoger hoe meer regen): '..regen..' binnen '..minuten..' minuten.')
Just compare this line with yours. The word nan should be the value of the var regen
tlpeter
Post by tlpeter »
Hi, i just checked and i do not see this error anymore.
I ran the script every minute for a test and then every second check results in this error.
Now it runs every ten minutes and the error is gone.
roblom
Post by roblom »
Update:
The code i gave was an addition on the code mentioned by the topic starter...
The complete code:
-- From http://www.domoticz.com/forum/viewtopic.php?uid=1095&f=38&t=5903&start=0
-- IsItGonnaRain( int minutesinfuture)
-- returns: int avarage rainfall for the next minutesinfuture
-- Function to get rain prediction from Buienradar.nl (dutch)
-- http://gratisweerdata.buienradar.nl/#Buienradar You may use their free service for non-commercial purposes.
-- Written in LUA by Hans van der Heijden (h4nsie @ gmail.com)
-- Spring 2015
-- 28-03-2015 v0.3 bug: quotes around url added.
-- 27-03-2015 v0.2 return value is now average for next time
-- 26-03-2015 v0.1 Initial release
-- todo: some error checking on http and file handling (tmp file)
-- Domoticz IDX and names of the needed devices
local RainTextIDX = 239
-- Script parameters
lat = '0.000000'
lon = '0.000000'
debug = false
tempfilename = '/var/tmp/rain.tmp' -- can be anywhere writeable
totalrain = 0
rainlines = 0
-- Lua Functions
function IsItGonnaRain( minutesinfuture )
	url='http://gps.buienradar.nl/getrr.php?lat='..lat..'&lon='..lon
	if debug then print(url) end
	read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
	file = io.open(tempfilename, "r")
	-- now analyse the received lines, format is like 000|15:30 per line.
	while true do
		line = file:read("*line")
		if not line then break end
		if debug then print('Line:'..line) end
		linetime=string.sub(tostring(line), 5, 9)
		if debug then print('Linetime: '..linetime) end
		-- Linetime2 holds the full date calculated from the time on a line
		linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
		difference = os.difftime (linetime2,os.time())
		-- When a line entry has a time in the future AND is in the given range, then totalize the rainfall
		if ((difference > 0) and (difference<=minutesinfuture*60)) then
			if debug then print('Line in time range found') end
			rain=tonumber(string.sub(tostring(line), 0, 3))
			totalrain = totalrain+rain
			rainlines=rainlines+1
			if debug then print('Rain in timerange: '..rain) end
			if debug then print('Total rain now: '..totalrain) end
	file:close()
	-- Returned value is average rain fall for next time
	-- 0 is no rain, 255 is very heavy rain
	-- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
	averagerain=totalrain/rainlines
	return(averagerain)
-- CommandArray
	minuten=15
		verw = 3
		verw = 2
Replace
239 → with the IDX of your text device.
lat = '0.000000' → your latitude
lon = '0.000000' → your longitude
mikeoo
Post by mikeoo »
Replace
Tnx working fine now :mrgreen:
Hansbit
Post by Hansbit »
Thanks all for using my code :-)
While using it I found out that sometimes I get values of 10 or 15 and these are set back to 0 by Buienrader within a minute (false positives). In my implementation I modified the threshold for 'no rain' to 20, with good results! I noticed it actually rains when my script reports values >20.
20 no rain -- 255 heavy rain.
tlpeter
Post by tlpeter »
Hi Hans,
So i am not going mad i guess.
I saw this happen once.
I will change my script too.
Thanks.
DutchHans
Post by DutchHans »
I am trying this script, but in the logfile I cant see that its triggered.
Any Idea why?
Only thing I did was changing the IDX and locationsettings.
tlpeter
Post by tlpeter »
What is the name of the script?
Where did you put it?
IanDury
Post by IanDury »
Cool!
Created a UserVariable named RainPeriod of type integer. The value you fill in determines the number of forecast minutes after making the following change in the script:
Change:
minuten=15
To:
minuten=uservariables['RainPeriod']
This way you can change the forecast period from the web browser and don't need to edit your script each time.
N.B. I was looking for a virtual device to pass integer values to the script but could not find one that matched.
remb0
Post by remb0 »
Very Nice indeed!
Can this + creating virtual device + original script added to the wiki for others?
IanDury wrote:Cool!
Change:
minuten=15
To:
gizmocuz
Post by gizmocuz »
This seems to work only for dutch users
roblom
Post by roblom »
gizmocuz wrote:This seems to work only for dutch users
Unless you find a service in your country that does the same....
Justintime
Post by Justintime »
Can someone help me to debug this Blocky??? Ok its a very simple one. At least thats what i thought. Just to test it.
Values are coming under the 70 at the moment. But no message from pushover sent out.
Whatsek
Domoticz version: Latest B
Post by Whatsek »
Justintime wrote:Can someone help me to debug this Blocky??? Ok its a very simple one. At least thats what i thought. Just to test it.
Blockly doesn't read the variable, so it is not triggered. I think you must use lua to accomplish this.
Justintime
Ow so thats why.... that's a shame because writing a lua script on my own is a little bit to high.
Maybe someone could share his sunscreen lua script? Adjustments in devices is no problem.
