Sure but keep in mind that my script is totally different.
It is based on Wunderground where you can choose a weather station near by.
I do not have any integration with buienradar.
I also added a switch where i can override the script partly (except for hard wind, rain and night)
Here it is:
--Weatherstation data:
sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues['Barometer']:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWeatherTemp = tonumber(sWeatherTemp);
sWeatherHumidity = tonumber(sWeatherHumidity);
sWeatherPressure = tonumber(sWeatherPressure);
sWeatherUV = tonumber(sWeatherUV);
sWeatherUV2 = tonumber(sWeatherUV2);
print("______________________________________________________________________________________")
print("Weather station: Temperature is " .. sWeatherTemp .. " ");
print("Weather station: Humidity is " .. sWeatherHumidity .. " ");
print("Weather station: Pressure is " .. sWeatherPressure .. " ");
print("Weather station: UV is " .. sWeatherUV .. " ");
print("Weather station: UV2 is " .. sWeatherUV2 .. " ");
--Windmeter data:
sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues['Wind']:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWindDirectionDegrees = tonumber(sWindDirectionDegrees);
sWindDirection = (sWindDirection);
sWindSpeed = tonumber(sWindSpeed);
sWindGust = tonumber(sWindGust);
sWindTemperature = tonumber(sWindTemperature);
sWindFeel = tonumber(sWindFeel);
print("Windmeter: Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ");
print("Windmeter: Winddirection is: " .. sWindDirection .. " ");
print("Windmeter: Windspeed is: " .. sWindSpeed .. " ");
print("Windmeter: Windgust is: " .. sWindGust .. " ");
print("Windmeter: Windtemperature is: " .. sWindTemperature .. " ");
print("Windmeter: Windfeel is: " .. sWindFeel .. " ");
--Rainmeter data:
sRainmeterCurrent, sRainmeterTotal = otherdevices_svalues['Regen']:match("([^;]+);([^;]+)")
sRainmeterCurrent = tonumber(sRainmeterCurrent);
sRainmeterTotal = tonumber(sRainmeterTotal);
print("Rainmeter: Actual rain is: " .. sRainmeterCurrent .. " ");
print("Rainmeter: Total rain is: " .. sRainmeterTotal .. " ");
--UV data:
sSolar = otherdevices_svalues['Solar']:match("([^;]+)")
--sUV = tonumber(sUV);
sSolar = tonumber(sSolar);
--print("UV: UV Strength is: " .. sUV .." ");
print("UV: Solar radiation is: " .. sSolar .." ");
--Sunscreen thresholds:
-- Windspeed = 100.0 (value is multiplied by 100)
-- Rain = 0.0
-- UV = 2.0
-- Temperature = 12.0
-- Closed = Down = On
-- Open = Up = Off
if (timeofday['Daytime'])
then
print('It is past sunrise, monitoring variables for sunscreen')
if (otherdevices['Zonnescherm'] == 'Open' )
then
print ('Sunscreen is up')
print ('Sunscreen is down')
if (otherdevices['Zonnescherm manual override'] == 'Off')
then
print('Manual override is turned off, follow the rest of the script')
print('Manual override is turned on, goto the end of the script and do nothing')
goto done
and sRainmeterCurrent == 0
and sWeatherTemp > 12.0
and sSolar > 100
and sWindSpeed < 50
and sWindGust < 150)
then
print ('Sun is shining, all thresholds OK, lowering sunscreen')
print('______________________________________________________________________________________')
commandArray['SendNotification']='Sunscreen#Sunscreen down --> Sun is shining'
commandArray['Zonnescherm']='On'
elseif (otherdevices['Zonnescherm'] == 'Closed' and sRainmeterCurrent > 0)
then
print ('It is raining, raising sunscreen')
commandArray['SendNotification']='Sunscreen#Sunscreen up --> It is raining'
commandArray['Zonnescherm']='Off'
elseif (otherdevices['Zonnescherm'] == 'Closed' and sWeatherTemp <11.0 and otherdevices['Zonnescherm manual override'] == 'Off')
then
print ('Temperature too low, raising sunscreen')
commandArray['SendNotification']='Sunscreen#Sunscreen up --> It is too cold'
elseif (otherdevices['Zonnescherm'] == 'Closed' and sSolar < 80 and otherdevices['Zonnescherm manual override'] == 'Off')
then
print ('Sun not shining too bright, raising sunscreen')
commandArray['SendNotification']='Sunscreen#Sunscreen up --> Sunshine not too bright'
elseif (otherdevices['Zonnescherm'] == 'Closed' and sWindSpeed > 50)
then
print ('Windspeed too high, raising sunscreen')
commandArray['SendNotification']='Sunscreen#Sunscreen up --> Windspeed too high'
elseif (otherdevices['Zonnescherm'] == 'Closed' and sWindGust > 150)
then
print ('Windgust too high, raising sunscreen')
commandArray['SendNotification']='Sunscreen#Sunscreen up --> Windgust too high'
print('Sunscreen status OK --> No action')
::done::
print("At the end of the script")
elseif (timeofday['Nighttime']
and otherdevices['Zonnescherm'] == 'Closed')
then
print('It is night, raising sunscreen')
commandArray['SendNotification']='Sunscreen#Sunscreen up --> It is night'
print('Sunscreen already up --> No action')
