Is it gonna rain within the next X minutes?
Hansbit
Post by Hansbit »
I wrote a function to predict if it gonna rain within the next X minutes. The function may be very handy for controlling sunscreens etcetera. The script uses the dutch weather website Buienradar.nl, so this script will only work for The Netherlands.
One may use the Buienradar's free service for non-commercial purposes.
Put your local lat/lon in the configuration part of the script. Calling the function IsItGonnaRain( 10) will return the average rain fall for the next 10 minutes. 0 is no rain, 255 is very heavy rain. When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
Please mail of PM your changes or suggestions, I'll update the script here.
Regards, Hans
-- IsItGonnaRain( int minutesinfuture)
-- returns: int avarage rainfall for the next minutesinfuture
-- Function to get rain prediction from Buienradar.nl (dutch)
-- http://gratisweerdata.buienradar.nl/#Buienradar You may use their free service for non-commercial purposes.
-- Written in LUA by Hans van der Heijden (h4nsie @ gmail.com)
-- Spring 2015
-- 28-03-2015 v0.3 bug: quotes around url added.
-- 27-03-2015 v0.2 return value is now average for next time
-- 26-03-2015 v0.1 Initial release
-- todo: some error checking on http and file handling (tmp file)
function IsItGonnaRain( minutesinfuture )
	-- config ---------------------------------------------------------
	lat='52.09'	-- example lat/lon for Utrecht
	lon='5.12' -- use MAX 2 decimals behind comma. (Requirement Buienrader)
	debug=false
	tempfilename = '/var/tmp/rain.tmp' -- can be anywhere writeable
	url='http://gps.buienradar.nl/getrr.php?lat='..lat..'&lon='..lon
	if debug then print(url) end
	read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
	file = io.open(tempfilename, "r")
	totalrain=0
	rainlines=0
	-- now analyse the received lines, format is like 000|15:30 per line.
	while true do
		line = file:read("*line")
		if not line then break end
		if debug then print('Line:'..line) end
		linetime=string.sub(tostring(line), 5, 9)
		if debug then print('Linetime: '..linetime) end
	   	-- Linetime2 holds the full date calculated from the time on a line
	   	linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
	   	difference = os.difftime (linetime2,os.time())
		-- When a line entry has a time in the future AND is in the given range, then totalize the rainfall
		if ((difference > 0) and (difference<=minutesinfuture*60)) then
			if debug then print('Line in time range found') end
			rain=tonumber(string.sub(tostring(line), 0, 3))
			totalrain = totalrain+rain
			rainlines=rainlines+1
			if debug then print('Rain in timerange: '..rain) end
			if debug then print('Total rain now: '..totalrain) end
	file:close()
	-- Returned value is average rain fall for next time
	-- 0 is no rain, 255 is very heavy rain
	-- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
	averagerain=totalrain/rainlines
return(averagerain)
Example implementation in Domoticz:
----- REGEN ------
minuten=10
regen = IsItGonnaRain(minuten)
print('Regen verwacht: '..regen..' binnen '..minuten..' minuten.')
if regen > 70 then
	commandArray['SendNotification']='Sunscreens#Regen verwacht'
xces
Post by xces »
Hi Hans,
Looking good! Can you post an example how to implement also? I have never done anything in Lua, only in C#. Do you run this script in a loop?
tlpeter
Re: Is it gonna rain within the next X minutes?
Post by tlpeter »
I am curious too.
I just installed a Fibaro roller/shutter for my sunscreen.
It would be nice to prevent it getting wet if i forget it :)
pvm
Domoticz version: 4.10538
Post by pvm »
Did you put the lua script in the domoticz scripts/lua folder? This is automatically executed every minute when choosing the correct name
johnwulp
Domoticz version: 3.4834
Post by johnwulp »
Thanks for your effort! I implemented it in my sunscreen script. Does is also spit out a value > 0 if it is raining?
if it ain't broke don't fix it!
tlpeter
Post by tlpeter »
John, can you share your script?
johnwulp
Post by johnwulp »
tlpeter wrote:John, can you share your script?
Offcourse. It's still 'in progress...'
   lat='51.818930'   -- example lat/lon for Utrecht
   lon='4.427236'
   debug=false
   totalrain=0
   rainlines=0
   while true do
   file:close()
return(averagerain)
time = os.date("*t")
--Extract Wind Gust speed from SValue Wind
wind = otherdevices_svalues['Wind']
--print("Wind: "..wind)
--Filter the third digitsequence from SValue
a = string.sub(wind,1,string.find(wind,';',1,true)-1)
--print("a: "..a)
b = string.sub(wind,string.find(wind,';',1,true)+1)
--print("b: "..b)
d = string.sub(b,string.find(b,';',1,true)+1)
--print("d: "..d)
windspeed = string.sub(d,1,string.find(d,';',1,true)-1)
f = string.sub(d,string.find(d,';',1,true)+1)
--print("f: "..f)
g = string.sub(f,string.find(f,';',1,true)+1)
--print("g: "..g)
--Extract Temp
tempstring = otherdevices_svalues['Temperatuur']
--print("Temp: "..tempstring)
temperature = string.sub(tempstring,1,string.find(tempstring,';',1,true)-1)
--Extract UV radiation from SValue Wind
-- solar = otherdevices_svalues['UV']
-- print("Solar Radiation: "..solar)
--Filter the first digit from SValue
-- uv = string.sub(solar,1,string.find(solar,';',1,true)-1)
-- print("UV: "..uv)
--Extract actual rainfall from Rain_SValue
rain = otherdevices_svalues['Regen']
--print("Rain: "..rain)
currentrain = string.sub(rain,1,string.find(rain,';',1,true)-1)
--Filter the last digit from SValue
--totalrain = string.sub(rain,string.find(rain,';',1,true)+1)
--print("Total rain: "..totalrain)
print("Uur: " ..time.hour)
minuten=5
--Sunscreen thresholds:
        -- Windspeed            = 50 (value is multiplied by 10)
        -- Rain                 =  0.0
        -- UV                   =  2.0
        -- Temperature          = 10.0
        -- Closed       = Down  = On
        -- Open         = Up    = Off
if (timeofday['Daytime'] and time.hour > 11)
        then
                print('It is past sunrise, and after 11. monitoring variables for sunscreen')
                if (otherdevices['Zonnescherm_virtual'] == 'Open' ) then
                print ('Zonnescherm is up')
                print ('Zonnescherm is down')
print("currentrain: "..currentrain)
print("temperature: "..temperature)
print("windspeed: "..windspeed)
currentrain = tonumber(currentrain)
temperature = tonumber(temperature)
windspeed = tonumber(windspeed)
        and regen         == 0
        and temperature         > 15
        and windspeed           < 50
	and time.hour		> 11)
        --and otherdevices['IemandThuis'] == 'On')
then
        print ('Sun is shining, all thresholds OK, lowering sunscreen')
        commandArray['SendNotification']='Zonnescherm#Zonnescherm gaat uit! --> De zon schijnt! Joepie!!! \rRegen: '..currentrain..'\rTemp: '..temperature..'\rWind: '..windspeed
        commandArray['Zonnescherm_virtual']='On'
        --elseif (otherdevices['Zonnescherm_virtual'] == 'Closed' and otherdevices['IemandThuis'] == 'Off') then
        --       print ('Nobody at home, raising sunscreen')
        --       commandArray['SendNotification']='Zonnescherm#Zonnescherm gaat naar binnen --> Niemand thuis!'
        --       commandArray['Zonnescherm_virtual']='Off'
        elseif (otherdevices['Zonnescherm_virtual'] == 'Closed' and regen > 0) then
                print ('It is raining, raising sunscreen')
                commandArray['SendNotification']='Zonnescherm#Zonnescherm gaat naar binnen --> Het gaat regenen!'
        elseif (otherdevices['Zonnescherm_virtual'] == 'Closed' and temperature <= 15) then
                print ('Temperature too low, raising sunscreen')
                commandArray['SendNotification']='Zonnescherm#Zonnescherm gaat naar binnen --> Te koud'
        --elseif (otherdevices['Zonnescherm_virtual'] == 'Closed' and uv < '1.0') then
        --        print ('Sun not shining too bright, raising sunscreen')
        --        commandArray['SendNotification']='Zonnescherm#Zonnescherm gaat naar binnen --> Zon schijnt niet voldoende'
        elseif (otherdevices['Zonnescherm_virtual'] == 'Closed' and windspeed > 49) then
                print ('Windspeed too high, raising sunscreen')
                commandArray['SendNotification']='Zonnescherm#Zonnescherm gaat naar binnen --> Teveel wind'
        print('Zonnescherm status OK --> No action')
elseif (timeofday['Nighttime']
        and otherdevices['Zonnescherm_virtual'] == 'Closed')
        then
                print('It is night, raising sunscreen')
                commandArray['SendNotification']='Zonnescherm#Zonnescherm naar binnen --> Zon gaat onder!'
                print('Zonnescherm already up --> No action')
return CommandArray
johnwulp
Post by johnwulp »
It also depends on several other devices:
The Wind, Temperatuur, Regen devices are from Forecast IO.
The IemandThuis device is a virtual one that i intend to use in the future. It switches on and off based on two bluetooth devices and a motion sensor.
The Zonnescherm_virtual device should be the actual sunscreen. In my case it's still a virtual one, when i'm happy with the code, i'll change it to the real sunscreen.
tlpeter
Post by tlpeter »
Thanks.
I do not have a weather station at the moment but I use weather underground at the moment.
There is a nice station near by but you will know that the weather can change quickly around the haringvliet.
I live on the other site of the water.
PS born and raised in spijkenisse.
johnwulp
Post by johnwulp »
Funny dat you live on the other side . I also don't have a weather station, that's why i use the forecast io. I've seen that rain is not very accurate. That's why this buienradar script comes in very handy!
Mediacj
Post by Mediacj »
Thanks Hansbit for this nice script!!
I have implemented it on this way:
1. made a virtual humidity sensor (didn't know a better type)
2. made a time based lua script of it: script_time_rain.lua with both scripts together (see code below) within the code I update the virtual humidity device with the rain value, I also forward the humidity status which changes from dry to wet when the rain value is bigger then 0
3. change in the script the idx 125 of mine virtual device (in the update_device command) with your virtual humidity device idx
4. placed the lua script in the lua directory: /home/pi/domoticz/scripts/lua
Now you can use the value of this virtual humidity device to react on it in scripts or in blockly
-- Spring 2015
   lat='51.687895'   -- example lat/lon for Utrecht
   lon='5.057482'
   debug=false
   totalrain=0
   rainlines=0
   while true do
   file:close()
return(averagerain)
----- REGEN ------
minuten=15
print('Regen verwacht(0-255 hoe hoger hoe meer regen): '..regen..' binnen '..minuten..' minuten.')
if (regen > 0  ) then verw = 3 else verw = 2 end
commandArray['UpdateDevice'] = '125|'..tostring(regen)..'|'..tostring(verw)
Hansbit
Post by Hansbit »
Thanks all for the positive feedback on my script.
It's today a nice day to test this function.. :lol: rainfall 15mm!
niki_lauda
Post by niki_lauda »
Mediacj wrote:Thanks Hansbit for this nice script!!
How do I create a virtual humidity device?
Mediacj
Post by Mediacj »
1. go to setup tab
2. choose hardware
3. name: give it a name
4. type: Dummy (Does nothing, use for virtual switches only)
5. click on Add
6. now you have a new hardware device with the given name
7. choose 'Create Virtual Sensors' on the line of your new hardware device you just created
8. Sensor type: 'Humidity' and click OK
9. Go to the Setup tab again and now choose 'Devices'
10. there will be a new device with a green arrow on the end, click on the arrow and give your device a name
11. now you have the humidity device under the temperature tab
niki_lauda
THX
tlpeter
Post by tlpeter »
Hansbit wrote:Thanks all for the positive feedback on my script.
Hi Hans,
I am running a Windows system with Domoticz.
Your script isn't working an i think because of some Linux commands.
The location /var/.... i have changed already.
What else needs to be changed?
Hansbit
Post by Hansbit »
tlpeter wrote:
Hansbit wrote: I am running a Windows system with Domoticz.
Hello tlpeter,
The 'curl' command is executed to get the url. That is not available in Windows.
Hans
tlpeter
Post by tlpeter »
Hi Hans i know, that is the problem :mrgreen:
I use a different script now and i have it working.
But thanks anyway.
roblom
Post by roblom »
I added also a text device and filled it with the text from this script.
function round(num, idp)
	local mult = 10^(idp or 0)
	return math.floor(num * mult + 0.5) / mult
-- CommandArray
	minuten=15
	RainPrediction = IsItGonnaRain(minuten)
	RainmmHour=10^((RainPrediction-109)/32)
	if (RainPrediction > 0  ) then
		verw = 3
		RainPredictionText=('Regen verwacht binnen '..minuten..' minuten, met ' ..round(RainmmHour, 1).. ' mm/uur')
		verw = 2
		RainPredictionText=('Geen regen verwacht binnen '..minuten..' minuten.')
	commandArray[1] = {['UpdateDevice'] = RainDeviceIDX .. '|'..tostring(RainPrediction)..'|'..tostring(verw)}
	commandArray[2] = {['UpdateDevice'] = RainTextIDX .. '|0|' .. tostring(RainPredictionText)}
	print('-- Regen verwacht(0-255 hoe hoger hoe meer regen): '..RainPrediction..' binnen '..minuten..' minuten.')
	print('-- ' .. RainPredictionText )
RainTextIDX = the IDX of the text device.
And added a round function to display only 1 digit.
markk
Post by markk »
tlpeter wrote:Hi Hans i know, that is the problem :mrgreen:
But thanks anyway.
Hi Tlpeter
Would you mind sharing your windows script please?
Mark
