How do I get batterylevels back?
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Re: How do I get batterylevels back?
Updated my live system to Trixy and applied the Domoticz update, Z-wave batterylevel problem remains the same. And yes, I did a wake-up on sensors and updated hardware (in case you wondered).
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
- gizmocuz
@Doler, do you have low batteries? If not, nothing will indeed change. Only when the Low Battery indication is set to 'true', then the battery levels of the sensors will be set to 0 (and only after they have been received one more time)
No, I have no low batteries, all Low Battery devices are false. Hereby the configs for battery_islow (state_topic: IsLow) and battery_level (state_topic: level)
"payload_on": true,
"payload_off": false,
"value_template": "{{ value_json.value }}",
"device_class": "battery",
"state_topic": "zwave/FMS1/128/0/isLow",
"availability": [
"payload_available": "true",
"payload_not_available": "false",
"topic": "zwave/FMS1/status",
"value_template": "{{'true' if value_json.value else 'false'}}"
"topic": "zwave/_CLIENTS/ZWAVE_GATEWAY-zwave-js-ui/status",
"value_template": "{{'online' if value_json.value else 'offline'}}"
"topic": "zwave/driver/status"
"availability_mode": "all",
"json_attributes_topic": "zwave/FMS1/128/0/isLow",
"device": {
"identifiers": [
"zwavejs2mqtt_0xfe88fc1e_node14"
"manufacturer": "Fibargroup",
"model": "Motion Sensor (FGMS001)",
"name": "FMS1",
"sw_version": "2.7"
"name": "FMS1_battery_islow",
"unique_id": "zwavejs2mqtt_0xfe88fc1e_14-128-0-isLow"
zwave-ad/binary_sensor/FMS1/battery_islow/config
"unit_of_measurement": "%",
"state_topic": "zwave/FMS1/128/0/level",
"availability": [
"json_attributes_topic": "zwave/FMS1/128/0/level",
"device": {
"identifiers": [
"name": "FMS1",
"sw_version": "2.7"
"name": "FMS1_battery_level",
"unique_id": "zwavejs2mqtt_0xfe88fc1e_14-128-0-level"
zwave-ad/sensor/FMS1/battery_level/config
- gizmocuz
So it is working correctly. (And the workings is how I wrote it before)
This morning all looks ok, battery level is populated for almost all (sub-)devices. I tested with updating the Hardware in order to check the generation of battery_level devices as it was the case in the faulty situation. Every thing is ok now and my battery check is working again.
Thanks for solving this.
