How do I get batterylevels back?
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Doler
Re: How do I get batterylevels back?
Post by Doler »
Updated my live system to Trixy and applied the Domoticz update, Z-wave batterylevel problem remains the same. And yes, I did a wake-up on sensors and updated hardware (in case you wondered).
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
gizmocuz
Post by gizmocuz »
@Doler, do you have low batteries? If not, nothing will indeed change. Only when the Low Battery indication is set to 'true', then the battery levels of the sensors will be set to 0 (and only after they have been received one more time)
Doler
Post by Doler »
No, I have no low batteries, all Low Battery devices are false. Hereby the configs for battery_islow (state_topic: IsLow) and battery_level (state_topic: level)
  "payload_on": true,
  "payload_off": false,
  "value_template": "{{ value_json.value }}",
  "device_class": "battery",
  "state_topic": "zwave/FMS1/128/0/isLow",
  "availability": [
      "payload_available": "true",
      "payload_not_available": "false",
      "topic": "zwave/FMS1/status",
      "value_template": "{{'true' if value_json.value else 'false'}}"
      "topic": "zwave/_CLIENTS/ZWAVE_GATEWAY-zwave-js-ui/status",
      "value_template": "{{'online' if value_json.value else 'offline'}}"
      "topic": "zwave/driver/status"
  "availability_mode": "all",
  "json_attributes_topic": "zwave/FMS1/128/0/isLow",
  "device": {
    "identifiers": [
      "zwavejs2mqtt_0xfe88fc1e_node14"
    "manufacturer": "Fibargroup",
    "model": "Motion Sensor (FGMS001)",
    "name": "FMS1",
    "sw_version": "2.7"
  "name": "FMS1_battery_islow",
  "unique_id": "zwavejs2mqtt_0xfe88fc1e_14-128-0-isLow"
zwave-ad/binary_sensor/FMS1/battery_islow/config
  "unit_of_measurement": "%",
  "state_topic": "zwave/FMS1/128/0/level",
  "availability": [
  "json_attributes_topic": "zwave/FMS1/128/0/level",
  "device": {
    "identifiers": [
    "name": "FMS1",
    "sw_version": "2.7"
  "name": "FMS1_battery_level",
  "unique_id": "zwavejs2mqtt_0xfe88fc1e_14-128-0-level"
zwave-ad/sensor/FMS1/battery_level/config
gizmocuz
Post by gizmocuz »
So it is working correctly. (And the workings is how I wrote it before)
Doler
Post by Doler »
This morning all looks ok, battery level is populated for almost all (sub-)devices. I tested with updating the Hardware in order to check the generation of battery_level devices as it was the case in the faulty situation. Every thing is ok now and my battery check is working again.
Thanks for solving this.
