How do I get batterylevels back?
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Doler
Post by Doler »
Sinds some time I'm missing the battery level report on Z-wave devices. It concerns motion sensors from Fibar/Neo and doorsensors from Neo. I am checking battery levels with a Lua script using:
local function getDevices()
	local  url = dz.settings['Domoticz url'] .. "/json.htm?type=command&param=getdevices&used=true&displayhidden=1"
	dz.openURL({ url = url, method = "GET", callback = CALLBACK })
local function processDevices(result)
	for index in pairs(result) do
		local deviceName = result[index].Name
		local batteryLevel = result[index].BatteryLevel
		dz.log(format('Device: %s, Battery level %s %%', deviceName, batteryLevel), dz.LOG_INFO)
		if batteryLevel and batteryLevel ~= 255  then
			dz.globalData.batteryLevels[deviceName] = batteryLevel
and in another script checking the retrieved values against a threshold level. This works for all battery operated devices (like Zigbee) but not, sinds some time, for the mentioned Z-wave devices.
The discovery configs are all like this:
FMS1
temperature_air
config = {"value_template":"{{ value_json.value }}","unit_of_measurement":"°C","state_class":"measurement","device_class":"temperature","state_topic":"zwave/FMS1/49/0/Air_temperature","availability":[{"payload_available":"true","payload_not_available":"false","topic":"zwave/FMS1/status","value_template":"{{'true' if value_json.value else 'false'}}"},{"topic":"zwave/_CLIENTS/ZWAVE_GATEWAY-zwave-js-ui/status…
illuminance
config = {"value_template":"{{ value_json.value }}","unit_of_measurement":"lx","state_class":"measurement","device_class":"illuminance","state_topic":"zwave/FMS1/49/0/Illuminance","availability":[{"payload_available":"true","payload_not_available":"false","topic":"zwave/FMS1/status","value_template":"{{'true' if value_json.value else 'false'}}"},{"topic":"zwave/_CLIENTS/ZWAVE_GATEWAY-zwave-js-ui/status","v…
battery_level
config = {"value_template":"{{ value_json.value }}","unit_of_measurement":"%","device_class":"battery","state_topic":"zwave/FMS1/128/0/level","availability":[{"payload_available":"true","payload_not_available":"false","topic":"zwave/FMS1/status","value_template":"{{'true' if value_json.value else 'false'}}"},{"topic":"zwave/_CLIENTS/ZWAVE_GATEWAY-zwave-js-ui/status","value_template":"{{'online' if value_js…
And the report for the battery_level like this:
0
isLow = {"time":1753016911001,"value":false,"nodeName":"FMS1","nodeLocation":"Living"}
level = {"time":1753639020819,"value":100,"nodeName":"FMS1","nodeLocation":"Living"}
In this example the battery level appears on the FMS1 MultiSensor device, on other hardware devices (if reported) on Low Battery. After enabling new devices and restarting the Z-wave AD hardware new devices '...128-0-level' were created, something that (imho) should not be.
71	  ZWave-AD	zwavejs2mqtt_0xfe88fc1e_14-156-0-state-0	1	FMS1 | MultiSensor		    Light/Switch	Switch		  Off	    -
72	  ZWave-AD	zwavejs2mqtt_0xfe88fc1e_14-48-0-Any  		1	FMS1 | Motion Living		  Light/Switch	Switch		  Off	    -	-
73	  ZWave-AD	zwavejs2mqtt_0xfe88fc1e_14-49-0-Illuminance	    1	FMS1 | Lux Living		      Lux		        Lux		      9 Lux	  -	-
74	  ZWave-AD	zwavejs2mqtt_0xfe88fc1e_14-49-0-Air_temperature	1	FMS1 | Temperature Living	Temp	THR128/138, THC138	24.3 C	-	-
75	  ZWave-AD	zwavejs2mqtt_0xfe88fc1e_14-128-0-isLow		      1	FMS1 | Low Battery		    Light/Switch	Switch		  Off	    -	-
1030	  ZWave-AD	zwavejs2mqtt_0xfe88fc1e_14-128-0-level		      1	FMS1 | Battery Level		  General	      Percentage	100%	  -	-
Could there be a connection with the commit on June 15?
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Domoticz version: 2025.1
Re: How do I get batterylevels back?
You are not mentioning on what version of Domoticz and Zwave-JS-Ui you are.
Doler
Post by Doler »
All latest version (see my signature).
I forgot to mention that the newly created devices (Battery_level) are NOT updated.
gizmocuz
Post by gizmocuz »
All your above config payloads are truncated and you also need to post the complete topics
Doler
Post by Doler »
The not truncated configs for FMS1:
zwave-ad/sensor/FMS1/temperature_air/config
  "value_template": "{{ value_json.value }}",
  "unit_of_measurement": "°C",
  "state_class": "measurement",
  "device_class": "temperature",
  "state_topic": "zwave/FMS1/49/0/Air_temperature",
  "availability": [
      "payload_available": "true",
      "payload_not_available": "false",
      "topic": "zwave/FMS1/status",
      "value_template": "{{'true' if value_json.value else 'false'}}"
      "topic": "zwave/_CLIENTS/ZWAVE_GATEWAY-zwave-js-ui/status",
      "value_template": "{{'online' if value_json.value else 'offline'}}"
      "topic": "zwave/driver/status"
  "availability_mode": "all",
  "json_attributes_topic": "zwave/FMS1/49/0/Air_temperature",
  "device": {
    "identifiers": [
      "zwavejs2mqtt_0xfe88fc1e_node14"
    "manufacturer": "Fibargroup",
    "model": "Motion Sensor (FGMS001)",
    "name": "FMS1",
    "sw_version": "2.7"
  "name": "FMS1_temperature_air",
  "unique_id": "zwavejs2mqtt_0xfe88fc1e_14-49-0-Air_temperature"
zwave-ad/sensor/FMS1/illuminance/config
  "unit_of_measurement": "lx",
  "device_class": "illuminance",
  "state_topic": "zwave/FMS1/49/0/Illuminance",
  "availability": [
  "json_attributes_topic": "zwave/FMS1/49/0/Illuminance",
  "device": {
    "identifiers": [
    "name": "FMS1",
    "sw_version": "2.7"
  "name": "FMS1_illuminance",
  "unique_id": "zwavejs2mqtt_0xfe88fc1e_14-49-0-Illuminance"
zwave-ad/sensor/FMS1/battery_level/config
  "unit_of_measurement": "%",
  "device_class": "battery",
  "state_topic": "zwave/FMS1/128/0/level",
  "availability": [
  "json_attributes_topic": "zwave/FMS1/128/0/level",
  "device": {
    "identifiers": [
    "name": "FMS1",
    "sw_version": "2.7"
  "name": "FMS1_battery_level",
  "unique_id": "zwavejs2mqtt_0xfe88fc1e_14-128-0-level"
Is this enough info?
gizmocuz
Post by gizmocuz »
Thank you, and could you also post the content of
Doler
Post by Doler »
zwave/FMS1/128/0/isLow
  "time": 1753016911001,
  "value": false,
  "nodeName": "FMS1",
  "nodeLocation": "Living"
  "time": 1754261342547,
  "value": 100,
  "nodeName": "FMS1",
gizmocuz
Post by gizmocuz »
I think the topic "zwave/FMS1/128/0/isLow" should have been "zwave/FMS1/128/0/level"
I added support for the battery isLow indication (boolean) in beta 16757
When it is 'true', I set all device battery levels to zero, you should be able to see this in the device overview
Doler
Post by Doler »
Hmm,
After updating Domoticz won't start anymore. Status message:
/lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.38' not found (required by /home/pi/domoticz/domoticz)
What to do?
Doler wrote: Tuesday 12 August 2025 8:30 Hmm,
What to do?
Are you running Ubuntu? Then you need 24.04 to get it running. Ubuntu 22.04 that has openssl3 but wrong version of glibc viewtopic.php?p=325831#p325831
Doler
Post by Doler »
No, I'm running Debian Bookworm on a virtual machine (AMD64).
Then it seems you run a different version of bookworm than the Domoticz build system...
Doler
Post by Doler »
Never had problems before. My bookworm version number is:
cat /etc/debian_version
12.11
gizmocuz
Post by gizmocuz »
The build system was updated to Trixy.... Maybe that is causing the issue?
Seems like the Docker (compose) AMD64 has no issues with it... running fine
gizmocuz
Post by gizmocuz »
You could upgrade your system with
sudo sed -i 's/bookworm/trixie/g' /etc/apt/sources.list
sudo find /etc/apt/sources.list.d -type f -exec sed -i 's/bookworm/trixie/g' {} \;
sudo apt update
sudo apt full-upgrade
sudo apt modernize-sources
sudo apt autoremove
sudo reboot
gizmocuz
Post by gizmocuz »
Seems this error has already been reported in 2023... ... so don't think (hope) it has anything to do with Trixy
https://www.reddit.com/r/linux4noobs/co ... und_error/
gizmocuz wrote: Tuesday 12 August 2025 14:23 The build system was updated to Trixy.... Maybe that is causing the issue?
Possibly not AMD64 but also update issues on Docker viewtopic.php?f=6&t=43859
Doler
Post by Doler »
I'm running the virtual machine on Proxmox that is still running on Debian bookworm. There is a Proxmox upgrade 8 to 9 that is based on Trixy but other than running a script checking if Proxmox is ok for an upgrade. I did nothing else since I wanted the problem with Domoticz be solved first. So I have no idea what changed.
I'm not running Domoticz in Docker.
Question is where the requirement for GLIBC comes from?
I'll try to switch to Trixy on my test system and see if it works.
Doler
Post by Doler »
Doler wrote: Tuesday 12 August 2025 14:58 I'll try to switch to Trixy on my test system and see if it works.
Ok, Domoticz updated fine. Going to do the same on my live system (backup first) and see if the Z-wave problem is solved. Thanks sofar.
gizmocuz
Post by gizmocuz »
I was just going to say I am trying to build a schroot environment on build server to build for bookworm again...
