need help dzevets script solar Toon
Wiers
Re: need help dzevets script solar Toon
I have got it working!
Now I have one device with the most recent solarpower output and a device with the total today.
Tomorrow I am gonna try to get this in the Energy dashboard.
Thanks for putting me in the right direction Walter.
- Domoticz version: 2026.3
Probably not working like this but you never know...
You probably need the Electric (Instant and counter) for connecting Solar to the Energy Dashboard.
Wiers
You are right.
But I made this from another piece of coding and adapted that to my needs. So the solarpower plus a zero device is now totalpower which shows up in the energy dashboard.
And I have total today also.
But I have 2 same scripts now, one with "current and one with "today"
I think this coud be running in one script but I have to figure that out.
- Schermafbeelding 2025-05-31 om 14.16.15.png (40.55 KiB) Viewed 6220 times
- madpatrick
- Domoticz version: 2026.1
if you post your scripts we can have a look for you.
Post it as CODE (text in brackets) and not as a picture
If you are filling the right data to the general kWh device totalPower you can delete the other 2.
It will also calculate the daily production for you but it needs a running total counter and not a daily (resetting to 0) counter.
You probably have to add JSON value "total". Please check if that total counter is increasing the same as the "today" value. It will help you a lot if you do this.
Wiers
This is the "solar" script.
timer = { 'every 1 minutes' },
httpResponses = { 'solar' }
if (item.isTimer) then
domoticz.openURL({
url = 'http://192.168.1.56/solar.html',
method = 'GET',
callback = 'solar'
elseif (item.isHTTPResponse) then
if (item.ok) then -- statusCode == 2xx
local current = item.json.solar.current
domoticz.devices('solar').updateEnergy(current)
domoticz.log(' current = ' .. current, domoticz.LOG_INFO )
And this is the "today" script.
domoticz.openURL({
method = 'GET',
callback = 'solar'
local today = item.json.solar.today
domoticz.devices('PanelsToday').updateEnergy(today)
domoticz.log(' today = ' .. today, domoticz.LOG_INFO )
domoticz.openURL({
method = 'GET',
callback = 'solar'
domoticz.openURL({
method = 'GET',
callback = 'solar'
Wiers
I do not really need a total counter because I already have that on my Apsystems app.
Same as the lifetime calculator.
Most important for me is the "current" value to be used in the Energy Dashboard.
The totalPower device can be used in the energy dashboard as it is now so what is the problem?
Wiers
There is no problem anymore.
You helped me in the right direction.
Only madpatrick asked me to show my 2 scripts so maybe we can combine them.
- madpatrick
try this
please use the code brackets to post script to make it readable
domoticz.openURL({
method = 'GET',
callback = 'solar'
domoticz.log('current = ' .. current, domoticz.LOG_INFO)
domoticz.log('today = ' .. today, domoticz.LOG_INFO)
}-= HP server GEN11 =- ZwaveJS-=- Domoticz v2026.2 -=- Dashticz =-
Wiers
It is working!
Thanks for helping me out.
Now I can delete one script.
Putting kWh data into a sensor created for Watt data is wrong. But if it works from you its fine for me. Just a warning for the next Toon user trying to do the same..
Wiers
I tried but if I make a device "general kWh" named "solar"
I get this error.
2025-06-01 12:02:01.048 Error: dzVents: An error occurred when calling event handler CombinedSolar
2025-06-01 12:02:01.048 Error: dzVents: ...ticz/scripts/dzVents/generated_scripts/CombinedSolar.lua:18: attempt to call a nil value (field 'updateEnergy')
I get this error.
The update command for the general kWh device is
updateElectricity(power, energy)
Wiers
That did it.
Now I could get rid of a couple of extra coding.
Thanks Walter.
Thanks Walter.
