Zwave JS- UI install how. Help please!
Dave47
Domoticz version: 2023.1
Re: Zwave JS- UI install how. Help please!
Post by Dave47 »
pi@raspberrypi:~/docker/zwjs $ docker compose up
[+] Running 0/0
⠋ Container zwave-js-ui Creating 0.0s
Error response from daemon: Conflict. The container name "/zwave-js-ui" is already in use by container "2ff5a4ecc2339b259469fef1e9d8d3b8d04dbabcfd55ca553a8dc57b81a08b6b". You have to remove (or rename) that container to be able to
reuse that name.
I can not find zwave-js-ui which is in use. How can i find?
Dave47
Post by Dave47 »
i have made a new install. on a clean raspberry pi with the same Domoticz.
Install docker
and then in opt/domoticz the image file docker-compose.yml
alwasy im getting: line 9 did not find expected key
and after that i have create you told me
Mkdir docker
within zwjs
and there i put docker-compose.yml
it looks better but it stocked by attaching zwave-js-ui
How can i come out of the screen?
Dave47
Post by Dave47 »
what can we do now first to get it running?
Ik have MQTT Client Gateway with LAN interface is that ok, is use it also for node-red?
thomasbaetge
Post by thomasbaetge »
CTRL C will terminate it.
if you start it with
docker compose up -d
it will run in background. then you can check if the UI is accessible under
<ipofmachine>:8091
Dave47
Post by Dave47 »
<ipofmachine>:8091
i can see the interface but no devices.
how the setting looks like?
thomasbaetge
if domoticz with OZW is up on the same machine, you won't see devices.
Your stick can only connect to either one at a time.
If you disable (NOT delete) OWZ in domoticz, you should see devices (maybe you need to restart the zwjs container, but I never tried)
Anyway, you made it this far...congrats!
Dave47
Post by Dave47 »
Disabled ozw but no devices are vissiible.
How to restart zwjs container?
Do i need MQTT discover to show devices and secure key?
Do i change maybe other settings?
Dave47
Post by Dave47 »
docker compose down in zwjs is not possible
And docker compose up also not possible anymore.
It gives:
yaml: did not find expected key
Dave47
Post by Dave47 »
<ipofmachine>:8091
I have made some settings there and i See look at image.
I setup the security key.
But no devices are vissible in Domoticz. I dont understsnd how to do these settings. I tried with MQTT discover but i don't understand how to setup.
thomasbaetge
For the restart, please use
docker compose down
and
from within the directory where your yaml file is.
As for the device migration, I can not help with it, because I did not do that yet because I am lacking the time at the moment.
Dave47
Post by Dave47 »
thanks for the support
I hope i will find the sollution
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Did you succeed?
Dave47
Post by Dave47 »
Yes, its ok. Some little things in NODE-RED. We work on these things.
thomasbaetge
well done, I'm happy you managed!!
Piet
Domoticz version: 3.8153
Post by Piet »
tried using "migrate Openzwave to Zwave-JS-UI"document
upgraded to debian11 Bullseye, domoticz version 2023.2
Domoticz started, web UI is visible but all devices seem dead
control Panel.jpg (347.47 KiB) Viewed 1619 times
