MQTT Auto Discovery with Mosquitto and Shelly1
lwolf
Re: MQTT Auto Discovery with Mosquitto and Shelly1
Post by lwolf »
sincze wrote: Saturday 20 January 2024 16:23
pikassent wrote: Saturday 20 January 2024 12:23 You are right. It will "teach" domoticz to discover your Tasmota v11+ device
Great same idea as shellyteacher4domo
Would be nice if we could modify https://github.com/enesbcs/shellyteacher4domo to tasmotateacher4domo. :D
UPDATE: 18:18
I managed to create my first device ;-) ON/OFF switch. :D
Added at ShellyTeacher testing branch. Can be tested on a linux client with python:
git clone -b testing https://github.com/enesbcs/shellyteacher4domo.git shellyteacher4domo-testing
cd shellyteacher4domo-testing
./preinstall.sh
./run
sincze
Domoticz version: 2024.4
Post by sincze »
$ ./shellyteacher4domo-test $ ./run.sh
Ini file exists
Ini settings loaded
Connecting to MQTT server...
Starting eval loop, waiting Shelly devices to appear on MQTT announce... pres
ONLINE GEN2 shellyplus1-1234ce560428
>>>GEN2 device shellyplus1-1234ce560428 shellyplus1-1234ce560428 found
So restarted some Tasmota devices to see if they would show up. Unfortunately I probably did something wrong ?
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
lwolf
Post by lwolf »
sincze wrote: Thursday 25 January 2024 21:10
Ini file exists
Ini settings loaded
I have the following information from this log: 1: python environment is ok 2: you are using the console mode 3: teacher sees the MQTT server 4: shelly gen2 part is working ok 5: you are not using the same settings.py from testing branch as i do not see debug messages
what i not see: your settings.py file
did you reboot the tasmota device after starting the teacher?
This is what is see on my console if "tasmo = True" and "debug = True" in settings.py (if earlier settings.ini exists here, you can delete it before)
Console mode requested
Ini file exists
Ini settings loaded
subscribed shellies/announce
subscribed +/online
subscribed shellies/+/online
subscribed shellies_discovery/rpc
subscribed tasmota/discovery/#
Starting eval loop, waiting Shelly devices to appear on MQTT announce... press CTRL-C to cancel
on_message::payload::{"ip":"192.168.2.92","dn":"tasmo","fn":["Gpio1","Gpio2",null,null,null,null,null,null],"hn":"tasmota-4D4A18-2584","mac":"30AEA44D4A18","md":"ESP32-DevKit","ty":0,"if":0,"ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"13.3.0.4","t":"tasmota_4D4A18","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1],"swn":[null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null],"btn":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"so":{"4":0,"11":0,"13":0,"17":0,"20":0,"30":0,"68":0,"73":0,"82":0,"114":0,"117":0},"lk":0,"lt_st":0,"bat":0,"dslp":0,"sho":[],"sht":[],"ver":1}
30AEA44D4A18 alive
on_message::payload::{"sn":{"Time":"2024-01-25T19:47:36","Switch1":"ON","ANALOG":{"A1":3889},"ESP32":{"Temperature":51.1},"TempUnit":"C"},"ver":1}
30AEA44D4A18 alive
>>>Tasmota device 192.168.2.92 ESP32-DevKit found
sincze
Post by sincze »
Haha the rootcause was quite easy,
As i was using your settings.py... the problem must have been in the settings.ini.
I added the following
tasmo = 1
debug = 1
And then...
Tasmota device 192.168.**.** LED Berging found
Let the testing begin.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Domoticz version: 2025.1
Just wondering, you call the new script shellyteacher, but the Shellies are flashed with Tasmota so it should be called tasmota teacher instead?
Will this script also find unflashed devices?
Edit: I get it, it is a branch of the ShellyTeacher..... Better call it tasmotateacher else we get other users also confused like me.....
lwolf
Post by lwolf »
Yep its part of the ShellyTeacher. Maybe i will rename it to "MQTT Autodiscovery helper" :)
I have a tinycontrol LAN controller device which also supports MQTT, and i think it can be also added in a similar way.
pikassent
Domoticz version: 2024.4b
Post by pikassent »
Hi lwolf,
It works like a charm :)
./run.sh
Mosquitto conf found.
persistence ENABLED
Ini file exists
subscribed +/online
on_message::payload::{"ip":"10.10.11.29","dn":"toma1","fn":["toma1",null,null,null,null,null,null,null],"hn":"toma1-1871","mac":"1234567890AB","md":"Athom SK01","ty":0,"if":0,"ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"13.3.0","t":"toma1","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1],"swn":[null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null],"btn":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"so":{"4":0,"11":0,"13":0,"17":0,"20":0,"30":0,"68":0,"73":0,"82":0,"114":0,"117":0},"lk":0,"lt_st":0,"bat":0,"dslp":0,"sho":[],"sht":[],"ver":1}
1234567890AB alive
on_message::payload::{"sn":{"Time":"2024-01-26T18:15:12","ENERGY":{"TotalStartTime":"2024-01-05T10:56:23","Total":0.056,"Yesterday":0.000,"Today":0.000,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":232,"Current":0.000}},"ver":1}
1234567890AB alive
>>>Tasmota device 10.10.11.29 Athom SK01 found
domoticz.log
2024-01-26 17:15:30.527  Status: MQTTAD-Tasmota: discovered: toma1 (toma1 Online)/toma1 (toma1 Online) (unique_id: 1234567890AB_online)
2024-01-26 17:15:30.631  Status: MQTTAD-Tasmota: discovered: toma1/toma1 (unique_id: 1234567890AB_RL_1)
2024-01-26 17:15:30.734  Status: MQTTAD-Tasmota: discovered: toma1 ENERGY TotalStartTime/toma1 ENERGY TotalStartTime (unique_id: 1234567890AB-energy-totalstarttime)
2024-01-26 17:15:30.835  Status: MQTTAD-Tasmota: discovered: toma1 ENERGY Total/toma1 ENERGY Total (unique_id: 1234567890AB-energy-total)
2024-01-26 17:15:30.937  Status: MQTTAD-Tasmota: discovered: toma1 ENERGY Yesterday/toma1 ENERGY Yesterday (unique_id: 1234567890AB-energy-yesterday)
2024-01-26 17:15:31.039  Status: MQTTAD-Tasmota: discovered: toma1 ENERGY Today/toma1 ENERGY Today (unique_id: 1234567890AB-energy-today)
2024-01-26 17:15:31.141  Status: MQTTAD-Tasmota: discovered: toma1 ENERGY (toma1 ENERGY Power)/toma1 ENERGY (toma1 ENERGY Power) (unique_id: 1234567890AB-energy-power)
2024-01-26 17:15:31.243  Status: MQTTAD-Tasmota: discovered: toma1 ENERGY (toma1 ENERGY ApparentPower)/toma1 ENERGY (toma1 ENERGY ApparentPower) (unique_id: 1234567890AB-energy-apparentpower)
2024-01-26 17:15:31.345  Status: MQTTAD-Tasmota: discovered: toma1 ENERGY (toma1 ENERGY ReactivePower)/toma1 ENERGY (toma1 ENERGY ReactivePower) (unique_id: 1234567890AB-energy-reactivepower)
2024-01-26 17:15:31.447  Status: MQTTAD-Tasmota: discovered: toma1 ENERGY Factor/toma1 ENERGY Factor (unique_id: 1234567890AB-energy-factor)
2024-01-26 17:15:31.549  Status: MQTTAD-Tasmota: discovered: toma1 ENERGY Voltage/toma1 ENERGY Voltage (unique_id: 1234567890AB-energy-voltage)
2024-01-26 17:15:31.652  Status: MQTTAD-Tasmota: discovered: toma1 ENERGY Current/toma1 ENERGY Current (unique_id: 1234567890AB-energy-current)
Devices:
sincze
Post by sincze »
Discovery Works for a lot of Tasmota devices.
After modifying settings.ini file
[CONFIG]
mqtt_ip = <<YOUR MQTT SERVER HERE>>
mqtt_port = 1883
mqtt_user = mqtt
mqtt_pass = user
discovery_prefix = shelly-pi5
testrun = 0
retain = 1
gen1 = 0
gen2 = 0
tasmo = 1
debug = 1
I personally ran into some issues where the RELAYS were unable to be controlled (Sonoff Basic).
https://github.com/enesbcs/shellyteache ... 1913579483
With the current script version it is sufficient to execute the following command in the console of your tasmota device:
SetOption26 1
SetOption26
Use indexes even when only one relay is present
0 = messages use POWER (default)
1 = messages use POWER1
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
